10.3. API Reference¶
This section describes how to use the API of each module of CVI_AUDIO in order.
Note that when using CVI_AUDIO, please confirm CVI_SYS_Init has been called to ensure that the corresponding system component is initialized.
CVI_AUDIO_Init must also be called to ensure that the software in the audio module has been initialized.
Users should pay attention to that CVI_AUDIO_Init only needs to be called once.
Please confirm the relevant modules of CVI_AUDIO has been disabled
when exiting Audio, and call CVI_SYS_Exit subsequently.
10.3.1. Module Properties API:¶
10.3.1.1. CVI_AUDIO_INIT¶
Initialize the audio module.
CVI_S32 CVI_AUDIO_INIT(void);
【Parameter】
Parameter |
Input/Output |
None |
No need to enter a value. |
【Return Value】
Return Value |
0 |
Success. |
Non 0 |
Failure. For details, please refer to Error Codes. |
【Requirement】
Header files: cvi_comm_aio.h, cvi_audio.h
Library files: libcvi_audio.a
The initialization through this API is required before using the audio module.
Otherwise, the functionality may be abnormal or the memory may be accessed incorrectly.
10.3.1.2. CVI_AUDIO_DEINIT¶
CVI_S32 CVI_AUDIO_DEINIT(void);
【Parameter】
Parameter |
Input/Output |
None |
【Return Value】
Return Value |
0 |
Success. |
Non 0 |
【Requirement】
Before exiting the audio module, it is necessary to release the module using this API.
Otherwise, the functionality may be abnormal or the memory data may be corrupted.
10.3.1.3. CVI_AUDIO_SetModParam¶
Set the audio module properties.
CVI_S32 CVI_AUDIO_SetModParam(const AUDIO_MOD_PARAM_S *pstModParam);
【Parameter】
Parameter |
Input/Output |
pstModParam |
Audio module property pointer. |
Input |
【Return Value】
Return Value |
0 |
Success. |
Non 0 |
【Requirement】
Before using each audio sub-module, initialization is required through this API.
【Example】
None.
10.3.1.4. CVI_AUD_SYS_Bind¶
Set the audio module binding properties.
CVI_S32 CVI_AUD_SYS_Bind(const MMF_CHN_S *pstSrcChn, const MMF_CHN_S *pstDestChn);
【parameters】
Parameter |
Input/Output |
pstSrcChn |
Audio bind source pointer. |
Input |
pstDestChn |
Audio bind destination pointer. |
Input |
【Return Value】
Return Value |
0 |
Success. |
Non 0 |
【Requirement】
The binding objects supported are:
(AudIn -> AudEnc),
(AudDec ->AudOut),
See SAMPLE_AUDIO_AiAenc and SAMPLE_AUDIO_AdecAo in cvi_sample_audio.c to understand the binding usage.
【Example】
None.
10.3.1.5. CVI_AUDIO_GetModParam¶
Get the properties of the audio module.
CVI_S32 CVI_AUDIO_GetModParam(AUDIO_MOD_PARAM_S *pstModParam);
【Parameter】
Parameter |
Input/Output |
pstModParam |
Output |
【Return Value】
Return Value |
0 |
Success. |
Non 0 |
【Requirement】
【Example】
None.
10.3.1.6. CVI_AUDIO_RegisterVQEModule¶
Register VQE module.
CVI_S32 CVI_AUDIO_RegisterVQEModule(const AUDIO_VQE_REGISTER_S *pstVqeRegister);
【Parameter】
Parameter |
Input/Output |
pstVqeRegister |
VQE related property pointer |
Input |
【Return Value】
Return Value |
0 |
Success. |
Non 0 |
【Requirement】
Library files: libcvi_audio.a, libcvi_vqe.so, libaec.so
This api is deprecated.
Please use CVI_AI_SetTalkVqeAttr and CVI_AI_EnableVqe.
【Example】
None.
10.3.1.7. CVI_AENC_RegisterExternalEncoder¶
Register audio encoding module.
CVI_S32 CVI_AENC_RegisterExternalEncoder(CVI_S32 *ps32Handle, const AAC_AENC_ENCODER_S *pstEncoder);
【Parameter】
Parameter |
Input/Output |
ps32Handle |
parameter property pointer |
Input |
pstEncoder |
Encoding module function pointer |
Input |
【Return Value】
Return Value |
0 |
Success. |
Non 0 |
【Requirement】
Header files: cvi_comm_aio.h, cvi_audio.h, cvi_audio_aac_adp.h
Library files: libcvi_audio.a, libaacenc2.so
This function is used for AAC audio encoding.
Before registering the function, make sure that the function pointer in pstEncoder is not null, otherwise there will be errors when calling it internally.
Related examples can refer to sample/audio/aac_sample/cvi_audio_aac_adp.c
This function only supports AAC code registration, please use CVI_AENC_CreateChn for related G7xx series coding. See SAMPLE_AUDIO_AiAenc in cvi_sample_audio.c for reference.
【Example】
None.
10.3.1.8. CVI_AENC_UnRegisterExternalEncoder¶
Cancel the encoder.
CVI_S32 CVI_AENC_UnRegisterExternalEncoder(CVI_S32 s32Handle);
【Parameter】
Parameter |
Input/Output |
s32Handle |
Register handle (the handle obtained when registering the encoder). |
Input |
【Return Value】
Return Value |
0 |
Success. |
Non 0 |
【Requirement】
This function is used for AAC audio coding.
Before unregistering the encoder, all encoding channels created through this encoder must be destroyed. Calling this interface without destroying all channels will result in an error.
【Example】
None.
10.3.1.9. CVI_ADEC_RegisterExternalDecoder¶
Register audio decoding module.
CVI_S32 CVI_ADEC_RegisterExternalDecoder(CVI_S32 *ps32Handle, const ADEC_DECODER_S *pstDecoder);
【Parameter】
Parameter |
Input/Output |
ps32Handle |
Input/Output |
pstDecoder |
Input |
【Return Value】
Return Value |
0 |
Success. |
Non 0 |
【Requirement】
Header files: cvi_comm_aio.h, cvi_audio.h , cvi_audio_aac_adp.h
Library files: libcvi_audio.a, libaadec2.so
This function is used for AAC audio decoding.
【Example】
None.
10.3.1.10. CVI_ADEC_UnRegisterExternalDecoder¶
Cancel audio decoding module.
CVI_S32 CVI_ADEC_UnRegisterExternalDecoder(CVI_S32 s32Handle);
【Parameter】
Parameter |
Input/Output |
s32Handle |
Register handle |
Input |
【Return Value】
Return Value |
0 |
Success. |
Non 0 |
【Requirement】
【Example】
None.
10.3.2. Audio Input¶
The audio input realizes the functions of configuring and enabling the audio input device and acquiring the audio frame data.
The function module provides the following APIs.
CVI_AI_SetPubAttr: Set Audio Input device properties.
CVI_AI_GetPubAttr: Get Audio Input device properties.
CVI_AI_Enable: Enable Audio Input device properties.
CVI_AI_Disable: Disable Audio Input device properties.
CVI_AI_EnableChn: Enable Audio Input channel.
CVI_AI_DisableChn: Disable Audio Input channel.
CVI_AI_GetFrame: Get the audio frame.
CVI_AI_ReleaseFrame: Release the audio frame.
CVI_AI_SetChnParam: Set Audio Input channel parameters.
CVI_AI_GetChnParam: Get Audio Input channel parameters.
CVI_AI_EnableReSmp: Enable Audio Input resampling.
CVI_AI_DisableReSmp: Disable Audio Input resampling.
CVI_AI_ClrPubAttr: Clear Audio Input device properties.
CVI_AI_SaveFile: Enable audio input file recording functionality.
CVI_AI_QueryFileStatus: Query the status of the audio input channel for saving to file.
CVI_AI_EnableAecRefFrame: When the AEC is not turned on, the user can also get the AEC reference frame.
CVI_AI_DisableAecRefFrame: When the AEC is not turned on, it is forbidden to obtain the AEC reference frame.
CVI_AI_SetVolume: Set the Audio Input device volume.
CVI_AI_GetVolume: Get the Audio Input device volume.
10.3.2.1. CVI_AI_SetPubAttr¶
CVI_S32 CVI_AI_SetPubAttr(AUDIO_DEV AiDevId, const AIO_ATTR_S *pstAttr);
【Parameter】
Parameter |
Input/Output |
AiDevId |
Audio Input device number |
Input |
pstAttr |
Audio Input device attribute pointer |
Input |
【Return Value】
Return Value |
0 |
Success. |
Non 0 |
【Requirement】
The properties of audio input device determine the format of input data.
The properties of input device include working mode, sampling rate, sampling precision, buffer size, sampling points per frame, extended flag, clock selection and channel number.
These properties should be consistent with the timing of docking codec configuration, that is, they can be successfully docked.
AiDevId is set to 0 by default. If amplification is not required, an error will be returned if it exceeds 2.
enBitwidth :
the bit depth is 8bit, 16bit or 24bit.
In practical application, the sampling accuracy is limited by Audio Codec.
The u32frmnum item in Buffer size AIO_ATTR_S is used to configure the audio of the block used to receive audio data in Audio Input.
UsrFrmDept :
block voice box, it is recommended to be greater than or equal to 5.
enSamplerate: When the audio sampling rate is high, it is recommended to increase the number of sampling points per frame accordingly.
If you want to encode the collected audio data, you should ensure that the duration of each frame is not less than 10ms (For example, the number of sampling points of each frame should be set to at least 160 at the sampling frequency of 16K).
Otherwise there may be abnormal sound after decoding.
enSoundmode :
two channel or single channel voice frame setting.
u32ChnCnt :
channel number.
Channel number refers to the number of Audio Input channels of the current input device, which should be consistent with the configuration of the audio codec to be connected.
It supports 1 channel and 2 channels.
u32EXFlag :
the extended flag is invalid for Audio Input devices.
u32ClkSel :
clock setting.
In this processor CV1835, there is no special setting, just note that Audio Input/Output attribute should be set consistently in Audio Input / Audio Output.
【Example】
None.
10.3.2.2. CVI_AI_GetPubAttr¶
CVI_S32 CVI_AI_GetPubAttr(AUDIO_DEV AiDevId, AIO_ATTR_S*pstAttr);
【Parameter】
Parameter |
Input/Output |
AiDevId |
Audio device number |
Input |
pstAttr |
Input |
【Return Value】
Return Value |
0 |
Success. |
Non 0 |
【Requirement】
If not initialized or CVI_AI_SetPubAttr has not been called, the user will get the pointer and value with the content of 0.
【Example】
None.
10.3.2.3. CVI_AI_Enable¶
Enable Audio Input device.
CVI_S32 CVI_AI_Enable(AUDIO_DEV AiDevId);
【Parameter】
Parameter |
Input/Output |
AiDevId |
Audio device number. The device number is preset to 0, and setting it to a value greater than 2 will return an error, unless customization requires expansion. |
Input |
【Return Value】
Return Value |
0 |
Success. |
Non 0 |
【Requirement】
This API is the last function to enable Audio Input.
Please confirm that the relevant properties have been set before calling.
