6.3. API Reference¶
The function module provides the following APIs for users.
CVI_VPSS_CreateGrp: Create a VPSS GROUP.
CVI_VPSS_DestroyGrp: Destroy a VPSS GROUP.
CVI_VPSS_GetAvailableGrp:Get an available VPSS group number.
CVI_VPSS_GetGrpAttr: Get properties of VPSS GROUP.
CVI_VPSS_SetGrpAttr: Set properties of VPSS GROUP.
CVI_VPSS_StartGrp: Enable VPSS GROUP.
CVI_VPSS_StopGrp: Disable VPSS GROUP.
CVI_VPSS_ResetGrp: Reset a VPSS GROUP.
CVI_VPSS_GetGrpProcAmpCtrl: Get a description of the color control function of VPSS GROUP.
CVI_VPSS_GetGrpProcAmp: Get the color control property of a VPSS GROUP.
CVI_VPSS_SetGrpProcAmp: Set the color control property of a VPSS GROUP.
CVI_VPSS_GetAllProcAmp: Get the color control property of all VPSS GROUP.
CVI_VPSS_SetGrpParamfromBin: Set the property of a VPSS GROUP according to Bin.
CVI_VPSS_SetGrpParam_fromLinuxBin: Set the property of a VPSS GROUP according to Bin in linux.
CVI_VPSS_GetBinScene: Get scene from bin.
CVI_VPSS_GetChnAttr: Get VPSS channel properties.
CVI_VPSS_SetChnAttr: Set VPSS channel properties.
CVI_VPSS_EnableChn: Enable VPSS channel.
CVI_VPSS_DisableChn: Disable VPSS channel.
CVI_VPSS_SetGrpCrop: Set the VPSS GROUP CROP function properties.
CVI_VPSS_GetGrpCrop: Get the VPSS GROUP CROP function properties.
CVI_VPSS_SendFrame: The user sends data to VPSS.
CVI_VPSS_GetChnFrame: The user gets a frame of processed images from the channel.
CVI_VPSS_SendChnFrame: The user send data to the specifies channel of VPSS.
CVI_VPSS_ReleaseChnFrame:The user releases a frame of image processed by channel.
CVI_VPSS_GetGrpFrame: The user gets the group image from VPSS.
CVI_VPSS_ReleaseGrpFrame: The user releases the group image
CVI_VPSS_SetChnCrop: Set the VPSS channel clipping feature properties.
CVI_VPSS_GetChnCrop: Get the VPSS channel clipping feature properties.
CVI_VPSS_SetChnRotation: Set the properties of VPSS channel rotation.
CVI_VPSS_GetChnRotation: Get the VPSS channel image rotation attribute.
CVI_VPSS_SetChnLDCAttr:Set VPSS LDC attribute.
CVI_VPSS_GetChnLDCAttr:Get VPSS LDC attribute.
CVI_VPSS_GetChnFd: Get the device file handle corresponding to the VPSS channel.
CVI_VPSS_CloseFd: Close the file handle for the VPSS device channel.
CVI_VPSS_AttachVbPool:Bind the channel of VPSS to a VB pool.
CVI_VPSS_DetachVbPool:Unbind the VPSS channel from a VB pool.
CVI_VPSS_SetChnAlign:Set the VPSS channel output frame width to align the number of bytes.
CVI_VPSS_GetChnAlign:Get the number of bytes aligned with the width of the VPSS channel output frame.
CVI_VPSS_SetChnYRatio:Set the ratio of the Y component of the VPSS channel image.
CVI_VPSS_GetChnYRatio:Get the ratio of the Y component of the VPSS channel image.
CVI_VPSS_SetChnScaleCoefLevel:Set the VPSS channel image scaling algorithm.
CVI_VPSS_GetChnScaleCoefLevel:Get VPSS channel image scaling algorithm.
CVI_VPSS_SetChnBufWrapAttr: Set the low-latency scrambling property.
CVI_VPSS_GetChnBufWrapAttr: Get the low-latency scrambling property.
CVI_VPSS_GetWrapBufferSize: Get the required low-latency scrambling cache size.
CVI_VPSS_ShowChn:Display VPSS channel image.
CVI_VPSS_HideChn:Hide VPSS channel images.
CVI_VPSS_GetRegionLuma:Get the total brightness of the specified image area.
CVI_VPSS_CreateStitch:Create vpss stitch.
CVI_VPSS_DestroyStitch:Destroy vpss stitch.
CVI_VPSS_SetStitchAttr:Set vpss stitch.
CVI_VPSS_GetStitchAttr:Get vpss stitch.
CVI_VPSS_StartStitch:Start vpss stitch.
CVI_VPSS_StopStitch:Stop vpss stitch.
CVI_VPSS_Suspend:vpss suspend.
CVI_VPSS_Resume:vpss resume.
6.3.1. CVI_VPSS_CreateGrp¶
CVI_S32 CVI_VPSS_CreateGrp(VPSS_GRP VpssGrp, const VPSS_GRP_ATTR_S *pstGrpAttr);
【Parameter】
Parameter |
Input/Output |
VpssGrp |
VPSS GROUP number. Value Range: [0, VPSS_MAX_GRP_NUM). |
Input |
pstGrpAttr |
VPSS GROUP property pointer. |
Input |
【Return Value】
Return Value |
0 |
Success. |
Non 0 |
Failure. For details, please refer to Error Codes. |
【Requirement】
Header files: cvi_comm_vpss.h、cvi_vpss.h
Library files: libvpss.a
Create VPSS_GRP_ATTR_S before using this interface.
