4.4. Data Types¶
The data types related to video input are defined as follows. For the differences between processors, see the supporting capabilities of each processor.
VI_MAX_PHY_DEV_NUM :Define the maximum number of VI physical devices.
VI_MAX_VIR_DEV_NUM :Define the maximum number of VI virtual devices.
VI_MAX_DEV_NUM: Define the maximum number of VI devices.
VI_MAX_PHY_PIPE_NUM: Defines the maximum number of VI physical PIPE.
VI_MAX_VIR_PIPE_NUM: Define the maximum number of VI virtual PIPE.
VI_MAX_PIPE_NUM: Define the maximum number of VI PIPE
VI_MAX_VIR_CHN_NUM :Define the maximum number of VI virtual channels.
VI_MAX_PHY_CHN_NUM: Defines the maximum number of VI physical channels.
VI_MAX_EXT_CHN_NUM :Define the maximum number of VI extended channels.
VI_EXT_CHN_START :Define the VI extended channel startup.
VI_MAX_EXTCHN_BIND_PER_CHN :Define the maximum number of extended channels bound to each VI channel.
VI_MAX_CHN_NUM: Defines the total number of VI physical channels and extended channels.
VI_PIPE1_MAX_WIDTH: Maximum width of images for processing with VI PIPE1
VI_PIXEL_FORMAT :VI Pixel format.
CVI_VI_VPSS_EXTRA_BUF :Define the number of extra buffers for VI VPSS.
CVI_VI_CHN_0_BUF :Define the number of buffers for VI channel 0.
CVI_VI_CHN_1_BUF :Define the number of buffers for VI channel 1.
CVI_VI_CHN_2_BUF :Define the number of buffers for VI channel 2.
CVI_VI_CHN_3_BUF :Define the number of buffers for VI channel 3.
VI_CMP_PARAM_SIZE :Define the size of the VI comparison parameters.
VI_MAX_ADCHN_NUM :Maximum number of analog-to-digital channels for VI.
VI_COMPMASK_NUM :Compare the number of masks for VI.
VI_SHARPEN_GAIN_NUM :Number of sharpening gain parameters for VI.
VI_AUTO_ISO_STRENGTH_NUM :Number of automatic ISO strength parameters for VI.
VI_INVALID_CHN :Invalid video input channel number for VI.
VI_DATA_TYPE_E: VI input data type enumeration.
VI_DEV_ATTR_S: Define the properties of the video input device.
VI_DEV_BIND_PIPE_S: Define the binding relationship between VI DEV and PIPE.
VI_PIPE_ATTR_S: Define VI PIPE properties.
VI_DUMP_TYPE_E: Enumerate dump types.
VI_DUMP_ATTR_S: Define the VI PIPE dump property.
VI_CHN_ATTR_S: Define VI channel properties.
VI_CROP_INFO_S: Define the VI CROP information structure.
VI_DEV_TIMING_ATTR_S: Self-generated timing attribute
VI_PIPE_STATUS_S: Define VI PIPE status information.
VI_CHN_STATUS_S: Define VI channel status information.
VI_PIPE_FRAME_SOURCE_E: Define the source type of VI PIPE data.
VI_LDC_ATTR_S: Define the VI lens distortion correction structure
VI_STATE_E: Enumerate VI status information.
VI_SYNC_CFG_S: synchronization information about the BT.601 or DC timing.
VI_BT656_SYNC_CFG_S: synchronization information about the BT.656.
VI_PIPE_BYPASS_MODE_E: VI pipeline bypass mode.
VI_CROP_COORDINATE_E: Different types of cropping coordinates.
VI_MOD_PARAM_S: VI module parameters.
VI_EARLY_INTERRUPT_S: Parameters for early interruption.
MLSC_GAIN_LUT_S: Gain lookup table.
VI_DUMP_REGISTER_TABLE_S: Register to store data.
VI_PM_OPS_S: Power management related operations.
VI_SMOOTH_RAW_DUMP_INFO_S: Continuous dump raw image information.
VI_INTF_MODE_E : Interface mode of video input.
VI_INPUT_MODE_E : Input mode.
VI_WORK_MODE_E : Work mode.
VI_SCAN_MODE_E : whether an input picture is interlaced or progressive.
VI_YUV_DATA_SEQ_E : Sequence of YUV data.
VI_CLK_EDGE_E : Clock edge mode.
VI_COMPONENT_MODE_E : Component mode.
VI_COMBINE_MODE_E : Y/C composite or separation mode.
VI_VSYNC_E : Attribute of the vertical synchronization signal.
VI_VSYNC_NEG_E : Polarity of the vertical synchronization signal.
VI_HSYNC_E : Attribute of the horizontal synchronization signal.
VI_HSYNC_NEG_E : Polarity of the horizontal synchronization signal.
VI_VSYNC_VALID_E : Attribute of the valid vertical synchronization signal.
VI_VSYNC_VALID_NEG_E : Polarity of the valid vertical synchronization signal.
VI_WDR_ATTR_S : Attribute of wdr.
VI_TIMING_BLANK_S : Blank information of the input timing.
VI_BT656_FIXCODE_E : The highest bit of the BT.656 timing reference code.
VI_BT656_FIELD_POLAR_E : Polarity of the field indicator bit (F) of the BT.656 timing reference code.
VI_DEV_ATTR_EX_S : The extended attributes of VI device.
VI_EXT_CHN_SOURCE_E :VI extended channel data source type.
VI_EXT_CHN_ATTR_S :VI extended channel attribute structure.
VI_USERPIC_BGC_S: The structure has been abandoned.
VI_LOW_DELAY_INFO_S: The structure has been abandoned.
VI_CMP_PARAM_S: The structure has been abandoned.
VI_USERPIC_ATTR_S: The structure has been abandoned.
VI_PIPE_SHARPEN_ATTR_S: The structure has been abandoned.
VI_PIPE_REPEAT_MODE_E: The structure has been abandoned.
VI_NR_VERSION_E: The structure has been abandoned.
NRX_PARAM_MANUAL_V1_S: The structure has been abandoned.
