8.4. Data Types¶
The data types and data structures related to video decoding are defined as follows:
VDEC_ATTR_VIDEO_S: Video decoding video channel attributes.
VIDEO_MODE_E: Enumeration of code stream transmission methods.
VDEC_CHN_STATUS_S: Channel state structure.
VDEC_DECODE_ERROR_S: Decoding error information structure.
VDEC_CHN_PARAM_S: Decoding channel advanced parameter structure.
VDEC_PARAM_VIDEO_S: Video decoding advanced parameter structure.
VDEC_PARAM_PICTURE_S: Picture decoding advanced parameter structure.
VIDEO_DEC_MODE_E: Decoding mode enumeration.
VIDEO_OUTPUT_ORDER_E: Decoding output order enumeration.
COMPRESS_MODE_E: Decode image compression mode enumeration.
H264_PRTCL_PARAM_S: H.264 protocol related memory allocation parameters.
H265_PRTCL_PARAM_S: H.265 protocol related memory allocation parameters.
VDEC_PRTCL_PARAM_S: Protocol related memory allocation parameter structure.
VDEC_STREAM_S: Decode the bitstream structure.
VDEC_USERDATA_S: User data structure.
VIDEO_DISPLAY_MODE_E: Display mode enumeration.
VDEC_CHN_POOL_S: Define the VB pool structure bound to the decoding channel.
VDEC_CHN_ATTR_S: Decoding channel attributes.
VDEC_ATTR_VIDEO_S: Video decoding channel properties.
VIDEO_MODE_E: Enumeration of bitstream delievry methods.
VIDEO_DEC_MODE_E: Decoding mode enumeration.。
H264_PRTCL_PARAM_S: Memory allocation parameters related to H.264 protocol.
H265_PRTCL_PARAM_S: Memory allocation parameters related to H.265 protocol.
VDEC_PRTCL_PARAM_S: Memory allocation parameters related to protocol.
VDEC_STREAM_S: Decoding bitstream structure
VDEC_CHN_POOL_S: Define the structure of VB pool bound to the decoding channel.
8.4.1. VDEC_CHN_ATTR_S¶
Define the decoding channel attribute structure.
typedef struct _VDEC_CHN_ATTR_S {
PAYLOAD_TYPE_E enType; /* RW; video type to be decoded */
VIDEO_MODE_E enMode; /* RW; send by stream or by frame */
CVI_U32 u32PicWidth; /* RW; max pic width */
CVI_U32 u32PicHeight; /* RW; max pic height */
CVI_U32 u32StreamBufSize; /* RW; stream buffer size(Byte) */
CVI_U32 u32FrameBufSize; /* RW; frame buffer size(Byte) */
CVI_U32 u32FrameBufCnt;
union {
VDEC_ATTR_VIDEO_S
stVdecVideoAttr; /* structure with video ( h264/h265) */
} VDEC_CHN_ATTR_S;
【Member】
Member |
enType |
Decode protocol type enumeration. Video Codec common enumeration: PT_JPEG/ PT_H264/ PT_H265/ PT_MJPEG |
enMode |
Bitstream delievry mode. Currently only support VIDEO_MODE_FRAME |
u32PicWidth |
Maximum width of decoded image supported by channel (in pixels) |
u32PicHeight |
Maximum height of decoded image supported by channel (in pixels) |
u32StreamBufSize |
The size of the bitstream buffer. (u32StreamBufSize = u32Width * u32Height) |
u32FrameBufSize |
Size of buffer for storing decoded image frames (varies depending on enType). |
u32FrameBufCnt |
The number of decoded image frames. |
stVdecVideoAttr |
Video (H.264/H.265) decoding channel properties. |
CV181x VDEC module only supports PT_JPEG/PT_MJPEG/PT_H264,CV180x only supports PT_JPEG/PT_MJPEG.
None.
8.4.2. VDEC_ATTR_VIDEO_S¶
Define the video decoding video channel attributes.
typedef struct _VDEC_ATTR_VIDEO_S {
CVI_U32 u32RefFrameNum;
CVI_BOOL bTemporalMvpEnable;
CVI_U32 u32TmvBufSize;
} VDEC_ATTR_VIDEO_S;
【Member】
Member |
u32RefFrameNum |
The number of reference frames. (currently not supported) |
bTemporalMvpEnable |
Whether time domain motion vector prediction is supported. (currently not supported) |
u32TmvBufSize |
The size of Tmv Buffer of video decoded image. (currently not supported) |
None.
