7.4. Data Types¶
Relevant data types and data structures are defined as follows:
VENC_MAX_CHN_NUM: Define the maximum number of channels.
VENC_MAX_ROI_NUM : Define the maximum number of Roi regions.
MAX_TILE_NUM : Define the maximum number of tile.
VENC_ALIGN_W : Define the width alignment of VENC.
VENC_ALIGN_H : Define the height alignment of VENC.
RC_TEXTURE_THR_SIZE : Define the number of texture threshold.
VENC_CHN_PARAM_S: Define the Venc channel parameter structure.
VENC_PACK_S: Define frame stream packet structure .
VENC_STREAM_S: Define the frame stream type structure.
VENC_ATTR_S: Define the encoder attribute structure.
VENC_GOP_ATTR_S: Define the structure of GOP mode type.
VENC_GOP_NORMALP_S: Define the normalP structure
VENC_GOP_SMARTP_S: Define the SmartP structure
VENC_CHN_ATTR_S: Define the encoding channel attribute structure.
VENC_RECV_PIC_PARAM_S: Define the frame number structure that the coding channel continuously receives and encodes.
VENC_CHN_STATUS_S: Define the state structure of the encoding channel.
VENC_JPEG_PARAM_S: Define a set of JPEG encoding parameters.
VENC_RC_ATTR_S: Define the rate controller attribute of the coding channel.
VENC_H264_CBR_S: Define the CBR attribute structure of H.264 coding channel.
VENC_H264_VBR_S: Define the VBR attribute structure of H.264 coding channel.
VENC_H264_QVBR_S: Define the QVBR attribute structure of H.264 coding channel.
VENC_H264_FIXQP_S: Define the Fixqp attribute structure of H.264 coding channel.
VENC_H264_QPMAP_S: Define the QPMAP attribute structure of H.264 coding channel.
VENC_MJPEG_FIXQP_S: Define the Fixqp attribute structure of MJPEG encoding channel.
VENC_MJPEG_CBR_S: Define the CBR attribute structure of MJPEG encoding channel.
VENC_MJPEG_VBR_S: Define the VBR attribute structure of MJPEG encoding channel.
VENC_H265_CBR_S: Define the CBR attribute structure of H.265 coding channel.
VENC_H265_VBR_S: Define the VBR attribute structure of H.265 coding channel.
VENC_H265_AVBR_S: Define the AVBR attribute structure of H.265 coding channel.
VENC_H265_QVBR_S: Define the QVBR attribute structure of H.265 coding channel.
VENC_H265_FIXQP_S: Define the Fixqp attribute structure of H.265 coding channel.
VENC_H265_QPMAP_S: Define the QPMAP attribute structure of H.265 coding channel.
VENC_RC_PARAM_S: Define the advanced rate control parameters of the coding channel.
VENC_CHN_POOL_S: Define the VB pool structure which is bound by encoding channel
VENC_H264_ENTROPY_S: Define H.264 entropy coding information structure
VENC_CU_PREDICTION_S: Define CU prediction information structure
7.4.1. VENC_MAX_CHN_NUM¶
Define the maximum number of channels for encoding
#define VENC_MAX_CHN_NUM 16
【Member】
Because the maximum number of channels is related to memory allocation, it is not open for expansion at present.
None.
7.4.2. VENC_MAX_ROI_NUM¶
#define VENC_MAX_ROI_NUM 8
【Member】
None.
None.
None.
7.4.3. MAX_TILE_NUM¶
#define MAX_TILE_NUM 1
【Member】
None.
None.
None.
7.4.4. VENC_ALIGN_W¶
#define VENC_ALIGN_W 32
【Member】
None.
None.
None.
7.4.5. VENC_ALIGN_H¶
#define VENC_ALIGN_H 16
【Member】
None.
None.
None.
7.4.6. RC_TEXTURE_THR_SIZE¶
#define RC_TEXTURE_THR_SIZE 1
【Member】
None.
None.
None.
7.4.7. VENC_CHN_PARAM_S¶
typedef struct _VENC_CHN_PARAM_S {
CVI_BOOL bColor2Grey;
CVI_U32 u32Priority
CVI_U32 u32MaxStrmCnt;
CVI_U32 u32PollWakeUpFrmCnt;
VENC_CROP_INFO_S stCropCfg;
VENC_FRAME_RATE_S stFrameRate;
} VENC_CHN_PARAM_S;
【Member】
Member |
bColor2Grey |
Reserved, not used yet |
u32Priority |
u32MaxStrmCnt |
u32PollWakeUpFrmCnt |
stCropCfg |
Channel intercept (Crop) parameter |
stFrameRate |
Channel frame rate control parameters |
None.
CVI_VENC_SetChnParam
7.4.8. VENC_PACK_S¶
Define the frame stream packet structure.
typedef struct _VENC_PACK_S {
CVI_U64 u64PhyAddr;
CVI_U8 ATTRIBUTE *pu8Addr;
CVI_U32 ATTRIBUTE u32Len;
CVI_U64 u64PTS;
CVI_BOOL bFrameEnd;
VENC_DATA_TYPE_U DataType;
CVI_U32 u32Offset;
CVI_U32 u32DataNum;
VENC_PACK_INFO_S stPackInfo[8];
} VENC_PACK_S;
【Member】
Member |
u64PhyAddr |
The first physical address of the bitstream. |
pu8Addr |
The first virtual address of the bitstream. |
u32Len |
The length of the stream packet. |
DataType |
Stream type, support H.264/JPEG/H.265 protocol type packet. |
bFrameEnd |
End of frame identifier. CVI_TRUE: the stream packet is the last packet of the frame. CVI_FALSE: the stream packet is not the last packet of the frame. |
u32Offset |
The offset between the valid data in the stream packet and the first address pu8Addr of the stream packet. |
u64PTS |
Time stamp. Unit: us. |
u32DataNum |
The number of other types of code stream packets in the current code stream packet (the type of current packet is specified by DataType). |
stPackInfo[8] |
The current stream packet contains other types of stream packet information. |
None.