NRX_PARAM_AUTO_V1_S: The structure has been abandoned.
tV500_VI_SFy: The structure has been abandoned.
VI_PIPE_NRX_PARAM_V2_S: The structure has been abandoned.
NRX_PARAM_AUTO_V2_S: The structure has been abandoned.
VI_PIPE_NRX_PARAM_S: The structure has been abandoned.
VI_RAW_INFO_S: The structure has been abandoned.
4.4.1. VI_MAX_PHY_DEV_NUM¶
#define VI_MAX_PHY_DEV_NUM 3
None.
None.
4.4.2. VI_MAX_VIR_DEV_NUM¶
#define VI_MAX_VIR_DEV_NUM 2
None.
None.
4.4.3. VI_MAX_DEV_NUM¶
Defines the maximum number of VI devices.
#define VI_MAX_DEV_NUM (VI_MAX_PHY_DEV_NUM + VI_MAX_VIR_DEV_NUM)
None.
None.
4.4.4. VI_MAX_PHY_PIPE_NUM¶
#define VI_MAX_PHY_PIPE_NUM 5
None.
None.
4.4.5. VI_MAX_VIR_PIPE_NUM¶
#define VI_MAX_VIR_PIPE_NUM 0
None.
None.
4.4.6. VI_MAX_PIPE_NUM¶
Define the maximum number of VI PIPE.
#define VI_MAX_PIPE_NUM (VI_MAX_PHY_PIPE_NUM + VI_MAX_VIR_PIPE_NUM)
None.
None.
4.4.7. VI_MAX_VIR_CHN_NUM¶
#define VI_MAX_VIR_CHN_NUM 2
None.
None.
4.4.8. VI_MAX_PHY_CHN_NUM¶
#define VI_MAX_PHY_CHN_NUM 3
None.
None.
4.4.9. VI_MAX_EXT_CHN_NUM¶
#define VI_MAX_EXT_CHN_NUM 3
None.
None.
4.4.10. VI_MAX_CHN_NUM¶
#define VI_MAX_CHN_NUM (VI_MAX_PHY_CHN_NUM + VI_MAX_EXT_CHN_NUM)
None.
None.
4.4.11. VI_EXT_CHN_START¶
#define VI_EXT_CHN_START VI_MAX_CHN_NUM
None.
None.
4.4.12. VI_MAX_EXTCHN_BIND_PER_CHN¶
#define VI_MAX_EXTCHN_BIND_PER_CHN 1
None.
None.
4.4.13. VI_PIPE1_MAX_WIDTH¶
#define VI_PIPE1_MAX_WIDTH 4096
None.
None.
4.4.14. VI_PIXEL_FORMAT¶
VI Pixel format.
#define VI_PIXEL_FORMAT PIXEL_FORMAT_NV21
None.
None.
4.4.15. CVI_VI_VPSS_EXTRA_BUF¶
#define CVI_VI_VPSS_EXTRA_BUF 0
None.
None.
4.4.16. CVI_VI_CHN_0_BUF¶
#define CVI_VI_CHN_0_BUF (2 + CVI_VI_VPSS_EXTRA_BUF)
None.
None.
4.4.17. CVI_VI_CHN_1_BUF¶
#define CVI_VI_CHN_1_BUF (2 + CVI_VI_VPSS_EXTRA_BUF)
None.
None.
4.4.18. CVI_VI_CHN_2_BUF¶
#define CVI_VI_CHN_2_BUF (2 + CVI_VI_VPSS_EXTRA_BUF)
None.
None.
4.4.19. CVI_VI_CHN_3_BUF¶
#define CVI_VI_CHN_3_BUF (2 + CVI_VI_VPSS_EXTRA_BUF)
None.
None.
4.4.20. VI_CMP_PARAM_SIZE¶
#define VI_CMP_PARAM_SIZE 152
None.
None.
4.4.21. VI_MAX_ADCHN_NUM¶
#define VI_MAX_ADCHN_NUM 4
None.
None.
4.4.22. VI_COMPMASK_NUM¶
#define VI_COMPMASK_NUM 2
None.
None.
4.4.23. VI_SHARPEN_GAIN_NUM¶
#define VI_SHARPEN_GAIN_NUM 32
None.
None.
4.4.24. VI_AUTO_ISO_STRENGTH_NUM¶
#define VI_AUTO_ISO_STRENGTH_NUM 16
None.
None.
4.4.25. VI_INVALID_CHN¶
#define VI_INVALID_CHN -1
None.
None.
4.4.26. VI_DATA_TYPE_E¶
typedef enum _VI_DATA_TYPE_E {
VI_DATA_TYPE_YUV = 0,
VI_DATA_TYPE_RGB,
VI_DATA_TYPE_YUV_EARLY,
VI_DATA_TYPE_BUTT
} VI_DATA_TYPE_E;
【Member】
Member |
VI_DATA_TYPE_YUV |
The data type is YUV |
VI_DATA_TYPE_RGB |
The data type is RGB |
VI_DATA_TYPE_YUV_EARLY |
The data type is YUV (Interrupt in advance) |
None.
None.
4.4.27. VI_DEV_ATTR_S¶
Define the properties of the VI device.