None.
8.4.3. VIDEO_MODE_E¶
Define the bitstream delievry mode.
typedef enum _VIDEO_MODE_E {
VIDEO_MODE_STREAM = 0, /* send by stream */
VIDEO_MODE_FRAME, /* send by frame */
VIDEO_MODE_COMPAT, /* One frame supports multiple packets sending. */
/* The current frame is considered to end when bEndOfFrame is equal to HI_TRUE */
VIDEO_MODE_BUTT
} VIDEO_MODE_E;
【Member】
Member |
VIDEO_MODE_STREAM |
Send the bitstream as a stream. This mode is not supported for JPEG/MJPEG decoding (currently not supported) |
VIDEO_MODE_FRAME |
The bitstream is sent in frame mode. |
VIDEO_MODE_COMPAT |
Sending bitstream in compatibility mode. (Currently not supported) |
None.
None.
8.4.4. VDEC_CHN_STATUS_S¶
Define the channel state structure.
typedef struct _VDEC_CHN_STATUS_S {
CVI_S32 u32LeftStreamBytes;
CVI_S32 u32LeftStreamFrames;
CVI_S32 u32LeftPics;
CVI_BOOL bStartRecvStream;
CVI_U32 u32RecvStreamFrames;
CVI_U32 u32DecodeStreamFrames;
VDEC_DECODE_ERROR_S stVdecDecErr;
CVI_U32 u32Width;
CVI_U32 u32Height;
} VDEC_CHN_STATUS_S;
【Member】
Member |
enType |
Decoding protocol type enumeration. Video Codec common enumeration: PT_JPEG/ PT_H264/ PT_H265/ PT_MJPEG |
u32LeftStreamBytes |
The number of bytes to be decoded in the bitstream buffer, including the number of undeciphered bytes in the current frame being decoded. |
u32LeftStreamFrames |
The number of frames to be decoded in the bitstream buffer, excluding the current frame being decoded. 1 means invalid. |
u32LeftPics |
The number of pic remaining in the image buffer. |
bStartRecvStream |
Whether the decoder has started receiving the bitstream. |
u32RecvStreamFrames |
The number of received frames in the bitstream buffer. - 1 means invalid. |
u32DecodeStreamFrames |
The number of decoded frames in the bitstream buffer. |
stVdecDecErr |
Decoding error message. |
u32Width |
image width |
u32Height |
image height. |
None.
8.4.5. VDEC_DECODE_ERROR_S¶
Define the decoding error information structure.
typedef struct _VDEC_DECODE_ERROR_S {
CVI_S32 s32FormatErr;
CVI_S32 s32PicSizeErrSet;
CVI_S32 s32StreamUnsprt;
CVI_S32 s32PackErr;
CVI_S32 s32PrtclNumErrSet;
CVI_S32 s32RefErrSet;
CVI_S32 s32PicBufSizeErrSet;
CVI_S32 s32StreamSizeOver;
CVI_S32 s32VdecStreamNotRelease;
} VDEC_DECODE_ERROR_S;
【Member】
Member |
s32FormatErr |
Unsupported format. |
s32PicSizeErrSet |
The width (or height) of the image is larger than that of the channel. |
s32StreamUnsprt |
Unsupported specification (the code stream specification is inconsistent with the specification claimed by the processor). |
s32PackErr |
There is an error in the bit stream. |
s32PrtclNumErrSet |
The number of protocol parameters set is insufficient. For example, the number of Slice, Pps and Sps. |
s32RefErrSet |
The number of reference frames set is insufficient. |
s32PicBufSizeErrSet |
The memory size of image buffer is insufficient. |
s32StreamSizeOver |
One frame code stream is too large. When the whole SCDbuffer can not hold the next frame code stream, the SCDbuffer is forced to be cleared. |
s32VdecStreamNotRelease |
VFMW internal management stream error. The bitstream is held for a long time without being released. |
None.
None.