【Example】
Audio In Examples:
CVI_S32 i;
CVI_S32 s32Ret;
s32Ret = CVI_AI_SetPubAttr(AiDevId, pstAioAttr);
if (s32Ret) {
printf("%s: CVI_AI_SetPubAttr(%d) failed with %#x\n"
, __func__,
AiDevId,
s32Ret);
return s32Ret;
s32Ret = CVI_AI_Enable(AiDevId);
if (s32Ret) {
printf("%s: CVI_AI_Enable(%d) failed with %#x\n", __func__, AiDevId,
s32Ret);
return s32Ret;
for (i = 0; i < s32AiChnCnt >> pstAioAttr->enSoundmode; i++) {
s32Ret = CVI_AI_EnableChn(AiDevId, i / (pstAioAttr->enSoundmode + 1));
if (s32Ret) {
printf("%s: CVI_AI_EnableChn(%d,%d) failed with %#x\n", __func__,
AiDevId, i, s32Ret);
return s32Ret;
if (bResampleEn == CVI_TRUE) {
s32Ret = CVI_AI_EnableReSmp(AiDevId, i, enOutSampleRate);
if (s32Ret) {
printf("%s: CVI_AI_EnableReSmp(%d,%d) failed with %#x\n",
__func__,
AiDevId, i,
s32Ret);
return s32Ret;
if (pstAiVqeAttr != NULL) {
CVI_BOOL bAiVqe = CVI_TRUE;
s32Ret = CVI_AI_SetTalkVqeAttr(
0,
0,
0,
0,
(AI_TALKVQE_CONFIG_S *)pstAiVqeAttr);
break;
if (s32Ret) {
printf("%s: SetAiVqe%d(%d,%d) failed with %#x\n",
__func__,
u32AiVqeType,
return s32Ret;
if (bAiVqe) {
s32Ret = CVI_AI_EnableVqe(AiDevId, i);
if (s32Ret) {
printf("%s: CVI_AI_EnableVqe(%d,%d) failed with %#x\n", __func__,
return s32Ret;
10.3.2.4. CVI_AI_Disable¶
Disable Audio Input device.
CVI_S32 CVI_AI_Disable(AUDIO_DEV AiDevId);
【Parameter】
Parameter |
Input/Output |
AiDevId |
Input |
【Return Value】
Return Value |
0 |
Success. |
Non 0 |
【Requirement】
This API is the last program to stop an Audio Input device.
Before you disable an Audio Input device, you must disable all enabled Audio Input channels under the device.
If there is an AENC or Audio Output connection, please stop the association with it before calling this API.
【Example】
None.
10.3.2.5. CVI_AI_EnableChn¶
CVI_S32 CVI_AI_EnableChn(AUDIO_DEV AiDevId, AI_CHN AiChn);
【Parameter】
Parameter |
Input/Output |
AiDevId |
Input |
AiChn |
Audio input channel number. It is independent of the sound mode enSoundmode. Users can obtain the same audio source through different AiChn under the same AiDevId. |
Input |
【Return Value】
Return Value |
0 |
Success. |
Non 0 |
【Requirement】
Before enabling an Audio Input channel, you must first enable its Audio Input device.
【Example】
None.
10.3.2.6. CVI_AI_DisableChn¶
CVI_S32 CVI_AI_DisableChn(AUDIO_DEV AiDevId, AI_CHN AiChn);
【Parameter】
Parameter |
Input/Output |
AiDevId |
Input |
AiChn |
Input |
【Return Value】
Return Value |
0 |
Success. |
Non 0 |
【Requirement】
Please call this API before CVI_AI_Disable to avoid channel parameter residue.
【Example】
None.
10.3.2.7. CVI_AI_GetFrame¶
CVI_S32 CVI_AI_GetFrame(AUDIO_DEV AiDevId, AI_CHN AiChn, AUDIO_FRAME_S *pstFrm, AEC_FRAME_S *pstAecFrm , CVI_S32 s32MilliSec);
【Parameter】
Parameter |
Input/Output |
AiDevId |
Input |
AiChn |
Input |
pstFrm |
Audio frame structure pointer. The user obtains the voice frame from the structure pointer. |
Output |
pstAecFrm |
Echo cancellation reference frame structure pointer. |
Output |
s32MilliSec |
The timeout of data acquisition - 1 indicates blocking mode, waiting all the time when there is no data; 0 indicates non-blocking mode, reporting an error and returning when there is no data; > 0 indicates blocking s32MilliSec MS, reporting an error and returning when there is a timeout |
Input |
【Return Value】
Return Value |
0 |
Success. |
Non 0 |
【Requirement】
The value of s32MilliSec must be greater than or equal to -1. The data shall be obtained in blocking mode when it is equal to -1; non-blocking mode shall be used when it is equal to 0; when greater than 0, it will block s32MilliSec for millisecond and will return timeout and report an error if there is no data.
Before acquiring audio frame data, the corresponding Audio Input channel must be enabled.
To get the AEC frame, please make sure that the AEC in VQE is turned on.
【Example】
None.
10.3.2.8. CVI_AI_ReleaseFrame¶
CVI_S32 CVI_AI_ReleaseFrame(AUDIO_DEV AiDevId, AI_CHN AiChn, const AUDIO_FRAME_S *pstFrm, const AEC_FRAME_S *pstAecFrm);
【Parameter】
Parameter |
Input/Output |
AiDevId |
Input |
AiChn |
Input |
pstFrm |
Input |
pstAecFrm |
Input |
【Return Value】
Return Value |
0 |
Success. |
Non 0 |
【Requirement】
If there is no need to release the echo cancellation reference frame, set pstAecFrm to null.
【Example】
None.
10.3.2.9. CVI_AI_SetChnParam¶
CVI_S32 CVI_AI_SetChnParam(AUDIO_DEV AiDevId, AI_CHN AiChn, const AI_CHN_PARAM_S *pstChnParam);
【Parameter】
Parameter |
Input/Output |
AiDevId |
Input |
AiChn |
Input |
pstChnParam |
Audio channel parameters |
Input |
【Return Value】
Return Value |
0 |
Success. |
Non 0 |
【Requirement】
At present, the channel parameter has only one member variable, which is used to set the block depth for the user to obtain the audio frame.
The default depth is 0.
The value of the member variable cannot be greater than 30.
【Example】
None.
10.3.2.10. CVI_AI_GetChnParam¶
CVI_S32 CVI_AI_GetChnParam(AUDIO_DEV AiDevId, AI_CHN AiChn, AI_CHN_PARAM_S *pstChnParam);
【Parameter】
Parameter |
Input/Output |
AiDevId |
Input |
AiChn |
Input |
pstChnParam |
Output |
【Return Value】
Return Value |
0 |
Success. |
Non 0 |
【Requirement】
The audio module mentioned in this file is one of the interfaces of Middleware multimedia layer.
At present, the channel parameter has only one member variable, which is used to set the block depth of the audio frame.
【Example】
None.
10.3.2.11. CVI_AI_EnableReSmp¶
CVI_S32 CVI_AI_EnableReSmp(AUDIO_DEV AiDevId, AI_CHN AiChn, AUDIO_SAMPLE_RATE_E enOutSampleRate);
【Parameter】
Parameter |
Input/Output |
AiDevId |
Input |
AiChn |
Input |
enOutSampleRat |
The output sampling rate of audio resampling. |
Input |
【Return Value】
Return Value |
0 |
Success. |
Non 0 |
【Requirement】
Library files: libcvi_audio.a, libcvi_vqe.so, libcvi_RES1.so
This API is not supported when CVI_AUD_SYS_Bind is used.
The sample rate supported is as follows.
typedef enum _AUDIO_SAMPLE_RATE_E {
AUDIO_SAMPLE_RATE_8000 = 8000, /* 8K samplerate*/
AUDIO_SAMPLE_RATE_11025 = 11025, /* 11.025K samplerate*/
AUDIO_SAMPLE_RATE_16000 = 16000, /* 16K samplerate*/
AUDIO_SAMPLE_RATE_22050 = 22050, /* 22.050K samplerate*/
AUDIO_SAMPLE_RATE_24000 = 24000, /* 24K samplerate*/
AUDIO_SAMPLE_RATE_32000 = 32000, /* 32K samplerate*/
AUDIO_SAMPLE_RATE_44100 = 44100, /* 44.1K samplerate*/
AUDIO_SAMPLE_RATE_48000 = 48000, /* 48K samplerate*/
AUDIO_SAMPLE_RATE_64000 = 64000, /* 64K samplerate*/
AUDIO_SAMPLE_RATE_BUTT,
} AUDIO_SAMPLE_RATE_E;
【Example】
None.
10.3.2.12. CVI_AI_DisableReSmp¶
CVI_S32 CVI_AI_DisableReSmp(AUDIO_DEV AiDevId, AI_CHN AiChn);
【Parameter】
Parameter |
Input/Output |
AiDevId |
Input |
AiChn |
Input |
【Return Value】
Return Value |
0 |
Success. |
Non 0 |
【Requirement】
Library files: libcvi_audio.a, libcvi_RES1.so, libcvi_vqe.so
Please disable the AENC channel and Audio Output channel that use the corresponding Audio Input device audio data before calling this interface, otherwise this interface may fail.
【Example】
None.
10.3.2.13. CVI_AI_ClrPubAttr¶
Clear the Pub property.
CVI_S32 CVI_AI_ClrPubAttr(AUDIO_DEV AiDevId);
【Parameter】
Parameter |
Input/Output |
AiDevId |
Input |
【Return Value】
Return Value |
0 |
Success. |
Non 0 |
【Requirement】
You need to stop the device before clearing its properties.
Before clearing the device properties, it is recommended to stop all internal connected or user-get mode actions to avoid abnormal behavior caused by the bottom layer still moving audio frames.
【Example】
None.
10.3.2.14. CVI_AI_SaveFile¶
CVI_S32 CVI_AI_SaveFile(AUDIO_DEV AiDevId, AI_CHN AiChn, const AUDIO_SAVE_FILE_INFO_S *pstSaveFileInfo);
【Parameter】
Parameter |
Input/Output |
AiDevId |
Input |
AiChn |
Input |
pstSaveFileInfo |
Pointer to audio recording file property structure |
Input |
【Return Value】
Return Value |
0 |
Success. |
Non 0 |
【Requirement】
This interface is only used for dumping Audio Input in Audio Input-AENC and Audio Input-Audio Output non-system binding mode.
【Example】
None.
10.3.2.15. CVI_AI_QueryFileStatus¶
CVI_S32 CVI_AI_QueryFileStatus(AUDIO_DEV AiDevId, AI_CHN AiChn, AUDIO_FILE_STATUS_S *pstFileStatus);
【Parameter】
Parameter |
Input/Output |
AiDevId |
Input |
AiChn |
Input |
pstFileStatus |
Pointer to file status property structure |
Output |
【Return Value】
Return Value |
0 |
Success. |
Non 0 |
【Requirement】
This interface is mainly used for debugging, which is not used in general processes.
This interface is used to query whether the audio input channel is in the state of saving files after users call CVI_AI_SaveFile to save files.
If bSaving of pstFileStatus is CVI_TRUE, it indicates that specified size has not been reached;
CVI_FALSE indicates that it has reached the specified size.
【Example】
None.
10.3.2.16. CVI_AI_EnableAecRefFrame¶
frame.
CVI_S32 CVI_AI_EnableAecRefFrame(AUDIO_DEV AiDevId, AI_CHN AiChn, AUDIO_DEV AoDevId, AO_CHN AoChn);
【Parameter】
Parameter |
Input/Output |
AiDevId |
Input |
AiChn |
Input |
AoDevId |
Audio Output device number used to obtain AEC reference frame. |
Input |
AoChn |
Audio Output channel number used to obtain AEC reference frame. |
Input |
【Return Value】
Return Value |
0 |
Success. |
Non 0 |
【Requirement】
None.
【Example】
None.
10.3.2.17. CVI_AI_DisableAecRefFrame¶
frame.
CVI_S32 CVI_AI_DisableAecRefFrame(AUDIO_DEV AiDevId, AI_CHN AiChn);
【Parameter】
Parameter |
Input/Output |
AiDevId |
Input |
AiChn |
Input |
【Return Value】
Return Value |
0 |
Success. |
Non 0 |
【Requirement】
None.