typedef struct _VI_DEV_ATTR_S {
VI_INTF_MODE_E enIntfMode;
VI_WORK_MODE_E enWorkMode;
VI_SCAN_MODE_E enScanMode;
CVI_S32 as32AdChnId[VI_MAX_ADCHN_NUM];
VI_YUV_DATA_SEQ_E enDataSeq;
VI_SYNC_CFG_S stSynCfg;
VI_DATA_TYPE_E enInputDataType;
SIZE_S stSize;
VI_WDR_ATTR_S stWDRAttr;
BAYER_FORMAT_E enBayerFormat;
CVI_U32 chn_num;
CVI_U32 snrFps;
CVI_U64 phy_addr;
CVI_U32 phy_size;
CVI_BOOL isMux;
CVI_U8 switchGpioIdx;
CVI_U8 switchGpioPin;
CVI_U8 switchGPioPol;
CVI_BOOL disEnableSbm;
CVI_BOOL isFrmCtrl;
CVI_U8 dstFrm;
} VI_DEV_ATTR_S;
【Member】
Member |
enIntfMode |
Sensor interface mode. |
enWorkMode |
1, 2, 4-channel composite working mode. |
enScanMode |
Input scanning mode (progressive, interlaced). |
as32AdChnId[VI_MAX_ADCHN_NUM] |
The Value range is [-1, 3], and it is recommended to set it to the default value of -1 uniformly. This parameter is meaningless. |
enDataSeq |
Input data order (only applicable to YUV format). |
stSynCfg |
Synchronous timing configuration, which must be configured in BT.601 mode and is invalid in other modes. |
enInputDataType |
Input data type, which is generally RGB for Sensor input and YUV for AD input |
stSize |
The VI device can set the height and width of the image to be captured. Minimum and Maximum widths and heights of captured images: width : [VI_DEV_MIN_WIDTH,VI_DEV_MAX_WIDTH] height: [VI_DEV_MIN_HEIGHT,VI_DEV_MAX_HEIGHT] |
stWDRAttr |
WDR property |
enBayerFormat |
The Bayer format of the device, which must be set when the inputDataType is RGB |
chn_num |
Total chn numbers |
snrFps |
The frame rate of the sensor |
phy_addr |
, If it is not 0, the VI uses the physical address assigned by the user, and the validity of the physical address must be ensured before use |
phy_size |
only ALIOS/DUAL OS support, The physical address memory size used. |
isMux |
whether multi sensor use same dev |
switchGpioIdx |
only ALIOS/DUAL OS support. gpio bank, -1 means not use gpio |
switchGpioPin |
gpio pin, -1 means not use gpio |
switchGPioPol |
gpio value[0,1], -1 means not use gpio |
disEnableSbm |
Sns timing support SBM or not |
isFrmCtrl |
only ALIOS/DUAL OS support. whether to enable frame ctrl |
dstFrm |
only ALIOS/DUAL OS support. set dst frm for switch |
The u32Width in stSize must be equal to the width of the actual input image,
and the u32Height must be equal to the height of the actual input image,
otherwise there no image will be output.
None.
4.4.28. VI_DEV_BIND_PIPE_S¶
typedef struct _VI_DEV_BIND_PIPE_S {
CVI_U32 u32Num; /* RW;Range [1,VI_MAX_PIPE_NUM] */
VI_PIPE PipeId[VI_MAX_PIPE_NUM]; /* RW;Array of pipe ID */
} VI_DEV_BIND_PIPE_S;
【Member】
Member |
U32Num |
Number of PIPEs bound to this VI Dev, Value range: [1, VI_MAX_PIPE_NUM] |
PipeId |
The PIPE ID bound to the VI Dev. |
None.
None.
4.4.29. VI_PIPE_ATTR_S¶
typedef struct _VI_PIPE_ATTR_S {
VI_PIPE_BYPASS_MODE_E enPipeBypassMode;
CVI_BOOL bYuvSkip; /* RW;YUV skip enable */
CVI_BOOL bIspBypass; /* RW;ISP bypass enable */
CVI_U32 u32MaxW; /* RW;Range[VI_PIPE_MIN_WIDTH,VI_PIPE_MAX_WIDTH];Maximum width */
CVI_U32 u32MaxH; /* RW;Range[VI_PIPE_MIN_HEIGHT,VI_PIPE_MAX_HEIGHT];Maximum height */
PIXEL_FORMAT_E enPixFmt; /* RW;Pixel format */
COMPRESS_MODE_E enCompressMode; /* RW;Compress mode.*/
DATA_BITWIDTH_E enBitWidth; /* RW;Bit width*/
CVI_BOOL bNrEn; /* RW;3DNR enable */
CVI_BOOL bSharpenEn; /* RW;Sharpen enable*/
FRAME_RATE_CTRL_S stFrameRate; /* RW;Frame rate */
CVI_BOOL bDiscardProPic;
CVI_BOOL bYuvBypassPath;
CVI_BOOL b3dnrBypass; /* RW;ISP 3dnr bypass enable */
} VI_PIPE_ATTR_S;
【Member】
Member |
enPipeBypassMode |
Bypass mode for VI PIPE. |
bYuvSkip |
Whether to turn off downsampling and CSC. CVI_FALSE: yuv skip unenable CVI_TRUE: yuv skip enable |
bIspBypass |
Whether the ISP is bypassed. CVI_FALSE: ISP working properly. CVI_TRUE: ISP bypass, do not run ISP. |
u32MaxW |
The input image width. This is a static attribute set when the PIPE is created and cannot be changed. Value range under online mode:: [VI_PIPE_ONLINE_MIN_WIDTH, VI_PIPE_ONLINE_MAX_WIDTH] Value range under offline mode: [VI_PIPE_OFFLINE_MIN_WIDTH, VI_PIPE_OFFLINE_MAX_WIDTH] |
u32MaxH |
The input image height. Value range: Value range under online mode: [VI_PIPE_ONLINE_MIN_HEIGHT, VI_PIPE_ONLINE_MAX_HEIGHT] Value range under offline mode: [VI_PIPE_OFFLINE_MIN_HEIGHT, VI_PIPE_OFFLINE_MAX_HEIGHT] |
enPixFmt |
Pixel format. |
enCompressMode |
Data compression format. |
enBitWidth |
The bit width of the input image. Set during PIPE creation and cannot be changed, only valid when pixel format enPixFmt is a YUV pixel format. |
bNrEn |
NR enable switch. CVI_FALSE: unenable; CVI_TRUE: enable |
bSharpenEn |
Sharpen enable switch. |
stFrameRate |
Frame rate control. |
bDiscardProPic |
Whether to discard long exposure frames. |
bYuvBypassPath |
Whether to switch to YUV pass-through mode |
b3dnrBypass |
only ALIOS/DUAL OS support.Is 3dnr bypass enable |
None.
None.