8.4.6. VDEC_CHN_PARAM_S¶
Define advanced parameters of decoding channel.
typedef struct _VDEC_CHN_PARAM_S {
CVI_U32 u32DisplayFrameNum;
union {
VDEC_PARAM_VIDEO_S
stVdecVideoParam;
stVdecPictureParam;
} VDEC_CHN_PARAM_S;
【Member】
Member |
enType |
Common enumeration: PT_JPEG/ PT_H264/ PT_H265/ PT_MJPEG |
u32DisplayFrameNum |
The minimum number of frames to decode the cached image. |
stVdecVideoParam |
Video (H.264 / H.265) decoding advanced parameters. |
stVdecPictureParam |
Picture (JPEG/MJPEG) decoding advanced parameters |
None.
CVI_VDEC_GetChnParam
CVI_VDEC_SetChnParam
8.4.7. VDEC_PARAM_VIDEO_S¶
Define advanced parameters of video decoding.
typedef struct _VDEC_PARAM_VIDEO_S {
CVI_S32 s32ErrThreshold;
VIDEO_DEC_MODE_E enDecMode;
VIDEO_OUTPUT_ORDER_E enOutputOrder;
COMPRESS_MODE_E enCompressMode;
VIDEO_FORMAT_E enVideoFormat;
} VDEC_PARAM_VIDEO_S;
【Member】
Member |
s32ErrThreshold |
Error threshold. Value range: [0, 100]. 0 stands for losing when there is an error, 100 stands for none. |
enDecMode |
Decoding mode: |
enOutputOrder |
Decoding image output order. |
enCompressMode |
Decoding image compression mode. COMPRESS_MODE_NONE = 0, COMPRESS_MODE_TILE, COMPRESS_MODE_LINE, COMPRESS_MODE_FRAME, |
enVideoFormat |
Decoding image data format. |
None.
This parameter setting is related to VI module.
8.4.8. VDEC_PARAM_PICTURE_S¶
Define advanced parameters of graphics decoding.
typedef struct _VDEC_PARAM_PICTURE_S {
PIXEL_FORMAT_E enPixelFormat;
CVI_U32 u32Alpha;
} VDEC_PARAM_PICTURE_S;
【Member】
Member |
enPixelFormat |
JPEG (MJPEG) decoding output format. Please refer to: typedef enum _PIXEL_FORMAT_E in cvi_comm_video.h |
u32Alpha |
Global alpha when outputting in ARGB format, only valid when outputting in ARGB (currently not supported). |
None.
None.
8.4.9. VIDEO_DEC_MODE_E¶
Define the video decoding mode enumeration.
typedef enum _VIDEO_DEC_MODE_E {
VIDEO_DEC_MODE_IPB = 0,
VIDEO_DEC_MODE_IP,
VIDEO_DEC_MODE_I,
VIDEO_DEC_MODE_BUTT
} VIDEO_DEC_MODE_E;
【Member】
Member |
VIDEO_DEC_MODE_IPB |
In IPB mode, i.e. I, P and B frames are all decoded. |
VIDEO_DEC_MODE_IP |
IP mode. Only I frames and P frames are decoded. |
VIDEO_DEC_MODE_I |
I mode. Only I frames are decoded. |
None.
None.
8.4.10. VIDEO_OUTPUT_ORDER_E¶
Define the video decoding output order enumeration.
typedef enum _VIDEO_OUTPUT_ORDER_E {
VIDEO_OUTPUT_ORDER_DISP = 0,
VIDEO_OUTPUT_ORDER_DEC,
VIDEO_OUTPUT_ORDER_BUTT
} VIDEO_OUTPUT_ORDER_E;
【Member】
Member |
VIDEO_OUTPUT_ORDER_DISP |
Display order output. |
VIDEO_OUTPUT_ORDER_DEC |
Decoding order output. |
The decoded bitstream with B frame should be set to display order output.
None.
8.4.11. COMPRESS_MODE_E¶
Define an enumeration of decoding image compression modes.
typedef enum _COMPRESS_MODE_E {
COMPRESS_MODE_TILE,
COMPRESS_MODE_LINE,
COMPRESS_MODE_BUTT
} COMPRESS_MODE_E;
【Member】
Member |
COMPRESS_MODE_NONE |
No compression. |
COMPRESS_MODE_TILE |
Reserved |
COMPRESS_MODE_LINE |
Reserved |
COMPRESS_MODE_FRAME |
Reserved |
None.
