5. Root file system (rootfs)
5.1. Introduction about root file system
Please refer to the SDK_Compilation_and_Usage_Guide Chapter 5 root file system (rootfs)
5.2. Busybox support
At present, the file system uses BusyBox v1.27.1. If you need to update busybox, you can put the compiled busybox in the following path:
$ ramdisk/rootfs/common_musl_riscv64/bin/busybox  // CV181X
$ ramdisk/rootfs/common_musl_riscv64/bin/busybox  // CV180X