4.4.30. VI_DUMP_TYPE_E¶
typedef enum _VI_DUMP_TYPE_E {
VI_DUMP_TYPE_RAW = 0,
VI_DUMP_TYPE_YUV = 1,
VI_DUMP_TYPE_IR = 2,
VI_DUMP_TYPE_BUTT
} VI_DUMP_TYPE_E;
【Member】
Member |
VI_DUMP_TYPE_RAW |
Dump RAW data |
VI_DUMP_TYPE_YUV |
Dump YUV data |
VI_DUMP_TYPE_IR |
Dump IR Component data. |
Does not support Dump IR data
To Dump YUV, run CVI_VI_GetChnFrame
None.
4.4.31. VI_DUMP_ATTR_S¶
Define the PIPE dump property.
typedef struct _VI_DUMP_ATTR_S {
CVI_BOOL bEnable; /* RW;Whether dump is enable */
CVI_U32 u32Depth; /* RW;Range [0,8];Depth */
VI_DUMP_TYPE_E enDumpType;
} VI_DUMP_ATTR_S;
【Member】
Member |
benable |
Whether to enable dump. |
u32depth |
Queue depth for dumping data. Value range: [0, 8] |
endumptype |
Dumping data type. |
None.
CVI_VI_SetPipeDumpAttr
CVI_VI_GetPipeDumpAttr
4.4.32. VI_CHN_ATTR_S¶
typedef struct _VI_CHN_ATTR_S {
SIZE_S stSize; /* RW;Channel out put size */
PIXEL_FORMAT_E enPixelFormat; /* RW;Pixel format */
DYNAMIC_RANGE_E enDynamicRange; /* RW;Dynamic Range */
VIDEO_FORMAT_E enVideoFormat; /* RW;Video format */
COMPRESS_MODE_E enCompressMode; /* RW;256B Segment compress or no compress. */
CVI_BOOL bMirror; /* RW;Mirror enable */
CVI_BOOL bFlip; /* RW;Flip enable */
CVI_U32 u32BindVbPool; /*chn bind vb*/
} VI_CHN_ATTR_S;
【Member】
Member |
stSize |
Target image size. The minimum and maximum width and height of the target image: Height in online mode [VI_PHYCHN_ONLINE_MIN_HEIGHT, VI_PHYCHN_ONLINE_MAX_HEIGHT] Height in offline mode [VI_PHYCHN_OFFLINE_MIN_HEIGHT, VI_PHYCHN_OFFLINE_MAX_HEIGHT] Width in online mode [VI_PHYCHN_ONLINE_MIN_WIDTH, VI_PHYCHN_ONLINE_MAX_WIDTH] Width in offline mode [VI_PHYCHN_OFFLINE_MIN_WIDTH, VI_PHYCHN_OFFLINE_MAX_WIDTH] |
enPixelFormat |
Target image pixel format. |
enDynamicRange |
The dynamic range of the target image. |
enVideoFormat |
Video data format of the target image. |
enCompressMode |
Compression format of the target image. |
bMirror |
Mirror enable switch. CVI_FALSE: disable; CVI_TRUE: enable |
bFlip |
Flip enable switch CVI_FALSE: disable; CVI_TRUE: enable |
u32Depth |
User polling depth for getting images. |
stFrameRate |
Frame rate control. Source frame rate range: (0, 240], and -1. When the source frame rate is -1, the target frame rate must be set to -1 (no frame rate control), and in other cases, the target frame rate cannot be greater than the source frame rate. |
u32BindVbPool |
VB pool ID bound to the channel |
Currently, VI does not support frame rate control
CVI_VI_SetChnAttr
CVI_VI_GetChnAttr
4.4.33. VI_CROP_INFO_S¶
typedef struct _VI_CROP_INFO_S {
CVI_BOOL bEnable; /* RW;CROP enable*/
VI_CROP_COORDINATE_E enCropCoordinate; /* RW;Coordinate mode of the crop start point*/
RECT_S stCropRect; /* RW;CROP rectangular*/
} VI_CROP_INFO_S;
【Member】
Member |
bEnable |
CROP enable switch |
enCropCoordinate |
CROP starting point coordinate mode. |
stCropRect |
Rectangular area of CROP. |
None.
None.
4.4.34. VI_DEV_TIMING_ATTR_S¶
User defined timing properties.
typedef struct _VI_DEV_TIMING_ATTR_S {
CVI_BOOL bEnable; /* RW;Whether enable VI generate timing */
CVI_S32 s32FrmRate; /* RW;Generate timing Frame rate*/
} VI_DEV_TIMING_ATTR_S;
【Member】
Member |
bEnable |
User defined timing enable switch. |
s32FrmRate |
The frame rate of the user-defined timing. |
When the user-defined timing is enabled, if the frame rate set by the user exceeds the maximum frame rate of the device, the system will automatically take the maximum frame rate of the device as the effective value.
CVI_VI_SetDevTimingAttr
4.4.35. VI_PIPE_STATUS_S¶
Define the status information of VI pipe.
typedef struct _VI_PIPE_STATUS_S {
CVI_BOOL bEnable; /* RO;Whether this pipe is enabled */
CVI_U32 u32IntCnt; /* RO;The video frame interrupt count */
CVI_U32 u32FrameRate; /* RO;Current frame rate */
CVI_U32 u32LostFrame; /* RO;Lost frame count */
CVI_U32 u32VbFail; /* RO;Video buffer malloc failure */
SIZE_S stSize; /* RO;Current pipe output size */
} VI_PIPE_STATUS_S;
【Member】
Member |
bEnable |
Whether the current pipe is enabled. |
u32IntCnt |
Interrupt count. |
u32FrameRate |
Real time frame rate of VI pipe. |
u32LostFrame |
Lost frame count. |
u32VbFail |
VB application failure count. |
stSize |
Current pipe output size |
None.
None.
