3.4. Data Types¶
3.4.1. Base Type¶
* The common data type
typedef unsigned char CVI_UCHAR;
typedef unsigned char CVI_U8;
typedef unsigned short CVI_U16;
typedef unsigned int CVI_U32;
typedef unsigned int CVI_HANDLE;
typedef signed char CVI_S8;
typedef signed char CVI_CHAR;
typedef short CVI_S16;
typedef int CVI_S32;
typedef unsigned long CVI_UL;
typedef signed long CVI_SL;
typedef float CVI_FLOAT;
typedef double CVI_DOUBLE;
typedef void CVI_VOID;
typedef bool CVI_BOOL;
typedef uint64_t CVI_U64;
typedef int64_t CVI_S64;
typedef size_t CVI_SIZE_T;
* const defination
#define CVI_NULL 0L
#define CVI_SUCCESS 0
#define CVI_FAILURE (-1)
#define CVI_TRUE 1
#define CVI_FALSE 0
3.4.2. MOD_ID_E¶
Defining module ID enumeration.
#define FOREACH_MOD(MOD) {\
MOD(CMPI) \
MOD(VB) \
MOD(SYS) \
MOD(RGN) \
MOD(CHNL) \
MOD(VDEC) \
MOD(VPSS) \
MOD(VENC) \
MOD(H264E) \
MOD(JPEGE) \
MOD(MPEG4E) \
MOD(H265E) \
MOD(JPEGD) \
MOD(VO) \
MOD(VI) \
MOD(DIS) \
MOD(RC) \
MOD(AIO) \
MOD(AI) \
MOD(AO) \
MOD(AENC) \
MOD(ADEC) \
MOD(AUD) \
MOD(VPU) \
MOD(ISP) \
MOD(IVE) \
MOD(USER) \
MOD(PROC) \
MOD(LOG) \
MOD(H264D) \
MOD(GDC) \
MOD(PHOTO) \
MOD(FB) \
MOD(BUTT) \
#define GENERATE_ENUM(ENUM) CVI_ID_ ## ENUM,
typedef enum _MOD_ID_E FOREACH_MOD(GENERATE_ENUM) MOD_ID_E;
None.
None.
3.4.3. VB_SOURCE_E¶
Define VB source selection.
typedef enum _VB_SOURCE_E {
VB_SOURCE_COMMON = 0,
VB_SOURCE_MODULE = 1,
VB_SOURCE_PRIVATE = 2,
VB_SOURCE_USER = 3,
VB_SOURCE_BUTT
} VB_SOURCE_E;
【Member】
Member |
VB_SOURCE_COMMON |
public VB |
VB_SOURCE_MODULE |
module VB |
VB_SOURCE_PRIVATE |
private VB |
VB_SOURCE_USER |
user VB |
None.
None.
3.4.4. ROTATION_E¶
Defining rotation angle enumeration.
typedef enum _ROTATION_E {
ROTATION_0 = 0,
ROTATION_90,
ROTATION_180,
ROTATION_270,
ROTATION_XY_FLIP,
ROTATION_MAX
} ROTATION_E;
【Member】
Member |
ROTATION_0 |
No rotation. |
ROTATION_90 |
Rotate 90 degrees. |
ROTATION_180 |
Rotate 180 degrees, not supported. |
ROTATION_270 |
Rotate 270 degrees. |
ROTATION_XY_FLIP |
Rotate 90 degrees and then mirror in the x-direction. |
None.
None.
3.4.5. BORDER_S¶
Defining border structure.
typedef enum _BORDER_S {
CVI_U32 u32TopWidth;
CVI_U32 u32BottomWidth;
CVI_U32 u32LeftWidth;
CVI_U32 u32RightWidth;
CVI_U32 u32Color;
} BORDER_S;
【Member】
Member |
u32TopWidth |
The width of the top border. |
u32BottomWidth |
The width of the bottom border. |
u32LeftWidth |
The width of the left border. |
u32RightWidth |
The width of the right border. |
u32Color |
The color of the border. |
None.