【Example】
None.
10.3.2.18. CVI_AI_SetVolume¶
Set the input volume.
CVI_S32 CVI_AI_SetVolume(AUDIO_DEV AiDevId, CVI_S32 s32VolumeStep);
【Parameter】
Parameter |
Input/Output |
AiDevId |
Input |
s32VolumeStep |
Step size for input volume amplification [24-0, 0:mute]. |
Input |
【Return Value】
Return Value |
0 |
Success. |
Non 0 |
【Requirement】
Library files: libcvi_audio.a/libcvi_audio.so
None.
【Example】
None.
10.3.2.19. CVI_AI_GetVolume¶
Get the input volume.
CVI_S32 CVI_AI_GetVolume(AUDIO_DEV AiDevId, CVI_S32 *ps32VolumeStep);
【Parameter】
Parameter |
Input/Output |
AiDevId |
Input |
ps32VolumeStep |
Pointer to step size for input volume amplification [24-0, 0:mute]. |
Output |
【Return Value】
Return Value |
0 |
Success. |
Non 0 |
【Requirement】
None.
【Example】
None.
10.3.3. Voice Quality Enhancement API¶
CVI_AI_SetVqeAttr: Set Audio Input voice quality enhancement related attributes.
CVI_AI_SetTalkVqeAttr: Set voice-related properties of Audio Input speech quality enhancement function.
CVI_AI_GetTalkVqeAttr: Get voice-related properties of Audio Input speech quality enhancement function.
CVI_AI_SetRecordVqeAttr: Set voice-related properties of Audio Input recording quality enhancement function (currently not supported).
CVI_AI_GetRecordVqeAttr: Get voice-related properties of Audio Input recording quality enhancement function (currently not supported).
CVI_AI_EnableVqe: Enable Audio Input voice quality enhancement.
CVI_AI_DisableVqe: Disable Audio Input voice quality enhancement.
CVI_AI_SetTrackMode: Set channel mode.
CVI_AI_GetTrackMode: Get channel mode.
CVI_AO_SetVqeAttr: Set the voice quality enhancement attributes of Audio Output.
CVI_AO_GetVqeAttr: Get the voice quality enhancement attributes of Audio Output.
CVI_AO_EnableVqe: Enable the voice quality enhancement of Audio Output.
CVI_AO_DisableVqe: Disable the voice quality enhancement of Audio Output
CVI_VQE_PathSelect: Setting VQE algorithm path.
10.3.3.1. CVI_AI_SetVqeAttr¶
CVI_S32 CVI_AI_SetVqeAttr(AUDIO_DEV AiDevId, AI_CHN AiChn, AUDIO_DEV AoDevId, AO_CHN AoChn, AI_VQE_CONFIG_S *pstVqeConfig);
【Parameter】
Parameter |
Input/Output |
AiDevId |
Input |
AiChn |
Input |
AoDevId |
Audio Output device number for echo cancellation. |
Input |
AoChn |
Audio Output channel number for echo cancellation. |
Input |
pstVqeConfig |
Pointer to Audio Input sound quality enhancement configuration structure. |
Input |
【Return Value】
Return Value |
0 |
Success. |
Non 0 |
【Requirement】
Library files: libcvi_audio.a, libcvi_RES1.so, libcvi_vqe.so,
Before enabling the sound quality enhancement function, you must first set the relevant properties of the sound quality enhancement function of the corresponding Audio Input channel.
Before setting the relevant attributes of Audio Input sound quality enhancement function, the corresponding Audio Input channel must be enabled.
The sound quality enhancement function of the same Audio Input channel does not support dynamic setting of attributes.
To reset the relevant attributes of the sound quality enhancement function of the Audio Input channel, you need to turn off the sound quality function of the Audio Input channel first, and then set the relevant attributes of the sound quality enhancement function of the Audio Input channel.
【Example】
None.
10.3.3.2. CVI_AI_SetTalkVqeAttr¶
CVI_S32 CVI_AI_SetTalkVqeAttr(AUDIO_DEV AiDevId, AI_CHN AiChn, AUDIO_DEV AoDevId, AO_CHN AoChn, AI_TALKVQE_CONFIG_S *pstVqeConfig);
【Parameter】
Parameter |
Input/Output |
AiDevId |
Input |
AiChn |
Input |
AoDevId |
Input |
AoChn |
Input |
pstVqeConfig |
Audio input sound quality enhancement configuration structure pointer. |
Input |
【Return Value】
Return Value |
0 |
Success. |
Non 0 |
【Requirement】
Library files: libcvi_audio.a, libcvi_RES1.so, libcvi_vqe.so, libaec.so
Talk VQE is mainly used in IPC scenarios.
【Example】
None.
10.3.3.3. CVI_AI_GetTalkVqeAttr¶
CVI_S32 CVI_AI_GetTalkVqeAttr(AUDIO_DEV AiDevId, AI_CHN AiChn, AI_TALKVQE_CONFIG_S *pstVqeConfig);
【Parameter】
Parameter |
Input/Output |
AiDevId |
Input |
AiChn |
Input |
pstVqeConfig |
Output |
【Return Value】
Return Value |
0 |
Success. |
Non 0 |
【Requirement】
Before acquiring the sound quality enhancement related attributes, it is necessary to set the sound quality enhancement related attributes of the corresponding Audio Input channel.
【Example】
None.
10.3.3.4. CVI_AI_SetRecordVqeAttr¶
CVI_S32 CVI_AI_SetRecordVqeAttr(AUDIO_DEV AiDevId, AI_CHN AiChn, const AI_RECORDVQE_CONFIG_S *pstVqeConfig);
【Parameter】
Parameter |
Input/Output |
AiDevId |
Input |
AiChn |
Input |
pstVqeConfig |
Input |
【Return Value】
Return Value |
0 |
Success. |
Non 0 |
【Requirement】
At present, the voice algorithm of CVI182X is mainly set by calling CVI_AI_SetTalkVqeAttr.
That Users use this RecordVqeAttr (CVI_AI_SetRecordVqeAttr/ GetRecordVqeAttr) may not support the algorithm or cannot be set, so it is not recommended.
【Example】
None.
10.3.3.5. CVI_AI_GetRecordVqeAttr¶
CVI_AI_GetRecordVqeAttr (AUDIO_DEV AiDevId, AI_CHN AiChn, const AI_RECORDVQE_CONFIG_S *pstVqeConfig);
【Parameter】
Parameter |
Input/Output |
AiDevId |
Input |
AiChn |
Input |
pstVqeConfig |
Output |
【Return Value】
Return Value |
0 |
Success. |
Non 0 |
【Requirement】
At present, the voice algorithm of CVI182x is mainly set by calling CVI_AI_SetTalkVqeAttr.
【Example】
None.
10.3.3.6. CVI_AI_EnableVqe¶
CVI_S32 CVI_AI_EnableVqe(AUDIO_DEV AiDevId, AI_CHN AiChn);
【Parameter】
Parameter |
Input/Output |
AiDevId |
Input |
AiChn |
Input |
【Return Value】
Return Value |
0 |
Success. |
Non 0 |
【Requirement】
Before enabling the sound quality enhancement function, the corresponding Audio Input channel must be enabled.
When the sound quality enhancement function of the same Audio Input channel is enabled several times, Success is returned.
After Audio Input channel is disabled, if Audio Input channel is re enabled and sound quality enhancement is used, this interface should be called to re enable sound quality enhancement.
【Example】
None.
10.3.3.7. CVI_AI_DisableVqe¶
CVI_S32 CVI_AI_DisableVqe(AUDIO_DEV AiDevId, AI_CHN AiChn);
【Parameter】
Parameter |
Input/Output |
AiDevId |
Input |
AiChn |
Input |
【Return Value】
Return Value |
0 |
Success. |
Non 0 |
【Requirement】
When Audio Input sound quality enhancement is no longer used, this interface should be called to disable it.
【Example】
None.
10.3.3.8. CVI_AI_SetTrackMode¶
Set Audio Input channel mode.
CVI_S32 CVI_AI_SetTrackMode(AUDIO_DEV AiDevId, AUDIO_TRACK_MODE_E enTrackMode);
【Parameter】
Parameter |
Input/Output |
AiDevId |
Input |
enTrackMode |
typedef enum _AUDIO_TRACK_MODE_E { AUDIO_TRACK_NORMAL = 0, AUDIO_TRACK_BOTH_LEFT = 1, AUDIO_TRACK_BOTH_RIGHT = 2, AUDIO_TRACK_EXCHANGE = 3, AUDIO_TRACK_MIX = 4, AUDIO_TRACK_LEFT_MUTE = 5, AUDIO_TRACK_RIGHT_MUTE = 6, AUDIO_TRACK_BOTH_MUTE = 7, AUDIO_TRACK_BUTT } AUDIO_TRACK_MODE_E; |
Input |
【Return Value】
Return Value |
0 |
Success. |
Non 0 |
【Requirement】
It supports acquiring channel mode when Audio Input device works in I2S mode,
but not in PCM mode.
Call this interface after Audio Input device is enabled successfully.
TrackMode capability is related to audio codec.
If the client uses its own codec, the settings may be different.
【Example】
None.
10.3.3.9. CVI_AI_GetTrackMode¶
Get Audio Input channel mode.
CVI_S32 CVI_AI_GetTrackMode(AUDIO_DEV AiDevId, AUDIO_TRACK_MODE_E *penTrackMode);
【Parameter】
Parameter |
Input/Output |
AiDevId |
Input |
enTrackMode |
Output |
【Return Value】
Return Value |
0 |
Success. |
Non 0 |
【Requirement】
It supports acquiring channel mode when Audio Input device works in I2S mode,but not in PCM mode.
【Example】
None.
10.3.3.10. CVI_AO_SetVqeAttr¶
CVI_S32 CVI_AO_SetVqeAttr(AUDIO_DEV AoDevId, AO_CHN AoChn, AO_VQE_CONFIG_S *pstVqeConfig);
【Parameter】
Parameter |
Input/Output |
AoDevId |
Input |
AoChn |
Audio output channel number |
Input |
pstVqeConfig |
Audio output sound quality enhancement configuration structure pointer |
Input |
【Return Value】
Return Value |
0 |
Success. |
Non 0 |
【Requirement】
Library files: libcvi_audio.a、libaec.so、libcvi_RES1.so
Before enabling the sound quality enhancement, you must first set the sound quality enhancement related properties of the corresponding AP channel.
The corresponding Audio Output channel must be enabled before setting the related attributes of the sound quality enhancement function of Audio Output.
【Example】
None.
10.3.3.11. CVI_AO_GetVqeAttr¶
CVI_S32 CVI_AO_GetVqeAttr(AUDIO_DEV AoDevId, AO_CHN AoChn, AO_VQE_CONFIG_S *pstVqeConfig);
【Parameter】
Parameter |
Input/Output |
AoDevId |
Input |
AoChn |
Input |
pstVqeConfig |
Output |
【Return Value】
Return Value |
0 |
Success. |
Non 0 |
【Requirement】
Library files: libcvi_audio.a、libaec.so、libcvi_RES1.so、libcvi_vqe.so
Before obtaining the sound quality enhancement related attributes, you must first set the sound quality enhancement related attributes of the corresponding Audio Output channel.
【Example】
None.
10.3.3.12. CVI_AO_EnableVqe¶
CVI_S32 CVI_AO_EnableVqe(AUDIO_DEV AoDevId, AO_CHN AoChn);
【Parameter】
Parameter |
Input/Output |
AoDevId |
Input |
AoChn |
Input |
【Return Value】
Return Value |
0 |
Success. |
Non 0 |
【Requirement】
The corresponding Audio Output channel must be enabled before enabling sound quality enhancement.
