2. Build CVITEK Software Compilation Environment¶
2.1. Linux Server¶
Developers can choose to use:
Ubuntu OS computer
Windows OS computer + Virtualbox VM (run Ubuntu on it)
In both cases, install Ubuntu 20.04 LTS.
Virtualbox VM Download site: https://www.virtualbox.org/wiki/Downloads
Ubuntu 20.04 LTS Download site: https://releases.ubuntu.com/focal/ubuntu-20.04.6-desktop-amd64.iso
2.1.1. Install Ubuntu on VirtualBoxVM¶
Create and name the new VM
Plan 8GB memory for VM use.
Reserve 200GB hard disk space for subsequent storage of SDK.
2.1.2. Ubuntu Boot Settings¶
First boot requires mounting the installation disk’s ISO file
Start Installation
Set up VirtualBox Host-only Ethernet Adapter for Host to communicate with VirtualBox (terminal services and files sharing)
2.1.3. Install SSH Server¶
SSH Server Installation
sudo apt-get install ssh
sudo apt-get install openssh-server
After installation, some ssh settings can be changed, such as port, password authentication, root login, etc.
vim /etc/ssh/sshd_config
Port 22
PasswordAuthentication yes
PermitRootLogin yes -> 是否开放 root 登入
Restart SSH after modification
sudo /etc/init.d/ssh restart
2.1.4. Install Samba Server¶
Ubuntu VB requires the Samba package to be installed for subsequent files sharing with Host PC.
Before installing Samba, use ifconfig to get IP information, the first installation will show that there is no net-tool support, it needs to install net-tool
sudo apt install net-tools
sudo apt-get install samba samba-common
Create the samba password for the account
sudo smbpasswd -a cvitek
Modify /etc/samba/smb.conf and add the following
[cvitek]path = /home/cvitek
writable = yes
browseable= yes
valid users = cvitek
Start samba server
sudo service smbd restart
WINDOW PC connects to Samba server (<Server IP>)
Refer to 1.2 to install CVITEK Build Environment to compile.
2.2. Build a compilation environment¶
Before compiling the SDK, the following packages need to be installed in Ubuntu.
sudo apt-get update
sudo apt-get install -y build-essential
sudo apt-get install -y ninja-build
sudo apt-get install -y automake
sudo apt-get install -y autoconf
sudo apt-get install -y libtool
sudo apt-get install -y wget
sudo apt-get install -y curl
sudo apt-get install -y git
sudo apt-get install -y gcc
sudo apt-get install -y libssl-dev
sudo apt-get install -y bc
sudo apt-get install -y slib
sudo apt-get install -y squashfs-tools
sudo apt-get install -y android-sdk-libsparse-utils
sudo apt-get install -y android-sdk-ext4-utils
sudo apt-get install -y jq
sudo apt-get install -y cmake
sudo apt-get install -y python3-distutils
sudo apt-get install -y tclsh
sudo apt-get install -y scons
sudo apt-get install -y parallel
sudo apt-get install -y ssh-client
sudo apt-get install -y tree
sudo apt-get install -y python3-dev
sudo apt-get install -y python3-pip
sudo apt-get install -y device-tree-compiler
sudo apt-get install -y cpio
sudo apt-get install -y fakeroot
sudo apt-get install -y libncurses5
sudo apt-get install -y flex
sudo apt-get install -y bison
sudo apt-get install -y pkg-config
sudo pip3 install -U yoctools
Attention
Make sure to check if the python command exists. If it doesn’t, a symbolic link needs to be created to the python3 command.
sudo ln -s /usr/bin/python3 /usr/bin/python
2.2.1. Compile Using Docker¶
You can map the SDK to a docker container and run compilation commands inside the container. If you have issues with your compilation environment, you can use this method.
Prepare Dockerfile, save the following content to file cvitek-linux-Dockerfile
# based on ubuntu:20.04 FROM ubuntu:20.04 ENV DEBIAN_FRONTEND=noninteractive ENV TZ=Asia/Shanghai # install deps RUN apt-get update \ && apt-get install -y \ pkg-config RUN DEBIAN_FRONTEND=noninteractive apt-get install -y \ build-essential \ ninja-build \ automake \ autoconf \ libtool \ wget \ curl \ git \ gcc \ libssl-dev \ bc \ slib \ squashfs-tools \ android-sdk-libsparse-utils \ android-sdk-ext4-utils \ jq \ cmake \ python3-distutils \ tclsh \ scons \ parallel \ ssh-client \ tree \ python3-dev \ python3-pip \ device-tree-compiler \ libssl-dev \ ssh \ cpio \ squashfs-tools \ fakeroot \ libncurses5 \ flex \ bison \ rsync \ && apt-get clean \ && rm -rf /var/lib/apt/lists/* # install yoctools for building alios RUN ln -s /usr/bin/python3 /usr/bin/python RUN pip3 install yoctools -U # set work dir WORKDIR /cvitek-sdk # set mount point VOLUME ["/cvitek-sdk"] CMD ["/bin/bash"]
Build docker image
docker build -t cvitek-linux -f cvitek-linux-Dockerfile .