None.
3.4.6. POINT_S¶
Define coordinate structure.
typedef struct _POINT_S {
CVI_S32 s32X;
CVI_S32 s32Y;
} POINT_S;
【Member】
Member |
s32X |
Abscissa |
s32Y |
Ordinate |
None.
None.
3.4.7. SIZE_S¶
Define size structure.
typedef struct _SIZE_S {
CVI_U32 u32Width;
CVI_U32 u32Height;
} SIZE_S;
【Member】
Member |
u32Width |
Width |
u32Height |
Height |
None.
VI_DEV_ATTR_S
VI_PIPE_STATUS_S
VI_CHN_ATTR_S
VI_CHN_STATUS_S
VO_VIDEO_LAYER_ATTR_S
3.4.8. RECT_S¶
Define the width, height, and position of the rectangle.
typedef struct _RECT_S {
CVI_S32 s32X;
CVI_S32 s32Y;
CVI_U32 u32Width;
CVI_U32 u32Height;
} RECT_S;
【Member】
Member |
s32X |
Abscissa |
s32Y |
Ordinate |
u32Width |
Width |
u32Height |
Height |
None.
VI_CROP_INFO_S
VPSS_CROP_INFO_S
VO_CHN_ATTR_S
3.4.9. LDC_ATTR_S¶
Define lens distortion correction structure.
typedef struct _LDC_ATTR_S {
bool bAspect; /* RW;Whether aspect ration is keep */
CVI_S32 s32XRatio; /* RW; Range: [0, 100], field angle ration of horizontal,valid when bAspect=0.*/
CVI_S32 s32YRatio; /* RW; Range: [0, 100], field angle ration of vertical,valid when bAspect=0.*/
CVI_S32 s32XYRatio; /* RW; Range: [0, 100], field angle ration of all,valid when bAspect=1.*/
CVI_S32 s32CenterXOffset;
CVI_S32 s32CenterYOffset;
CVI_S32 s32DistortionRatio;
} LDC_ATTR_S;
【Member】
Member |
bAspect |
Whether the distortion correction is horizontal and vertical in the same proportion. |
s32XRatio |
The size of horizontal field of view is valid when bAspect=0. [0, 100] |
s32YRatio |
The size of veritcal field of view is valid when bAspect=0. [0, 100] |
s32XYRatio |
The overall field of view is valid when bAspect = 1. [0, 100] |
s32CenterXOffset |
The horizontal offset of the distortion center from the image center. [-511, 511] |
s32CenterYOffset |
The vertical offset of the distortion center from the image center. [-511, 511] |
s32DistortionRatio |
The degree of distortion. [-300, 500] |
None.
None.
3.4.10. MMF_CHN_S¶
Define module channel structure.
typedef struct _MMF_CHN_S {
MOD_ID_E enModId;
CVI_S32 s32DevId;
CVI_S32 s32ChnId;
} MMF_CHN_S;
【Member】
Member |
enModId |
Module ID |
s32DevId |
Device ID In some modules, it may also be a group ID. |
s32ChnId |
Channel ID |
None.
CVI_SYS_Bind
CVI_SYS_UnBind
CVI_SYS_GetBindByDest
CVI_SYS_GetBindBySrc
3.4.11. MMF_BIND_DEST_S¶
Define MMF system binding target structure.
typedef struct _MMF_BIND_DEST_S {
CVI_U32 u32Num;
MMF_CHN_S astMmfChn[BIND_DEST_MAXNUM];
} MMF_BIND_DEST_S;
【Member】
Member |
u32Num |
Number of bound destinations. |
astMmfChn |
Channel structure array for binding purposes. |
None.
3.4.12. BIND_NODE_S¶
Define MMF system binding node structure.
typedef struct _BIND_NODE_S {
CVI_BOOL bUsed;
MMF_CHN_S src;
MMF_BIND_DEST_S dsts;
} BIND_NODE_S;
【Member】
Member |
bUsed |
is bind node used. |
src |
bind node src chn. |
dsts |
bind node dest chns. |
None.
