.. |Product| replace:: BM1688 系统接口使用 ================ RTC_SRAM存储OEM说明 --------------------- OEM参数位置是eMMC的硬件boot1分区,进入kernel后挂载在/dev/mmcblk0boot1。MCU在fsbl阶段开始运行,需要OEM参数用于设置不同的board,A53和MCU不能同时访问eMMC,因此在FSBL加载MCU之前,先从eMMC的boot1分区读OEM参数到RTC_SRAM,然后MCU再去取参数。 RTC_SRAM起始地址:0x5200000,长度:0x8000(32K),预留RTC_SRAM最后256 byte用于存储OEM参数,OEM组成结构如下: +--------+----------------+---------------------------------+ | offset | name | description | +--------+----------------+---------------------------------+ | 0x00 | SN0 | chip sn | +--------+----------------+---------------------------------+ | 0x20 | SN1 | reserve for product or customer | +--------+----------------+---------------------------------+ | 0x40 | MAC0 | | +--------+----------------+---------------------------------+ | 0x50 | MAC1 | | +--------+----------------+---------------------------------+ | 0x60 | PRODUCT_TYPE | | +--------+----------------+---------------------------------+ | 0x70 | MODULE_TYPE | | +--------+----------------+---------------------------------+ | 0x80 | INTERFACE_FLAG | | +--------+----------------+---------------------------------+ | 0x81 | AGING_FLAG | | +--------+----------------+---------------------------------+ | 0x90 | VENDER | | +--------+----------------+---------------------------------+ | 0xa0 | DTS_TYPE | | +--------+----------------+---------------------------------+ | 0xc0 | HW_VERSION | | +--------+----------------+---------------------------------+ | 0xd0 | PRODUCT | 产品系列,例如: SE9 | +--------+----------------+---------------------------------+ | 0xe0 | CHIP | BM1688/CV186AH | +--------+----------------+---------------------------------+ | 保留 | | | +--------+----------------+---------------------------------+ 修改和读取SN和MAC地址 ----------------------- |Product| 的SN和MAC地址存放在MCU的EEPROM中,您可以通过如下方式进行修改和读取操作。 首先需要解锁mmcblk0boot1设备节点: .. code-block:: bash sudo -i echo 0 > /sys/block/mmcblk0boot1/force_ro 写入SN: .. code-block:: bash echo "HQATEVBAIAIAI0001" > sn.txt dd if=sn.txt of=/dev/mmcblk0boot1 count=17 bs=1 echo "HQATEVBAIAIAI0002" > sn.txt dd if=sn.txt of=/dev/mmcblk0boot1 count=17 bs=1 seek=32 读取SN: .. code-block:: bash dd if=/dev/mmcblk0boot1 of=dump.bin count=17 bs=1 hexdump -C dump.bin | head 写入MAC(双网卡各有一个MAC): .. code-block:: bash echo "E0A509261417" > mac0.txt xxd -p -u -r mac0.txt > mac0.bin dd if=mac0.bin of=/dev/mmcblk0boot1 count=6 bs=1 seek=64 echo "E0A509261418" > mac1.txt xxd -p -u -r mac1.txt > mac1.bin dd if=mac1.bin of=/dev/mmcblk0boot1 count=6 bs=1 seek=80 读取MAC: .. code-block:: bash dd if=/dev/mmcblk0boot1 of=mac_dump.bin count=6 bs=1 skip=64 hexdump mac_dump.bin 最后重新对mmcblk0boot1设备节点加锁,以避免意外改写: .. code-block:: bash echo 1 > /sys/block/mmcblk0boot1/force_ro 新的MAC地址将在重启系统后生效。 读取BM1688芯片温度 ----------------------- 命令: .. code-block:: bash cat /sys/class/thermal/thermal_zone0/temp 返回(单位为毫摄氏度): .. code-block:: bash 38745 即38.745摄氏度。 Linux的thermal框架会使用这个温度做管理(需要加载soph_clock_cooling驱动): - 当温度升到110度时,TPU频率会降到450MHz,CPU降频到1GHz; - 当温度升高到120度时,TPU降频到100MHz,CPU降频到1GHz; - 当温度回落到100度时,TPU和CPU频率恢复额定值; - 当温度升高到125度时,系统关机。 