7.4.9. VENC_STREAM_S¶
typedef struct _VENC_STREAM_S {
VENC_PACK_S ATTRIBUTE *pstPack;
CVI_U32 ATTRIBUTE u32PackCount;
CVI_U32 u32Seq;
union {
VENC_STREAM_INFO_H264_S stH264Info;
VENC_STREAM_INFO_JPEG_S stJpegInfo;
VENC_STREAM_INFO_H265_S stH265Info;
VENC_STREAM_INFO_PRORES_S stProresInfo;
union {
VENC_STREAM_ADVANCE_INFO_H264_S stAdvanceH264Info;
VENC_STREAM_ADVANCE_INFO_JPEG_S stAdvanceJpegInfo;
VENC_STREAM_ADVANCE_INFO_H265_S stAdvanceH265Info;
VENC_STREAM_ADVANCE_INFO_PRORES_S stAdvanceProresInfo;
} VENC_STREAM_S;
【Member】
Member |
pstPack |
Frame stream packet structure. |
u32PackCount |
The number of all packets in a frame stream. |
u32Seq |
Code stream sequence number. |
stH264Info/stJpegInfo/stH265Info/stProresInfo |
Stream information. |
stAdvanceH264Info/stAdvanceJpegInfo/stAdvanceH265Info/stAdvanceProresInfo |
Bit stream advanced information. |
None.
7.4.10. VENC_GOP_ATTR_S¶
Define the encoder GOP attribute structure.
typedef struct _VENC_GOP_ATTR_S {
VENC_GOP_MODE_E enGopMode;
union {
VENC_GOP_NORMALP_S stNormalP;
VENC_GOP_DUALP_S stDualP;
VENC_GOP_SMARTP_S stSmartP;
VENC_GOP_ADVSMARTP_S stAdvSmartP;
VENC_GOP_BIPREDB_S stBipredB;
} VENC_GOP_ATTR_S;
【Member】
Member |
enGopMode |
Encoding GOP type. |
stNormalP |
Encoding single reference frame P frame GOP attribute structure. |
stDualP |
stSmartP |
Encoding intelligent P-frame GOP attribute structure |
stAdvSmartP |
stBipredB |
None.
CVI_VENC_CreateChn
7.4.11. VENC_GOP_NORMALP_S¶
Define the encoder NormalP GOP attribute structure
typedef struct _VENC_GOP_NORMALP_S {
CVI_S32 s32IPQpDelta;
} VENC_GOP_NORMALP_S;
【Member】
Member |
s32IPQpDelta |
QP difference between I frame and P frame |
None.
CVI_VENC_CreateChn
7.4.12. VENC_GOP_SMARTP_S¶
Define the encoder SmartP GOP attribute structure
typedef struct _VENC_GOP_SMARTP_S {
CVI_U32 u32BgInterval;
CVI_S32 s32BgQpDelta;
CVI_S32 s32ViQpDelta;
} VENC_GOP_SMARTP_S;
【Member】
Member |
u32BgInterval |
IDR frame interval |
s32BgQpDelta |
QP difference between IDR frame and P frame |
s32ViQpDelta |
QP difference between Vi frame and P frame |
None.
CVI_VENC_CreateChn
7.4.13. VENC_RECV_PIC_PARAM_S¶
Defines the frame number structure that the coding channel continuously receives and encodes.
typedef struct _VENC_RECV_PIC_PARAM_S {
CVI_S32 s32RecvPicNum;
} VENC_RECV_PIC_PARAM_S;
【Member】
Member |
s32RecvPicNum |
The number of frames continuously received and encoded by the encoding channel. Range: [- 1,0) ∪ (0 ∞] |
None.
CVI_VENC_StartRecvFrame
7.4.14. VENC_CHN_ATTR_S¶
Define VENC_CHN_ATTR_S attribute.
typedef struct _VENC_CHN_ATTR_S {
VENC_ATTR_S stVencAttr;
VENC_RC_ATTR_S stRcAttr;
VENC_GOP_ATTR_S stGopAttr;
} VENC_CHN_ATTR_S;
【Member】
Member |
stVencAttr |
Venc attribute |
stRcAtt |
Rate controller properties. |
stGopAttr |
GOP Mode type structure. Please refer to the above typedef struct _VENC_GOP_ATTR_S |
None.
CVI_VENC_CreateChn
7.4.15. VENC_ATTR_S¶
Define VENC_ATTR_S attribute.