CVI_SYS_Bind
CVI_SYS_UnBind
3.4.13. MMF_VERSION_S¶
Define MMF version structure.
#define VERSION_NAME_MAXLEN 128
typedef struct _MMF_VERSION_S {
char version[VERSION_NAME_MAXLEN];
} MMF_VERSION_S;
【Member】
Member |
version |
Version description string. |
None.
CVI_SYS_GetVersion
3.4.14. VB_CONFIG_S¶
Define MMF system video block pool structure.
typedef struct _VB_CONFIG_S {
CVI_U32 u32MaxPoolCnt;
VB_POOL_CONFIG_S astCommPool[VB_MAX_COMM_POOLS];
} VB_CONFIG_S;
【Member】
Member |
u32MaxPoolCnt |
Number of common video block pools. |
astCommPool |
Common video block pool properties. |
None.
CVI_VB_SetConfig
CVI_VB_GetConfig
3.4.15. VB_POOL_CONFIG_S¶
Define MMF video block pool structure.
typedef struct _VB_POOL_CONFIG_S {
CVI_U32 u32BlkSize;
CVI_U32 u32BlkCnt;
VB_REMAP_MODE_E enRemapMode;
CVI_CHAR acName[MAX_VB_POOL_NAME_LEN];
} VB_POOL_CONFIG_S;
【Member】
Member |
u32BlkSize |
Video block size |
u32BlkCnt |
The number of blocks in the video block pool |
enRemapMode |
Memory-map mode of block |
acName |
Block name |
u32BlkSize should be calculated according to the required image size, format and other information. If it is too large, it will cause unnecessary waste of memory space; if it is too small, each mod cannot get video blocks to use.
The video block pool is obtained from the free memory. If the size of the video block pool exceeds the free memory size, the video block pool fails to be created.
3.4.16. VB_USER_BLOCK_S¶
Define block structure in MMF external video block pool.
typedef struct _VB_USER_BLOCK_S {
CVI_U64 au64PhyAddr[3];
} VB_USER_BLOCK_S;
【Member】
Member |
au64PhyAddr |
Y/U/V base addr. |
None.
3.4.17. VB_POOL_CONFIG_EX_S¶
Define MMF external video block pool structure.
typedef struct _VB_POOL_CONFIG_EX_S {
CVI_U32 u32BlkCnt;
VB_USER_BLOCK_S astUserBlk[VB_POOL_MAX_BLK];
} VB_POOL_CONFIG_EX_S;
【Member】
Member |
u32BlkCnt |
The number of blk in the pool. |
astUserBlk |
block addr. |
The external video block pool is obtained through ion memory allocated by the user. After the block pool is destroyed, the user needs to release the memory.
3.4.18. VB_CAL_CONFIG_S¶
Define MMF video buffer structure.
typedef struct _VB_CAL_CONFIG_S {
CVI_U32 u32VBSize;
CVI_U32 u32MainStride;
CVI_U32 u32CStride;
CVI_U32 u32MainSize;
CVI_U32 u32MainYSize;
CVI_U32 u32MainCSize;
CVI_U16 u16AddrAlign;
CVI_U8 plane_num;
} VB_CAL_CONFIG_S;
【Member】
Member |
u32VBSize |
The size of VB needed. |
u32MainStride |
stride of planar0. |
u32CStride |
stride of planar1/2 if there is. |
u32MainSize |
size of all planars. |
u32MainYSize |
size of planar0. |
u32MainCSize |
size of planar1/2 if there is. |
u16AddrAlign |
address alignment needed between planar. |
plane_num |
The number of planars. |
None.
None.