After getting the SDK to folder /data/xxx/SDK/ (see description below), start the container:
docker run -it --name cvitek-linux \ -v /data/xxx/SDK:/cvitek-sdk \ cvitek-linux
2.3. Config github account¶
Create a personal account on GitHub and set up the SSH key. A personal GitHub account is required to download the code.
Set up account email address
git config --global user.name "your_name" git config --global user.email "your_email@example.com"
Configure the ssh key
ssh-keygen -t ed25519 -C "your_email@example.com" cat ~/.ssh/id_ed25519.pubAdd the public key to GitHub
Verify whether SSH is configured successfully
ssh -T git@github.com
2.4. Get SDK Source Code¶
Use Git to pull the latest SDK source code from GitHub. See: https://github.com/sophgo/sophpi
git clone -b sg200x-evb git@github.com:sophgo/sophpi.git # 获取 v4.1.0 SDK ./sophpi/scripts/repo_clone.sh --gitclone sophpi/scripts/subtree.xml
2.5. Compilation¶
2.5.1. Environment Variables Description¶
The pre-compilation operation is mostly for setting two environment variables: $CHIP, $BOARD,
$CHIP variable is required to be set according to the user’s SOC.
$BOARD variable has a different driver for each EVB and must be set correctly.
For example:
$BOARD=wevb_0008a_spinor: is SPINOR+DDR2 1333 64 MB hardware combination
$BOARD=wevb_0009a_spinand: is SPINAND+DDR3 1866 128MB hardware combination
Note: wevb_0008a / wevb_0009a can be obtained by the EVB laser model directly.
2.5.2. Compile the Entire Package¶
Before setting the environment variables, the following commands are required to initialize the environment. The ICs and EVB version numbers currently supported by the SDK will be listed by the system.
$ source build/cvisetup.sh
Usage:
(1) menuconfig - Use menu to configure your board.
ex: $ menuconfig
(2) defconfig $CHIP_ARCH - List EVB boards($BOARD) by CHIP_ARCH.
** cv183x ** -> ['cv1829', 'cv1832', 'cv1835', 'cv1838', 'cv9520', 'cv7581']
** cv182x ** -> ['cv1820', 'cv1821', 'cv1822', 'cv1823', 'cv1825', 'cv1826', 'cv7327', 'cv7357']
** cv181x ** -> ['cv181x', 'cv1823a', 'cv1821a', 'cv1820a', 'cv1811h', 'cv1811c', 'cv1810c', 'cv1812h']
** cv180x ** -> ['cv180x', 'cv1800b', 'cv1800c', 'cv1801b', 'cv1801c']
ex: $ defconfig cv183x (3) defconfig $BOARD - Choose EVB board settings.
ex: $ defconfig cv1835_wevb_0002a
ex: $ defconfig cv1826_wevb_0005a_spinand
ex: $ defconfig cv180x_fpga_c906
After initialization, the compilation configuration can be set in the following two ways
2.5.2.1. Set by defconfig¶
Select IC: Take cv180x as an example, the system will print out the EVB ($CHIP_$BOARD) board supported by cv180x built-in.
$ defconfig cv180x
* cv180x * the avaliable cvitek EVB boards
cv180x - cv180x_fpga [FPGA]
cv180x_palladium [PALLADIUM]
cv1800b - cv1800b_wdmb_0008a_spinor [C906B + SPINOR 8MB + QFN SIP 64MB]
cv1800b_wevb_0008a_spinor [C906B + SPINOR 16MB + QFN SIP 64MB]
cv1800c - cv1800c_wevb_0009a_spinor [C906B + SPINOR 16MB + QFN SIP 64MB]
cv1801b - cv1801b_wevb_0008a_spinor [C906B + SPINOR 16MB + QFN SIP 128MB]
cv1801c - cv1801c_wdmb_0009a_spinor [C906B + SPINOR 16MB + QFN SIP 128MB]
cv1801c_wevb_0009a_spinand [C906B + SPINAND 256MB + QFN SIP 128MB]
cv1801c_wevb_0009a_spinor [C906B + SPINOR 16MB + QFN SIP 128MB]
cv1812h_wevb_0007a_spinor [C906B + SPINOR 16MB + BGA SIP 256MB]
Select the EVB version number cv1801c_wevb_0009a_spinor, then the system will list the automatically set environment variables. (Subsequently, cvi_print_env can also be used to print the environment variables currently in use)
$ defconfig cv1801c_wevb_0009a_spinor
====== Environment Variables =======
PROJECT: cv1801c_wevb_0009a_spinor, DDR_CFG=ddr3_1866_x16
CHIP_ARCH: CV180X, DEBUG=0
SDK VERSION: musl_riscv64, RPC=0
ATF options: ATF_KEY_SEL=default, BL32=1
Linux source folder:linux_5.10, Uboot source folder: u-boot-2021.10
CROSS_COMPILE_PREFIX: riscv64-unknown-linux-musl-
ENABLE_BOOTLOGO: 0
Flash layout xml: build/boards/cv180x/cv1801c_wevb_0009a_spinor/part
ition/partition_spinor.xml
Sensor tuning bin: gcore_gc4653
Output path: install/soc_cv1801c_wevb_0009a_spinor
2.5.3. Compile the Entire SDK Files¶
Execute the compilation and get the images available for burning.