typedef struct _VENC_ATTR_S {
PAYLOAD_TYPE_E enType;
CVI_U32 u32MaxPicWidth;
CVI_U32 u32MaxPicHeight;
CVI_U32 u32BufSize;
CVI_U32 u32Profile;
CVI_BOOL bByFrame;
CVI_U32 u32PicWidth;
CVI_U32 u32PicHeight;
CVI_BOOL bSingleCore;
CVI_BOOL bEsBufQueueEn;
CVI_BOOL bIsoSendFrmEn;
union {
VENC_ATTR_H264_S stAttrH264e;
VENC_ATTR_H265_S stAttrH265e;
VENC_ATTR_JPEG_S stAttrJpege;
VENC_ATTR_PRORES_S stAttrProres;
} VENC_ATTR_S;
【Member】
Member |
enType |
payload type. |
u32MaxPicWidth |
Maximum encoded image width |
u32MaxPicHeight |
Maximum encoded image height |
u32BufSize |
Encoded bitstream buffer size |
u32Profile |
Coding level |
bByFrame |
Encoded bitstream collection method CVI_TRUE: mainly in frame CVI_FALSE: Mainly in packets |
u32PicWidth |
Encoded image width |
u32PicHeight |
Encoded image height |
bSingleCore |
Only H264 or H265 is used |
bEsBufQueueEn |
Use an es buffer queue |
bIsoSendFrmEn |
Removes the restriction that SendFrame/GetStream must be paired |
stAttrH264e / stAttrH265e /stAttrJpege / stAttrProres |
Encoder attribute |
Open bIsoSendFrmEn at the same time as bEsBufQueueEn, otherwise there will be a burst screen
The bIsoSendFrmEn function must be disabled in dual-system, the dual-system removes the restriction that SendFrame/GetStream must be paired by default
7.4.16. VENC_ATTR_H264_S¶
Define H264 encoding attribute.
typedef struct _VENC_ATTR_H264_S {
CVI_BOOL bRcnRefShareBuf;
CVI_BOOL bSingleLumaBuf;
} VENC_ATTR_H264_S;
【Member】
Member |
bRcnRefShareBuf |
Reserved |
bSingleLumaBuf |
None.
7.4.17. VENC_ATTR_H265_S¶
Define H265 encoding attribute.
typedef struct _VENC_ATTR_H265_S {
} VENC_ATTR_H265_S;
【Member】
Member |
bRcnRefShareBuf |
Reserved |
None.
7.4.18. VENC_STREAM_INFO_S¶
Define VENC_STREAM_INFO_S attribute.
typedef struct _ VENC_STREAM_INFO_S {
H265E_REF_TYPE_E enRefType;
CVI_U32 u32PicBytesNum;
CVI_U32 u32PicCnt;
CVI_U32 u32StartQp;
CVI_U32 u32MeanQp;
CVI_BOOL bPSkip;
CVI_U32 u32ResidualBitNum;
CVI_U32 u32HeadBitNum;
CVI_U32 u32MadiVal;
CVI_U32 u32MadpVal;
CVI_U32 u32MseSum;
CVI_U32 u32MseLcuCnt;
double dPSNRVal;
} VENC_STREAM_INFO_S;
【Member】
Member |
u32MeanQp |
The average QP of the current Frame |
None.
CVI_VENC_QueryStatus
7.4.19. VENC_CHN_STATUS_S¶
Define VENC_CHN_STATUS_S attribute.
typedef struct _VENC_CHN_STATUS_S {
CVI_U32 u32LeftPics;
CVI_U32 u32LeftStreamBytes;
CVI_U32 u32LeftStreamFrames;
CVI_U32 u32CurPacks;
CVI_U32 u32LeftRecvPics;
CVI_U32 u32LeftEncPics;
CVI_BOOL bJpegSnapEnd;
VENC_STREAM_INFO_S stVencStrmInfo;
} VENC_CHN_STATUS_S;
【Member】
Member |
u32LeftPics |
Reserved |
u32LeftStreamBytes |
Reserved |
u32LeftStreamFrames |
Number of remaining frames to be received |
u32CurPacks |
The number of packets currently in the Frame |
u32LeftRecvPics |
Reserved |
u32LeftEncPics |
Reserved |
bJpegSnapEnd |
Reserved |
stVencStrmInfo |
Reserved |
None.
7.4.20. VENC_JPEG_PARAM_S¶
Define advanced parameters for JPEG encoding protocol.
typedef struct _VENC_JPEG_PARAM_S {
CVI_U32 u32Qfactor;
CVI_U8 u8YQt[64];
CVI_U8 u8CbQt[64];
CVI_U8 u8CrQt[64];
CVI_U32 U32MCUPerECS;
} VENC_JPEG_PARAM_S;
【Member】
Member |
u32Qfactor |
For details, see RFC2435. The default value is 0. |
u8YQt |
Y quantization table. (not implemented) |
u8CbQt |
Cb quantization table. (not implemented) |
u8CrQt |
Cr quantization table. (not implemented) |
u32MCUPerECS |
How many MCU are contained in each ECS? The default value is 0, indicating that Ecs are not divided. (not implemented) |
None.
CVI_VENC_SetJpegParam
CVI_VENC_GetJpegParam
7.4.21. VENC_RC_ATTR_S¶
Defines the rate controller attribute of the coding channel.