None.
8.4.12. H264_PRTCL_PARAM_S¶
typedef struct _H264_PRTCL_PARAM_S {
CVI_S32 s32MaxSliceNum; /* RW; max slice num support */
CVI_S32 s32MaxSpsNum; /* RW; max sps num support */
CVI_S32 s32MaxPpsNum; /* RW; max pps num support */
} H264_PRTCL_PARAM_S;
【Member】
Member |
s32MaxSliceNum |
The maximum number of Slice supported by the channel decoding. |
s32MaxSpsNum |
The maximum number of SPS supported by the channel decoding. |
s32MaxPpsNum |
The maximum number of PPS supported by the channel decoding. |
None.
8.4.13. H265_PRTCL_PARAM_S¶
typedef struct _H265_PRTCL_PARAM_S {
CVI_S32 s32MaxSliceSegmentNum; /* RW; max slice segmnet num support */
CVI_S32 s32MaxVpsNum; /* RW; max vps num support */
} H265_PRTCL_PARAM_S;
【Member】
Member |
s32MaxSliceSegmentNum |
The maximum number of SliceSegment supported by the channel decoding. |
s32MaxVpsNum |
The maximum number of VPS supported by the channel decoding. |
s32MaxSpsNum |
s32MaxPpsNum |
None.
8.4.14. VDEC_PRTCL_PARAM_S¶
typedef struct _VDEC_PRTCL_PARAM_S {
PAYLOAD_TYPE_E
enType;
union {
H264_PRTCL_PARAM_S
stH264PrtclParam;
H265_PRTCL_PARAM_S
stH265PrtclParam;
} VDEC_PRTCL_PARAM_S;
【Member】
Member |
enType |
Decoding protocol supported by channel. |
stH264PrtclParam |
H.264 protocol parameter |
stH265PrtclParam |
H.265 protocol parameter |
None.
8.4.15. VDEC_STREAM_S¶
Define the bitstream structure of video decoding.
typedef struct _VDEC_STREAM_S {
CVI_U32 u32Len;
CVI_U64 u64PTS;
CVI_BOOL bEndOfFrame;
CVI_BOOL bEndOfStream;
CVI_BOOL bDisplay;
CVI_U8 *pu8Addr;
} VDEC_STREAM_S;
【Member】
Member |
u32Len |
The length of the stream packet. |
u64PTS |
The timestamp of the stream packet. |
bEndOfFrame |
Whether the current frame ends. |
bEndOfStream |
Whether all the bitstream has been sent. |
pu8Addr |
The address of the stream packet. |
bDisplay |
Whether the current frame is output for display. |
None.
None.
8.4.16. VDEC_USERDATA_S¶
Define the user data structure.
typedef struct _VDEC_USERDATA_S {
CVI_U64 u64PhyAddr;
CVI_U32 u32Len;
CVI_BOOL bValid;
CVI_U8 *pu8Addr;
} VDEC_USERDATA_S;
【Member】
Member |
u32PhyAddr |
The physical address of the user data |
u32Len |
The length of user data. |
bValid |
Valid identifier of the current data. |
pu8Addr |
The virtual address of the user data. |
None.
None.
8.4.17. VIDEO_DISPLAY_MODE_E¶
Defines the display mode enumeration.
typedef enum _VIDEO_DISPLAY_MODE_E {
VIDEO_DISPLAY_MODE_PREVIEW = 0x0,
VIDEO_DISPLAY_MODE_PLAYBACK = 0x1,
VIDEO_DISPLAY_MODE_MAX
} VIDEO_DISPLAY_MODE_E;
【Member】
Member |
VIDEO_DISPLAY_MODE_PREVIEW |
Preview mode. |
VIDEO_DISPLAY_MODE_PLAYBACK |
Playback mode. |
None.
None.