cvitek@cvitek-VirtualBox:~/working_dir$ build_all
. Run build_uboot () function
/work/install/cv1801c_wevb_0009a_spinor/upgrade.zip done!
The complied file will be placed in ./install/soc_<EVB Name>/
2.5.4. Compile part of the SDK files¶
2.5.4.1. Compile Uboot Separately¶
Each EVB board defines in a specific location the initialization operations that the EVB needs to take before entering U-Boot or defines a specific PINMUX. Taking the board cv1801c_wevb_0009a_spinor as an example, they will be defined in.
build/boards/CV181X/$CHIP_$BOARD/u-boot/cvi_board_init.c
int cvi_board_init(void)
#if defined(CV180X_QFN_88_PIN)
PINMUX_CONFIG(PAD_MIPI_TXP1, IIC2_SCL);
PINMUX_CONFIG(PAD_MIPI_TXM1, IIC2_SDA);
PINMUX_CONFIG(PAD_MIPI_TXP0, XGPIOC_13);
PINMUX_CONFIG(PAD_MIPI_TXM0, CAM_MCLK1);
#elif defined(CV180X_QFN_88_PIN_38)
return 0;
The corresponding u-boot configuration, defined in CV181X:
./build/boards/CV181X/$CHIP_$BOARD/u-boot/$CHIP_$BOARD_defconfig
Partial cvitek_cv1801c_wevb_0009a_spinor_defconfig
CONFIG_RISCV=y
CONFIG_SYS_MALLOC_F_LEN=0x2000
CONFIG_NR_DRAM_BANKS=1
CONFIG_DEFAULT_DEVICE_TREE="cv180x_asic"
CONFIG_IDENT_STRING=" cvitek_cv180x"
Modify Uboot Config with a graphical interface
After exiting, the settings will be stored in:
./u-boot/build/"$CHIP"_"$BOARD"/.config
Execute compilation
$ build_uboot
When completed, fip.bin will be generated
Compile U-Boot fragments in Makefile
u-boot-build: ${UBOOT_PATH}/${UBOOT_OUTPUT_FOLDER} ${UBOOT_CVIPART_DEP} ${UBOOT_OUTPUT_CONFIG_PATH}
$(call print_target)
${Q}rm -f ${UBOOT_CVI_BOARD_INIT_PATH}
${Q}ln -s ${BUILD_PATH}/boards/${PROJECT_FULLNAME}/u-boot/cvi_board_init.c ${UBOOT_CVI_BOARD_INIT_PATH}
${Q}$(MAKE) -j${NPROC} -C ${UBOOT_PATH} olddefconfig
${Q}$(MAKE) -j${NPROC} -C ${UBOOT_PATH} all
$(call uboot_compress_action)
2.5.4.2. Compile kernel separately¶
Modify the kernel (ex:*.dts, kernel) and recompile the Linux kernel image.
Each EVB has a corresponding dts file to define its device tree, take cv1801c_wevb_0009a_spinor for example, its DTS file is defined in:
./build/boards/cv180x/"$CHIP"_"$BOARD"/dts_riscv/"$CHIP"_"$BOARD".dts`
#/dts-v1/;
#include "cv180x_base_riscv.dtsi"
#include "cv180x_asic_qfn.dtsi"
#include "cv180x_asic_spinor.dtsi"
#include "cv180x_default_memmap.dtsi"
Its corresponding linux configuration is defined in:
./build/boards/"$CHIP"_"$BOARD"/linux/"$CHIP"_"$BOARD"_defconfig
Partial cv1801c_wevb_0009a_spinor
CONFIG_SYSVIPC=y
CONFIG_POSIX_MQUEUE=y
CONFIG_NO_HZ_IDLE=y
CONFIG_HIGH_RES_TIMERS=y
CONFIG_PREEMPT=y
CONFIG_IKCONFIG=y
CONFIG_IKCONFIG_PROC=y
CONFIG_LOG_BUF_SHIFT=15
CONFIG_BLK_DEV_INITRD=y
Modify Kernel Config with graphical interface
$ menuconfig_kernel
After exiting, the settings will be store in:
./linux/build/"$CHIP"_"$BOARD"/.config
$ build_kernel
When completed, boot.spinor will be generated
Compile Kernel fragments in Makefile.