After the Audio Output channel is disabled, if you re enable the Audio Output channel again and use the sound quality enhancement function, you need to call this interface to re enable the sound quality enhancement function.
【Example】
None.
10.3.3.13. CVI_VQE_PathSelect¶
CVI_S32 CVI_VQE_PathSelect(E_VQE_ALGO_PATH eVqePath);
【Parameter】
Parameter |
Input/Output |
AoDevId |
Input |
【Return Value】
Return Value |
0 |
Success. |
Non 0 |
【Requirement】
This API is only available on ICs that support it and must be enabled before use.
【Example】
None.
10.3.4. Audio Output¶
Audio output (AO) mainly realizes the functions of enabling audio output device and sending audio frame to output channel.
The API is listed below with additional details.
CVI_AO_SetPubAttr: Set Audio Output device properties.
CVI_AO_GetPubAttr: Get Audio Output device properties.
CVI_AO_Enable: Enable Audio Output devices.
CVI_AO_Disable: Disable Audio Output devices.
CVI_AO_EnableChn: Enable Audio Output channel.
CVI_AO_DisableChn: Disable Audio Output channel.
CVI_AO_SendFrame: Send Audio Output audio frame.
CVI_AO_EnableReSmp: Enable Audio Output resampling.
CVI_AO_DisableReSmp: Disable Audio Output resampling.
CVI_AO_PauseChn: Pause Audio Output channel.
CVI_AO_ResumeChn: Restore Audio Output channel.
CVI_AO_ClearChnBuf: Clear the current audio data buffer in Audio Output channel.
CVI_AO_QueryChnStat: Query the current status of the audio data block in Audio Output channel.
CVI_AO_SetTrackMode: Set the Audio Output device channel mode.
CVI_AO_GetTrackMode: Get the Audio Output device channel mode.
CVI_AO_SetVolume: Set the volume of Audio Output device.
CVI_AO_GetVolume: Get the volume of Audio Output device.
CVI_AO_SetMute: Set the mute status of an Audio Output device
CVI_AO_GetMute: Get the mute status of an Audio Output device
CVI_AO_SaveFile: Enable audio output file saving functionality. (this function is not supported at present.Users can use CVI_AO_SendFrame to save files.);
CVI_AO_ClrPubAttr: Clear Audio Output device properties.
10.3.4.1. CVI_AO_SetPubAttr¶
CVI_S32 CVI_AO_SetPubAttr(AUDIO_DEV AoDevId,const AIO_ATTR_S *pstAttr);
【Parameter】
Parameter |
Input/Output |
AoDevId |
Input |
pstAttr |
Audio output device properties. |
Input |
【Return Value】
Return Value |
0 |
Success. |
Non 0 |
【Requirement】
Before setting properties, you need to ensure that Audio Output is disabled. If it is enabled, you need to disable Audio Output devices first.
Audio Output must cooperate with DA in order to work normally. Users must know the relationship between the data format and channel sent by DA in order to send data from the correct channel.
u32ClkSel does not need to be configured under CV182x processor.
In the main mode of Audio Output device, the key configuration items that determine the output clock of Audio Output device are sampling rate, sampling precision and number of channels.
The sampling precision multiplied by the number of channels is the bit width of one sampling of the timing sequence of Audio Output device.
CV182x extended flag is invalid for Audio Output device, so it does not need to be set.
For other items in Audio Output device attribute structure, please refer to the description of related interfaces in Audio Input module.
【Example】
None.
10.3.4.2. CVI_AO_GetPubAttr¶
CVI_S32 CVI_AO_GetPubAttr(AUDIO_DEV AoDevId, AIO_ATTR_S *pstAttr);
【Parameter】
Parameter |
Input/Output |
AoDevId |
Input |
pstAttr |
Output |
【Return Value】
Return Value |
0 |
Success. |
Non 0 |
【Requirement】
Header files: -cvi_comm_aio.h, cvi_audio.h
Library files: ibcvi_audio.a
The property obtained is the property of the previous configuration.
If the property has never been configured, the error that the property is not configured is returned.
【Example】
CVI_S32 s32ret;
AUDIO_DEV AoDevId = 0;
AIO_ATTR_S stAttr;
s32ret = CVI_AO_GetPubAttr(AoDevId, &stAttr);
if(s32ret != CVI_SUCCESS) {
printf("get ao %d attr err:0x%x\n", AoDevId,s32ret);
return s32ret; }
10.3.4.3. CVI_AO_Enable¶
Enables Audio Output devices.
CVI_S32 CVI_AO_Enable(AUDIO_DEV AoDevId);
【Parameter】
Parameter |
Input/Output |
AoDevId |
Input |
【Return Value】
Return Value |
0 |
Success. |
Non 0 |
【Requirement】
Require Audio Output device properties to be configured before enabling, otherwise an error with properties not configured will be returned.
If the Audio Output device is enabled, Success is returned.
【Example】
CVI_S32 i;
CVI_S32 s32Ret;
s32Ret = CVI_AO_SetPubAttr(AoDevId, pstAioAttr);
if (s32Ret != CVI_SUCCESS) {
printf("%s: CVI_AO_SetPubAttr(%d) failed with %#x!\n", __func__,
AoDevId, s32Ret);
return CVI_FAILURE;
s32Ret = CVI_AO_Enable(AoDevId);
printf("%s: CVI_AO_Enable(%d) failed with %#x!\n", __func__, AoDevId,
s32Ret);
return CVI_FAILURE;
for (i = 0; i < s32AoChnCnt; i++) {
s32Ret = CVI_AO_EnableChn(AoDevId, i / (pstAioAttr->enSoundmode + 1));
printf("%s: CVI_AO_EnableChn(%d) failed with %#x!\n", __func__, i,
s32Ret);
return CVI_FAILURE;
s32Ret = CVI_AO_DisableReSmp(AoDevId, i);
s32Ret |= CVI_AO_EnableReSmp(AoDevId, i, enInSampleRate);
printf("%s: CVI_AO_EnableReSmp(%d,%d) failed with %#x!\n", __func__,
AoDevId, i, s32Ret);
return CVI_FAILURE;
s32Ret = CVI_AO_EnableChn(AoDevId, AO_SYSCHN_CHNID);
s32Ret);
return CVI_FAILURE;
10.3.4.4. CVI_AO_Disable¶
Deactivate Audio Output device.
CVI_S32 CVI_AO_Disable(AUDIO_DEV AoDevId);
【Parameter】
Parameter |
Input/Output |
AoDevId |
Input |
【Return Value】
Return Value |
0 |
Success. |
Non 0 |
【Requirement】
All Audio Output channels under the device must be disabled before the Audio Output device can be disabled.
【Example】
None.
10.3.4.5. CVI_AO_EnableChn¶
CVI_S32 CVI_AO_EnableChn(AUDIO_DEV AoDevId, AO_CHN AoChn);
【Parameter】
Parameter |
Input/Output |
AoDevId |
Input |
AoChn |
Audio output channel number.The supported channel range is determined by the maximum number of channels u32ChnCnt in the Audio Output device properties and the channel mode enSoundmode. |
Input |
【Return Value】
Return Value |
0 |
Success. |
Non 0 |
【Requirement】
Before enabling the Audio Output channel, the Audio Output device to which it belongs must be enabled, otherwise an error code that the device did not start is returned.
【Example】
None.
10.3.4.6. CVI_AO_DisableChn¶
CVI_S32 CVI_AO_DisableChn(AUDIO_DEV AoDevId, AO_CHN AoChn);
【Parameter】
Parameter |
Input/Output |
AoDevId |
Input |
AoChn |
Input |
【Return Value】
Return Value |
0 |
Success. |
Non 0 |
【Requirement】
none
【Example】
None.
10.3.4.7. CVI_AO_SendFrame¶
CVI_S32 _AO_SendFrame(AUDIO_DEV AoDevId, AO_CHN AoChn, const AUDIO_FRAME_S *pstData, CVI_S32 s32MilliSec);
【Parameter】
Parameter |
Input/Output |
AoDevId |
Input |
AoChn |
Input |
pstData |
Pointer to Audio frame structure. |
Input |
s32MilliSec |
The timeout for sending data -1 indicates blocking mode; 0 means non-blocking mode; >0 indicates blocking s32MilliSec 毫秒 Returning an error if a timeout occurs. |
Input |
【Return Value】
Return Value |
0 |
Success. |
Non 0 |
【Requirement】
This interface is used to actively send audio frames to Audio Output output.
The Audio Output channel has been bound to Audio Input or ADEC through the system binding (CVI_SYS_Bind) interface, and calling this interface is not necessary and not recommended.
When calling this interface to send audio frames to the Audio Output output channel, you must first enable the corresponding Audio Output channel.
【Example】
None.
10.3.4.8. CVI_AO_EnableReSmp¶
CVI_S32 CVI_AO_EnableReSmp(AUDIO_DEV AoDevId, AO_CHN AoChn, AUDIO_SAMPLE_RATE_E enInSampleRate);
【Parameter】
Parameter |
Input/Output |
AoDevId |
Input |
AoChn |
Input |
enInSampleRate |
Input sampling rate for audio resampling. |
Input |
【Return Value】
Return Value |
0 |
Success. |
Non 0 |
【Requirement】
This API is not supported when CVI AUD SYS Bind is used
This interface should be called to enable resampling after the Audio Output channel is enabled and before binding the Audio Output channel.
Resampling is allowed to be enabled repeatedly, but the resampled input sampling rate of the post-configuration must be guaranteed to be the same as the previously configured resampled input sampling rate.
If the Audio Output channel is disabled and the resampling function is enabled again, you need to invoke this interface to enable resampling again.
The input sampling rate for Audio Output resampling must be different from the sampling rate for the Audio Output device property configuration.
【Example】
None.
10.3.4.9. CVI_AO_DisableReSmp¶
CVI_S32 CVI_AO_DisableReSmp(AUDIO_DEV AoDevId, AO_CHN AoChn);
【Parameter】
Parameter |
Input/Output |
AoDevId |
Input |
AoChn |
Input |
【Return Value】
Return Value |
0 |
Success. |
Non 0 |
【Requirement】
If Audio Output resampling is no longer used, this interface should be called to disable it.
【Example】
None.
10.3.4.10. CVI_AO_PauseChn¶
CVI_S32 CVI_AO_PauseChn(AUDIO_DEV AoDevId, AO_CHN AoChn);
【Parameter】
Parameter |
Input/Output |
AoDevId |
Input |
AoChn |
Input |
【Return Value】
Return Value |
0 |
Success. |
Non 0 |
【Requirement】
When the Audio Output channel is paused, if the bound ADEC channel continues to send audio frame data to this channel, the transmitted audio frame data will be blocked.
If the bound Audio Input channel continues to send audio frame data to this channel, the audio frame is put into the buffer when the channel buffer is not full, and the audio frame is discarded when it is full.
Calling this interface to pause the Audio Output channel is not allowed when the Audio Output channel is disabled.
【Example】
None.
10.3.4.11. CVI_AO_ResumeChn¶
CVI_S32 CVI_AO_ResumeChn(AUDIO_DEV AoDevId, AO_CHN AoChn);
【Parameter】
Parameter |
Input/Output |
AoDevId |
Input |
AoChn |
Input |
【Return Value】
Return Value |
0 |
Success. |
Non 0 |
【Requirement】
The Audio Output channel can be restored by calling when this interface is paused.
If the Audio Output channel is in the suspended or enabled state, the interface is invoked successfully.
Otherwise the call will return an error.
【Example】
None.
10.3.4.12. CVI_AO_ClearChnBuf¶
Clear the current audio data buffer in the Audio Output channel.