4.4.36. VI_CHN_STATUS_S¶
Define the status information of VI channel.
typedef struct _VI_CHN_STATUS_S {
CVI_BOOL bEnable; /* RO;Whether this channel is enabled */
CVI_U32 u32FrameRate; /* RO;current frame rate */
SIZE_S stSize; /* RO;chn output size */
} VI_CHN_STATUS_S;
【Member】
Member |
bEnable |
Whether the current PIPE is enabled. |
u32FrameRate |
Real time frame rate of channel. |
u32LostFrame |
Lost frame count. |
u32VbFail |
stSize |
Current channel output size. |
None.
None.
4.4.37. VI_PIPE_FRAME_SOURCE_E¶
typedef enum _VI_PIPE_FRAME_SOURCE_E {
VI_PIPE_FRAME_SOURCE_DEV = 0, /* RW;Source from dev */
VI_PIPE_FRAME_SOURCE_USER_FE, /* RW;User send to FE */
VI_PIPE_FRAME_SOURCE_USER_BE, /* RW;User send to BE */
VI_PIPE_FRAME_SOURCE_BUTT
} VI_PIPE_FRAME_SOURCE_E;
【Member】
Member |
vi_pipe_frame_source_dev |
The data comes from the device. |
vi_pipe_frame_source_user_fe |
The data comes from the user’s data sent in from FE |
vi_pipe_frame_source_user_be |
The data comes from the user’s data sent in from BE |
Do not support data from BE.
CVI_VI_SetPipeFrameSource
4.4.38. VI_LDC_ATTR_S¶
Define VI lens distortion correction structure
typedef struct _VI_LDC_ATTR_S {
CVI_BOOL bEnable;
LDC_ATTR_S stAttr;
} VI_LDC_ATTR_S;
【Member】
Member |
benable |
LDC enable |
stattr |
LDC properties |
None.
LDC_ATTR_S
CVI_VI_GetChnLDCAttr
CVI_VI_SetChnLDCAttr
4.4.39. VI_STATE_E¶
typedef enum _VI_STATE {
VI_RUNNING,
VI_SUSPEND,
VI_MAX,
} VI_STATE_E;
【Member】
Member |
VI_RUNNING |
VI is running. |
VI_SUSPEND |
VI is in sleep mode. |
None.
None.
4.4.40. VI_SYNC_CFG_S¶
typedef struct _VI_SYNC_CFG_S {
VI_VSYNC_E enVsync;
VI_VSYNC_NEG_E enVsyncNeg;
VI_HSYNC_E enHsync;
VI_HSYNC_NEG_E enHsyncNeg;
VI_VSYNC_VALID_E enVsyncValid;
VI_VSYNC_VALID_NEG_E enVsyncValidNeg;
VI_TIMING_BLANK_S stTimingBlank;
} VI_SYNC_CFG_S;
【Member】
Member |
enVsync |
Configuration of Vertical Synchronization Signal |
enVsyncNeg |
The effective state of the vertical synchronization signal |
enHsync |
Configuration of horizontal synchronization signal |
enHsyncNeg |
The effective state of the horizontal synchronization signal |
enVsyncValid |
Configuration of effective signals for vertical synchronization |
enVsyncValidNeg |
The effective state of the vertical synchronization effective signal |
stTimingBlank |
Parameters related to timeing blank |
None.
None.
4.4.41. VI_BT656_SYNC_CFG_S¶
typedef struct _VI_BT656_SYNC_CFG_S {
VI_BT656_FIXCODE_E enFixCode;
VI_BT656_FIELD_POLAR_E enFieldPolar;
} VI_BT656_SYNC_CFG_S;
【Member】
Member |
enFixCode |
Fixed code configuration |
enFieldPolar |
Configuration of field polarity |
None.
None.
4.4.42. VI_PIPE_BYPASS_MODE_E¶
typedef enum _VI_PIPE_BYPASS_MODE_E {
VI_PIPE_BYPASS_NONE,
VI_PIPE_BYPASS_FE,
VI_PIPE_BYPASS_BE,
VI_PIPE_BYPASS_BUTT
} VI_PIPE_BYPASS_MODE_E;
【Member】
Member |
VI_PIPE_BYPASS_NONE |
VI pipeline no bypass |
VI_PIPE_BYPASS_FE |
VI pipeline fe bypass |
VI_PIPE_BYPASS_BE |
VI pipeline be bypas |
None.
None.
4.4.43. VI_CROP_COORDINATE_E¶
typedef enum _VI_CROP_COORDINATE_E {
VI_CROP_RATIO_COOR = 0,
VI_CROP_ABS_COOR,
VI_CROP_BUTT
} VI_CROP_COORDINATE_E;
【Member】
Member |
VI_CROP_RATIO_COOR |
Crop coordinates using ratio coordinates |
VI_CROP_ABS_COOR |
Crop coordinates using absolute coordinates |
None.
None.
4.4.44. VI_MOD_PARAM_S¶
typedef struct _VI_MOD_PARAM_S {
CVI_S32 s32DetectErrFrame;
CVI_U32 u32DropErrFrame;
} VI_MOD_PARAM_S;
【Member】
Member |
s32DetectErrFrame |
The number of error frames detected |
u32DropErrFrame |
The number of discarded error frames |
None.
None.
4.4.45. VI_EARLY_INTERRUPT_S¶
typedef struct _VI_EARLY_INTERRUPT_S {
CVI_BOOL bEnable;
CVI_U32 u32LineCnt;
} VI_EARLY_INTERRUPT_S;
【Member】
Member |
bEnable |
Enable the early interrupt function or not |
u32LineCnt |
Early Interrupted line Count |
None.
None.
4.4.46. MLSC_GAIN_LUT_S¶
Gain lookup table.
typedef struct _MLSC_GAIN_LUT_S {
CVI_U16 *RGain;
CVI_U16 *GGain;
CVI_U16 *BGain;
} MLSC_GAIN_LUT_S;
【Member】
Member |
RGain |
lut pointing to the red gain value |
GGain |
lut pointing to the green gain value |
BGain |
lut pointing to the blue gain value |
None.
None.
4.4.47. VI_DUMP_REGISTER_TABLE_S¶
typedef struct _VI_DUMP_REGISTER_TABLE_S {
MLSC_GAIN_LUT_S MlscGainLut;
} VI_DUMP_REGISTER_TABLE_S;
【Member】
Member |
MlscGainLut |
Gain lookup table |
None.
