11. ADC Operation Guide¶
11.1. The Preparations of ADC Operation Are as Follow¶
Use the kernel released by SDK.
11.2. Operation Process¶
Insert module: cv180x, insmod cv180x_saradc.ko, cv181x, insmod cv181x_saradc.ko.
Run ADC read/write command under the console or write ADC read/write program in kernel space or user space to carry out input/output operation on ADC.
The user layer accesses the IIO interface to implement trigger and sampling operations of three-channel and 12-bit ADC.
1.5v ref reference voltage.
11.3. Operation Example¶
11.3.1. ADC Operation Commands Example:¶
Step 1:
Specify ADC channels 1 to 6, in this example, ADC1:
(ADC channel 4 is dedicated to measuring VDDC_RTC; ADC channel 5 is PWR_GPIO1; ADC channel 6 is PWR_VBAT_
echo 1 > /sys/class/cvi-saradc/cvi-saradc0/device/cv_saradc
Step 2:
Read selected ADC channe
cat /sys/class/cvi-saradc/cvi-saradc0/device/cv_saradc
11.3.2. ADC Read-Write Operation Program Example with User Space¶
Step 1:
Configure the ADC channel number to be operated:
fd = open(/sys/class/cvi-saradc/cvi-saradc0/device/cv_saradc”, O_RDWR|O_NOCTTY|O_NDELAY)); If (fd < 0) printf("open adc err!\n"); write(fd, “1”, 1);
Step 2:
Read the ADC values:
char buffer[512]; int len = 0; int adc_value = 0; len = read(fd, buffer, 10); if (len != 0) { adc_value= atoi(buffer); printf("adc value is %d\n", adc_alue); } close(fd);
