8.1. 微服务器定制化软件包
在微服务器[SE5/SE7]上执行系统打包脚本
  1. 下载打包需要使用的脚本: socBak.sh 。
#!/bin/bash
# These parameters are used to exclude irrelevant files
# and directories in the context of repackaging mode.
# Users can add custom irrelevant files and directories
# in the format of ROOTFS_EXCLUDE_FLAGS_INT to the
# ROOTFS_EXCLUDE_FLAGS_USER parameter.
ROOTFS_EXCLUDE_FLAGS_INT='--exclude=./var/log/* --exclude=./boot/* --exclude=./recovery/* --exclude=./data/* --exclude=./media/* --exclude=./sys/* --exclude=./proc/* --exclude=./dev/* --exclude=./factory --exclude=./run/udev/* --exclude=./run/user/* --exclude=./socrepack'
ROOTFS_EXCLUDE_FLAGS_USER=''
ROOTFS_EXCLUDE_FLAGS_OPT="${ROOTFS_EXCLUDE_FLAGS_INT} ${ROOTFS_EXCLUDE_FLAGS_USER} --exclude=./opt/*"
ROOTFS_EXCLUDE_FLAGS_SYSTEM="${ROOTFS_EXCLUDE_FLAGS_INT} ${ROOTFS_EXCLUDE_FLAGS_USER} --exclude=./system/*"
ROOTFS_EXCLUDE_FLAGS=''
# These parameters define several generated files and
# their default sizes for repackaging. Users can modify
# them according to their device specifications.
TGZ_FILES=(boot data opt system recovery rootfs)
# Here are the default sizes for each partition
declare -A TGZ_FILES_SIZE
TGZ_FILES_SIZE=(["boot"]=131072 ["recovery"]=3145728 ["rootfs"]=2621440 ["opt"]=2097152 ["system"]=2097152 ["data"]=4194304)
# The increased size of each partition compared to the original partition table
TGZ_ALL_SIZE=$((100*1024))
EMMC_ALL_SIZE=20971520
EMMC_MAX_SIZE=30000000
TAR_SIZE=0
TGZ_FILES_PATH=$(pwd)
PARTITION_FILE=partition32G.xml
SOC_VERSION=0
ONLY_TEST=0
if [ -d "/system" ]; then
    SOC_VERSION=0
    TGZ_FILES=( ${TGZ_FILES[@]/opt} )
    unset TGZ_FILES_SIZE[opt]
    echo find /system dir, the version is 3.0.0 or lower
    ROOTFS_EXCLUDE_FLAGS="${ROOTFS_EXCLUDE_FLAGS_SYSTEM}"
elif [ -d "/opt" ]; then
    SOC_VERSION=1
    TGZ_FILES=( ${TGZ_FILES[@]/system} )
    unset TGZ_FILES_SIZE[system]
    echo find /opt dir, the version is V22.09.02 or higher
    ROOTFS_EXCLUDE_FLAGS="${ROOTFS_EXCLUDE_FLAGS_OPT}"
else
    echo cannot find /opt or /system, Please check the operating environment
    exit
fi
for TGZ_FILE in "${TGZ_FILES[@]}"
do
    case $TGZ_FILE in
        "rootfs")
            pushd /
            echo tar $TGZ_FILE flags : $ROOTFS_EXCLUDE_FLAGS ...
            if [ "$ONLY_TEST" == "0" ]; then
                mkdir -p /etc/systemd/system/basic.target.wants/
                pushd /etc/systemd/system/basic.target.wants/
                ln -s ../../../../lib/systemd/system/resize-helper.service
                popd
                tar -caSf $TGZ_FILES_PATH/$TGZ_FILE.tgz $ROOTFS_EXCLUDE_FLAGS ./*
                rm /etc/systemd/system/basic.target.wants/resize-helper.service
            fi
            TAR_SIZE=$(du -s ./ $ROOTFS_EXCLUDE_FLAGS | awk '{s=$1} END {printf "%d", s}')
            TAR_SIZE=$(($TAR_SIZE+$((512*1024))))
            popd
            pushd /$TGZ_FILE
            echo tar $TGZ_FILE ...
                tar -caSf $TGZ_FILES_PATH/$TGZ_FILE.tgz ./*
            fi
            TAR_SIZE=$(du -s ./ | awk '{s=$1} END {printf "%d", s}')
            TAR_SIZE=$(($TAR_SIZE+$((100*1024))))
            popd
    esac
    echo $TGZ_FILES_PATH/$TGZ_FILE.tgz : $TAR_SIZE KB
    if [ $TAR_SIZE -gt ${TGZ_FILES_SIZE["$TGZ_FILE"]} ];
    then
        echo need to expand $TGZ_FILE from ${TGZ_FILES_SIZE[$TGZ_FILE]} KB to $TAR_SIZE KB
        TGZ_FILES_SIZE[$TGZ_FILE]=$TAR_SIZE
    fi
done
do
    TGZ_ALL_SIZE=$(($TGZ_ALL_SIZE+${TGZ_FILES_SIZE["$TGZ_FILE"]}))
done
echo partition table size : $TGZ_ALL_SIZE KB
if [ $TGZ_ALL_SIZE -gt $EMMC_ALL_SIZE ];
    then
        echo need to expand default partition table size from $EMMC_ALL_SIZE KB to $TGZ_ALL_SIZE KB
        EMMC_ALL_SIZE=$TGZ_ALL_SIZE
fi
if [ $TGZ_ALL_SIZE -gt $EMMC_MAX_SIZE ];
    then
        echo The total size is too large.