typedef struct _VENC_RC_ATTR_S {
VENC_RC_MODE_E enRcMode;
union {
VENC_H264_CBR_S stH264Cbr;
VENC_H264_VBR_S stH264Vbr;
VENC_H264_AVBR_S stH264AVbr;
VENC_H264_QVBR_S stH264QVbr;
VENC_H264_FIXQP_S stH264FixQp;
VENC_H264_QPMAP_S stH264QpMap;
VENC_MJPEG_CBR_S stMjpegCbr;
VENC_MJPEG_VBR_S stMjpegVbr;
VENC_MJPEG_FIXQP_S stMjpegFixQp;
VENC_H265_CBR_S stH265Cbr;
VENC_H265_VBR_S stH265Vbr;
VENC_H265_AVBR_S stH265AVbr;
VENC_H265_QVBR_S stH265QVbr;
VENC_H265_FIXQP_S stH265FixQp;
VENC_H265_QPMAP_S stH265QpMap;
} VENC_RC_ATTR_S;
【Member】
Member |
enRcMode |
RC mode. |
stH264Cbr |
H.264 protocol coding channel Cbr mode attribute. |
stH264Vbr |
H.264 protocol coding channel Vbr mode attribute. |
stH264AVbr |
H.264 protocol coding channel AVbr mode attribute. |
stH264QVbr |
H.264 protocol coding channel QVbr mode attribute. |
stH264CVbr |
H.264 protocol coding channel CVbr mode attribute. |
stH264FixQp |
H.264 protocol coding channel Fixqp mode attribute. |
stH264QpMap |
H.264 protocol coding channel QPMAP mode attribute. |
stMjpegeFixQp |
Mjpeg protocol coding channel Fixqp mode attribute. |
stMjpegeCbr |
Mjpeg protocol coding channel cbr mode attribute. |
stMjpegeVbr |
Mjpeg protocol coding channel vbr mode attribute. |
stH265Cbr |
H.265 protocol coding channel Cbr mode attribute. |
stH265Vbr |
H.265 protocol coding channel Vbr mode attribute. |
stH265AVbr |
H.265 protocol coding channel AVbr mode attribute. |
stH265QVbr |
H.265 protocol coding channel QVbr mode attribute. |
stH265CVbr |
H.265 protocol coding channel CVbr mode attribute. |
stH265FixQp |
H.265 protocol coding channel Fixqp mode attribute. |
stH265QpMap |
H.265 protocol coding channel QPMAP mode attribute. |
None.
CVI_VENC_CreateChn
7.4.22. VENC_H264_CBR_S¶
Structure definition for H.264 video encoding channel’s CBR properties.
typedef struct _VENC_H264_CBR_S {
CVI_U32 u32Gop;
CVI_U32 u32StatTime;
CVI_U32 u32SrcFrameRate
CVI_FR32 fr32DstFrameRate;
CVI_U32 u32BitRate;
CVI_BOOL bVariFpsEn;
} VENC_H264_CBR_S;
【Member】
Member |
u32Gop |
H.264 gop value. Range: [1, 65536]。 |
u32StatTime |
CBR rate statistics time, in seconds. Range: [1, 60]. |
u32SrcFrameRate |
Input frame rate in fps. |
fr32DstFrameRate |
Encoder output frame rate, in fps. |
u32BitRate |
Average bitrate in kbps. |
bVariFpsEn |
Enable Variable FPS. After this function is enabled, the Frame rate conversion function is enabled and disabled. |
None.
CVI_VENC_CreateChn
7.4.23. VENC_H264_VBR_S¶
Structure definition for H.264 video encoding channel’s VBR properties.
typedef struct _VENC_H264_VBR_S {
CVI_U32 u32Gop;
CVI_U32 u32SrcFrameRate;
CVI_U32 u32MaxBitRate;
} VENC_H264_VBR_S;
【Member】
Member |
u32Gop |
H.264 gop value Range: [1, 65536]。 |
u32StatTime |
VBR rate statistics time, in seconds.. Range: [1, 60]. |
u32SrcFrameRate |
Input frame rate in fps, |
fr32DstFrameRate |
u32MaxBitRate |
Maximum output bitrate of the encoder, in kbps. |
bVariFpsEn |
None.
CVI_VENC_CreateChn
7.4.24. VENC_H264_AVBR_S¶
Structure definition for H.264 video encoding channel’s AVBR properties.
typedef struct _VENC_H264_AVBR_S {
CVI_U32 u32Gop;
} VENC_H264_AVBR_S;
【Member】
Member |
u32Gop |
u32StatTime |
u32SrcFrameRate |
fr32DstFrameRate |
u32MaxBitRate |
bVariFpsEn |
None.
CVI_VENC_CreateChn
7.4.25. VENC_H264_FIXQP_S¶
Structure definition for H.264 video encoding channel’s FIXQP properties.
typedef struct _VENC_H264_FIXQP_S {
CVI_U32 u32Gop;
CVI_U32 u32IQp;
CVI_U32 u32PQp;
CVI_U32 u32BQp;
} VENC_H264_FIXQP_S;
【Member】
Member |
u32Gop |
u32IQp |
QP value of all macroblocks in I frame. |
u32SrcFrameRate |
fr32DstFrameRate |
u32PQp |
The QP value of all macroblocks in P frame. |
u32BQp |
QP values of all macroblocks in B frame. |
bVariFpsEn |
None.
CVI_VENC_CreateChn
7.4.26. VENC_H264_QPMAP_S¶
Structure definition for H.264 video encoding channel’s QPMAP properties.
typedef struct _VENC_H264_QPMAP_S {
CVI_U32 u32Gop;
} VENC_H264_QPMAP_S;
【Member】
Member |
u32Gop |
u32SrcFrameRate |
fr32DstFrameRate |
u32StatTime |
QPMAP rate statistics time, in seconds.. |
bVariFpsEn |
None.
CVI_VENC_CreateChn
7.4.27. VENC_MJPEG_FIXQP_S¶
Structure definition for MJPEG video encoding channel’s FIXQP properties.
typedef struct _VENC_MJPEG_FIXQP_S {
CVI_U32 u32Qfactor;
} VENC_MJPEG_FIXQP_S;
【Member】
Member |
u32SrcFrameRate |
fr32DstFrameRate |
bVariFpsEn |
u32Qfactor |
Qfactor of MJPEG encoding |
None.
CVI_VENC_CreateChn
7.4.28. VENC_MJPEG_CBR_S¶
Structure definition for MJPEG video encoding channel’s CBR properties.
typedef struct _VENC_MJPEG_CBR_S {
CVI_U32 u32BitRate;
} VENC_MJPEG_CBR_S;
【Member】
Member |
u32StatTime |
CBR rate statistics time, in seconds.. |
u32BitRate |
u32SrcFrameRate |
fr32DstFrameRate |
bVariFpsEn |
None.