【Example】
VPSS_GRP_ATTR_S stVpssGrpAttr;
VPSS_CHN VpssChn = VPSS_CHN0;
CVI_BOOL abChnEnable[VPSS_MAX_PHY_CHN_NUM] = {0};
VPSS_CHN_ATTR_S astVpssChnAttr[VPSS_MAX_PHY_CHN_NUM];
CVI_S32 s32Ret = CVI_SUCCESS;
VPSS_CROP_INFO_S pstCropInfo;
stVpssGrpAttr.stFrameRate.s32SrcFrameRate = -1;
stVpssGrpAttr.stFrameRate.s32DstFrameRate = -1;
stVpssGrpAttr.enPixelFormat = PIXEL_FORMAT_YUV_PLANAR_420;
stVpssGrpAttr.u32MaxW = stSize.u32Width;
stVpssGrpAttr.u32MaxH = stSize.u32Height;
astVpssChnAttr[VpssChn].u32Width = 800;
astVpssChnAttr[VpssChn].u32Height = 600;
astVpssChnAttr[VpssChn].enChnMode = VPSS_CHN_MODE_USER;
astVpssChnAttr[VpssChn].enVideoFormat = VIDEO_FORMAT_LINEAR;
astVpssChnAttr[VpssChn].enPixelFormat = PIXEL_FORMAT_BGR_888_PLANAR;
astVpssChnAttr[VpssChn].stFrameRate.s32SrcFrameRate = 30;
astVpssChnAttr[VpssChn].stFrameRate.s32DstFrameRate = 30;
astVpssChnAttr[VpssChn].u32Depth = 0;
astVpssChnAttr[VpssChn].bMirror = CVI_FALSE;
astVpssChnAttr[VpssChn].bFlip = CVI_FALSE;
astVpssChnAttr[VpssChn].stAspectRatio.enMode = ASPECT_RATIO_NONE;
/*start vpss*/
VPSS_CHN VpssChn;
s32Ret = CVI_VPSS_CreateGrp(0, &stVpssGrpAttr);
if (s32Ret != CVI_SUCCESS) {
SAMPLE_PRT("CVI_VPSS_CreateGrp failed with %#x!\n", s32Ret);
return CVI_FAILURE;
s32Ret = CVI_VPSS_SetChnAttr(0, 0, &astVpssChnAttr[0]);
SAMPLE_PRT("CVI_VPSS_SetChnAttr failed with %#x\n", s32Ret);
return CVI_FAILURE;
s32Ret = CVI_VPSS_EnableChn(0, 0);
SAMPLE_PRT("CVI_VPSS_EnableChn failed with %#x\n", s32Ret);
return CVI_FAILURE;
s32Ret = CVI_VPSS_StartGrp(0);
SAMPLE_PRT("CVI_VPSS_StartGrp failed with %#x\n", s32Ret);
return CVI_FAILURE;
s32Ret = CVI_VPSS_GetGrpCrop(0, &pstCropInfo);
SAMPLE_PRT("CVI_VPSS_ GetGrpCrop failed with %#x\n", s32Ret);
return CVI_FAILURE;
pstCropInfo.stCropRect.s32X = 0;
pstCropInfo.stCropRect.s32Y = 0;
pstCropInfo.stCropRect.u32Width = 600;
pstCropInfo.stCropRect.u32Height = 600;
s32Ret = CVI_VPSS_SetGrpCrop(0, &pstCropInfo);
SAMPLE_PRT("CVI_VPSS_ SetGrpCrop failed with %#x\n", s32Ret);
return CVI_FAILURE;
s32Ret = CVI_VPSS_DisableChn(0, 0);
SAMPLE_PRT("failed with %#x!\n", s32Ret);
return CVI_FAILURE;
s32Ret = CVI_VPSS_StopGrp(VpssGrp);
return CVI_FAILURE;
s32Ret = CVI_VPSS_DestroyGrp(VpssGrp);
return CVI_FAILURE;
【Related Topic】
6.3.2. CVI_VPSS_DestroyGrp¶
CVI_S32 CVI_VPSS_DestroyGrp (VPSS_GRP VpssGrp);
【Parameter】
Parameter |
Input/Output |
VpssGrp |
Input |
【Return Value】
Return Value |
0 |
Success. |
Non 0 |
【Requirement】
Before calling this interface, CVI_VPSS_StopGrp must be called to disable this GROUP first.
The function will release all vb_jobs under grp.
【Example】
Please refer to CVI_VPSS_CreateGrp.
【Related Topic】
6.3.3. CVI_VPSS_GetAvailableGrp¶
VPSS_GRP CVI_VPSS_GetAvailableGrp(CVI_VOID);
【Parameter】
None.
【Return Value】
Return Value |
>=0 |
valid group number. |
-1 |
Non valid group number. |
【Requirement】
Group must be created if Getvalid group number via this API.
【Example】
None.
【Related Topic】
6.3.4. CVI_VPSS_GetGrpAttr¶
Get the properties of VPSS GROUP.
CVI_S32 CVI_VPSS_GetGrpAttr (VPSS_GRP VpssGrp, VPSS_GRP_ATTR_S *pstGrpAttr);
【Parameter】
Parameter |
Input/Output |
VpssGrp |
Input |
pstGrpAttr |
VPSS GROUP properties pointer. |
Output |
【Return Value】
Return Value |
0 |
Success. |
Non 0 |
【Requirement】
Group must have been created.
The GROUP properties must be valida, and some static properties cannot be set dynamically. Please refer to PSS_GRP_ATTR_S for details.
【Example】
【Related Topic】
6.3.5. CVI_VPSS_SetGrpAttr¶
Set the properties of VPSS GROUP.
CVI_S32 CVI_VPSS_SetGrpAttr (VPSS_GRP VpssGrp, const VPSS_GRP_ATTR_S *pstGrpAttr);
【Parameter】
Parameter |
Input/Output |
VpssGrp |
Input |
pstGrpAttr |
Input |
【Return Value】
Return Value |
0 |
Success. |
Non 0 |
【Requirement】
The GROUP properties must be valid, and some static properties cannot be set dynamically. Please refer to PSS_GRP_ATTR_S for details.
【Example】
【Related Topic】
6.3.6. CVI_VPSS_StartGrp¶
Enable the VPSS GROUP.
CVI_S32 CVI_VPSS_StartGrp (VPSS_GRP VpssGrp);
【Parameter】
Parameter |
Input/Output |
VpssGrp |
Input |
【Return Value】
Return Value |
0 |
Success. |
Non 0 |
【Requirement】
Repetitive calls to this function to set the same group will return a Success.
