3. Secure Image Generation
3.1. List of Keys
rsa_hash0.pem
RSA private key for sign FSBL
loader_ek.key
AES key for encrypt FSBL
bl_priv.pem
RSA private key for sign Monitor/u-boot
bl_ek.key
AES key for encrypt Monitor/u-boot
3.2. Generate Keys
  1. Generate signature private keys rsa_hash0.pem and bl_priv.pem.
    * RSA keys use 2048 bits and the 4th fermat number.
    host$ openssl genrsa -out rsa_hash0.pem -F4 2048
    host$ openssl genrsa -out bl_priv.pem -F4 2048
  2. Generate encryption/decryption keys loader_ek.key and bl_ek.key.
    * If signature only without encryption you do not need to generate these keys
    * The following uses random numbers to generate the keys
    host$ head -c 16 /dev/random > loader_ek.key
    host$ head -c 16 /dev/random > bl_ek.key
3.3. Sign and Encrypt
3.3.1. Generate Image
Please refer to <U-boot Porting Development Guide> to generate FIP.bin image.
3.3.2. Sign FIP.bin
Note
Precautions
In order to avoid the mass production key being stolen, it is suggested that the mass production key should be kept separately, and the signature tool should be used to sign and encrypt in a secure environment.
Execute the following command to sign the FIP image, fip.bin is the original image, fip_sign.bin is the signed image.
cv_crypt$ ./fipsign.py sign \
--root-priv= rsa_hash0.pem \
--bl-priv=bl_priv.pem \
fip.bin fip_sign.bin
Tool parameters:
usage: fipsign.py sign [-h] [--root-priv ROOT_PRIV] [--bl-priv BL_PRIV] SRC_FIP DEST_FIP
3.3.3. Sign and encrypt FIP.bin
Execute the following command to sign and encrypt the FIP image, fip.bin is the original image, fip_enc.bin is the signed and encrypted image.
cv_crypt$ ./fipsign.py sign-enc \
--ldr-ek=loader_ek.key \
--bl-ek=bl_ek.key \
fip.bin fip_enc.bin
Tool parameters:
usage: fipsign.py sign-enc [-h] [--ldr-ek LDR_EK] [--bl-ek BL_EK] [--root-priv ROOT_PRIV] [--bl-priv BL_PRIV] SRC_FIP DEST_FIP
Note
Encryption is optional, if encryption is required, the FIP.bin needs to be configured when compiling.
CONFIG_FSBL_SECURE_BOOT_SUPPORT = y, configuration method:
host$ source build/envsetup_soc.sh
host$ defconfig xxxxxx
host$ menuconfig –> FIP setting –> select [ ] Add secure boot support to FSBL