CVI_VENC_CreateChn
7.4.29. VENC_H265_CBR_S¶
Structure definition for H.265 video encoding channel’s CBR properties.
CVI_U32 u32Gop;
CVI_U32 u32StatTime
CVI_U32 u32BitRate;
} VENC_H264_CBR_S;
typedef struct _VENC_H264_CBR_S VENC_H265_CBR_S;
【Member】
Member |
u32Gop |
H.265 gop value |
u32StatTime |
u32SrcFrameRate |
fr32DstFrameRate |
u32BitRate |
bVariFpsEn |
None.
CVI_VENC_CreateChn
7.4.30. VENC_H265_VBR_S¶
Structure definition for H.265 video encoding channel’s VBR properties.
CVI_U32 u32Gop;
CVI_U32 u32IQp;
CVI_U32 u32PQp;
CVI_U32 u32BQp;
【Member】
Member |
u32Gop |
H.265 gop value |
u32StatTime |
VBR rate statistics time, in seconds.. |
u32SrcFrameRate |
fr32DstFrameRate |
u32MaxBitRate |
bVariFpsEn |
None.
CVI_VENC_CreateChn
7.4.31. VENC_H265_AVBR_S¶
Structure definition for H.265 video encoding channel’s AVBR properties.
CVI_U32 u32Gop;
} VENC_H264_AVBR_S;
typedef struct _VENC_H264_AVBR_S VENC_H265_AVBR_S;
【Member】
Member |
u32Gop |
H.265 gop value. range |
u32StatTime |
AVBR rate statistics time, in seconds. |
u32SrcFrameRate |
fr32DstFrameRate |
u32MaxBitRate |
bVariFpsEn |
u32Gop |
None.
CVI_VENC_CreateChn
7.4.32. VENC_H265_FIXQP_S¶
Structure definition for H.265 video encoding channel’s FIXQP properties.
CVI_U32 u32Gop;
CVI_U32 u32IQp;
CVI_U32 u32PQp;
CVI_U32 u32BQp;
typedef struct _VENC_H264_FIXQP_S VENC_H265_FIXQP_S;
【Member】
Member |
u32Gop |
H.265 gop value |
u32IQp |
u32SrcFrameRate |
fr32DstFrameRate |
u32PQp |
u32BQp |
Reserved |
bVariFpsEn |
None.
CVI_VENC_CreateChn
7.4.33. VENC_H265_QPMAP_S¶
Structure definition for H.265 video encoding channel’s QPMAP properties.
typedef struct _VENC_H265_QPMAP_S {
CVI_U32 u32Gop;
VENC_RC_QPMAP_MODE_E enQpMapMode;
} VENC_H265_QPMAP_S;
【Member】
Member |
u32Gop |
u32StatTime |
VBR rate statistical time in seconds |
u32SrcFrameRate |
fr32DstFrameRate |
enQpMapMode |
The method of selecting the QP value as either CU32 or CU64 |
u32BQp |
bVariFpsEn |
None.
CVI_VENC_CreateChn
7.4.34. VENC_RC_PARAM_S¶
Definition of advanced bitrate control parameters for encoding channels. Main structure for bitrate control.
typedef struct _VENC_RC_PARAM_S {
CVI_U32 u32ThrdI[RC_TEXTURE_THR_SIZE];
CVI_U32 u32ThrdP[RC_TEXTURE_THR_SIZE];
CVI_U32 u32ThrdB[RC_TEXTURE_THR_SIZE];
CVI_U32 u32DirectionThrd;
CVI_S32 s32FirstFrameStartQp;
CVI_S32 s32InitialDelay;
CVI_U32 u32ThrdLv;
CVI_BOOL bBgEnhanceEn;
CVI_S32 s32BgDeltaQp;
union {
VENC_PARAM_H264_CBR_S stParamH264Cbr;
VENC_PARAM_H264_VBR_S stParamH264Vbr;
VENC_PARAM_H264_AVBR_S stParamH264AVbr;
VENC_PARAM_H264_QVBR_S stParamH264QVbr;
VENC_PARAM_H265_CBR_S stParamH265Cbr;
VENC_PARAM_H265_VBR_S stParamH265Vbr;
VENC_PARAM_H265_AVBR_S stParamH265AVbr;
VENC_PARAM_H265_QVBR_S stParamH265QVbr;
VENC_PARAM_MJPEG_CBR_S stParamMjpegCbr;
VENC_PARAM_MJPEG_VBR_S stParamMjpegVbr;
} VENC_RC_PARAM_S;
【Member】
Member |
u32ThrdI |
Reserved |
u32ThrdP |
Reserved |
u32ThrdB |
Reserved |
u32DirectionThrd |
Reserved |
u32RowQpDelta |
The fluctuation amplitude value of the starting Qp for each row of macroblocks in macroblock-level bitrate control relative to the starting Qp of the frame. |
s32FirstFrameStartQp |
Set the initial Qp value of the first frame, CBR/VBR/AVBR/QVBR/CVBR is valid. |
stSceneChangeDetect |
Reserved |
s32InitialDelay |
Influence the frame encoding of the bitrate control. |
u32ThrdLv |
MAD threshold for macroblock level rate control |
bBgEnhanceEn |
Reserved |
s32BgDeltaQp |
The QP difference between IDR frame and P frame in smartP mode. |
stParamH264Cbr |
Advanced parameters for CBR rate control mode in H.264 channel. |
stParamH264Vbr |
Advanced parameters for VBR rate control mode in H.264 channel. |
stParamH264AVbr |
Advanced parameters for AVBR rate control mode in H.264 channel. |
stParamH264QVbr |
Reserved |
stParamH264CVbr |
Reserved |
stParamMjpegCbr |
Advanced parameters for CBR rate control mode in MJPEG channel. |
stParamMjpegVbr |
Reserved |
stParamH265Cbr |
Advanced parameters for CBR rate control mode in H.265 channel. |
stParamH265Vbr |
Advanced parameters for VBR rate control mode in H.265 channel. |
stParamH265AVbr |
Advanced parameters for AVBR rate control mode in H.265 channel. |
stParamH265QVbr |
Reserved |
stParamH265CVbr |
Reserved |
None.