3.4.19. VI_VPSS_MODE_E¶
Define the working mode between VI and VPSS.
typedef enum _VI_VPSS_MODE_E {
VI_OFFLINE_VPSS_OFFLINE = 0,
VI_OFFLINE_VPSS_ONLINE,
VI_ONLINE_VPSS_OFFLINE,
VI_ONLINE_VPSS_ONLINE,
VI_VPSS_MODE_BUTT
} VI_VPSS_MODE_E;
【Member】
Member |
VI_OFFLINE_VPSS_OFFLINE |
VI_PROC/VI_CAP offline, VI_CAP/VPSS offline |
VI_OFFLINE_VPSS_ONLINE |
VI_PROC/VI_CAP offline, VI_CAP/VPSS online |
VI_ONLINE_VPSS_OFFLINE |
VI_PROC/VI_CAP online, VI_CAP/VPSS offline |
VI_ONLINE_VPSS_ONLINE |
VI_PROC/VI_CAP online, VI_CAP/VPSS online |
When VPSS_ONLINE, VPSS can’t process by time sharing and can only bind specific VI PIPE.
None.
3.4.20. VI_VPSS_MODE_S¶
typedef struct _VI_VPSS_MODE_S {
VI_VPSS_MODE_E aenMode[VI_MAX_PIPE_NUM];
} VI_VPSS_MODE_S;
【Member】
Member |
aenMode |
vi vpss mode |
None.
3.4.21. VPSS_MODE_E¶
Define the working mode of VPSS enumeration.
typedef enum _VPSS_MODE_E {
VPSS_MODE_SINGLE = 0,
VPSS_MODE_DUAL,
VPSS_MODE_BUTT,
VPSS_MODE_RGNEX
} VPSS_MODE_E;
【Member】
Member |
VPSS_MODE_SINGLE |
VPSS works as a single hardware entity. |
VPSS_MODE_DUAL |
VPSS works in two hardware entities. |
VPSS_MODE_RGNEX |
VPSS works in two hardware entities. VPSS device 0 is used for RGN overlay, so only VPSS device 1 can operate in online mode. |
CV181x/CV180x does not support VPSS MODE RGNEX mode
None.
3.4.22. VPSS_INPUT_E¶
Define the input source enumeration of VPSS.
VPSS_INPUT_MEM = 0,
VPSS_INPUT_ISP,
VPSS_INPUT_BUTT
} VPSS_MODE_E;
【Member】
Member |
VPSS_INPUT_MEM |
VPSS input is DDR. |
VPSS_INPUT_ISP |
VPSS works online, and input is ISP. |
None.
None.
3.4.23. VPSS_MODE_S¶
Define the work mode structure of VPSS.
typedef struct _VPSS_MODE_S {
VPSS_MODE_E enMode;
VPSS_INPUT_E aenInput[VPSS_IP_NUM];
VI_PIPE ViPipe[VPSS_IP_NUM];
} VPSS_MODE_S;
【Member】
Member |
enMode |
VPSS work mode. |
aenInput |
VPSS input. |
ViPipe |
VI PIPE online with VPSS. |
None.
None.
3.4.24. ASPECT_RATIO_E¶
Define rotation angle enumeration.
typedef enum _ASPECT_RATIO_E {
ASPECT_RATIO_NONE = 0,
ASPECT_RATIO_AUTO,
ASPECT_RATIO_MANUAL,
ASPECT_RATIO_MAX
} ASPECT_RATIO_E;
【Member】
Member |
ASPECT_RATIO_NONE |
No motion, full screen. |
ASPECT_RATIO_AUTO |
Keeping video aspect ratio and automatically calculating video area. |
ASPECT_RATIO_MANUAL |
Manually determine the video area. |
None.
None.
3.4.25. ASPECT_RATIO_S¶
Define screen ratio structure.
typedef struct _ASPECT_RATIO_S {
ASPECT_RATIO_E enMode;
CVI_BOOL bEnableBgColor;
CVI_U32 u32BgColor;
RECT_S stVideoRect;
} ASPECT_RATIO_S;
【Member】
Member |
enMode |
The ratio of pictures is listed. |
bEnableBgColor |
Whether to cover the outside of the picture with a background color. |
u32BgColor |
The background color of the screen scale is RGB888. Bit [7:0] is B, bit [15:8] is G, and bit [23:16] is R. |
stVideoRect |
The area of the video. It works only when the enMode is ASPECT_RATIO_MANUAL. |
None.
