3. ISP System Overview¶
3.1. Function Introduction¶
ISP system supports standard image processing functions, including bad point correction, lens shadow correction, auto exposure, auto white balance, auto focus, demosaic and other basic functions, as well as advanced processing functions such as noise reduction, WDR and DRC.
The main image processing functions supported by ISP are as follows:
Black level correction (BLC)
Static and Dynamic Defect Pixel Correction (DPC)
CrossTalk Removal
Lens shadow correction (LSC)
Bayer noise reduction
Demosaic processing
Color Correction Matrix (CCM)
Gamma correction
Purple fringing correction (LCAC, RGBCAC and CAC)
Wide Dynamic Range (WDR)
Dynamic Range Compression (DRC)
Auto Exposure (AE)
Auto Focus (AF)
Auto White Balance (AWB)
3A related statistical information output
Image Sharpening (Sharpen)
Auto dehaze treatment (Dehaze)
Local Dynamic Contrast Improvement (LDCI)
3D noise reduction (3DNR)
Color 3D look up table enhancement (CLUT)
Brightness coloring
Digital image stabilization
3.2. Function Block Diagram¶
The overall structure of ISP is shown in Fig. 3.1. The following chapters of this document will introduce the function of each module, the parameter calibration method and image quality tuning method of each module (BLC, DPC, MLSC, AWB, BNR, CCM and CLUT).
Fig. 3.1 ISP Overall structure diagram¶
3.3. Introduction to Each Module¶
The following chapters of this document will introduce the function and the image quality tuning method of each module. The functions of ISP modules are shown in Table 3.1.
Module Name |
Function |
Crop |
Function of clipping the input image. |
BLC |
Black level correction. |
DPC |
Realize the function of detecting and correcting static defect pixel and dynamic defect pixel. |
CrossTalkRemoval |
Correct the imbalance between Gr and Gb channels. |
LSC |
Provide lens shadow correction. |
WDR |
Wide dynamic function of multi frame synthesis. |
DRC |
Adjust the dynamic range of the image so that the display effect on the display device is consistent with the human visual experience. |
BNR |
Realize the image denoising function in Bayer domain. |
Demosaic |
Convert Raw image in Bayer format to RGB image. |
AE |
Provide automatic exposure information statistics to the software to adjust the Sensor to achieve automatic exposure function. |
AWB |
Provide global and regional statistical information to the software to adjust the Sensor to achieve automatic white balance function. |
AF |
The module outputs the statistical information related to the image definition, and the software completes the auto focusing function based on the statistical information. |
CAC |
Realize the function of removing purple fringing of the image, and improve the purple fringing of the image edge. |
CCM |
Use the 3x3 matrix to correct the color. |
Gamma |
Adjust the overall brightness of the image according to the gamma curve. |
Dehaze |
Dehaze the scene with haze to improve the contrast and clarity of the image. |
CSC |
Transform the RGB image into YUV image through 3x3 matrix. |
YNR |
Realizes the function of removing bright noise. |
CNR |
Provides the function of removing color noise and reducing color spots. |
Sharpen |
Realizes the image sharpening function and increase the image clarity. |
DCI |
Based on histogram equalization method to improve the overall image contrast and the details of the dark area |
LDCI |
Based on the method of image blocking statistics, the local contrast of the image is enhanced, and the filtering parameters can be adjusted to adjust the local range of local contrast enhancement. |
CLUT |
Uses 3D LUT to achieve complex color adjustment functions, including brightness adjustment and saturation adjustment. |
3DNR |
Removes the noise in the image by time domain filtering, keep the image details and reduce the coding bitrate. |
CA |
Provides saturation adjustment and thermal imaging coloring functions. |
CA_Lite |
Provides saturation adjustment function. |
LDC |
Realizes the lens deformity correction. |
DIS |
Digital image stabilization function. |