【Example】
【Related Topic】
6.3.7. CVI_VPSS_StopGrp¶
Disable the VPSS GROUP.
CVI_S32 CVI_VPSS_StopGrp (VPSS_GRP VpssGrp);
【Parameter】
Parameter |
Input/Output |
VpssGrp |
Input |
【Return Value】
Return Value |
0 |
Success. |
Non 0 |
【Requirement】
Group must have been created, otherwise it will return a failure.
Repetitive calls to disable the same VPSS group will return a Success
【Example】
【Related Topic】
6.3.8. CVI_VPSS_ResetGrp¶
Reset the VPSS GROUP.
CVI_S32 CVI_VPSS_ResetGrp (VPSS_GRP VpssGrp);
【Parameter】
Parameter |
Input/Output |
VpssGrp |
Input |
【Return Value】
Return Value |
0 |
Success. |
Non 0 |
【Requirement】
Group must have been created .
【Example】
【Related Topic】
6.3.9. CVI_VPSS_GetGrpProcAmpCtrl¶
Get a VPSS group color control function description.
CVI_S32 CVI_VPSS_GetGrpProcAmpCtrl(VPSS_GRP VpssGrp, PROC_AMP_E type, PROC_AMP_CTRL_S *ctrl);
【Parameter】
Parameter |
Input/Output |
VpssGrp |
Input |
type |
Type of Proc Amp(color control); |
Input |
ctrl |
Define the specific parameter of ProcAmp, including min, max, step, default, etc |
Output |
【Return Value】
Return Value |
0 |
Success. |
Non 0 |
【Requirement】
None.
【Example】
PROC_AMP_CTRL_S stAmpCtrl;
CVI_S32 tmp;
if (CVI_VPSS_GetGrpProcAmp(0, PROC_AMP_BRIGHTNESS, &tmp) != CVI_SUCCESS) {
CVI_TRACE_LOG(CVI_DBG_ERR, "CVI_VPSS_GetGrpProcAmp NG on grp0!\n");
return CVI_FAILURE;
if (CVI_VPSS_GetGrpProcAmpCtrl(0, PROC_AMP_BRIGHTNESS, &stAmpCtrl) != CVI_SUCCESS) {
CVI_TRACE_LOG(CVI_DBG_ERR, "CVI_VPSS_GetGrpProcAmpCtrl NG on grp0!\n");
return CVI_FAILURE;
if (CVI_VPSS_SetGrpProcAmp(0, PROC_AMP_BRIGHTNESS, stAmpCtrl.maximum) != CVI_SUCCESS) {
CVI_TRACE_LOG(CVI_DBG_ERR, "CVI_VPSS_SetGrpProcAmp NG on grp0!\n");
return CVI_FAILURE;
【Related Topic】
PROC_AMP_E
PROC_AMP_CTRL_S
6.3.10. CVI_VPSS_GetGrpProcAmp¶
CVI_S32 CVI_VPSS_GetGrpProcAmp(VPSS_GRP VpssGrp, PROC_AMP_E type, CVI_S32 *value);
【Parameter】
Parameter |
Input/Output |
VpssGrp |
Input |
type |
Input |
value |
Configuration of ProcAmp |
Output |
【Return Value】
Return Value |
0 |
Success. |
Non 0 |
【Requirement】
None.
【Example】
Please refer to CVI_VPSS_GetGrpProcAmpCtrl.
【Related Topic】
PROC_AMP_E
PROC_AMP_CTRL_S
6.3.11. CVI_VPSS_SetGrpProcAmp¶
CVI_S32 CVI_VPSS_SetGrpProcAmp(VPSS_GRP VpssGrp, PROC_AMP_E type, const CVI_S32 value);
【Parameter】
Parameter |
Input/Output |
VpssGrp |
Input |
type |
Input |
value |
Input |
【Return Value】
Return Value |
0 |
Success. |
Non 0 |
【Requirement】
None.
【Example】
【Related Topic】
PROC_AMP_E
PROC_AMP_CTRL_S
6.3.12. CVI_VPSS_GetAllProcAmp¶
CVI_S32 CVI_VPSS_GetAllProcAmp(struct vpss_all_proc_amp_cfg *cfg);
【Parameter】
Parameter |
Input/Output |
cfg |
color control property |
Output |
【Return Value】
Return Value |
0 |
Success. |
Non 0 |
【Requirement】
None.
【Example】
None.
【Related Topic】
6.3.13. CVI_VPSS_SetGrpParamfromBin¶
CVI_S32 CVI_VPSS_SetGrpParamfromBin(VPSS_GRP VpssGrp, CVI_U8 scene);
【Parameter】
Parameter |
Input/Output |
VpssGrp |
Input |
scene |
VPSS Bin scene settings to be applied |
Input |
【Return Value】
Return Value |
0 |
Success. |
Non 0 |
【Requirement】
If a new PQ bin is used, the group must already be created
If the PQ bin does not exist, default parameters will be used.
Currently, only the setting of ProcAmp (brightness, contract, hue, saturation) is supported
【Example】
/*start vpss*/
VPSS_CHN VpssChn;
return CVI_FAILURE;
/*vpss grp0套用場景0*/
s32Ret = CVI_VPSS_SetGrpParamfromBin(0, 0);
SAMPLE_PRT("CVI_VPSS_SetGrpParamfromBin failed with %#x!\n", s32Ret);
return CVI_FAILURE;
【Related Topic】
PROC_AMP_E
PROC_AMP_CTRL_S
6.3.14. CVI_VPSS_SetGrpParam_fromLinuxBin¶
CVI_S32 CVI_VPSS_SetGrpParam_fromLinuxBin(VPSS_GRP VpssGrp, struct vpss_proc_amp_cfg *csc_cfg);
【Parameter】
Parameter |
Input/Output |
VpssGrp |
Input |
csc_cfg |
Input |
【Return Value】
Return Value |
0 |
Success. |
Non 0 |
【Requirement】
【Example】
Please refer to CVI_VPSS_SetGrpParamfromBin.