CVI_S32 CVI_AO_ClearChnBuf(AUDIO_DEV AoDevId, AO_CHN AoChn);
【Parameter】
Parameter |
Input/Output |
AoDevId |
Input |
AoChn |
Input |
【Return Value】
Return Value |
0 |
Success. |
Non 0 |
【Requirement】
Call this interface after the Audio Output channel is successfully enabled.
In order to completely clear all buffer data on decoding playback path, this interface should be used in conjunction with the CVI_ADEC_ClearChnBuf interface.
【Example】
None.
10.3.4.13. CVI_AO_QueryChnStat¶
Query the current status of audio data block in the Audio Output channel.
CVI_S32 CVI_AO_QueryChnStat(AUDIO_DEV AoDevId, AO_CHN AoChn, AO_CHN_STATE_S *pstStatus);
【Parameter】
Parameter |
Input/Output |
AoDevId |
Audio Output device number. The device number is preset to 0, and setting it to a value greater than 2 will return an error, unless customization requires expansion. |
Input |
AoChn |
Input |
pstStatus |
Pointer to block status structure |
Input |
【Return Value】
Return Value |
0 |
Success. |
Non 0 |
【Requirement】
【Example】
None.
10.3.4.14. CVI_AO_SetTrackMode¶
Set Audio Output device channel mode.
CVI_S32 CVI_AO_SetTrackMode(AUDIO_DEV AoDevId, AUDIO_TRACK_MODE_E enTrackMode);
【Parameter】
Parameter |
Input/Output |
AoDevId |
Input |
enTrackMode |
Audio device channel mode. |
Input |
【Return Value】
Return Value |
0 |
Success. |
Non 0 |
【Requirement】
Call this interface after the Audio Output device is successfully enabled.
Audio Output supports setting the channel mode when it works in I2S mode, but does not support setting the channel mode when it works in PCM mode.
【Example】
CVO_S32 s32Ret;
AUDIO_DEV AoDev = 0;
AUDIO_TRACK_MODE_E enTrackMode = AUDIO_TRACK_NORMAL;
AUDIO_TRACK_MODE_E temp;
s32Ret = CVI_AO_SetTrackMode(AoDev, enTrackMode);
if (CVI_SUCCESS != s32Ret) {
printf("Ao set track mode failure! AoDev: %d, enTrackMode: %d, s32Ret: 0x%x.\n", AoDev, enTrackMode, s32Ret);
return s32Ret;
s32Ret = CVI_AO_GetTrackMode(AoDev, &temp);
if (s32Ret!=CVI_SUCCESS) {
printf("Ao get track mode failure! AoDev: %d, s32Ret: 0x%x.\n", AoDev, s32Ret);
return s32Ret;
10.3.4.15. CVI_AO_GetTrackMode¶
Gets the channel mode of the Audio Output device.
CVI_S32 CVI_AO_GetTrackMode(AUDIO_DEV AoDevId, AUDIO_TRACK_MODE_E *penTrackMode);
【Parameter】
Parameter |
Input/Output |
AoDevId |
Input |
enTrackMode |
Output |
【Return Value】
Return Value |
0 |
Success. |
Non 0 |
【Requirement】
【Example】
None.
10.3.4.16. CVI_AO_SetVolume¶
Set Audio Output device volume.
CVI_S32 CVI_AO_SetVolume(AUDIO_DEV AoDevId, CVI_S32 s32VolumeDb);
【Parameter】
Parameter |
Input/Output |
AoDevId |
Input |
s32VolumeDb |
The volume range is from 32 to 0, which corresponds to a gain range from 0dB to -22.5dB, with a decrease of 1.5dB for each step. |
Input |
【Return Value】
Return Value |
0 |
Success. |
Non 0 |
【Requirement】
【Example】
None.
10.3.4.17. CVI_AO_GetVolume¶
Gets the volume size of the Audio Output device.
CVI_S32 CVI_AO_GetVolume(AUDIO_DEV AoDevId, CVI_S32 *ps32VolumeDb);
【Parameter】
Parameter |
Input/Output |
AoDevId |
Input |
ps32VolumeDb |
Pointer to the Ao device volume. The volume range is from 32 to 0, which corresponds to a gain range from 0dB to -22.5dB, with a decrease of 1.5dB for each step. |
Output |
【Return Value】
Return Value |
0 |
Success. |
Non 0 |
【Requirement】
【Example】
None.
10.3.4.18. CVI_AO_SetMute¶
CVI_S32 CVI_AO_SetMute(AUDIO_DEV AoDevId, CVI_BOOL bEnable, const AUDIO_FADE_S *pstFade);
【Parameter】
Parameter |
Input/Output |
AoDevId |
Input |
bEnable |
Whether the audio device is muted. CVI_TRUE: Enable mute function; CVI_FALSE: Turn off mute function |
Input |
pstFade |
Fade in and out structure pointers. |
Input |
【Return Value】
Return Value |
0 |
Success. |
Non 0 |
【Requirement】
【Example】
None.
10.3.4.19. CVI_AO_GetMute¶
Gets the mute status of the Audio Output device.
CVI_S32 CVI_AO_GetMute(AUDIO_DEV AoDevId, CVI_BOOL *pbEnable, AUDIO_FADE_S *pstFade);
【Parameter】
Parameter |
Input/Output |
AoDevId |
Input |
bEnable |
Audio device mute state pointer. |
Output |
pstFade |
Output |
【Return Value】
Return Value |
0 |
Success. |
Non 0 |
【Requirement】
【Example】
None.
10.3.4.20. CVI_AO_SaveFile¶
This function is not supported at present. Users can use
CVI_S32 CVI_AO_SaveFile(AUDIO_DEV AoDevId, AO_CHN AoChn, AUDIO_SAVE_FILE_INFO_S *pstSaveFileInfo);
【Parameter】
【Return Value】
【Requirement】
Header files:
Library files:
【Example】
None.
10.3.4.21. CVI_AO_ClrPubAttr¶
CVI_S32 CVI_AO_ClrPubAttr(AUDIO_DEV AoDevId);
【Parameter】
Parameter |
Input/Output |
AoDevId |
Input |
【Return Value】
Return Value |
0 |
Success. |
Non 0 |
【Requirement】
Audio Input device and Audio Output device clocks do not need to be set.
【Example】
None.
10.3.5. Audio Encoding¶
Audio encoding is mainly dedicated to voice frame data conversion.
Cvitek supports G.711, G.726, LDPCM-related encoding.
The encoded voice frame data is small, but the voice encoding belongs to lossy compression, which results in different sound quality.
The bit rate/sample rate used by different encoding varies.
Users need to know the specifications of the encoding protocol and set the corresponding API.
Otherwise the function will return an error.
Codec |
Sampling Rat e(KHZ) |
Ban dwidth(kbps) |
Nominal Ban dwidth(kbps) |
License |
G.711* |
8 |
64 |
87.2 |
Open Source |
G.726 |
8 |
16/24/32/40 |
47.2/55.2 |
Open Source |
*G.711 include a-law/mu-law
The AENC module provides the following APIs:
CVI_AENC_CreateChn: Create an audio encoding channel.
CVI_AENC_DestroyChn: Destroy the audio encoding channel.
CVI_AENC_SendFrame: Send Audio Coded Audio Frames
CVI_AENC_GetStream: Gets the audio encoding stream.
CVI_AENC_ReleaseStream: Release the audio encoding stream.
CVI_AENC_SaveFile: Enabling channel file recording functionality before audio encoding
CVI_AENC_QueryFileStatus: Checking the file storage status of the audio encoding channel
CVI_AENC_GetStreamBufInfo: Get information about the audio stream buffer.
CVI_AENC_SetMute: Set the mute status of an AENC (Audio Encode) channel.
CVI_AENC_GetMute: Get the mute status of an AENC (Audio Encode) channel
10.3.5.1. CVI_AENC_CreateChn¶
CVI_S32 CVI_AENC_CreateChn(AENC_CHN AeChn, const AENC_CHN_ATTR_S *pstAttr);
【Parameter】
Parameter |
Input/Output |
AeChn |
Encoding device channel number. Range of values: [0, AENC_MAX_CHN_NUM] |
Input |
pstAttr |
Encoded Channel Property Pointer |
Input |
【Return Value】
Return Value |
0 |
Success. |
Non 0 |
【Requirement】
Header files: cvi_comm_aio.h, cvi_audio.h, cvi_comm_aenc.h
Library files: libcvi_audio.a, libcvi_transcode.so, libcvi_RES1.so
Currently supports G711, G726, ADPCM
The format supports 16-bit S16LE, and others are not supported.
Set Audio Input attribute/AENC attribute.
If you want to use it after VQE, set the length of the sound frame to a multiple of 160.
To comply with the Cvitek VQE specification.
Some of the attributes of audio encoding need to match the attributes of the input audio data, such as sampling rate, frame length (number of sampling points per frame), etc.
The buffer size is expressed in frames.
The Value range is [2, MAX_BUFFERING_DEPTH].
You are advised to set the value to more than 10.
Too small buffer configuration may cause exceptions such as frame loss.
【Example】
None.
10.3.5.2. CVI_AENC_DestroyChn¶
Destroy audio codec pass.
CVI_S32 CVI_AENC_DestroyChn(AENC_CHN AeChn);
【Parameter】
Parameter |
Input/Output |
AeChn |
Encoding device channel number. Value Range: [0, AENC_MAX_CHN_NUM] |
Input |
【Return Value】
Return Value |
0 |
Success. |
Non 0 |
【Requirement】
Header files: cvi_comm_aio.h, cvi_audio.h、cvi_comm_aenc.h
The call to this function is invalid if the channel is not created.
If the channel is destroyed while obtaining/releasing the stream or sending the frame, a failure will be returned.
Users should pay attention when synchronizing the process
【Example】
None.
10.3.5.3. CVI_AENC_SendFrame¶
Send audio encoded audio frames.
CVI_S32 CVI_AENC_SendFrame(AENC_CHN AeChn, const AUDIO_FRAME_S *pstFrm, const AEC_FRAME_S *pstAecFrm);
【Parameter】
Parameter |
Input/Output |
AeChn |
Input |
pstFrm |
Audio frame structure pointer. |
Input |
pstAecFrm |
Input |
【Return Value】
Return Value |
0 |
Success. |
Non 0 |
【Requirement】
pstAecFrm can be set to NULL if echo cancellation is not required.
This interface is used to actively send audio frames for encoding. If the AENC channel is already bound to Audio Input through the system binding (CVI_SYS_Bind) interface, calling this interface is unnecessary and not advised.
【Example】
s32Ret = CVI_AI_GetChnParam(AiDev, AiChn, &stAiChnPara);
printf("%s: Get ai chn param failed\n", __func__);
return NULL;
stAiChnPara.u32UsrFrmDepth = 10;
s32Ret = CVI_AI_SetChnParam( AiDev, AiChn, &stAiChnPara);
printf("%s: set ai chn param failed\n", __func__);
return NULL;
while ( 1) {
/* get frame from ai chn */
memset(&stAecFrm, 0, sizeof(AEC_FRAME_S));
s32Ret = CVI_AI_GetFrame( AiDev, AiChn, &stFrame,
&stAecFrm, CVI_FALSE);
printf("CVI_AI_GetFrame none!!\n");
continue;
/* send frame to encoder */
if ( bSendAenc == CVI_TRUE) {
s32Ret = CVI_AENC_SendFrame( AencChn, &stFrame, &stAecFrm);
printf("%s: CVI_AENC_SendFrame(%d), failed with %#x!\n",
__func__, AencChn, s32Ret);
bStart = CVI_FALSE;
return NULL;
/* send frame to ao */
/* If owner toggle bSendAenc, do not toggle bSendAo */
/* You cannot send encode frame to CVI_AO_SendFrame */
/* It cannot play out encode frame by only AO_SendFrame*/
if ( bSendAo == CVI_TRUE) {
s32Ret = CVI_AO_SendFrame( AoDev, AoChn, &stFrame, 1000);
printf("%s: CVI_AO_SendFrame(%d, %d), failed with %#x!\n",
__func__, AoDev, AoChn, s32Ret);
bStart = CVI_FALSE;
return NULL;
/* finally you must release the stream */
s32Ret = CVI_AI_ReleaseFrame( AiDev, AiChn, &stFrame,
&stAecFrm);
printf("%s: CVI_AI_ReleaseFrame(%d, %d), failed with %#x!\n",
__func__, AiDev, AiChn, s32Ret);
bStart = CVI_FALSE;
return NULL;
10.3.5.4. CVI_AENC_GetStream¶
Gets the encoded stream.