CVI_VENC_SetRcParam
CVI_VENC_GetRcParam
7.4.35. VENC_PARAM_H264_CBR_S¶
Definition of H.264 CBR advanced parameters
typedef struct _VENC_PARAM_H264_CBR_S {
CVI_U32 u32MinIprop;
CVI_U32 u32MaxIprop;
CVI_U32 u32MaxQp;
CVI_U32 u32MinQp;
CVI_U32 u32MaxIQp;
CVI_U32 u32MinIQp;
CVI_S32 s32MaxReEncodeTimes;
CVI_BOOL bQpMapEn;
} VENC_PARAM_H264_CBR_S;
【Member】
Member |
u32MinIprop |
minimum IP ratio |
u32MaxIprop |
maximum IP ratio |
u32MaxQp |
Minimum QP |
u32MinQp |
Maximum QP |
u32MaxIQp |
Maximum QP for I-frames |
u32MinIQp |
Minimum QP for I-frames |
s32MaxReEncodeTimes |
Reserved |
CVI_BOOL bQpMapEn |
Reserved |
None.
CVI_VENC_SetRcParam
CVI_VENC_GetRcParam
7.4.36. VENC_PARAM_H264_VBR_S¶
Definition of H.264 VBR advanced parameters
typedef struct _VENC_PARAM_H264_VBR_S {
CVI_S32 s32ChangePos;
CVI_BOOL bQpMapEn;
CVI_U32 u32MaxQp;
CVI_U32 u32MinQp;
CVI_U32 u32MaxIQp;
CVI_U32 u32MinIQp;
} VENC_PARAM_H264_VBR_S;
【Member】
Member |
s32ChangePos |
bitrate control threshold |
u32MinIprop |
Reserved |
u32MaxIprop |
maximum IP ratio |
Reserved |
CVI_BOOL bQpMapEn |
Reserved |
u32MaxQp |
Maximum QP |
u32MinQp |
Minimum QP |
u32MaxIQp |
maximum QP for I-frames |
u32MinIQp |
minimum QP for I-frames |
None.
CVI_VENC_SetRcParam
CVI_VENC_GetRcParam
7.4.37. VENC_PARAM_H264_AVBR_S¶
Definition of H.264 AVBR advanced parameters
typedef struct _VENC_PARAM_H264_AVBR_S {
CVI_BOOL bQpMapEn;
CVI_S32 s32MinStillPercent;
CVI_U32 u32MaxStillQP;
CVI_U32 u32MinStillPSNR;
CVI_U32 u32MaxQp;
CVI_U32 u32MinQp;
CVI_U32 u32MaxIQp;
CVI_U32 u32MinIQp;
CVI_U32 u32MinQpDelta;
CVI_U32 u32MotionSensitivity;
CVI_S32 s32AvbrFrmLostOpen;
CVI_S32 s32AvbrFrmGap;
CVI_S32 s32AvbrPureStillThr;
} VENC_PARAM_H264_AVBR_S;
【Member】
Member |
s32ChangePos |
u32MinIprop |
Reserved |
u32MaxIprop |
maximum IP ratio |
Reserved |
CVI_BOOL bQpMapEn |
Reserved |
s32MinStillPercent |
minimum bitrate percentage for static scenes |
u32MaxStillQP |
Maximum QP for static scenes |
u32MinStillPSNR |
Reserved |
u32MaxQp |
Maximum QP |
u32MinQp |
Minimum QP |
u32MaxIQp |
u32MinIQp |
u32MinQpDelta |
The difference between frame-level minimum QP and macroblock-level minimum QP |
u32MotionSensitivity |
Motion sensitivity |
s32AvbrFrmLostOpen |
Frame dropping enable |
s32AvbrFrmGap |
Maximum number of dropped frames |
s32AvbrPureStillThr |
Still macroblock threshold value |
None.
CVI_VENC_SetRcParam
CVI_VENC_GetRcParam
7.4.38. VENC_PARAM_H265_CBR_S¶
Definition of H.265 CBR advanced parameters
typedef struct _VENC_PARAM_H265_CBR_S {
CVI_U32 u32MaxQp;
CVI_U32 u32MinQp;
CVI_U32 u32MaxIQp;
CVI_U32 u32MinIQp;
CVI_BOOL bQpMapEn;
} VENC_PARAM_H265_CBR_S;
【Member】
Member |
u32MinIprop |
Reserved |
u32MaxIprop |
Reserved |
u32MaxQp |
Maximum QP |
u32MinQp |
Minimum QP |
u32MaxIQp |
u32MinIQp |
Reserved |
bQpMapEn |
Enable QP map feature or not |
enQpMapMode |
QpMap mode |
None.