【Related Topic】
vpss_proc_amp_cfg
6.3.15. CVI_VPSS_GetBinScene¶
Get scene from bin.
CVI_S32 CVI_VPSS_GetBinScene(VPSS_GRP VpssGrp, CVI_U8 *scene);
【Parameter】
Parameter |
Input/Output |
VpssGrp |
Input |
scene |
the scene of settings stored in bin to get |
Output |
【Return Value】
Return Value |
0 |
Success. |
Non 0 |
【Requirement】
【Example】
None.
【Related Topic】
None.
6.3.16. CVI_VPSS_GetChnAttr¶
CVI_S32 CVI_VPSS_GetChnAttr (VPSS_GRP VpssGrp, VPSS_CHN VpssChn, VPSS_CHN_ATTR_S *pstChnAttr);
【Parameter】
Parameter |
Input/Output |
VpssGrp |
Input |
VpssChn |
VPSS channel number. Value Range: [0, VPSS_MAX_PHY_CHN_NUM); |
Input |
pstChnAttr |
VPSS channel properties |
Output |
【Return Value】
Return Value |
0 |
Success. |
Non 0 |
【Requirement】
【Example】
【Related Topic】
6.3.17. CVI_VPSS_SetChnAttr¶
Set the VPSS channel properties.
CVI_S32 CVI_VPSS_SetChnAttr (VPSS_GRP VpssGrp, VPSS_CHN VpssChn, const VPSS_CHN_ATTR_S *pstChnAttr);
【Parameter】
Parameter |
Input/Output |
VpssGrp |
Input |
VpssChn |
Input |
pstChnAttr |
Input |
【Return Value】
Return Value |
0 |
Success. |
Non 0 |
【Requirement】
【Example】
【Related Topic】
6.3.18. CVI_VPSS_EnableChn¶
Enable the VPSS channel.
CVI_S32 CVI_VPSS_EnableChn(VPSS_GRP VpssGrp, VPSS_CHN VpssChn);
【Parameter】
Parameter |
Input/Output |
VpssGrp |
Input |
VpssChn |
Input |
【Return Value】
Return Value |
0 |
Success. |
Non 0 |
【Requirement】
Repetitive enable calls will return a Success.
【Example】
【Related Topic】
6.3.19. CVI_VPSS_DisableChn¶
Disable the VPSS channel.
CVI_S32 CVI_VPSS_DisableChn (VPSS_GRP VpssGrp, VPSS_CHN VpssChn);
【Parameter】
Parameter |
Input/Output |
VpssGrp |
Input |
VpssChn |
Input |
【Return Value】
Return Value |
0 |
Success. |
Non 0 |
【Requirement】
Repetitive disable calls will return a Success.
【Example】
【Related Topic】
6.3.20. CVI_VPSS_SetGrpCrop¶
CVI_S32 CVI_VPSS_SetGrpCrop (VPSS_GRP VpssGrp, const VPSS_CROP_INFO_S *pstCropInfo);
【Parameter】
Parameter |
Input/Output |
VpssGrp |
Input |
pstCropInfo |
CROP function properties |
Input |
【Return Value】
Return Value |
0 |
Success. |
Non 0 |
【Requirement】
The size of the crop area cannot be less than the minimum size of the VPSS,
and cannot exceed the maximum size.
Otherwise, the failure is returned.
VPSS Online mode does not support group cropping.
This setting is invalid when the DIS is enabled
【Example】
【Related Topic】
6.3.21. CVI_VPSS_GetGrpCrop¶
CVI_S32 CVI_VPSS_GetGrpCrop (VPSS_GRP VpssGrp, VPSS_CROP_INFO_S *pstCropInfo);
【Parameter】
Parameter |
Input/Output |
VpssGrp |
Input |
pstCropInfo |
Output |
【Return Value】
Return Value |
0 |
Success. |
Non 0 |
【Requirement】
【Example】
【Related Topic】
6.3.22. CVI_VPSS_SendFrame¶
User sends data to VPSS.
CVI_S32 CVI_VPSS_SendFrame (VPSS_GRP VpssGrp, const VIDEO_FRAME_INFO_S *pstVideoFrame, CVI_S32 s32MilliSec);
【Parameter】
Parameter |
Input/Output |
VpssGrp |
VPSS GROUP number. Value Range: [0, VPSS_MAX_GRP_NUM); |
Input |
pstVideoFrame |
Image information to be sent. Please refer to the chapter “system control” for details . |
Input |
s32MilliSec |
Not used in the current version. |
Input |
【Return Value】
Return Value |
0 |
Success. |
Non 0 |
【Requirement】
Group must have been created and enabled, otherwise it will return a failure.
【Example】
None.
【Related Topic】
None.
6.3.23. CVI_VPSS_GetChnFrame¶
The user obtains a processed image from the channel.
CVI_S32 CVI_VPSS_GetChnFrame(VPSS_GRP VpssGrp, VPSS_CHN VpssChn, VIDEO_FRAME_INFO_S *pstFrameInfo, CVI_S32 s32MilliSec);
【Parameter】
Parameter |
Input/Output |
VpssGrp |
VPSS GROUP number. Value Range: [0, VPSS_MAX_GRP_NUM)。 |
Input |
VpssChn |
VPSS channel number. Value Range: [0, VPSS_MAX_CHN_NUM); |
Input |
pstVideoFrame |
Image information to be sent. Please refer to the chapter “system control” for details. |
Output |
s32MilliSec |
Time out |
Input |
【Return Value】
Return Value |
0 |
Success. |
Non 0 |
【Requirement】
This function saves the acquired image information in pstvideoFrame, including the virtual and physical addresses of the image.