None.
4.4.48. VI_PM_OPS_S¶
typedef struct _VI_PM_OPS_S {
pfnViDevPmOps pfnSnsSuspend;
pfnViDevPmOps pfnSnsResume;
pfnViDevPmOps pfnMipiSuspend;
pfnViDevPmOps pfnMipiResume;
} VI_PM_OPS_S;
【Member】
Member |
pfnSnsSuspend |
Sensor suspend operation |
pfnSnsResume |
Sensor resume operation |
pfnMipiSuspend |
Mipi suspend operation |
pfnMipiResume |
Mipi resume operation |
None.
None.
4.4.49. VI_SMOOTH_RAW_DUMP_INFO_S¶
typedef struct _VI_SMOOTH_RAW_DUMP_INFO_S {
VI_PIPE ViPipe;
RECT_S stCropRect;
CVI_U8 u8BlkCnt;
CVI_U32 phy_size;
CVI_U64 *phy_addr_list;
CVI_U32 padding[2];
} VI_SMOOTH_RAW_DUMP_INFO_S;
【Member】
Member |
ViPipe |
vi pipe。 |
stCropRect |
Crop rectangular area |
u8BlkCnt |
The number of buffer blocks |
phy_size |
only ALIOS/DUAL OS support. The size of each buffer zone |
phy_addr_list |
Physical address list |
padding |
only ALIOS/DUAL OS support. Pad Field |
None.
None.
4.4.50. VI_INTF_MODE_E¶
typedef enum _VI_INTF_MODE_E {
VI_MODE_BT656 = 0,
VI_MODE_BT601,
VI_MODE_DIGITAL_CAMERA,
VI_MODE_BT1120_STANDARD,
VI_MODE_BT1120_INTERLEAVED,
VI_MODE_MIPI,
VI_MODE_MIPI_YUV420_NORMAL,
VI_MODE_MIPI_YUV420_LEGACY,
VI_MODE_MIPI_YUV422,
VI_MODE_LVDS,
VI_MODE_HISPI,
VI_MODE_SLVS,
VI_MODE_BUTT
} VI_INTF_MODE_E;
【Member】
Member |
VI_MODE_BT656 |
BT656 mode |
VI_MODE_BT601 |
BT601 mode |
VI_MODE_DIGITAL_CAMERA |
digatal camera mode |
VI_MODE_BT1120_STANDARD |
BT.1120 progressive mode |
VI_MODE_BT1120_INTERLEAVED |
BT.1120 interstage mode |
VI_MODE_MIPI |
MIPI RAW mode |
VI_MODE_MIPI_YUV420_NORMAL |
MIPI YUV420 normal mode |
VI_MODE_MIPI_YUV420_LEGACY |
MIPI YUV420 legacy mode |
VI_MODE_MIPI_YUV422 |
MIPI YUV422 mode |
VI_MODE_LVDS |
LVDS mode |
VI_MODE_HISPI |
HISPI mode |
VI_MODE_SLVS |
SLVS mode |
None.
None.
4.4.51. VI_INPUT_MODE_E¶
Input mode.
typedef enum _VI_INPUT_MODE_E {
VI_INPUT_MODE_BT656 = 0,
VI_INPUT_MODE_BT601,
VI_INPUT_MODE_DIGITAL_CAMERA,
VI_INPUT_MODE_INTERLEAVED,
VI_INPUT_MODE_MIPI,
VI_INPUT_MODE_LVDS,
VI_INPUT_MODE_HISPI,
VI_INPUT_MODE_SLVS,
VI_INPUT_MODE_BUTT
} VI_INPUT_MODE_E;
【Member】
Member |
VI_INPUT_MODE_BT656 |
BT656 mode |
VI_INPUT_MODE_BT601 |
BT601 mode |
VI_INPUT_MODE_DIGITAL_CAMERA |
VI_INPUT_MODE_INTERLEAVED |
interstage mode |
VI_INPUT_MODE_MIPI |
MIPI mode |
VI_INPUT_MODE_LVDS |
LVDS mode |
VI_INPUT_MODE_HISPI |
HiSPi mode |
VI_INPUT_MODE_SLVS |
SLVS mode |
None.
None.
4.4.52. VI_WORK_MODE_E¶
Work mode.
typedef enum _VI_WORK_MODE_E {
VI_WORK_MODE_1Multiplex = 0,
VI_WORK_MODE_2Multiplex,
VI_WORK_MODE_3Multiplex,
VI_WORK_MODE_4Multiplex,
VI_WORK_MODE_BUTT
} VI_WORK_MODE_E;
【Member】
Member |
VI_WORK_MODE_1Multiplex |
1 Multiplex mode |
VI_WORK_MODE_2Multiplex |
2 Multiplex mode |
VI_WORK_MODE_3Multiplex |
3 Multiplex mode |
VI_WORK_MODE_4Multiplex |
4 Multiplex mode |
None.
None.
4.4.53. VI_SCAN_MODE_E¶
typedef enum _VI_SCAN_MODE_E {
VI_SCAN_INTERLACED = 0,
VI_SCAN_PROGRESSIVE,
VI_SCAN_BUTT
} VI_SCAN_MODE_E;
【Member】
Member |
VI_SCAN_INTERLACED |
interlaced mode |
VI_SCAN_PROGRESSIVE |
progressive mode |
None.
None.
4.4.54. VI_YUV_DATA_SEQ_E¶
typedef enum _VI_YUV_DATA_SEQ_E {
VI_DATA_SEQ_VUVU = 0,
VI_DATA_SEQ_UVUV,
VI_DATA_SEQ_UYVY,
VI_DATA_SEQ_VYUY,
VI_DATA_SEQ_YUYV,
VI_DATA_SEQ_YVYU,
VI_DATA_SEQ_BUTT
} VI_YUV_DATA_SEQ_E;
【Member】
Member |
VI_DATA_SEQ_VUVU |
The input sequence of the second component(only contains u and v) in BT.1120 mode is VUVU |
VI_DATA_SEQ_UVUV |
The input sequence of the second component(only contains u and v) in BT.1120 mode is UVUV |
VI_DATA_SEQ_UYVY |
The input sequence of YUV is UYVY |
VI_DATA_SEQ_VYUY |
The input sequence of YUV is VYUY |
VI_DATA_SEQ_YUYV |
The input sequence of YUV is YUYV |
VI_DATA_SEQ_YVYU |
The input sequence of YUV is YVYU |
None.