CVI_VENC_SetRcParam
CVI_VENC_GetRcParam
7.4.39. VENC_PARAM_H265_VBR_S¶
Definition of H.265 VBR advanced parameters
typedef struct _VENC_PARAM_H265_VBR_S {
CVI_U32 u32MaxQp;
CVI_U32 u32MinQp;
CVI_U32 u32MaxIQp;
CVI_U32 u32MinIQp;
CVI_BOOL bQpMapEn;
} VENC_PARAM_H265_VBR_S;
【Member】
Member |
s32ChangePos |
u32MinIprop |
Reserved |
u32MaxIprop |
Reserved |
Reserved |
u32MaxQp |
Maximum QP |
u32MinQp |
Minimum QP |
u32MaxIQp |
u32MinIQp |
CVI_BOOL bQpMapEn |
Reserved |
enQpMapMode |
Reserved |
None.
CVI_VENC_SetRcParam
CVI_VENC_GetRcParam
7.4.40. VENC_PARAM_H265_AVBR_S¶
Definition of H.265 AVBR advanced parameters
typedef struct _VENC_PARAM_H265_AVBR_S {
CVI_U32 u32MaxQp;
CVI_U32 u32MinQp;
CVI_U32 u32MaxIQp;
CVI_U32 u32MinIQp;
CVI_BOOL bQpMapEn;
} VENC_PARAM_H265_AVBR_S;
【Member】
Member |
s32ChangePos |
Bitrate control threshold |
u32MinIprop |
Reserved |
u32MaxIprop |
Reserved |
Reserved |
Minimum bitrate percentage for static scenes |
u32MaxStillQP |
u32MinStillPSNR |
Reserved |
u32MaxQp |
Maximum QP |
u32MinQp |
Minimum QP |
u32MaxIQp |
u32MinIQp |
u32MinQpDelta |
s32AvbrFrmGap |
bQpMapEn |
Reserved |
enQpMapMode |
Reserved |
None.
CVI_VENC_SetRcParam
CVI_VENC_GetRcParam
7.4.41. VENC_PARAM_MOD_S¶
Encoding-related module parameters
typedef struct _VENC_MODPARAM_S {
VENC_MODTYPE_E enVencModType; /* RW; VencModType*/
union {
VENC_MOD_VENC_S stVencModParam;
VENC_MOD_H264E_S stH264eModParam;
VENC_MOD_H265E_S stH265eModParam;
VENC_MOD_JPEGE_S stJpegeModParam;
VENC_MOD_RC_S stRcModParam;
} VENC_PARAM_MOD_S;
【Member】
Member |
enVencModType |
Types of module parameters |
stVencModParam /stH264eModParam /stH265eModParam /stJpegeModParam /stRcModParam |
Venc / H264e / H265e / Jpege / Rc module parameter structure. |
None.
CVI_VENC_SetModParam
CVI_VENC_GetModParam
7.4.42. VENC_MOD_H264E_S¶
H.264 encoding-related module parameters
typedef struct _VENC_MOD_H264E_S {
CVI_U32 u32OneStreamBuffer;
CVI_U32 u32H264eMiniBufMode;
CVI_U32 u32H264ePowerSaveEn;
VB_SOURCE_E enH264eVBSource;
CVI_BOOL bQpHstgrmEn;
CVI_U32 u32UserDataMaxLen;
CVI_BOOL bSingleEsBuf;
CVI_U32 u32SingleEsBufSize;
} VENC_MOD_H264E_S;
【Member】
Member |
u32OneStreamBuffer |
Reserved |
u32H264eMiniBufMode |
Reserved |
u32H264ePowerSaveEn |
Reserved |
enH264eVBSource |
VB mode |
bQpHstgrmEn |
Reserved |
u32UserDataMaxLen |
Maximum user data size |
bSingleEsBuf |
Multiple channels using a shared stream buffer |
u32SingleEsBufSize |
StreamBuffer size |
None.
7.4.43. VENC_MOD_H265E_S¶
H.265 encoding-related module parameters
typedef struct _VENC_MOD_H265E_S {
CVI_U32 u32H265eMiniBufMode;
CVI_U32 u32H265ePowerSaveEn;
VB_SOURCE_E enH265eVBSource;
H265E_REFRESH_TYPE_E enRefreshType;
} VENC_MOD_H265E_S;
【Member】
Member |
Reserved |
u32H265eMiniBufMode |
Reserved |
u32H265ePowerSaveEn |
Reserved |
enH265eVBSource |
VB mode |
bQpHstgrmEn |
Reserved |
u32UserDataMaxLen |
bSingleEsBuf |
StreamBuffer size |
enRefreshType |
Refresh type |
None.
7.4.44. VENC_MOD_JPEGE_S¶
JPEG encoding-related module parameters
typedef struct _VENC_MOD_JPEGE_S {
CVI_U32 u32JpegeMiniBufMode;
CVI_U32 u32JpegClearStreamBuf;
JPEGE_FORMAT_E enJpegeFormat;
JPEGE_MARKER_TYPE_E JpegMarkerOrder[JPEG_MARKER_ORDER_CNT];
} VENC_MOD_JPEGE_S;
【Member】
Member |
Reserved |
u32JpegeMiniBufMode |
Reserved |
u32JpegClearStreamBuf |
Reserved |
bSingleEsBuf |
StreamBuffer size |
enJpegeFormat |
JPEG header encoding mode |
JpegMarkerOrder |
Header encoding mark order |
None.
7.4.45. VENC_CHN_POOL_S¶
Define the VB pool structure, which is bound to the encoding channel.
typedef struct _VENC_CHN_POOL_S {
VB_POOL hPicVbPool; /* RW; vb pool id for pic buffer */
VB_POOL hPicInfoVbPool; /* RW; vb pool id for pic info buffer */
} VENC_CHN_POOL_S;
【Member】
Member |
hPicVbPool |
VB pool Poold for storing Picture |
hPicInfoVbPool |
VB pool Poold for storing Picture information |
None.
