4.5. Error Codes¶
The error codes of video input API are defined as follows:
Error code |
Macro definition |
0xC00E8001 |
CVI_ERR_VI_INVALID_DEVID |
Invalid device number |
0xC00E8002 |
CVI_ERR_VI_INVALID_CHNID |
Invalid channel number |
0xC00E8003 |
CVI_ERR_VI_INVALID_PARA |
Invalid parameter setting |
0xC00E8004 |
CVI_ERR_VI_PIPE_EXIST |
PIPE already exists |
0xC00E8005 |
CVI_ERR_VI_PIPE_UNEXIST |
PIPE does not exist |
0xC00E8006 |
CVI_ERR_VI_INVALID_NULL_PTR |
Null pointer error |
0xC00E8007 |
CVI_ERR_VI_FAILED_NOTCONFIG |
Device or channel properties are not configured |
0xC00E8008 |
CVI_ERR_VI_NOT_SUPPORT |
Operation not supported |
0xC00E8009 |
CVI_ERR_VI_NOT_PERM |
Operation forbidden |
0xC00E800A |
CVI_ERR_VI_INVALID_PIPEID |
Invalid PIPE ID |
0xC00E800C |
CVI_ERR_VI_NOMEM |
Memory allocation error |
0xC00E800E |
CVI_ERR_VI_BUF_EMPTY |
The cache is empty |
0xC00E800F |
CVI_ERR_VI_BUF_FULL |
The cache is full |
0xC00E8010 |
CVI_ERR_VI_SYS_NOTREADY |
The system is not initialized |
0xC00E8012 |
CVI_ERR_VI_BUSY |
The system is busy |
0xC00E8040 |
CVI_ERR_VI_FAILED_NOTENABLE |
The device has not been started |
0xC00E8041 |
CVI_ERR_VI_FAILED_NOTDISABLE |
The device has not been shut down |
0xC00E8042 |
CVI_ERR_VI_FAILED_CHNOTDISABLE |
The channel has not been closed |
0xC00E8043 |
CVI_ERR_VI_CFG_TIMEOUT |
Configuration timeout |
0xC00E8044 |
CVI_ERR_VI_NORM_UNMATCH |
No matching number found |
0xC00E8045 |
CVI_ERR_VI_INVALID_WAYID |
Invalid channel ID |
0xC00E8046 |
CVI_ERR_VI_INVALID_PHYCHNID |
Invalid physical channel ID |
0xC00E8047 |
CVI_ERR_VI_FAILED_NOTBIND |
Channel unbound |
0xC00E8048 |
CVI_ERR_VI_FAILED_BINDED |
Channel binding failed |