CVI_S32 CVI_AENC_GetStream(AENC_CHN AeChn, AUDIO_STREAM_S *pstStream, CVI_S32 s32MilliSec);
【Parameter】
Parameter |
Input/Output |
AeChn |
Input |
pstStream |
The obtained audio stream. |
Output |
s32MilliSec |
Timeout to acquring data 1 indicates blocking mode and waits until there is no data; 0 means non-blocking mode, error returns when no data is available; >0 indicates blocking s32MilliSec milliseconds. Returning an error if a timeout occurs |
Input |
【Return Value】
Return Value |
0 |
Success. |
Non 0 |
【Requirement】
The code stream can be obtained only after the channel is created. Otherwise, a direct failure is returned.
If the channel is destroyed in the process of obtaining the code stream, a failure is returned immediately.
The value of s32MilliSec must be greater than or equal to -1, blocking mode for data when the value is equal to -1, non-blocking mode for data when it is equal to 0, and blocking s32MilliSec milliseconds when greater than 0, returning a timeout and reporting if no data.
【Example】
None.
10.3.5.5. CVI_AENC_ReleaseStream¶
Release the stream obtained from the audio encoding channel.
CVI_S32 CVI_AENC_ReleaseStream(AENC_CHN AeChn, const AUDIO_STREAM_S *pstStream);
【Parameter】
Parameter |
Input/Output |
AeChn |
Input |
pstStream |
Pointer to the audio stream. |
Input |
【Return Value】
Return Value |
0 |
Success. |
Non 0 |
【Requirement】
It is best to release the code stream immediately after use.
If not released in time, the coding process will be blocked.
The code stream to be released must be the code stream obtained from the channel.
Do not modify the code stream information structure; otherwise, the code stream cannot be released, the buffer of the code stream will be lost, and even program exceptions will be caused.
When releasing the stream, ensure that the channel has been created.
If the channel is destroyed during the release process, an immediate failure is returned.
【Example】
None.
10.3.5.6. CVI_AENC_SaveFile¶
CVI_S32 CVI_AENC_SaveFile(AENC_CHN AeChn, const AUDIO_SAVE_FILE_INFO_S *pstSaveFileInfo);
【Parameter】
Parameter |
Input/Output |
AeChn |
Audio encoding channel number. Range of values: [0, AENC_MAX_CHN_NUM]. |
Input |
pstSaveFileInfo |
Audio save file property structure pointer. |
Input |
【Return Value】
Return Value |
0 |
Success. |
Non 0 |
【Requirement】
Cvitek does not support this API.
-Please use CVI_AI_SaveFile.
【Example】
None.
10.3.5.7. CVI_AENC_QueryFileStatus¶
CVI_S32 CVI_AENC_QueryFileStatus(AENC_CHN AeChn, AUDIO_FILE_STATUS_S *pstFileStatus);
【Parameter】
Parameter |
Input/Output |
AeChn |
Input |
pstFileStatus |
Pointer to status attribute structure |
Output |
【Return Value】
Return Value |
0 |
Success. |
Non 0 |
【Requirement】
Please use CVI_AI_SaveFile/CVI_AI_QueryFileStatus
【Example】
None.
10.3.5.8. CVI_AENC_GetStreamBufInfo¶
CVI_S32 CVI_AENC_GetStreamBufInfo(AENC_CHN AeChn, CVI_U32 *pu32PhysAddr, CVI_U32 *pu32Size);
【Parameter】
Parameter |
Input/Output |
AeChn |
Input |
pu32PhysAddr |
The physical address of the audio stream buffer. |
Output |
pu32Size |
Length of audio stream buffer in byte |
Output |
【Return Value】
Return Value |
0 |
Success. |
Non 0 |
【Requirement】
None.
【Example】
None.
10.3.5.9. CVI_AENC_SetMute¶
Set AENC mute state
CVI_AENC_SetMute(AENC_CHN AeChn,CVI_BOO; bEnable);
【Parameter】
Parameter |
Input/Output |
AeChn |
Input |
bEnable |
Input |
【Return Value】
Return Value |
0 |
Success. |
Non 0 |
【Requirement】
Header files: cvi_audio.h,
Use only after AENC creates a device channel.
【Example】
None.
10.3.5.10. CVI_AENC_GetMute¶
CVI_AENC_GetMute(AENC_CHN AeChn, CVI_BOOL *pbEnable);
【Parameter】
Parameter |
Input/Output |
AeChn |
Input |
pbEnable |
Pointer to audio device mute status |
Input |
【Return Value】
Return Value |
0 |
Success. |
Non 0 |
【Requirement】
【Example】
None.
10.3.6. Audio Decoding¶
The main functions of audio decoding include creating decoding channels, decoding audio streams, and obtaining decoded audio frames
The supported APIs and details are listed below:
CVI_ADEC_CreateChn: Create an audio decoding channel.
CVI_ADEC_DestroyChn: Destroy the audio decoding channel.
CVI_ADEC_SendStream: Sends an audio stream to an audio decoding channel.
CVI_ADEC_ClearChnBuf: Clear the current audio data block in the ADEC channel.
CVI_ADEC_GetFrame: Gets the audio decoded frame data.
CVI_ADEC_ReleaseFrame: Release audio decoded frame data.
CVI_ADEC_SendEndOfStream: Sending the end-of-stream (EOS) marker to the decoder and clearing the stream buffer.
10.3.6.1. CVI_ADEC_CreateChn¶
CVI_S32 CVI_ADEC_CreateChn(ADEC_CHN AdChn, const ADEC_CHN_ATTR_S *pstAttr);
【Parameter】
Parameter |
Input/Output |
AdChn |
Channel number. Range: [0, ADEC_MAX_CHN_NUM]. |
Input |
pstAttr |
Channel property pointer. |
Input |
【Return Value】
Parameter |
0 |
Success. |
Non 0 |
【Requirement】
Currently support G711, G726, ADPCM.
Some properties of audio decoding need to match those of the output device, such as sampling rate, frame length (number of sampling points per frame), etc.
【Example】
None.
10.3.6.2. CVI_ADEC_DestroyChn¶
CVI_S32 CVI_ADEC_DestroyChn(ADEC_CHN AdChn);
【Parameter】
Parameter |
Input/Output |
AdChn |
Input |
【Return Value】
Return Value |
0 |
Success. |
Non 0 |
【Requirement】
Calling this interface without channel creation returns Success.
If a stream is being acquired/released or a frame is being sent, destroying the channel will return failure immediately.
【Example】
None.
10.3.6.3. CVI_ADEC_SendStream¶
Sends a stream to an audio decoding channel.
CVI_S32 CVI_ADEC_SendStream(ADEC_CHN AdChn, const AUDIO_STREAM_S *pstStream, CVI_BOOL bBlock);
【Parameter】
Parameter |
Input/Output |
AdChn |
Input |
pstStream |
Audio stream |
Input |
bBlock |
CVI_TRUE: Blocked. CVI_FALSE: Non-blocking. |
Input |
【Return Value】
Return Value |
0 |
Success. |
Non 0 |
【Requirement】
The stream mode is inefficient and may have delay when the bitstream packet size is not determined to be one frame (greater than or equal to one frame);
Ensure that a channel has been created before sending data.
If the channel is destroyed during data sending, a failure is returned immediately.
Ensure the correctness of the stream data sent to the ADEC channel, otherwise the decoder may exit abnormally.
【Example】
None.
10.3.6.4. CVI_ADEC_ClearChnBuf¶
CVI_S32 CVI_ADEC_ClearChnBuf(ADEC_CHN AdChn);
【Parameter】
Parameter |
Input/Output |
AdChn |
Input |
【Return Value】
Return Value |
0 |
Success. |
Non 0 |
【Requirement】
Decoding channel has been created is required.
Stream decoding is not recommended when using this interface.When using streaming decoding to clear blocks, the user needs to ensure that after clearing blocks, the data sent to the decoder must be a complete frame stream, otherwise the decoder may not operate properly.
Regardless of whether stream decoding is utilized, it is crucial to ensure synchronization between the data feeding operation and the buffer clearing operation.
【Example】
none
10.3.6.5. CVI_ADEC_GetFrame¶
Gets the decoded audio frame.
CVI_S32 CVI_ADEC_GetFrame(ADEC_CHN AdChn, AUDIO_FRAME_INFO_S *pstFrmInfo, CVI_BOOL bBlock);
【Parameter】
Parameter |
Input/Output |
AdChn |
Audio decoding channel. |
Input |
pstFrmInfo |
Audio frame data structure. |
Output |
bBlock |
Whether to retrieve data in a blocking mode. |
Input |
【Return Value】
Return Value |
0 |
Success. |
Non 0 |
【Requirement】
Header files: -cvi_comm_aio.h, cvi_audio.h、cvi_comm_aenc.h
Library files:-libcvi_audio.a, libcvi_transcode.so, libcvi_RES1.so
Must be called after the ADEC channel is created.
When using this interface to obtain decoded frame data, it is recommended to send the stream by frame.
When using this interface to obtain audio data, unbind ADEC from Audio Output, otherwise the frames are discontinuous.
When you use this interface to obtain audio frame data, ensure that the decoded frame data is obtained in a timely manner if the sent code stream is sent as stream. Otherwise, an exception may occur.
【Example】
None.
10.3.6.6. CVI_ADEC_ReleaseFrame¶
Release the acquired audio decoded frame data.
CVI_S32 CVI_ADEC_ReleaseFrame(ADEC_CHN AdChn, AUDIO_FRAME_INFO_S *pstFrmInfo);
【Parameter】
Parameter |
Input/Output |
AdChn |
Input |
pstFrmInfo |
Input |
【Return Value】
Return Value |
0 |
Success. |
Non 0 |
Failure. For details, please refer to Error Codes. |
【Requirement】
This interface must be used together with the CVI_ADEC_GetFrame interface.
-Must be called after the ADEC channel is created.
【Example】
None.
10.3.6.7. CVI_ADEC_SendEndOfStream¶
CVI_S32 CVI_ADEC_SendEndOfStream (ADEC_CHN AdChn, CVI_BOOL bInstant);
【Parameter】
Parameter |
Input/Output |
AdChn |
Input |
bInstant |
The parameter specifies in whether to immediately clear the internal buffer data of the decoder. The Value range is: - CVI_FALSE: Delayed clearing. The decoder’s internal buffer data will not be cleared immediately, and the decoding process will continue until the remaining buffer is not enough for one frame of data. The clearing operation will then be performed. CVI_TRUE: Immediate clearing of the decoder’s internal buffer data.” |
Input/Output |
【Return Value】
Return Value |
0 |
Success. |
Non 0 |
【Requirement】
None.
【Example】
None.
10.3.7. Built-in Codec¶
The built-in audio codec is mainly operated through ioctl to manipulate the hardware device. The ioctl calls are used to read and write to the registers of the built-in audio codec.