8.4.18. VDEC_PARAM_MOD_S¶
Parameters related to decoding modules.
typedef struct _VDEC_MOD_PARAM_S {
VB_SOURCE_E enVdecVBSource;
CVI_U32 u32MiniBufMode;
CVI_U32 u32ParallelMode;
VDEC_VIDEO_MOD_PARAM_S stVideoModParam;
VDEC_PICTURE_MOD_PARAM_S stPictureModParam;
} VDEC_MOD_PARAM_S;
【Member】
Member |
enVdecVBSource |
Source of decoding frame buffer (VB). Value range: only supported VB_SOURCE_COMMON, VB_SOURCE_USER |
u32MiniBufMode |
Stream buffer configuration mode |
u32ParallelMode |
VDH decoding mode |
stVideoModParam |
Parameters of video decoding module. Invalid for JPEG / MJPEG. |
stPictureModParam |
Picture decoding module parameters. Invalid for H264/H265. |
None.
CVI_VDEC_SetModParam
CVI_VDEC_GetModParam
8.4.19. VDEC_VIDEO_MOD_PARAM_S¶
Define the parameter structure of video decoding module
typedef struct _VDEC_VIDEO_MOD_PARAM_S {
CVI_U32 u32MaxPicWidth;
CVI_U32 u32MaxPicHeight;
CVI_U32 u32MaxSliceNum;
CVI_U32 u32VdhMsgNum;
CVI_U32 u32VdhBinSize;
CVI_U32 u32VdhExtMemLevel;
} VDEC_VIDEO_MOD_PARAM_S;
【Member】
Member |
u32MaxPicWidth |
Maximum width supported by video decoding. Value range: See Table 7-1, the minimum value is the minimum width of the resolution supported by H.264/H.265 decoding. The maximum value is the maximum width of the resolution supported by H.264/H.265 decoding. The default value is the maximum value. |
u32MaxPicHeight |
Maximum height supported by video decoding. Value range: See Table 7-1, the minimum value is the minimum width of the resolution supported by H.264/H.265 decoding. The maximum value is the maximum width of the resolution supported by H.264/H.265 decoding. The default value is the maximum value. |
u32MaxSliceNum |
Maximum number of slice supported by H.264/H.265 decoding. Value range: the minimum value is 1, and the maximum value is the maximum number of slice supported by H.264/H.265 decoding. The default value is the maximum value. |
u32VdhMsgNum |
The number of VDH decoded message pools. |
u32VdhBinSize |
Size of the buffer used to cache bin data for VDH decoding. |
u32VdhExtMemLevel |
Level of external memory allocation for VDH decoding. |
CV812x only supports H264 decoding.
8.4.20. VDEC_PICTURE_MOD_PARAM_S¶
Define the parameter structure of picture decoding module.
typedef struct _VDEC_PICTURE_MOD_PARAM_S {
CVI_BOOL bSupportProgressive;
CVI_BOOL bDynamicAllocate;
VDEC_CAPACITY_STRATEGY_E enCapStrategy;
} VDEC_PICTURE_MOD_PARAM_S;
【Member】
Member |
u32MaxPicWidth |
The maximum width supported by image decoding, with a default value of the maximum width supported by the current processor. Value range: the minimum value is the minimum width supported by JPEG/MJPEG decoding, and the maximum value is the maximum width supported by JPEG/MJPEG decoding. The default value is the maximum value. |
u32MaxPicHeight |
The maximum height supported by the image decoding, with a default value of the maximum height supported by the current processor. The value range is from the minimum width of the supported resolution for JPEG/MJPEG decoding to the maximum width of the supported resolution for JPEG/MJPEG decoding, with a default value of the maximum width. |
bSupportProgressive |
Whether JPEG / MJPEG decoding supports progressive format. |
bDynamicAllocate |
When JPEG / MJPEG decoding supports progressive format, the required buf allocation method is 0 by default. |
enCapStrategy |
The maximum width and height capability set strategy of decoding image. |
None.
8.4.21. VDEC_CHN_POOL_S¶
typedef struct _VDEC_CHN_POOL_S {
VB_POOL hPicVbPool; /* RW; vb pool id for pic buffer */
VB_POOL hTmvVbPool; /* RW; vb pool id for tmv buffer */
} VDEC_CHN_POOL_S;
【Member】
Member |
hPicVbPool |
VB pool Poold for storing picture |
hTmvVbPool |
VB pool Poolld used to store TMV. |
None.
CVI_VDEC_AttachVbPool