CVI_VENC_AttachVbPool
7.4.46. VENC_FRAMELOST_S¶
Define the encoding frame dropping structure.
typedef struct _VENC_FRAMELOST_S {
CVI_BOOL bFrmLostOpen;
CVI_U32 u32FrmLostBpsThr;
VENC_FRAMELOST_MODE_E enFrmLostMode;
CVI_U32 u32EncFrmGaps;
} VENC_FRAMELOST_S;
【Member】
Member |
bFrmLostOpen |
Frame dropping strategy enable |
u32FrmLostBpsThr |
Frame dropping bitrate threshold value |
enFrmLostMode |
Frame dropping mode |
u32EncFrmGaps |
Maximum consecutive dropped frames |
None.
CVI_VENC_SetFrameLostStrategy
CVI_VENC_GetFrameLostStrategy
7.4.47. VENC_H264_ENTROPY_S¶
Define H.264 entropy coding information structure.
typedef struct _VENC_H264_ENTROPY_S {
CVI_U32 u32EntropyEncModeI;
CVI_U32 u32EntropyEncModeP;
CVI_U32 u32EntropyEncModeB;
CVI_U32 cabac_init_idc;
} VENC_H264_ENTROPY_S;
【Member】
Member |
u32EntropyEncModeI |
I-frame entropy coding mode: 0 for CAVLC and 1 for CABAC. |
u32EntropyEncModeP |
P-frame entropy coding mode: 0 for CAVLC and 1 for CABAC. |
u32EntropyEncModeB |
cabac_init_idc |
Refer to H264 encoding protocol |
None.
CVI_VENC_SetH264Entropy
CVI_VENC_GetH264Entropy
7.4.48. VENC_CU_PREDICTION_S¶
Define the structure of coding unit prediction properties
typedef struct _VENC_CU_PREDICTION_S {
OPERATION_MODE_E enPredMode;
CVI_U32 u32IntraCost;
CVI_U32 u32Intra32Cost;
CVI_U32 u32Intra16Cost;
CVI_U32 u32Intra8Cost;
CVI_U32 u32Intra4Cost;
CVI_U32 u32Inter64Cost;
CVI_U32 u32Inter32Cost;
CVI_U32 u32Inter16Cost;
CVI_U32 u32Inter8Cost;
} VENC_CU_PREDICTION_S;
【Member】
Member |
enPredMode |
u32IntraCost |
Default to 0, used to reduce the probability of Intra Blocks. |
u32Intra32Cost |
u32Intra16Cost |
u32Intra8Cost |
u32Intra4Cost |
u32Inter64Cost |
u32Inter32Cost |
u32Inter16Cost |
u32Inter8Cost |
None.
CVI_VENC_SetCuPrediction
CVI_VENC_GetCuPrediction
7.4.49. VENC_H264_TRANS_S¶
Define the structure of the H.264 protocol encoding channel transformation quantization.
typedef struct _VENC_H264_TRANS_S {
CVI_U32 u32IntraTransMode;
CVI_U32 u32InterTransMode;
CVI_BOOL bScalingListValid;
CVI_U8 InterScalingList8X8[64];
CVI_U8 IntraScalingList8X8[64];
CVI_S32 chroma_qp_index_offset;
} VENC_H264_TRANS_S;
【Member】
Member |
u32IntraTransMode |
u32InterTransMode |
bScalingListValid |
InterScalingList8X8[64] |
IntraScalingList8X8[64] |
chroma_qp_index_offset |
For details, see H.264 Protocol. The default value is 0. Value range: [-12, 12] |
None.
CVI_VENC_GetH264Trans
CVI_VENC_SetH264Trans
7.4.50. VENC_H265_TRANS_S¶
Define the structure of the H.265 protocol encoding channel transformation quantization.
typedef struct _VENC_H265_TRANS_S {
CVI_S32 cb_qp_offset;
CVI_S32 cr_qp_offset;
CVI_BOOL bScalingListEnabled;
CVI_BOOL bScalingListTu4Valid;
CVI_U8 InterScalingList4X4[2][16];
CVI_U8 IntraScalingList4X4[2][16];
CVI_BOOL bScalingListTu8Valid;
CVI_U8 InterScalingList8X8[2][64];
CVI_U8 IntraScalingList8X8[2][64];
CVI_BOOL bScalingListTu16Valid;
CVI_U8 InterScalingList16X16[2][64];
CVI_U8 IntraScalingList16X16[2][64];
CVI_BOOL bScalingListTU32Valid;
CVI_U8 InterScalingList32X32[64];
CVI_U8 IntraScalingList32X32[64];
} VENC_H265_TRANS_S;
【Member】
Member |
cb_qp_offset |
For details, see H.265 Protocol. The default value is 0. Value range: [-12, 12] |
cr_qp_offset |
bScalingListEnabled |
bScalingListTu4Valid |
InterScalingList4X4[2][16] |
IntraScalingList4X4[2][16] |
bScalingListTu8Valid |
InterScalingList8X8[2][64] |
IntraScalingList8X8[2][64] |
bScalingListTu16Valid |
InterScalingList16X16[2][64] |
IntraScalingList16X16[2][64] |
bScalingListTu32Valid |
InterScalingList32X32[64] |
IntraScalingList32X32[64] |
None.
CVI_VENC_GetH265Trans
CVI_VENC_SetH265Trans