3.4.26. PIXEL_FORMAT_E¶
Define pixel format enumeration.
typedef enum _PIXEL_FORMAT_E {
PIXEL_FORMAT_RGB_888 = 0,
PIXEL_FORMAT_BGR_888,
PIXEL_FORMAT_RGB_888_PLANAR,
PIXEL_FORMAT_BGR_888_PLANAR,
PIXEL_FORMAT_ARGB_1555, // 4,
PIXEL_FORMAT_ARGB_4444,
PIXEL_FORMAT_ARGB_8888,
PIXEL_FORMAT_RGB_BAYER_8BPP, // 7,
PIXEL_FORMAT_RGB_BAYER_10BPP,
PIXEL_FORMAT_RGB_BAYER_12BPP,
PIXEL_FORMAT_RGB_BAYER_14BPP,
PIXEL_FORMAT_RGB_BAYER_16BPP,
PIXEL_FORMAT_YUV_PLANAR_422, // 12,
PIXEL_FORMAT_YUV_PLANAR_420,
PIXEL_FORMAT_YUV_PLANAR_444,
PIXEL_FORMAT_YUV_400,
PIXEL_FORMAT_HSV_888, // 16,
PIXEL_FORMAT_HSV_888_PLANAR,
PIXEL_FORMAT_NV12, // 18,
PIXEL_FORMAT_NV21,
PIXEL_FORMAT_NV16,
PIXEL_FORMAT_NV61,
PIXEL_FORMAT_YUYV,
PIXEL_FORMAT_UYVY,
PIXEL_FORMAT_YVYU,
PIXEL_FORMAT_VYUY,
PIXEL_FORMAT_FP32_C1 = 32, // 32
PIXEL_FORMAT_FP32_C3_PLANAR,
PIXEL_FORMAT_INT32_C1,
PIXEL_FORMAT_INT32_C3_PLANAR,
PIXEL_FORMAT_UINT32_C1,
PIXEL_FORMAT_UINT32_C3_PLANAR,
PIXEL_FORMAT_BF16_C1,
PIXEL_FORMAT_BF16_C3_PLANAR,
PIXEL_FORMAT_INT16_C1,
PIXEL_FORMAT_INT16_C3_PLANAR,
PIXEL_FORMAT_UINT16_C1,
PIXEL_FORMAT_UINT16_C3_PLANAR,
PIXEL_FORMAT_INT8_C1,
PIXEL_FORMAT_INT8_C3_PLANAR,
PIXEL_FORMAT_UINT8_C1,
PIXEL_FORMAT_UINT8_C3_PLANAR,
PIXEL_FORMAT_MAX
} PIXEL_FORMAT_E;
【Member】
None.
None.
None.
3.4.27. VIDEO_FRAME_S¶
Define video frame information structure.
typedef struct _VIDEO_FRAME_S {
CVI_U32 u32Width;
CVI_U32 u32Height;
PIXEL_FORMAT_E enPixelFormat;
BAYER_FORMAT_E enBayerFormat;
VIDEO_FORMAT_E enVideoFormat;
COMPRESS_MODE_E enCompressMode;
DYNAMIC_RANGE_E enDynamicRange;
COLOR_GAMUT_E enColorGamut;
CVI_U32 u32Stride[3];
CVI_U64 u64PhyAddr[3];
CVI_U8 *pu8VirAddr[3];
CVI_U32 u32Length[3];
CVI_S16 s16OffsetTop;
CVI_S16 s16OffsetBottom;
CVI_S16 s16OffsetLeft;
CVI_S16 s16OffsetRight;
CVI_U32 u32TimeRef;
CVI_U64 u64PTS;
void *pPrivateData;
CVI_U32 u32FrameFlag;
} VIDEO_FRAME_S;
【Member】
Member |
u32Width |
image width |
u32Height |
image height |
enPixelFormat |
image pixel format |
enBayerFormat |
image raw format |
enVideoFormat |
image format |
enCompressMode |
image compression format |
enDynamicRange |
dynamic range |
enColorGamut |
gamut range |
u32Stride |
Image row stride. |
u64PhyAddr |
physical address |
pu8VirAddr |
virtual address |
u32Length |
image space size (Bytes) |
s16OffsetTop |
image top crop width |
s16OffsetBottom |
image bottom crop width |
s16OffsetLeft |
image left crop width |
s16OffsetRight |
image right crop width |
u32TimeRef |
Image frame sequence number |
u64PTS |
Image timestamp |
pPrivateData |
private data |
u32FrameFlag |
the mark of the current frame |
None.