None.
4.4.55. VI_CLK_EDGE_E¶
Clock edge mode.
typedef enum _VI_CLK_EDGE_E {
VI_CLK_EDGE_SINGLE_UP = 0,
VI_CLK_EDGE_SINGLE_DOWN,
VI_CLK_EDGE_BUTT
} VI_CLK_EDGE_E;
【Member】
Member |
VI_CLK_EDGE_SINGLE_UP |
single-edge mode and in rising edge |
VI_CLK_EDGE_SINGLE_DOWN |
single-edge mode and in falling edge |
None.
None.
4.4.56. VI_COMPONENT_MODE_E¶
Component mode.
typedef enum _VI_COMPONENT_MODE_E {
VI_COMPONENT_MODE_SINGLE = 0,
VI_COMPONENT_MODE_DOUBLE,
VI_COMPONENT_MODE_BUTT
} VI_COMPONENT_MODE_E;
【Member】
Member |
VI_COMPONENT_MODE_SINGLE |
single component mode |
VI_COMPONENT_MODE_DOUBLE |
double component mode |
None.
None.
4.4.57. VI_COMBINE_MODE_E¶
typedef enum _VI_COMBINE_MODE_E {
VI_COMBINE_COMPOSITE = 0,
VI_COMBINE_SEPARATE,
VI_COMBINE_BUTT
} VI_COMBINE_MODE_E;
【Member】
Member |
VI_COMBINE_COMPOSITE |
Composite mode |
VI_COMBINE_SEPARATE |
Separate mode |
None.
None.
4.4.58. VI_VSYNC_E¶
typedef enum _VI_VSYNC_E {
VI_VSYNC_FIELD = 0,
VI_VSYNC_PULSE,
VI_VSYNC_BUTT
} VI_VSYNC_E;
【Member】
Member |
VI_VSYNC_FIELD |
Field/toggle mode:a signal reversal means a new frame or a field |
VI_VSYNC_PULSE |
Pusle/effective mode:a pusle or an effective signal means a new frame or a field |
None.
None.
4.4.59. VI_VSYNC_NEG_E¶
typedef enum _VI_VSYNC_NEG_E {
VI_VSYNC_NEG_HIGH = 0,
VI_VSYNC_NEG_LOW,
VI_VSYNC_NEG_BUTT
} VI_VSYNC_NEG_E;
【Member】
Member |
VI_VSYNC_NEG_HIGH |
if VIU_VSYNC_E = VIU_VSYNC_FIELD,then the v-sync signal of even field is high-level,if VIU_VSYNC_E = VIU_VSYNC_PULSE,then the v-sync pulse is positive pulse. |
VI_VSYNC_NEG_LOW |
if VIU_VSYNC_E = VIU_VSYNC_FIELD,then the v-sync signal of even field is low-level,if VIU_VSYNC_E = VIU_VSYNC_PULSE,then the v-sync pulse is negative pulse. |
None.
None.
4.4.60. VI_HSYNC_E¶
typedef enum _VI_HSYNC_E {
VI_HSYNC_VALID_SINGNAL = 0,
VI_HSYNC_PULSE,
VI_HSYNC_BUTT
} VI_HSYNC_E;
【Member】
Member |
VI_HSYNC_VALID_SINGNAL |
the h-sync is valid signal mode |
VI_HSYNC_PULSE |
the h-sync is pulse mode, a new pulse means the beginning of a new line |
None.
None.
4.4.61. VI_HSYNC_NEG_E¶
typedef enum _VI_HSYNC_NEG_E {
VI_HSYNC_NEG_HIGH = 0,
VI_HSYNC_NEG_LOW,
VI_HSYNC_NEG_BUTT
} VI_HSYNC_NEG_E;
【Member】
Member |
VI_HSYNC_NEG_HIGH |
if VI_HSYNC_E = VI_HSYNC_VALID_SINGNAL,then the valid h-sync signal is high-level;if VI_HSYNC_E = VI_HSYNC_PULSE,then the h-sync pulse is positive pulse |
VI_HSYNC_NEG_LOW |
if VI_HSYNC_E = VI_HSYNC_VALID_SINGNAL,then the valid h-sync signal is low-level;if VI_HSYNC_E = VI_HSYNC_PULSE,then the h-sync pulse is negative pulse |
None.
None.
4.4.62. VI_VSYNC_VALID_E¶
typedef enum _VI_VSYNC_VALID_E {
VI_VSYNC_NORM_PULSE = 0,
VI_VSYNC_VALID_SIGNAL,
VI_VSYNC_VALID_BUTT
} VI_VSYNC_VALID_E;
【Member】
Member |
VI_VSYNC_NORM_PULSE |
the v-sync is pusle mode, a pusle means a new frame or field |
VI_VSYNC_VALID_SIGNAL |
the v-sync is effective mode, a effective signal means a new frame or field |
None.
None.
4.4.63. VI_VSYNC_VALID_NEG_E¶
typedef enum _VI_VSYNC_VALID_NEG_E {
VI_VSYNC_VALID_NEG_HIGH = 0,
VI_VSYNC_VALID_NEG_LOW,
VI_VSYNC_VALID_NEG_BUTT
} VI_VSYNC_VALID_NEG_E;
【Member】
Member |
VI_VSYNC_VALID_NEG_HIGH |
if VI_VSYNC_VALID_E = VI_VSYNC_NORM_PULSE,a positive pulse means v-sync pulse;if VI_VSYNC_VALID_E = VI_VSYNC_VALID_SIGNAL,the valid v-sync signal is high-level |
VI_VSYNC_VALID_NEG_LOW |
if VI_VSYNC_VALID_E = VI_VSYNC_NORM_PULSE,a negative pulse means v-sync pulse;if VI_VSYNC_VALID_E = VI_VSYNC_VALID_SIGNAL,the valid v-sync signal is low-level |
None.