【Example】
VIDEO_FRAME_INFO_S pstVideoFrame;
FILE *fp;
size_t image_size;
unsigned char ptr[image_size];
int count = 0;
CVI_VPSS_GetChnFrame(0, 0, &pstVideoFrame, 5000);
image_size = pstVideoFrame.stVFrame.u32Width * pstVideoFrame.stVFrame.u32Height * 3;
for (int i = 0; i < 3; i++) {
memcpy(&ptr[count], (const CVI_VOID *)pstVideoFrame.stVFrame.u64VirAddr[i], pstVideoFrame.stVFrame.u32Length[i]);
count += pstVideoFrame.stVFrame.u32Length[i];
fp = fopen("/tmp/dump.bin", "w");
if (fp == CVI_NULL) {
CVI_TRACE_VPSS(CVI_DBG_ERR, "open data file error\n");
return CVI_FAILURE;
fwrite(ptr, image_size, 1, fp);
fclose(fp);
if (CVI_VPSS_ReleaseChnFrame(0, 0, &pstVideoFrame) != 0)
SAMPLE_PRT("CVI_VI_ReleaseChnFrame NG\n");
【Related Topic】
6.3.24. CVI_VPSS_SendChnFrame¶
The user specifies channel data to the VPSS, which can be used for image stitching.
CVI_S32 CVI_VPSS_SendChnFrame (VPSS_GRP VpssGrp, VPSS_CHN VpssChn, const VIDEO_FRAME_INFO_S *pstVideoFrame, CVI_S32 s32MilliSec);
【Parameter】
Parameter |
Input/Output |
VpssGrp |
Input |
VpssChn |
Input |
pstVideoFrame |
Input |
s32MilliSec |
Not used in current version. |
Input |
【Return Value】
Return Value |
0 |
Success. |
Non 0 |
【Requirement】
Group/Chn must have been created.
【Example】
None.
【Related Topic】
None.
6.3.25. CVI_VPSS_ReleaseChnFrame¶
The user releases a frame of image processed by the channel.
CVI_S32 CVI_VPSS_ReleaseChnFrame (VPSS_GRP VpssGrp, VPSS_CHN VpssChn, VIDEO_FRAME_INFO_S *pstFrameInfo);
【Parameter】
Parameter |
Input/Output |
VpssGrp |
Input |
VpssChn |
Input |
pstVideoFrame |
Input |
【Return Value】
Return Value |
0 |
Success. |
Non 0 |
【Requirement】
This interface should be used in conjunction with CVI_VPSS_GetChnFrame.
【Example】
Please refer to CVI_VPSS_GetChnFrame.
【Related Topic】
6.3.26. CVI_VPSS_GetGrpFrame¶
The function has not been implemented so far.
6.3.27. CVI_VPSS_ReleaseGrpFrame¶
6.3.28. CVI_VPSS_SetChnCrop¶
Set the attributes of VPSS channel clipping function
CVI_S32 CVI_VPSS_SetChnCrop(VPSS_GRP VpssGrp, VPSS_CHN VpssChn, const VPSS_CROP_INFO_S *pstCropInfo);
【Parameter】
Parameter |
Input/Output |
VpssGrp |
VPSS GROUP number. Value Range:[0, VPSS_MAX_GRP_NUM)。 |
Input |
VpssChn |
VPSS channel number. Value Range:[0, VPSS_MAX_CHN_NUM); |
Input |
pstCropInfo |
Image information to be sent. Please refer to the chapter “system control” for detailed description. |
Input |
【Return Value】
Return Value |
0 |
Success. |
Non 0 |
【Requirement】
Groupmust have been created.
The size of the CROP area can neither be less than the minimum size of the VPSS nor exceed the maximum size.
Otherwise, a failure will be returned.
This function sets the image for the VPSS output channel, while GrpCrop sets the image for the VPSS input.
【Example】
None.
【Related Topic】
6.3.29. CVI_VPSS_GetChnCrop¶
Get the attributes of VPSS channel clipping function.
CVI_S32 CVI_VPSS_GetChnCrop(VPSS_GRP VpssGrp, VPSS_CHN VpssChn, VPSS_CROP_INFO_S *pstCropInfo);
【Parameter】
Parameter |
Input/Output |
VpssGrp |
Input |
VpssChn |
Input |
pstCropInfo |
CROP function properties. |
Output |
【Return Value】
Return Value |
0 |
Success. |
Non 0 |
【Requirement】
This function obtains the image cropping information for the VPSS output channel,
while CVI_VPSS_GetGrpCrop obtains the image cropping information for the VPSS input.
【Example】
None.
【Related Topic】
6.3.30. CVI_VPSS_SetChnRotation¶
Set the attributes of VPSS channel rotation.
CVI_S32 CVI_VPSS_SetChnRotation(VPSS_GRP VpssGrp, VPSS_CHN VpssChn, ROTATION_E enRotation);
【Parameter】
Parameter |
Input/Output |
VpssGrp |
Input |
VpssChn |
Input |
enRotation |
Rotation attributes. See ROTATION_E for details. |
Input |
【Return Value】
Return Value |
0 |
Success. |
Non 0 |
【Requirement】
Header files: cvi_vpss.h, cvi_comm_vpss.h
Before using this interface, it is necessary to call CVI_VPSS_SetChnAttr first, otherwise it will fail.
The channel attributes must be set before setting this attribute.
CV181x/CV180x do not support 180-degree rotation, but it can be achieved using mirror+flip.
Only NV12/NV21/YUV400 rotation formats are supported.
After rotation, the output image size of the channel may change.
For example, the 1920x1080 input image, rotated 90 degrees, the actual output is 1088x1920.
Since rotation requires 64 pixel alignment, invalid areas will be generated.
If the back end is connected to vo or venc, the back end module will automatically crop the valid part.
In the case of GetChnFrame, the valid region is specified in the VIDEO_FRAME_S structure s16OffsetTop, s16OffsetBottom, s16OffsetLeft, s16OffsetRight.
【Example】
None.
【Related Topic】
None.
6.3.31. CVI_VPSS_GetChnRotation¶
Get the attributes of VPSS channel rotation.
CVI_S32 CVI_VPSS_GetChnRotation(VPSS_GRP VpssGrp, VPSS_CHN VpssChn, ROTATION_E *penRotation);
【Parameter】
Parameter |
Input/Output |
VpssGrp |
Input |
VpssChn |
Input |
penRotation |
Output |
【Return Value】
Return Value |
0 |
Success. |
Non 0 |
【Requirement】
【Example】
None.