None.
3.4.28. VIDEO_FRAME_INFO_S¶
typedef struct _VIDEO_FRAME_INFO_S {
VIDEO_FRAME_S stVFrame; ///< Video frame
CVI_U32 u32PoolId; ///< VB pool ID
} VIDEO_FRAME_INFO_S;
【Member】
Member |
stVFrame |
Video frame |
u32PoolId |
Cache pool ID |
None.
3.4.29. BITMAP_S¶
Define BITMAP information.
typedef struct _BITMAP_S {
CVI_U32 u32Width;
CVI_U32 u32Height;
CVI_VOID * ATTRIBUTE pData;
} BITMAP_S;
【Member】
Member |
enPixelFormat |
Bitmap pixel format |
u32Width |
Bitmap width |
u32Height |
Bitmap height |
pData |
Bitmap data address |
None.
None.
3.4.30. CVI_TDMA_2D_S¶
Define 2-dimension TDMA structure.
typedef struct _CVI_TDMA_2D_S {
uint64_t paddr_src;
uint64_t paddr_dst;
uint32_t w_bytes;
uint32_t h;
uint32_t stride_bytes_src;
uint32_t stride_bytes_dst;
} CVI_TDMA_2D_S;
【Member】
Member |
paddr_src |
physical address of src mem |
paddr_dst |
physical address of dst mem |
w_bytes |
width of mem |
h |
height of mem |
stride_bytes_src |
row span of src mem |
stride_bytes_dst |
row span of dst mem |
None.
None.
3.4.31. WDR_MODE_E¶
Defined different wide dynamic range mode enumerations.
typedef enum _WDR_MODE_E {
WDR_MODE_NONE= 0;
WDR_MODE_NONE = 0,
WDR_MODE_BUILT_IN,
WDR_MODE_QUDRA,
WDR_MODE_2To1_LINE,
WDR_MODE_2To1_FRAME,
WDR_MODE_2To1_FRAME_FULL_RATE,
WDR_MODE_3To1_LINE,
WDR_MODE_3To1_FRAME,
WDR_MODE_3To1_FRAME_FULL_RATE,
WDR_MODE_4To1_LINE,
WDR_MODE_4To1_FRAME,
WDR_MODE_4To1_FRAME_FULL_RATE,
WDR_MODE_MAX,
} WDR_MODE_E;
【Member】
Member |
WDR_MODE_NONE |
No WDR mode |
WDR_MODE_BUILT_IN |
Built in WDR mode |
WDR_MODE_QUDRA |
Four channel WDR mode |
WDR_MODE_2To1_LINE |
2-to-1 line mode WDR |
WDR_MODE_2To1_FRAME |
2-to-1 frame mode WDR |
WDR_MODE_2To1_FRAME_FULL_RATE |
2-to-1 full frame rate mode WDR |
WDR_MODE_3To1_LINE |
3-to-1 line mode WDR |
WDR_MODE_3To1_FRAME |
3-to-1 frame mode WDR |
WDR_MODE_3To1_FRAME_FULL_RATE |
3-to-1 full frame rate mode WDR |
WDR_MODE_4To1_LINE |
4-to-1 line mode WDR |
WDR_MODE_4To1_FRAME |
4-to-1 frame mode WDR |
WDR_MODE_4To1_FRAME_FULL_RATE |
4-to-1 full frame rate mode WDR |
WDR_MODE_MAX |
The maximum value of enumeration |
None.
None.