Built-in audio codec standard function cmd
ACODEC_SOFT_RESET_CTRL: Restore Codec to its default setting.
ACODEC_SET_INPUT_VOL: Total input volume control.
ACODEC_GET_INPUT_VOL: Gets the total input volume.
ACODEC_SET_OUTPUT_VOL: Total output volume control.
ACODEC_GET_OUTPUT_VOL: Gets the total output volume.
ACODEC_SET_GAIN_MICL: Analog Gain Control of Left Channel MIC Input
ACODEC_SET_GAIN_MICR: Analog Gain Control of Right Channel MIC Input
ACODEC_SET_DACL_VOL: Left channel output volume control.
ACODEC_SET_DACR_VOL: Right channel output volume control.
ACODEC_SET_ADCL_VOL: Left channel input volume control.
ACODEC_SET_ADCR_VOL: Right channel input volume control.
ACODEC_SET_MICL_MUTE: Left channel MIC input mute control.
ACODEC_SET_MICR_MUTE: Right channel MIC input mute control.
ACODEC_SET_DACL_MUTE: Left channel output mute control.
ACODEC_SET_DACR_MUTE: Right channel output mute control.
ACODEC_GET_GAIN_MICL: Get Analog Gain of Left Channel MIC Input .
ACODEC_GET_GAIN_MICR: Get Analog Gain of Right Channel MIC Input .
ACODEC_GET_DACL_VOL: Gets the volume control of the left channel output.
ACODEC_GET_DACR_VOL: Gets the volume control of the right channel output.
ACODEC_GET_ADCL_VOL: Gets the volume control of the left channel input.
ACODEC_GET_ADCR_VOL: Gets the volume control of the right channel input.
ACODEC_SET_PD_DACL: Power-Off Control of Left Channel Output .
ACODEC_SET_PD_DACR: Power-Off Control of Right Channel Output .
ACODEC_SET_PD_ADCL: Power-Off Control of Left Channel Input .
ACODEC_SET_PD_ADCR: Power-Off Control of Right Channel Input .
ACODEC_SET_PD_LINEINL: Power-Off Control of Left Channel LINEIN Input .
ACODEC_SET_PD_LINEINR: Power-Off Control of Right Channel LINEIN Input .
10.3.7.1. ACODEC_SOFT_RESET_CTRL¶
CVI_S32 ioctl (CVI_S32 fd, ACODEC_SOFT_RESET_CTRL);
【Parameter】
Parameter |
Input/Output |
fd |
File Description of Audio Codec Device |
Input |
ACODEC_SOFT_RESET_CTRL |
Ioctl Number |
Input |
【Return Value】
Return Value |
0 |
Success. |
Non 0 |
【Requirement】
Header files: acodec.h
None.
【Example】
if (ioctl(Acodec_Fd, ACODEC_SOFT_RESET_CTRL))
printf("ioctl reset err!\n");
10.3.7.2. ACODEC_SET_INPUT_VOL¶
Total input volume control. Configure the user’s desired gain to the digital gain control register.
CVI_S32 ioctl (CVI_S32 fd, ACODEC_SET_INPUT_VOL, CVI_U32 *arg);
【Parameter】
Parameter |
Input/Output |
fd |
Input |
ACODEC_SET_INPUT_VOL |
Ioctl Number |
Input |
arg |
Unsigned integer pointer |
Input |
【Return Value】
Return Value |
0 |
Success. |
Non 0 |
【Requirement】
The input volume ranges from [24 to 0]. If the input value is 0, it is mute.
Both left and right channels are in effect during adjustment.
【Example】
CVI_U32 vol = 20;
if (ioctl(Acodec_Fd, ACODEC_SET_INPUT_VOL, &vol))
printf("ioctl err!\n");
10.3.7.3. ACODEC_GET_INPUT_VOL¶
CVI_S32 ioctl (CVI_S32 fd, ACODEC_GET_INPUT_VOL, CVI_U32 *arg);
【Parameter】
Parameter |
Input/Output |
fd |
Audio Codec Device File Description |
Input |
ACODEC_GET_INPUT_VOL |
Ioctl Number |
Input |
arg |
Output |
【Return Value】
Return Value |
0 |
Success. |
Non 0 |
【Requirement】
【Example】
CVI_U32 vol;
10.3.7.4. ACODEC_SET_OUTPUT_VOL¶
Total output volume control. Configure the user’s desired gain to the digital gain control register.
CVI_S32 ioctl (CVI_S32 fd, ACODEC_SET_OUTPUT_VOL, CVI_U32 *arg);
【Parameter】
Parameter |
Input/Output |
fd |
Input |
ACODEC_SET_OUTPUT_VOL |
Ioctl Number |
Input |
arg |
Input |
【Return Value】
Return Value |
0 |
Success. |
Non 0 |
【Requirement】
The output volume ranges from [32 to 0].
【Example】
CVI_U32 vol = 7;
if (ioctl(Acodec_Fd, ACODEC_SET_OUTPUT_VOL, &vol))
10.3.7.5. ACODEC_GET_OUTPUT_VOL¶
Get the total output volume
CVI_S32 ioctl (CVI_S32 fd, ACODEC_GET_OUTPUT_VOL, CVI_U32 *arg);
【Parameter】
Parameter |
Input/Output |
fd |
Input |
ACODEC_GET_OUTPUT_VOL |
Ioctl Number |
Input |
arg |
Output |
【Return Value】
Return Value |
0 |
Success. |
Non 0 |
【Requirement】
The output volume range is [32~0].
【Example】
CVI_U32 vol;
10.3.7.6. ACODEC_SET_GAIN_MICL¶
CVI_S32 ioctl (CVI_S32 fd, ACODEC_SET_GAIN_MICL, CVI_U32 *arg);
【Parameter】
Parameter |
Input/Output |
fd |
Input |
ACODEC_SET_GAIN_MICL |
Ioctl number |
Input |
arg |
Input |
【Return Value】
Return Value |
0 |
Success. |
Non 0 |
【Requirement】
When using passive audio signal input, it is necessary to appropriately increase the analog gain.
The input volume range is [24~0]. The input value 0 represent mute.
【Example】
CVI_U32 gain_mic;
gain_mic = 5;
if (ioctl(Acodec_Fd, ACODEC_SET_GAIN_MICL, &gain_mic))
10.3.7.7. ACODEC_SET_GAIN_MICR¶
CVI_S32 ioctl (CVI_S32 fd, ACODEC_SET_GAIN_MICR, CVI_U32 *arg);
【Parameter】
Parameter |
Input/Output |
fd |
Input |
ACODEC_SET_GAIN_MICR |
Ioctl number |
Input |
arg |
Input |
【Return Value】
Return Value |
0 |
Success. |
Non 0 |
【Requirement】
Header files:acodec.h
-The input volume range is [24~0]. The input value 0 represent mute.
【Example】
CVI_U32 gain_mic;
gain_mic = 5;
if (ioctl(Acodec_Fd, ACODEC_SET_GAIN_MICR, &gain_mic))
10.3.7.8. ACODEC_SET_DACL_VOL¶
CVI_S32 ioctl (CVI_S32 fd, ACODEC_SET_DACL_VOL, struct cvi_vol_ctrl *arg);
【Parameter】
Parameter |
Input/Output |
fd |
Input |
ACODEC_SET_DACL_VOL |
Ioctl number |
Input |
arg |
cvi_vol_ctrl structure pointer |
Input |
【Return Value】
Return Value |
0 |
Success. |
Non 0 |
【Requirement】
Output volume ranges from [32 to 0].
If vol_ctrl_ctrl_mute is set to 1, the mute will be enabled.
If vol_ctrl.vol_ctrl_mute is set to 0, the mute will be disabled.
【Example】
struct cvi_vol_ctrl vol_ctrl;
vol_ctrl.vol_ctrl_mute = 0x0;
vol_ctrl.vol_ctrl = 0x05;
if (ioctl(Acodec_Fd, ACODEC_SET_DACL_VOL, &vol_ctrl))
10.3.7.9. ACODEC_SET_DACR_VOL¶
CVI_S32 ioctl (CVI_S32 fd, ACODEC_SET_DACR_VOL, struct cvi_vol_ctrl *arg);
【Parameter】
Parameter |
Input/Output |
fd |
Input |
ACODEC_SET_DACR_VOL |
Ioctl number |
Input |
arg |
Input |
【Return Value】
Return Value |
0 |
Success. |
Non 0 |
【Requirement】
Output volume ranges from [32 to 0]. If vol_ctrl_ctrl_mute is set to 1, the mute will be enabled. If vol_ctrl.vol_ctrl_mute is set to 0, the mute will be disabled.
【Example】
if (ioctl(Acodec_Fd, ACODEC_SET_DACR_VOL, &vol_ctrl))
10.3.7.10. ACODEC_SET_ADCL_VOL¶
CVI_S32 ioctl (CVI_S32 fd, ACODEC_SET_ADCL_VOL, struct cvi_vol_ctrl *arg);
【Paramters】
Parameter |
Input/Output |
fd |
Audio Codec device file description |
Input |
ACODEC_SET_ADCL_VOL |
Ioctl number |
Input |
arg |
Input |
【Return Value】
Return Value |
0 |
Success. |
Non 0 |
【Requirement】
When the Input is configured as MIC in, the input volume range is [24~0]. If the value of vol_ctrl.vol_ctrl_mute is 1, it will be muted, and if the value is 0, the mute will be cancelled.
【Example】
if (ioctl(Acodec_Fd, ACODEC_SET_ADCL_VOL, &vol_ctrl))
10.3.7.11. ACODEC_SET_ADCR_VOL¶
CVI_S32 ioctl (CVI_S32 fd, ACODEC_SET_ADCR_VOL, struct cvi_vol_ctrl *arg);
【Parameter】
Parameter |
Input/Output |
fd |
Audio codec device file description |
Input |
ACODEC_SET_ADCR_VOL |
Ioctl number |
Input |
arg |
Input |
【Return Value】
Return Value |
0 |
Success. |
Non 0 |
【Requirement】
【Example】
if (ioctl(Acodec_Fd, ACODEC_SET_ADCR_VOL, &vol_ctrl))
10.3.7.12. ACODEC_SET_MICL_MUTE¶
CVI_S32 ioctl (CVI_S32 fd, ACODEC_SET_MICL_MUTE, CVI_U32 *arg);
【Parameter】
Parameter |
Input/Output |
fd |
Input |
ACODEC_SET_MICL_MUTE |
Ioctl number |
Input |
arg |
Input |
【Return Value】
Return Value |
0 |
Success. |
Non 0 |
【Requirement】
The arg parameter ranges from 0 to 1, where 0 means unmute and 1 means mute.
