10. PWM Operation Guide¶
10.1. The Preparations for PWM Operation Are as Follow¶
Use the kernel released by SDK
10.2. Operation Process¶
Insert module :cv180x: Insmod cv180x_pwm.ko, cv181x: insmod cv181x_pwm.ko.
Run PMW read/write command under console or write PWM read/write program in kernel space or user space to carry out input/output operation on PWM.
PWM operation has 16 channels at 100MHz constant frequency clock, each channel can be controlled independently.
Cv180X/CV181X has 4 PWM IP (pwmprocessor0/ pwmprocessor4/ pwmprocessor8/ pwmprocessor12), each IP controls 4 channels, can control 16 signals in total. The circuit diagram is represented by pwm0 to pwm15
In Linux sysfs, the pwm0 to pwm3 device nodes are as follows:
/sys/class/pwm/pwmprocessor0/pwm0~3
In Linux sysfs, the pwm4 to pwm7 device nodes are listed as follows:
/sys/class/pwm/pwmprocessor4/pwm0~3
And so on
10.3. Operation Example¶
10.3.1. PWM Operation Commands Example¶
Step 1:
Use the echo command in the console to configure the PWM number to be operated, for example, PWM1:
echo 1 > /sys/class/pwm/pwmprocessor0/export
Step 2:
Set the duration of a PWM cycle (unit: ns):
echo 1000000 >/sys/class/pwm/pwmprocessor0/pwm1/period
Step 3:
Set the “ON” time of a cycle(unit: ns), namely the duty cycle= duty_cycle/period=50% :
echo 500000 >/sys/class/pwm/pwmprocessor0/pwm1/duty_cycle
Step 4:
Enable the PWM :
echo 1 >/sys/class/pwm/pwmprocessor0/pwm1/enable
10.3.2. An Example of a Program to Operate Through File IO¶
IO read-write operation program example with user space:
Step 1:
Configure the number of the PWM to be operated, for example, PWM1:
fd = open("/sys/class/pwm/pwmprocessor0/export", O_WRONLY); if(fd < 0) { dbmsg("open export error\n"); return -1; } ret = write(fd, "1", strlen("0")); if(ret < 0) { dbmsg("Export pwm1 error\n"); return -1; }
Step 2:
fd_period = open("/sys/class/pwm/pwmprocessor0/pwm1/period", O_RDWR); ret = write(fd_period, "1000000”,strlen("1000000”)); if(ret < 0) { dbmsg("Set period error\n"); return -1; }
Step 3:
Set the “ON” time of a cycle. (unit: ns) Duty cycle=50% for this example.
fd_duty = open("/sys/class/pwm/pwmprocessor0/pwm1/duty_cycle", O_RDWR); ret = write(fd_duty, "500000", strlen("500000")); if(ret < 0) { dbmsg("Set period error\n"); return -1; }
Step 4:
Enable PWM:
fd_enable = open("/sys/class/pwm/pwmprocessor0/pwm1/enable", O_RDWR); ret = write(fd_enable, "1", strlen("1")); if(ret < 0) { dbmsg("enable pwm0 error\n"); return -1; }