kernel-build: ${KERNEL_OUTPUT_CONFIG_PATH}
${Q}echo LOCALVERSION=${LOCALVERSION}
${Q}$(MAKE) -j${NPROC} -C ${KERNEL_PATH} O=${KERNEL_PATH}/${KERNEL_OUTPUT_FOLDER} olddefconfig
${Q}$(MAKE) -j${NPROC} -C ${KERNEL_PATH}/${KERNEL_OUTPUT_FOLDER} Image modules
${Q}$(MAKE) -j${NPROC} -C ${KERNEL_PATH}/${KERNEL_OUTPUT_FOLDER} modules_install headers_install INSTALL_HDR_PATH=${KERNEL_PATH}/${KERNEL_OUTPUT_FOLDER}/$(ARCH)/usr
${Q} ln -sf ${KERNEL_PATH}/${KERNEL_OUTPUT_FOLDER}/$(ARCH)/usr/include ${KERNEL_PATH}/${KERNEL_OUTPUT_FOLDER}/usr/include
2.5.4.3. Compile middleware separately¶
Modify middleware (cvi_test / sample_dsi), recompile middleware and system
The generated Install/PROJECT_NAME/system.* contains the latest middleware
$ build_middleware; pack_rootfs
pushd "$MW_PATH"/component/isp
make all
popd
pushd "$MW_PATH"/sample
make all
build_middleware will recompile the Sensor driver (in middleware/component/isp/) and sample application (in middleware/sample/), and finally pack_rootfs will package the changed driver and application into a burnable image.
2.6. Partitions¶
CV181X SDK will generate the following image files, each representing a different partition, listed below:
FIP : Bootloader/U-Boot partition
CV180X/ CV181X C906 adopts FSBL+OPENSBI+UBOOT architecture, and also reuses (FIP) file name after the final package, which is convenient for subsequent use.
BOOT : Partition for Linux Kernel
2nd(dual-system) : The partition where Yun on Processor (YOC) is located.
MISC : Boot Logo partition
ROOTFS : root file system partition
SYSTEM: Partition where CVITEK libraries are located
DATA : Using data partition
Note: The 2nd partition is a dual-system-specific partition and exists only in a dual-system environment.
2.6.1. Partition File Modification¶
The same EVB may have different Flash, and the SDK will separate them with different board numbers. For example cv1811c_wdmb_0006a_spinand and cv1811c_wdmb_0006a_spinor represent the Flash on the development board as SPINAND and SPINOR respectively, and the partition files are placed in
./build/boards/<CHIP>/<EVB_Name>/partition/partition_<physical_partition>.xml
Note:physical_partition supports SPINAND/SPINOR。
For example, the partition files of cv1801c_wdmb_0009a_spinor are displayed as follows:
In a single-system environment:
build/boards/cv181x/cv1811c_wdmb_0006a_spinor/partition/partition_spinor.xml
<physical_partition type="spinor">
<partition label="fip" size_in_kb="800" readonly="false" file="fip.bin"/>
<partition label="BOOT" size_in_kb="2600" readonly="false" file="boot.spinor"/>
<partition label="ENV" size_in_kb="64" file="" />
<partition label="ROOTFS" size_in_kb="4000" readonly="false" file="rootfs.spinor" />
<partition label="DATA" size_in_kb="512" readonly="false" file="data.spinor" mountpoint="/mnt/data" type="jffs2" />
</physical_partition>
In a dual-system environment:
<partition label="fip" size_in_kb="512" readonly="false" file="fip.bin"/>
<partition label="2nd" size_in_kb="3072" readonly="false" file="yoc.bin"/>
<partition label="BOOT" size_in_kb="5120" readonly="false" file="boot.spinor"/>
<partition label="MISC" size_in_kb="128" readonly="false" file="logo.jpg"/>
<partition label="PARAM" size_in_kb="64" file="" />
<partition label="PARAM_BAK" size_in_kb="64" file="" />
<partition label="ENV_BAK" size_in_kb="64" file="" />
<partition label="ROOTFS" size_in_kb="3392" readonly="false" file="rootfs.spinor" />
<partition label="DATA" size_in_kb="1024" readonly="false" file="data.spinor" mountpoint="/mnt/data" type="jffs2" />
physical_partiti type: flash type.
partition label: partition name.
size_in_kb: partition size (in KB).
file: name of the image file pointed to.
type: (in the partition tab field) file system format.
mountpoint: partition mount path.