【Related Topic】
6.3.32. CVI_VPSS_SetChnLDCAttr¶
Set the attributes of VPSS channel lens distortion correction.
CVI_S32 CVI_VPSS_SetChnLDCAttr(VPSS_GRP VpssGrp, VPSS_CHN VpssChn, const VPSS_LDC_ATTR_S *pstLDCAttr);
【Parameter】
Parameter |
Input/Output |
VpssGrp |
Input |
VpssChn |
Input |
pstLDCAttr |
Lens distortion correction attributes. |
Input |
【Return Value】
Return Value |
0 |
Success. |
Non 0 |
【Requirement】
Only NV21 and YUV400 rotation formats are supported.
【Example】
None.
【Related Topic】
VPSS_LDC_ATTR_S
6.3.33. CVI_VPSS_GetChnLDCAttr¶
Get the attributes of VPSS channel lens distortion correction.
CVI_S32 CVI_VPSS_GetChnLDCAttr(VPSS_GRP VpssGrp, VPSS_CHN VpssChn, VPSS_LDC_ATTR_S *pstLDCAttr);
【Parameter】
Parameter |
Input/Output |
VpssGrp |
Input |
VpssChn |
Input |
pstLDCAttr |
Output |
【Return Value】
Return Value |
0 |
Success. |
Non 0 |
【Requirement】
【Example】
None.
【Related Topic】
VPSS_LDC_ATTR_S
6.3.34. CVI_VPSS_GetChnFd¶
CVI_S32 CVI_VPSS_GetChnFd(VPSS_GRP VpssGrp, VPSS_CHN VpssChn);
【Parameter】
Parameter |
Input/Output |
VpssGrp |
Input |
VpssChn |
Input |
【Return Value】
Return Value |
Positive value |
Success. |
Negative value |
invalid value |
【Requirement】
None.
【Example】
None.
【Related Topic】
None.
6.3.35. CVI_VPSS_CloseFd¶
Close the file handle of the VPSS device channel.
CVI_S32 CVI_VPSS_CloseFd(CVI_VOID);
【Parameter】
None.
【Return Value】
Return Value |
0 |
Success. |
Non 0 |
【Requirement】
After calling this interface, other MMF interfaces of VPSS will be invalidated.
【Example】
None.
【Related Topic】
6.3.36. CVI_VPSS_AttachVbPool¶
Bind the VPSS channel to a video cache VB pool.
CVI_S32 CVI_VPSS_AttachVbPool(VPSS_GRP VpssGrp, VPSS_CHN VpssChn, VB_POOL hVbPool);
【Parameter】
Parameter |
Input/Output |
VpssGrp |
Input |
VpssChn |
Input |
hVbPool |
Video memory block pool ID |
Input |
【Return Value】
Return Value |
0 |
Success. |
Non 0 |
【Requirement】
Group must already be created.
Repeated calls to this function to set the same group return Success.
The CVI_VPSS_AttachVbPool interface needs to be adjusted again when switching the VB pool bound to the current group.
Correct configuration to the VB pool.
hVbPool must be a valid Pool Id of a created VB pool.
After calling CVI_VPSS_DetachVbPool, before destroying the created VB, we need to ensure that the VB is not used by the back-end bound module of VPSS.
We can release the VB by sleep or clear the cache of the back-end module channel, and then destroy the cache VB pool.
VB size is calculated according to the output image of VPSS channel.
For details, refer to cvi_buffer.h.
【Example】
None.
【Related Topic】
None.
6.3.37. CVI_VPSS_DetachVbPool¶
Unbind the VPSS channel from a video cache VB pool
CVI_S32 CVI_VPSS_DetachVbPool(VPSS_GRP VpssGrp, VPSS_CHN VpssChn);
【Parameter】
Parameter |
Input/Output |
VpssGrp |
Input |
VpssChn |
Input |
【Return Value】
Return Value |
0 |
Success. |
Non 0 |
【Requirement】
【Example】
None.
【Related Topic】
None.
6.3.38. CVI_VPSS_SetChnAlign¶
Set width alignment bytes of VPSS channel out frame.
CVI_S32 CVI_VPSS_SetChnAlign(VPSS_GRP VpssGrp, VPSS_CHN VpssChn,
CVI_U32 u32Align);
【Parameter】
Parameter |
Input/Output |
VpssGrp |
VPSS GROUP number. Value Range:[0, VPSS_MAX_GRP_NUM). |
Input |
VpssChn |
VPSS channel number Value Range:[0, VPSS_MAX_CHN_NUM). |
Input |
u32Align |
Alignment bytes. |
Input |
【Return Value】
Return Value |
0 |
Success. |
Non 0 |
【Requirement】
Must use after CVI_VPSS_SetChnAttr, default alignment bytes is 64.
If set u32Align=1, memory width will be same with output resolution.
【Example】
None.
【Related Topic】
None.
6.3.39. CVI_VPSS_GetChnAlign¶
Get width alignment bytes of VPSS channel out frame.
CVI_S32 CVI_VPSS_GetChnAlign(VPSS_GRP VpssGrp, VPSS_CHN VpssChn,
CVI_U32 *pu32Align);
【Parameter】
Parameter |
Input/Output |
VpssGrp |
Input |
VpssChn |
Input |
pu32Align |
Alignment bytes. |
Output |
【Return Value】
Return Value |
0 |
Success. |
Non 0 |
【Requirement】
None.
【Example】
None.
【Related Topic】
None.
6.3.40. CVI_VPSS_SetChnYRatio¶
Set Y ratio of VPSS channel frame.
CVI_S32 CVI_VPSS_SetChnYRatio(VPSS_GRP VpssGrp, VPSS_CHN VpssChn, CVI_FLOAT YRatio);
【Parameter】
Parameter |
Input/Output |
VpssGrp |
Input |
VpssChn |
Input |
YRatio |
Ratio Value Range:[0, 1]. |
Input |
【Return Value】
Return Value |
0 |
Success. |
Non 0 |
【Requirement】
Must use after CVI_VPSS_SetChnAttr, channel output frame format must be YUV, default is 1.