【Example】
CVI_U32 mic_mute;
mic_mute = 0;
if (ioctl(Acodec_Fd, ACODEC_SET_MICL_MUTE, &mic_mute))
10.3.7.13. ACODEC_SET_MICR_MUTE¶
CVI_S32 ioctl (CVI_S32 fd, ACODEC_SET_MICR_MUTE, CVI_U32 *arg);
【Parameter】
Parameter |
Input/Output |
fd |
Input |
ACODEC_SET_MICR_MUTE |
Ioctl number |
Input |
arg |
Input |
【Return Value】
Return Value |
0 |
Success. |
Non 0 |
【Requirement】
【Example】
CVI_U32 mic_mute;
mic_mute = 0;
if (ioctl(Acodec_Fd, ACODEC_SET_MICR_MUTE, &mic_mute))
10.3.7.14. ACODEC_SET_DACL_MUTE¶
CVI_S32 ioctl (CVI_S32 fd, ACODEC_SET_DACL_MUTE, CVI_U32 *arg);
【Parameter】
Parameter |
Input/Output |
fd |
Input |
ACODEC_SET_DACL_MUTE |
Ioctl number |
Input |
arg |
Input |
【Return Value】
Return Value |
0 |
Success. |
Non 0 |
【Requirement】
【Example】
CVI_U32 mute;
mute = 0;
if (ioctl(Acodec_Fd, ACODEC_SET_DACL_MUTE, &mute))
10.3.7.15. ACODEC_SET_DACR_MUTE¶
CVI_S32 ioctl (CVI_S32 fd, ACODEC_SET_DACR_MUTE, CVI_U32 *arg);
【Parameter】
Parameter |
Input/Output |
fd |
Input |
ACODEC_SET_DACR_MUTE |
Ioctl number |
Input |
arg |
Input |
【Return Value】
Return Value |
0 |
Success. |
Non 0 |
【Requirement】
【Example】
CVI_U32 mute;
mute = 0;
if (ioctl(Acodec_Fd, ACODEC_SET_DACR_MUTE, &mute))
10.3.7.16. ACODEC_GET_GAIN_MICL¶
CVI_S32 ioctl (CVI_S32 fd, ACODEC_GET_GAIN_MICL, CVI_U32 *arg);
【Parameter】
Parameter |
Input/Output |
fd |
Input |
ACODEC_GET_GAIN_MICL |
Ioctl number |
Input |
arg |
Output |
【Return Value】
Return Value |
0 |
Success. |
Non 0 |
【Requirement】
None.
【Example】
CVI_U32 gain_mic;
mute = 0;
if (ioctl(Acodec_Fd, ACODEC_GET_GAIN_MICL, &gain_mic))
10.3.7.17. ACODEC_GET_GAIN_MICR¶
CVI_S32 ioctl (CVI_S32 fd, ACODEC_GET_GAIN_MICR, CVI_U32 *arg);
【Parameter】
Parameter |
Input/Output |
fd |
Input |
ACODEC_GET_GAIN_MICR |
Ioctl number |
Input |
arg |
Output |
【Return Value】
Return Value |
0 |
Success. |
Non 0 |
【Requirement】
None.
【Example】
CVI_U32 gain_mic;
mute = 0;
if (ioctl(Acodec_Fd, ACODEC_GET_GAIN_MICR, &gain_mic))
10.3.7.18. ACODEC_GET_DACL_VOL¶
Get the volume control of the left channel output.
CVI_S32 ioctl (CVI_S32 fd, ACODEC_GET_DACL_VOL, struct cvi_vol_ctrl *arg);
【Parameter】
Parameter |
Input/Output |
fd |
Input |
ACODEC_GET_DACL_VOL |
Ioctl number |
Input |
arg |
Output |
【Return Value】
Return Value |
0 |
Success. |
Non 0 |
【Requirement】
None.
【Example】
if (ioctl(Acodec_Fd, ACODEC_GET_DACL_VOL, & vol_ctrl))
10.3.7.19. ACODEC_GET_DACR_VOL¶
CVI_S32 ioctl (CVI_S32 fd, ACODEC_GET_DACR_VOL, struct cvi_vol_ctrl *arg);
【Parameter】
Parameter |
Input/Output |
fd |
Input |
ACODEC_GET_DACR_VOL |
Ioctl number |
Input |
arg |
Output |
【Return Value】
Return Value |
0 |
Success. |
Non 0 |
【Requirement】
None.
【Example】
if (ioctl(Acodec_Fd, ACODEC_GET_DACR_VOL, & vol_ctrl))
10.3.7.20. ACODEC_GET_ADCL_VOL¶
CVI_S32 ioctl (CVI_S32 fd, ACODEC_GET_ADCL_VOL, struct cvi_vol_ctrl *arg);
【Parameter】
Parameter |
Input/Output |
fd |
Input |
ACODEC_GET_ADCL_VOL |
Ioctl number |
Input |
arg |
Output |
【Return Value】
Return Value |
0 |
Success. |
Non 0 |
【Requirement】
None.
【Example】
if (ioctl(Acodec_Fd, ACODEC_GET_ADCL_VOL, & vol_ctrl))
10.3.7.21. ACODEC_GET_ADCR_VOL¶
CVI_S32 ioctl (CVI_S32 fd, ACODEC_GET_ADCR_VOL, struct cvi_vol_ctrl *arg);
【Parameter】
Parameter |
Input/Output |
fd |
Input |
ACODEC_GET_ADCR_VOL |
Ioctl number |
Input |
arg |
Output |
【Return Value】
Return Value |
0 |
Success. |
Non 0 |
【Requirement】
None.
【Example】
if (ioctl(Acodec_Fd, ACODEC_GET_ADCR_VOL, & vol_ctrl))
10.3.7.22. ACODEC_SET_PD_DACL¶
CVI_S32 ioctl (CVI_S32 fd, ACODEC_SET_PD_DACL, CVI_U32 *arg);
【Parameter】
Parameter |
Input/Output |
fd |
Input |
ACODEC_SET_PD_DACL |
Ioctl number |
Input |
arg |
Input |
【Return Value】
Return Value |
0 |
Success. |
Non 0 |
【Requirement】
This interface can be called when not using DACL to power down DACL.
The arg parameter ranges from 0 to 1.
0 means power up, and 1 means power down.
【Example】
CVI_U32 pd_ctrl;
pd_ctrl = 0x1;
if (ioctl(Acodec_Fd, ACODEC_SET_PD_DACL, &pd_ctrl))
10.3.7.23. ACODEC_SET_PD_DACR¶
CVI_S32 ioctl (CVI_S32 fd, ACODEC_SET_PD_DACR, CVI_U32 *arg);
【Parameter】
Parameter |
Input/Output |
fd |
Input |
ACODEC_SET_PD_DACR |
Ioctl number |
Input |
arg |
Input |
【Return Value】
Return Value |
0 |
Success. |
Non 0 |
【Requirement】
【Example】
CVI_U32 pd_ctrl;
pd_ctrl = 0x1;
if (ioctl(Acodec_Fd, ACODEC_SET_PD_DACR, &pd_ctrl))
10.3.7.24. ACODEC_SET_PD_ADCL¶
CVI_S32 ioctl (CVI_S32 fd, ACODEC_SET_PD_ADCL, CVI_U32 *arg);
【Parameter】
Parameter |
Input/Output |
fd |
Input |
ACODEC_SET_PD_ADCL |
Ioctl number |
Input |
arg |
Input |
【Return Value】
Return Value |
0 |
Success. |
Non 0 |
【Requirement】
【Example】
CVI_U32 pd_ctrl;
pd_ctrl = 0x1;
if (ioctl(Acodec_Fd, ACODEC_SET_PD_ADCL, &pd_ctrl))
10.3.7.25. ACODEC_SET_PD_ADCR¶
CVI_S32 ioctl (CVI_S32 fd, ACODEC_SET_PD_ADCR, CVI_U32 *arg);
【Parameter】
Parameter |
Input/Output |
fd |
Input |
ACODEC_SET_PD_ADCR |
Ioctl number |
Input |
arg |
Input |
【Return Value】
Return Value |
0 |
Success. |
Non 0 |
【Requirement】
【Example】
CVI_U32 pd_ctrl;
pd_ctrl = 0x1;
if (ioctl(Acodec_Fd, ACODEC_SET_PD_ADCR, &pd_ctrl))
10.3.7.26. ACODEC_SET_PD_LINEINL¶
Power-Off Control of Left Channel LINEIN input.
CVI_S32 ioctl (CVI_S32 fd, ACODEC_SET_PD_LINEINL, CVI_U32 *arg);
【Parameter】
Parameter |
Input/Output |
fd |
Input |
ACODEC_SET_PD_LINEINL |
Ioctl number |
Input |
arg |
Input |
【Return Value】
Return Value |
0 |
Success. |
Non 0 |
【Requirement】
This interface can be called when not using LINEIN to power down LINEIN.
【Example】
CVI_U32 pd_ctrl;
pd_ctrl = 0x1;
if (ioctl(Acodec_Fd, ACODEC_SET_PD_LINEINL, &pd_ctrl))
10.3.7.27. ACODEC_SET_PD_LINEINR¶
Power-Off Control of Right Channel LINEIN input.
CVI_S32 ioctl (CVI_S32 fd, ACODEC_SET_PD_LINEINR, CVI_U32 *arg);
【Parameter】
Parameter |
Input/Output |
fd |
Input |
ACODEC_SET_PD_LINEINR |
Ioctl number |
Input |
arg |
Input |
【Return Value】
Return Value |
0 |
Success. |
Non 0 |
【Requirement】
【Example】
CVI_U32 pd_ctrl;
pd_ctrl = 0x1;
if (ioctl(Acodec_Fd, ACODEC_SET_PD_LINEINR, &pd_ctrl))
10.3.8. Resampling¶
The Resampler module provides independent resampling processing.
When a client needs to resample data in the upper layer, this module can be used.
The following are related API and detailed description.
CVI_Resampler_Create: Create a resampling module.
CVI_Resampler_Process: Resampling module data processing.
CVI_Resampler_Destroy: Destroy the resampling module.
CVI_Resampler_GetMaxOutputNum: Computing maximum output data for resampling.
10.3.8.1. CVI_Resampler_Create¶
CVI_VOID *CVI_Resampler_Create(CVI_S32 s32Inrate, CVI_S32 s32Outrate, CVI_S32 s32Chans);
【Parameter】
Parameter |
Input/Output |
s32Inrate |
Input sampling rate. Value Range: 8000, 11025, 12000, 16000, 22050, 24000, 32000, 44100, 48000, 64000. |
Input |
s32Outrate |
Output sampling rate. Value Range: 8000, 11025, 12000, 16000, 22050, 24000, 32000, 44100, 48000, 64000. |
Input |
s32Chans |
Number of processing channels (currently Cvitek supports mono channel); |
Input |
【Return Value】
Return Value |
0 |
Success. |
Non 0 |
【Requirement】
Header files: cvi_comm_aio.h, cvi_audio.h、cvi_resample_api.h
The input sampling rate and output sampling rate should be different.
【Example】
None.
10.3.8.2. CVI_Resampler_Process¶
Process one frame of resampled data.
CVI_S32 CVI_Resampler_Process(CVI_VOID *inst, CVI_S16 *s16Inbuf, CVI_S32 s32Insamps, CVI_S16 *s16Outbuf);
【Parameter】
Parameter |
Input/Output |
inst |
Resample module handle. |
Input |
s16Inbuf |
Input data buf pointer. |
Input |
s32Insamps |
Number of input sample points. Value Range: [0, 2048]. |
Input |
s16Outbuf |
Output data buf pointer |
Output |
【Return Value】
Return Value |
0 |
Success. |
Non 0 |
【Requirement】
The maximum number of input sample points should be less than 2048.
【Example】
None.
10.3.8.3. CVI_Resampler_Destroy¶
Destroy a resampling module instance.
CVI_VOID CVI_Resampler_Destroy(CVI_VOID *inst);
【Parameter】
Parameter |
Input/Output |
inst |
Resampling module handle. |
Input |
【Return Value】
Return Value |
0 |
Success. |
Non 0 |
【Requirement】
None.
【Example】
None.
10.3.8.4. CVI_Resampler_GetMaxOutputNum¶
Get the maximum number of output sample points (per channel).
CVI_S32 CVI_Resampler_GetMaxOutputNum(CVI_VOID *inst, CVI_S32 s32Insamps);
【Parameter】
Parameter |
Input/Output |
inst |
Input |
s32Insamps |
Input sampling points for each channel. |
Input |
【Return Value】
Return Value |
0 |
Success. |
Non 0 |
【Requirement】
None.
【Example】
None.