        exit 1
fi
echo The generated file partition32G.xml can replace file bootloader-arm64/scripts/partition32G.xml in VXX
echo or replace some information for 3.0.0
echo "<physical_partition size_in_kb=\"$EMMC_ALL_SIZE\">" > $TGZ_FILES_PATH/$PARTITION_FILE
echo "      <partition label=\"BOOT\"       size_in_kb=\"${TGZ_FILES_SIZE[boot]}\"  readonly=\"false\"  format=\"1\" />" >> $TGZ_FILES_PATH/$PARTITION_FILE
echo "      <partition label=\"RECOVERY\"   size_in_kb=\"${TGZ_FILES_SIZE[recovery]}\"  readonly=\"false\" format=\"2\" />" >> $TGZ_FILES_PATH/$PARTITION_FILE
echo "      <partition label=\"MISC\"       size_in_kb=\"10240\"  readonly=\"false\"   format=\"0\" />" >> $TGZ_FILES_PATH/$PARTITION_FILE
echo "      <partition label=\"ROOTFS\"     size_in_kb=\"${TGZ_FILES_SIZE[rootfs]}\" readonly=\"true\"   format=\"2\" />" >> $TGZ_FILES_PATH/$PARTITION_FILE
echo "      <partition label=\"ROOTFS_RW\"  size_in_kb=\"6291456\" readonly=\"false\"  format=\"2\" />" >> $TGZ_FILES_PATH/$PARTITION_FILE
if [ "$SOC_VERSION" == "1" ]; then
    echo "  <partition label=\"OPT\"        size_in_kb=\"${TGZ_FILES_SIZE[opt]}\" readonly=\"false\"  format=\"2\" />" >> $TGZ_FILES_PATH/$PARTITION_FILE
else
    echo "  <partition label=\"SYSTEM\"     size_in_kb=\"${TGZ_FILES_SIZE[system]}\" readonly=\"false\"  format=\"2\" />" >> $TGZ_FILES_PATH/$PARTITION_FILE
fi
echo "      <partition label=\"DATA\"       size_in_kb=\"${TGZ_FILES_SIZE[data]}\" readonly=\"false\"  format=\"2\" />" >> $TGZ_FILES_PATH/$PARTITION_FILE
echo "</physical_partition>" >> $TGZ_FILES_PATH/$PARTITION_FILE
cat $TGZ_FILES_PATH/$PARTITION_FILE
  1. 准备一个外部存储设备(SD卡,TF卡或U盘等),将打包工具 socBak.sh 拷入该设备下, 将设备插到微服务上, 切换到root账户。
sudo su
  1. 登录到微服务器上,使用 fdisk -l 指令查看刚才接入的外部存储的设备文件名,外部存储设备接入盒子后,系统会自动分配一个设备文件名。
fdisk -l
测试使用的设备在微服务上显示的是 /dev/sda4, 后面操作是在此基础上进行的,不同的设备显示可能不同。
  1. 在根目录下创建 socrepack 目录,将外部存储挂载到该目录下。
cd /
mkdir socrepack
cd socrepack/
mount /dev/sda4 /socrepack/
  1. 给脚本添加执行权限, 然后执行打包脚本。
chmod +x socBak.sh
bash socBak.sh
执行成功后主要生成一下几个文件
└── socrepack
    ├── boot.tgz
    ├── data.tgz
    ├── opt.tgz
    ├── partition32G.xml
    ├── recovery.tgz
    └── rootfs.tgz
在X86机器上制作定制的系统包, 推荐使用Ubuntu18.04
  1. 下载重打包所需文件:
工具链及Ubuntu基础环境包的目录解压后如下:
├── distro
├── gcc-linaro-6.3.1-2017.05-x86_64_aarch64-linux-gnu.tar.xz
└── memory_layout_modification_tool
2. 将distro放到bootloader-arm64同级目录, 将gcc-linaro-6.3.1-2017.05-x86_64_aarch64-linux-gnu.tar.xz解压到bootloader-arm64同级目录; 在bootloader-arm64同级目录下创建install目录, 并在install目录下创建soc_bm1684目录;将sdcard.tgz移动到install/soc_bm1684路径下。
最终的目录结构如下:
├── bootloader-arm64
├── install
│   └── soc_bm1684
│       └── sdcard.tgz
└── distro
  1. 安装依赖项。
sudo apt install bison flex bc rsync kmod byobu language-pack-en gcc util-linux exfat-utils dosfstools
sudo apt install cpio uuid-dev cmake libssl-dev fakeroot dpkg-dev uuid libxml2
sudo apt install device-tree-compiler u-boot-tools libxml2-dev debootstrap qemu-user-static kpartx
  1. 设置环境变量。
source bootloader-arm64/scripts/envsetup.sh
  1. 使用revert_package命令进行拆包。
revert_package
  1. 拆包结果会在install/soc_bm1684路径,软件包和文件夹的具体描述请参考《 官方BSP文档 》。
其目录结构如下:
└── soc_bm1684
    ├── boot.tgz
    ├── package_update
    ├── rootfs.tgz
    ├── sdcard.tgz
    ├── spi_flash_bm1684.bin
    ├── data.tgz
    ├── opt.tgz
    ├── recovery.tgz
    ├── rootfs_rw.tgz
    ├── spi_flash.bin
    └── spi_flash_bm1684x.bin
  1. 将微服务器上生成的文件替换到install/soc_bm1684目录下。
  2. 将微服务器上生成的partition32G.xml替换到bootloader-arm64/scripts/目录下。
  3. 使用build_update sdcard指令更新刷机包,得到的定制刷机包位于install/soc_bm1684/sdcard目录下。