另支持pwm控制风扇进行主动降温,默认策略为: - 温度在40度以下时,风扇不转; - 温度升高到40度时,风扇以100/255最大转速运行; - 温度升高到60度时,风扇以170/255最大转速运行; - 温度升高到80度时,风扇以最大转速运行。 注:可以通过设备树修改以上策略,在soph_base.dtsi文件中: .. code-block:: sophgo_cooling:sophgo-cooling { clocks = <&clk CV186X_AP_CPU_CLK>, <&clk CV186X_TPU_CLK_TPU>; clock-names = "clk_cpu", "clk_tpu_axi"; dev-freqs = <1650000000 900000000>, <1000000000 450000000>, <1000000000 100000000>; compatible = "cvitek,cv186x-cooling"; #cooling-cells = <2>; }; fan0: pwm-fan { compatible = "pwm-fan"; #cooling-cells = <2>; pwms = <&pwm0 0 1000000 0>; // default pwm0, 1ms period, normal polarity cooling-levels = <1 100 170 255>; // max 255 }; thermal-zones { soc_thermal_0: soc_thermal_0 { polling-delay-passive = <1000>; /* milliseconds */ polling-delay = <1000>; /* milliseconds */ thermal-sensors = <&thermal 0>; trips { soc_thermal_trip_0: soc_thermal_trip_0 { temperature = <110000>; /* millicelsius */ hysteresis = <10000>; /* millicelsius */ type = "passive"; }; soc_thermal_trip_1: soc_thermal_trip_1 { temperature = <120000>; /* millicelsius */ hysteresis = <20000>; /* millicelsius */ type = "passive"; }; soc_thermal_crtical_0: soc_thermal_crtical_0 { temperature = <125000>; /* millicelsius */ hysteresis = <0>; /* millicelsius */ type = "critical"; }; soc_thermal_active_0: soc_thermal_active_0 { temperature = <40000>; /* millicelsius */ hysteresis = <0>; /* millicelsius */ type = "active"; }; soc_thermal_active_1: soc_thermal_active_1 { temperature = <60000>; /* millicelsius */ hysteresis = <0>; /* millicelsius */ type = "active"; }; soc_thermal_active_2: soc_thermal_active_2 { temperature = <80000>; /* millicelsius */ hysteresis = <0>; /* millicelsius */ type = "active"; }; }; cooling-maps { map0 { trip = <&soc_thermal_trip_0>; cooling-device = <&sophgo_cooling 1 1>; }; map1 { trip = <&soc_thermal_trip_1>; cooling-device = <&sophgo_cooling 2 2>; }; map2 { trip = <&soc_thermal_active_0>; cooling-device = <&fan0 1 1>; }; map3 { trip = <&soc_thermal_active_1>; cooling-device = <&fan0 2 2>; }; map4 { trip = <&soc_thermal_active_2>; cooling-device = <&fan0 3 3>; }; }; }; 修改以上设备树节点即可自定义温控策略(TPU分频只可整数倍),参考linux Documention相关设备树说明。 查询内存用量 ----------------- |Product| 板载了16GB DDR,可以分为三类: 1. kernel管理的部分,即可以用malloc、kmalloc等常规API分配出来使用。 2. ION管理的部分,预留给TPU、VPU、VPP使用,需要使用ION的ionctl接口,或使用sophonSDK中bmlib库提供的接口分配出来使用。 3. 预留给固件的部分,用户无法使用。 您可以使用如下方式检查各部分内存的用量: 1. 查看系统内存 .. code-block:: bash linaro@bm1684:~$ free -h total used free shared buff/cache available Mem: 6.6Gi 230Mi 6.2Gi 1.0Mi 230Mi 6.3Gi Swap: 0B 0B 0B 2. 查看ION内存 .. code-block:: bash sudo -i root@bm1684:~# cat /sys/kernel/debug/ion/cvi_npu_heap_dump/summary | head -2 Summary: [0] npu heap size:4141875200 bytes, used:0 bytes usage rate:0%, memory usage peak 0 bytes root@bm1684:~# cat /sys/kernel/debug/ion/cvi_vpp_heap_dump/summary | head -2 Summary: [2] vpu heap size:2147483648 bytes, used:0 bytes usage rate:0%, memory usage peak 0 bytes 如上,通常会有2个ION heap(即两块预留的内存区域),如名字所示,分别供TPU、VPP使用。以上示例中只打印了每个heap使用信息的开头,如果完整地cat summary文件,可以看到其中分配的每块buffer的地址和大小信息。
