4.2. Design Overview
4.2.1. System Architecture
../_images/Design0023.png
  • VI is divided into four levels: input device (DEV), image capture device (ISP_FE), image processing (ISP_BE), and image correction (CHN).
  • Sensor transmits images through CIF interface and delivers images to ISP_FE, which extracts statistics such as AE, AWB, AF, etc., and stores raw files in DDR. Then, the ISP_BE converts the color space and adjusts the image quality of the raw files in either online or offline mode before storing the YUV in DDR. Finally, the backend CHN can perform processing such as crop, rotation on the YUV data.
  • The parameter configuration of current processor devices is shown in Table 4.1 .
Table 4.1 Capability of each processor series
Processor
DEV
PHY_PIPE
PHY_CHN
VIR_CHN
MAX resolution
FPS
CV181x
3
5
5
0
5M(2880x1620)
30
CV180x
1
1
1
0
4M(2560x1440)
30
Attention
CV180x does not support HDR.
4.2.2. Video Input PIPE
  • The PIPE of VI contains the relevant processing functions of ISP, mainly for pipelining image data processing and outputting YUV image format to channels. Please refer to the “VI and VPSS” work mode description in the “System Control” chapter for the working mode of PIPE.
4.2.3. Video Physical Channel
4.2.4. Binding Relationship
  • The binding relationship between Dev and CIF is fixed and cannot be modified dynamically.
  • The constraint relationship between Dev and timing input interface is shown in Table 4.2 .
Table 4.2 Binding Relationship between DEV and MIPI/SLVS interface
VI DEV
MIPI
SLVS
BT.1120/BT.656/BT.601
DC
TTL
0
0
0
0
X
X
1
1
1
1
X
X
2
X
X
X
X
2
