11.4. Data Types¶
11.4.1. GDC_HANDLE¶
Define the handle to the GDC JOB
typedef CVI_S32 GDC_HANDLE;
None
None
11.4.2. LDC_ALIGN¶
Alignment size of GDC
#define LDC_ALIGN 64
None
None
11.4.3. GDC_PROC_JOB_INFO_NUM¶
Maximum number of GDC proc jobs
#define GDC_PROC_JOB_INFO_NUM (500)
None
None
11.4.4. GDC_MIN_IMAGE_WIDTH¶
minimum size width information supported by GDC hardware
#define GDC_MIN_IMAGE_WIDTH 64 /* minimum width of the GDC image */
None
None
11.4.5. GDC_MIN_IMAGE_HEIGHT¶
minimum size height information supported by GDC hardware
#define GDC_MIN_IMAGE_HEIGHT 64 /* minimum height of the GDC image */
None
None
11.4.6. GDC_MAX_IMAGE_WIDTH¶
Maximum size width information supported by GDC hardware
#define GDC_MAX_IMAGE_WIDTH 4032 /* maximum width of the GDC image */
None
None
11.4.7. GDC_MAX_IMAGE_HEIGHT¶
Maximum size height information supported by GDC hardware
#define GDC_MAX_IMAGE_HEIGHT 4032 /* maximum height of the GDC image */
None
None
11.4.8. GDC_TASK_ATTR_S¶
Define the attributes of GDC TASK. GDC supports pixel formats such as NV21, NV12, and YUV400.
typedef struct _GDC_TASK_ATTR_S {
VIDEO_FRAME_INFO_S stImgIn;
VIDEO_FRAME_INFO_S stImgOut;
CVI_U64 au64privateData[4];
CVI_U64 reserved;
} GDC_TASK_ATTR_S;
【Member】
Member |
stImgIn |
Input image properties |
stImgOut |
Output image properties |
au64privateData |
Task related private data |
reserved |
Reserved |
The image attributes must match the corresponding hardware attributes
VIDEO_FRAME_INFO_S
11.4.9. LDC_ATTR_S¶
Define the Lens Distortion Correction (LDC) properties.
typedef struct _LDC_ATTR_S {
CVI_BOOL bAspect; /* RW;Whether aspect ration is keep */
CVI_S32 s32XRatio; /* RW; Range: [0, 100], field angle ration of horizontal,valid when bAspect=0.*/
CVI_S32 s32YRatio; /* RW; Range: [0, 100], field angle ration of vertical,valid when bAspect=0.*/
CVI_S32 s32XYRatio; /* RW; Range: [0, 100], field angle ration of all,valid when bAspect=1.*/
CVI_S32 s32CenterXOffset;
CVI_S32 s32CenterYOffset;
CVI_S32 s32DistortionRatio;
GRID_INFO_ATTR_S stGridInfoAttr;
} LDC_ATTR_S;
【Member】
Member |
Value Range |
bAspect |
Whether aspect ration is keep |
bool |
s32XRatio |
Field angle ration of horizontal. Valid when bAspect=0. |
0~100 |
s32YRatio |
Field angle ration of vertical. Valid when bAspect=0. |
0~100 |
s32XYRatio |
Field angle ration of all,valid when bAspect=1. |
0~100 |
s32CenterXOffset |
Horizontal offset of the image center point relative to the physical center point. |
-511~+511 |
s32CenterYOffset |
Vertical offset of the image center point relative to the physical center point. |
-511~+511 |
s32DistortionRatio |
Correction strength Negative values for pincushion distortion. Positive values for barrel distortion. |
-300~+500 |
stGridInfoAttr |
gridinfo parameters. |
VIDEO_FRAME_INFO_S
11.4.10. GRID_INFO_ATTR_S¶
Define the GridInfo properties.
typedef struct _GRID_INFO_ATTR_S {
CVI_BOOL Enable;
char gridFileName[128];
char gridBindName[128];
CVI_BOOL isBlending;
CVI_BOOL bEISEnable; /* enable EIS */
uint8_t homoRgnNum;
} GRID_INFO_ATTR_S;
【Member】
Member |
Value Range |
bEnable |
Whether to enable GridInfo. |
bool |
gridFileName |
GridInfo file name. |
gridBindName |
GridInfo binding name. |
isBlending |
Not used at the moment. |
bool |
bEISEnable |
bool |
homoRgnNum |
11.4.11. MESH_DUMP_ATTR_S¶
Define the properties of the dump mesh.
typedef struct _MESH_DUMP_ATTR_S {
CVI_CHAR binFileName[128];
MOD_ID_E enModId;
union {
VI_MESH_ATTR_S viMeshAttr;
VPSS_MESH_ATTR_S vpssMeshAttr;
} MESH_DUMP_ATTR_S;
【Member】
Member |
binFileName |
mesh file name |
enModId |
Module ID |
viMeshAttr |
mesh related Settings for vi |
vpssMeshAttr |
mesh related Settings for vpss |
VIDEO_FRAME_INFO_S
11.4.12. VI_MESH_ATTR_S¶
typedef struct _VI_MESH_ATTR_S {
VI_CHN chn;
} VI_MESH_ATTR_S;
【Member】
Member |
chn |
vi chn |
11.4.13. VPSS_MESH_ATTR_S¶
typedef struct _VPSS_MESH_ATTR_S {
VPSS_GRP grp;
VPSS_CHN chn;
} VPSS_MESH_ATTR_S;
【Member】
Member |
grp |
vpss grp |
chn |
vpss chn |