None.
4.4.64. VI_WDR_ATTR_S¶
Attribute of wdr.
typedef struct _VI_WDR_ATTR_S {
WDR_MODE_E enWDRMode;
CVI_U32 u32CacheLine;
CVI_BOOL bSyntheticWDR;
} VI_WDR_ATTR_S;
【Member】
Member |
enWDRMode |
WDR mode |
u32CacheLine |
WDR cache line |
bSyntheticWDR |
Synthetic WDR mode |
None.
None.
4.4.65. VI_TIMING_BLANK_S¶
typedef struct _VI_TIMING_BLANK_S {
CVI_U32 u32HsyncHfb;
CVI_U32 u32HsyncAct;
CVI_U32 u32HsyncHbb;
CVI_U32 u32VsyncVfb;
CVI_U32 u32VsyncVact;
CVI_U32 u32VsyncVbb;
CVI_U32 u32VsyncVbfb;
CVI_U32 u32VsyncVbact;
CVI_U32 u32VsyncVbbb;
} VI_TIMING_BLANK_S;
【Member】
Member |
u32HsyncHfb |
Horizontal front blanking width |
u32HsyncAct |
Horizontal effetive width |
u32HsyncHbb |
Horizontal back blanking width |
u32VsyncVfb |
Vertical front blanking height of one frame or odd-field frame picture |
u32VsyncVact |
Vertical effetive width of one frame or odd-field frame picture |
u32VsyncVbb |
Vertical back blanking height of one frame or odd-field frame picture |
u32VsyncVbfb |
Even-field vertical front blanking height when input mode is interlace(invalid when progressive input mode) |
u32VsyncVbact |
Even-field vertical effetive width when input mode is interlace(invalid when progressive input mode) |
u32VsyncVbbb |
Even-field vertical back blanking height when input mode is interlace(invalid when progressive input mode) |
None.
None.
4.4.66. VI_BT656_FIXCODE_E¶
typedef enum _VI_BT656_FIXCODE_E {
VI_BT656_FIXCODE_1 = 0,
VI_BT656_FIXCODE_0,
VI_BT656_FIXCODE_BUTT
} VI_BT656_FIXCODE_E;
【Member】
Member |
VI_BT656_FIXCODE_1 |
The highest bit of the EAV/SAV data over the BT.656 protocol is always 1 |
VI_BT656_FIXCODE_0 |
The highest bit of the EAV/SAV data over the BT.656 protocol is always 0 |
None.
None.
4.4.67. VI_BT656_FIELD_POLAR_E¶
typedef struct _VI_BT656_FIELD_POLAR_E {
VI_BT656_FIELD_POLAR_STD = 0,
VI_BT656_FIELD_POLAR_NSTD,
VI_BT656_FIELD_POLAR_BUTT
} VI_BT656_FIELD_POLAR_E;
【Member】
Member |
VI_BT656_FIELD_POLAR_STD |
the standard BT.656 mode,the first filed F=0,the second filed F=1 |
VI_BT656_FIELD_POLAR_NSTD |
the standard BT.656 mode,the first filed F=1,the second filed F=0 |
None.
None.
4.4.68. VI_DEV_ATTR_EX_S¶
typedef struct _VI_DEV_ATTR_EX_S {
VI_INPUT_MODE_E enInputMode;
VI_COMBINE_MODE_E enCombineMode;
VI_COMPONENT_MODE_E enComponentMode;
VI_CLK_EDGE_E enClkEdge;
CVI_U32 au32ComponentMask[VI_COMPMASK_NUM];
VI_BT656_SYNC_CFG_S stBT656SynCfg;
CVI_BOOL bDataReverse;
SIZE_S stSize;
} VI_DEV_ATTR_EX_S;
【Member】
Member |
enInputMode |
Input mode |
enWorkMode |
Work mode |
enCombineMode |
Y/C composite or separation mode |
enComponentMode |
Component mode (single-component or dual-component) |
enClkEdge |
Clock edge mode (sampling on the rising or falling edge) |
au32ComponentMask |
Component mask |
enScanMode |
Input scanning mode (progressive or interlaced) |
as32AdChnId |
AD channel ID. Typically, the default value -1 is recommended |
enDataSeq |
Input data sequence (only the YUV format is supported) |
stSynCfg |
Sync timing. This member must be configured in BT.601 mode or DC mode |
stBT656SynCfg |
Sync timing. This member must be configured in BT.656 mode |
enInputDataType |
VI input data type enumeration |
bDataReverse |
Data reverse |
stSize |
Input size |
stWDRAttr |
Attribute of WDR |
None.
None.
4.4.69. VI_EXT_CHN_SOURCE_E¶
typedef enum _VI_EXT_CHN_SOURCE_E {
VI_EXT_CHN_SOURCE_TAIL,
VI_EXT_CHN_SOURCE_HEAD,
VI_EXT_CHN_SOURCE_BUTT
} VI_EXT_CHN_SOURCE_E;
【Member】
Member |
VI_EXT_CHN_SOURCE_TAIL |
Tail source of VI external channel |
VI_EXT_CHN_SOURCE_HEAD |
HEAD source of VI external channel |
None.
None.
4.4.70. VI_EXT_CHN_ATTR_S¶
typedef struct _VI_EXT_CHN_ATTR_S {
VI_EXT_CHN_SOURCE_E enSource;
VI_CHN s32BindChn;
SIZE_S stSize;
CVI_U32 u32Depth;
} VI_EXT_CHN_ATTR_S;
【Member】
Member |
enSource |
extended channel data source |
s32BindChn |
The channel num which extend channel will bind to |
stSize |
Channel out put size |
enPixelFormat |
Pixel format |
u32Depth |
Depth |
stFrameRate |
Frame rate |
None.
None.