Can not use with Normalize && Convertfunction.
【Example】
None.
【Related Topic】
None.
6.3.41. CVI_VPSS_GetChnYRatio¶
Get Y ratio of VPSS channel frame.
CVI_S32 CVI_VPSS_GetChnYRatio(VPSS_GRP VpssGrp, VPSS_CHN VpssChn, CVI_FLOAT *pYRatio);
【Parameter】
Parameter |
Input/Output |
VpssGrp |
Input |
VpssChn |
Input |
YRatio |
Output |
【Return Value】
Return Value |
0 |
Success. |
Non 0 |
【Requirement】
None.
【Example】
None.
【Related Topic】
None.
6.3.42. CVI_VPSS_SetChnScaleCoefLevel¶
CVI_S32 CVI_VPSS_SetChnScaleCoefLevel(VPSS_GRP VpssGrp, VPSS_CHN VpssChn,
VPSS_SCALE_COEF_E enCoef);
【Parameter】
Parameter |
Input/Output |
VpssGrp |
Input |
VpssChn |
Input |
enCoef |
Resize algorithm Value Range:[0, VPSS_SCALE_COEF_MAX]. |
Input |
【Return Value】
Return Value |
0 |
Success. |
Non 0 |
【Requirement】
Group must have been created..
【Example】
None.
【Related Topic】
None.
6.3.43. CVI_VPSS_GetChnScaleCoefLevel¶
CVI_S32 CVI_VPSS_GetChnScaleCoefLevel(VPSS_GRP VpssGrp, VPSS_CHN VpssChn,
VPSS_SCALE_COEF_E *penCoef);
【Parameter】
Parameter |
Input/Output |
VpssGrp |
Input |
VpssChn |
Input |
penCoef |
Output |
【Return Value】
Return Value |
0 |
Success. |
Non 0 |
【Requirement】
【Example】
None.
【Related Topic】
None.
6.3.44. CVI_VPSS_SetChnBufWrapAttr¶
Setting low-latency looping property.
CVI_S32 CVI_VPSS_SetChnBufWrapAttr(VPSS_GRP VpssGrp, VPSS_CHN VpssChn, const VPSS_CHN_BUF_WRAP_S *pstVpssChnBufWrap);
【Parameter】
Parameter |
Input/Output |
VpssGrp |
Input |
VpssChn |
Input |
pstVpssChnBufWrap |
Channel Buffer Loop Attribute structure. |
Input |
【Return Value】
Return Value |
0 |
Success. |
Non 0 |
【Requirement】
Channel enablement is not supported.
The interface can be set only after the channel attributes have been set.
semi-planar422 graphics and Flip graphics are not supported.
When channel winding with low delay is enabled, access, brightness, rotation, CoverEx, OverlayEx, rotation at any Angle, and LDC of the channel are invalid.
In low-delay winding channel binding coding scenarios, the software does not support frame rate control.
【Example】
None.
【Related Topic】
None.
6.3.45. CVI_VPSS_GetChnBufWrapAttr¶
Get the low-latency looping property.
CVI_S32 CVI_VPSS_GetChnBufWrapAttr(VPSS_GRP VpssGrp, VPSS_CHN VpssChn, VPSS_CHN_BUF_WRAP_S *pstVpssChnBufWrap);
【Parameter】
Parameter |
Input/Output |
VpssGrp |
Input |
VpssChn |
Input |
pstVpssChnBufWrap |
Output |
【Return Value】
Return Value |
0 |
Success. |
Non 0 |
【Requirement】
【Example】
None.
【Related Topic】
None.
6.3.46. CVI_VPSS_GetWrapBufferSize¶
Get the required buffer size for low-latency wrapping
CVI_U32 CVI_VPSS_GetWrapBufferSize(CVI_U32 u32Width, CVI_U32 u32Height, PIXEL_FORMAT_E enPixelFormat, CVI_U32 u32BufLine, CVI_U32 u32BufDepth);
【Parameter】
Parameter |
Input/Output |
u32Width |
Image width |
Input |
u32Height |
Image height |
Input |
enPixelFormat |
Image pixel format |
Input |
u32BufLine |
Number of lines in a single winding cache |
Input |
u32BufDepth |
Number of winding caches |
Input |
【Return Value】
Return Value |
0 |
Success. |
Non 0 |
【Requirement】
None.
【Example】
None.
【Related Topic】
None.
6.3.47. CVI_VPSS_ShowChn¶
CVI_S32 CVI_VPSS_ShowChn(VPSS_GRP VpssGrp, VPSS_CHN VpssChn);
【Parameter】
Parameter |
Input/Output |
VpssGrp |
Input |
VpssChn |
Input |
【Return Value】
Return Value |
0 |
Success. |
Non 0 |
【Requirement】
【Example】
None.
【Related Topic】
None.
6.3.48. CVI_VPSS_HideChn¶
CVI_S32 CVI_VPSS_HideChn(VPSS_GRP VpssGrp, VPSS_CHN VpssChn);
【Parameter】
Parameter |
Input/Output |
VpssGrp |
Input |
VpssChn |
Input |
【Return Value】
Return Value |
0 |
Success. |
Non 0 |
【Requirement】
Group must have been created, frame will be all black after calling this.
【Example】
None.
【Related Topic】
None.
6.3.49. CVI_VPSS_GetRegionLuma¶
CVI_S32 CVI_VPSS_GetRegionLuma(VPSS_GRP VpssGrp, VPSS_CHN VpssChn, const
VIDEO_REGION_INFO_S *pstRegionInfo,CVI_U64 *pu64LumaData,
【Parameter】
Parameter |
Input/Output |
VpssGrp |
Input |
VpssChn |
Input |
pstRegionInfo |
Region properties |
Input |
pu64LumaData |
Pointer to receive data |
Output |
s32MilliSec |
Overtime parameter |
Input |
【Return Value】
Return Value |
0 |
Success. |
Non 0 |
【Requirement】
Only supports YUV format images.
This interface is designed for the output image of VPSS channel. The timing for obtaining brightness statistics information is before these images are obtained by the user or sent to the backend module.
The determination of the starting coordinates of the statistical area can be divided into two situations: if CROP is not enabled, the starting coordinates are relative to the upper left corner coordinates of the original image; If CROP is enabled, the starting coordinate is relative to the upper left corner coordinate of the image after CROP. The statistical area shall not exceed the original image or the image area after CROP.
【Example】
None.
【Related Topic】
None.
6.3.50. CVI_VPSS_CreateStitch¶
Create vpss stitch.
CVI_S32 CVI_VPSS_CreateStitch(VPSS_GRP VpssGrp, const CVI_STITCH_ATTR_S *pstStitchAttr);
【Parameter】
Parameter |
Input/Output |
VpssGrp |
Input |
pstStitchAttr |
VPSS stitch property pointer. |
Input |
【Return Value】
Return Value |
0 |
Success. |
Non 0 |
【Requirement】
Create CVI_STITCH_ATTR_S before using this interface.
【Example】
CVI_STITCH_ATTR_S stStitchAttr;
stStitchAttr.u8ChnNum = 2;
stStitchAttr.VoChn = 0;
stStitchAttr.s32OutFps = 2;
stStitchAttr.enOutPixelFormat = PIXEL_FORMAT_RGB_888_PLANAR;
stStitchAttr.stOutSize.u32Width = 720;
stStitchAttr.stOutSize.u32Height = 1280;
stStitchAttr.hVbPool = 0;
stStitchAttr.astStitchChn[0].stDstRect.s32X = 0;
stStitchAttr.astStitchChn[0].stDstRect.s32Y = 0;
stStitchAttr.astStitchChn[0].stDstRect.u32Width = 360;
stStitchAttr.astStitchChn[0].stDstRect.u32Height = 640;
stStitchAttr.astStitchChn[0].stStitchSrc.VpssGrp = 0;
stStitchAttr.astStitchChn[0].stStitchSrc.VpssChn = 0;
stStitchAttr.astStitchChn[1].stDstRect.s32X = 360;
stStitchAttr.astStitchChn[1].stDstRect.s32Y = 640;
stStitchAttr.astStitchChn[1].stDstRect.u32Width = 360;
stStitchAttr.astStitchChn[1].stDstRect.u32Height = 640;
stStitchAttr.astStitchChn[1].stStitchSrc.VpssGrp = 0;
stStitchAttr.astStitchChn[1].stStitchSrc.VpssChn = 0;
s32Ret = CVI_VPSS_CreateStitch(1, &stStitchAttr);
SAMPLE_PRT("CVI_VPSS_CreateStitch failed. s32Ret: 0x%x !\n", s32Ret);
return s32Ret;
s32Ret = CVI_VPSS_StartGrp(VpssGrp);
return CVI_FAILURE;
s32Ret = CVI_VPSS_StartStitch(1);
SAMPLE_PRT("CVI_VPSS_StartStitch failed. s32Ret: 0x%x !\n", s32Ret);
return s32Ret;
CVI_VPSS_StopStitch(1);
CVI_VPSS_DestroyStitch(1);
【Related Topic】
6.3.51. CVI_VPSS_DestroyStitch¶
CVI_S32 CVI_VPSS_DestroyStitch(VPSS_GRP VpssGrp);
【Parameter】
Parameter |
Input/Output |
VpssGrp |
Input |
【Return Value】
Return Value |
0 |
Success. |
Non 0 |
【Requirement】
Create vpss stitch before using this interface.
【Example】
Please refer to CVI_VPSS_CreateStitch.
【Related Topic】
6.3.52. CVI_VPSS_SetStitchAttr¶
Set vpss stitch.
CVI_S32 CVI_VPSS_SetStitchAttr(VPSS_GRP VpssGrp, const CVI_STITCH_ATTR_S *pstStitchAttr);
【Parameter】
Parameter |
Input/Output |
VpssGrp |
Input |
pstStitchAttr |
Input |
【Return Value】
Return Value |
0 |
Success. |
Non 0 |
【Requirement】
【Example】
【Related Topic】
6.3.53. CVI_VPSS_GetStitchAttr¶
Get vpss stitch.
CVI_S32 CVI_VPSS_GetStitchAttr(VPSS_GRP VpssGrp, CVI_STITCH_ATTR_S *pstStitchAttr);
【Parameter】
Parameter |
Input/Output |
VpssGrp |
Input |
pstStitchAttr |
Output |
【Return Value】
Return Value |
0 |
Success. |
Non 0 |
【Requirement】
【Example】
【Related Topic】
6.3.54. CVI_VPSS_StartStitch¶
Start vpss stitch.
CVI_S32 CVI_VPSS_StartStitch(VPSS_GRP VpssGrp);
【Parameter】
Parameter |
Input/Output |
VpssGrp |
Input |
【Return Value】
Return Value |
0 |
Success. |
Non 0 |
【Requirement】
【Example】
【Related Topic】
6.3.55. CVI_VPSS_StopStitch¶
Stop vpss stitch.
CVI_S32 CVI_VPSS_StopStitch(VPSS_GRP VpssGrp);
【Parameter】
Parameter |
Input/Output |
VpssGrp |
Input |
【Return Value】
Return Value |
0 |
Success. |
Non 0 |
【Requirement】
【Example】
【Related Topic】
6.3.56. CVI_VPSS_Suspend¶
vpss suspend, only dual OS SDK supports.
CVI_S32 CVI_VPSS_Suspend(void);
【Parameter】
None.
【Return Value】
Return Value |
0 |
Success. |
Non 0 |
【Requirement】
None.
【Example】
None.
【Related Topic】
6.3.57. CVI_VPSS_Resume¶
vpss resume, only dual OS SDK supports.
CVI_S32 CVI_VPSS_Resume(void);
【Parameter】
None.
【Return Value】
Return Value |
0 |
Success. |
Non 0 |
【Requirement】
None.
【Example】
None.
【Related Topic】
