6.4. Data Types
The data types of VPSS module are defined as follows:
6.4.1. VPSS_IP_NUM
Define the number of VPSS IP.
#define VPSS_IP_NUM 2
None.
None.
6.4.2. VPSS_MAX_GRP_NUM
Define the maximum number of VPSS GROUP.
#define VPSS_MAX_GRP_NUM 16
None.
None.
6.4.3. VPSS_ONLINE_NUM
Define the maximum number of VPSS ONLINE GROUP.
#define VPSS_ONLINE_NUM 5
None.
None.
6.4.4. VPSS_ONLINE_GRP_0
Define VPSS ONLINE GROUP 0.
#define VPSS_ONLINE_GRP_0 0
None.
None.
6.4.5. VPSS_ONLINE_GRP_1
Define VPSS ONLINE GROUP 1.
#define VPSS_ONLINE_GRP_1 1
None.
None.
6.4.6. VPSS_MAX_CHN_NUM
Define the maximum number of VPSS channels.
#define VPSS_MAX_CHN_NUM  VPSS_MAX_PHY_CHN_NUM
The maximum number of VPSS channels is the number of physical channels.
None.
6.4.7. VPSS_MAX_PHY_CHN_NUM
Define the maximum number of VPSS physical channels.
// cv181x
#define VPSS_MAX_PHY_CHN_NUM     4
// cv180x
#define VPSS_MAX_PHY_CHN_NUM     3
None.
None.
6.4.8. SC_D_MAX_LIMIT
Define the maximum width of VPSS sc_d.
// cv181x
#define SC_D_MAX_LIMIT     1920
// cv180x
#define SC_D_MAX_LIMIT     1280
None.
None.
6.4.9. SC_V1_MAX_LIMIT
Define the maximum width of VPSS sc_v1.
// cv181x
#define SC_V1_MAX_LIMIT     2880
// cv180x
None.
None.
6.4.10. SC_V2_MAX_LIMIT
Define the maximum width of VPSS sc_v2.
// cv181x
#define SC_V2_MAX_LIMIT     1920
// cv180x
None.
None.
6.4.11. SC_V3_MAX_LIMIT
Define the maximum width of VPSS sc_v3.
// cv181x
#define SC_V3_MAX_LIMIT     1280
cv180x does not have sc_v3.
None.
6.4.12. VPSS_MIN_IMAGE_WIDTH
Define the minimum width of the VPSS image.
#define VPSS_MIN_IMAGE_WIDTH 32
None.
None.
6.4.13. VPSS_MIN_IMAGE_HEIGHT
Define the minimum height of the VPSS image.
#define VPSS_MIN_IMAGE_HEIGHT 32
None.
None.
6.4.14. VPSS_MAX_IMAGE_WIDTH
Define the maximum width of the VPSS image.
#define VPSS_MAX_IMAGE_WIDTH 2880
None.
None.
6.4.15. VPSS_MAX_IMAGE_HEIGHT
Define the maximum height of the VPSS image.
#define VPSS_MAX_IMAGE_HEIGHT 4096
None.
None.
6.4.16. VPSS_MAX_ZOOMIN
Definition of the maximum zoom-in factor of VPSS physical channels.
#define VPSS_MAX_ZOOMIN                 32
None.
None.
6.4.17. VPSS_MAX_ZOOMOUT
Definition of the maximum zoom-out factor of VPSS physical channels.
#define VPSS_MAX_ZOOMOUT                32
None.
None.
6.4.18. VPSS_GRP
Define VPSS group number.
typedef CVI_U32 VPSS_GRP;
None.
None.
6.4.19. VPSS_CHN
Define the VPSS channel number.
typedef CVI_U32 VPSS_CHN;
None.
None.
6.4.20. VPSS_ROUNDING_E
Define the pattern of rounding mode during Normalize.
 typedef enum _VPSS_ROUNDING_E {
  VPSS_ROUNDING_TO_EVEN = 0,
  VPSS_ROUNDING_AWAY_FROM_ZERO,
  VPSS_ROUNDING_TRUNCATE,
  VPSS_ROUNDING_MAX,
} VPSS_ROUNDING_E;
【Member】
Member
Description
Round off, refer to the table below.
Unconditional rounding, see table below.
TO_EVEN
AWAY_FROM_ZERO
TRUNCATE
+1.8
+2
+2
+1
+1.5
+1.2
+1
+1
+0.8
0
+0.5
0
+0.2
0
−0.2
−0.5
−1
−0.8
−1
−1.2
−1
−1.5
−2
−2
−1.8
6.4.21. VPSS_CROP_COORDINATE_E
Define the start point coordinate mode of CROP.
 typedef enum _VPSS_CROP_COORDINATE_E
  VPSS_CROP_RATIO_COOR = 0,
  VPSS_CROP_ABS_COOR
}VPSS_CROP_COORDINATE_E;
【Member】
Member
Description
Relative coordinates.
VPSS_CROP_ABS_COOR
Absolute coordinates.
VPSS_CROP_RATIO_COOR not supported currently.
6.4.22. VPSS_NORMALIZE_S
Define the information required for Normalize function.
 typedef struct _VPSS_NORMALIZE_S {
  CVI_BOOL bEnable;
  CVI_FLOAT factor[3];
  CVI_FLOAT mean[3];
  VPSS_ROUNDING_E rounding;
} VPSS_NORMALIZE_S;
【Member】
Member
Description
bEnable
Normalize enable switch.
factor
Normalization factor.
1/8192 ~ 8191/8192
or
1/4096 ~ 8191/4096
Normalized root mean square difference.
0 ~ 255
rounding
Method to deal with the decimal part.
  1. After Normalize is enabled, the Output is int8, -128 ~ 127
  2. Normalize is equivalent to convertTo() function in OpenCV
    cv::convertTo(image, CV_8S, factor, -mean)
  3. According to the format of VPSS CHN, the results will be different.
    If the format is PIXEL_FORMAT_RGB_888_PLANAR or PIXEL_FORMAT_RGB_888, the operation modes are as follows:
    • (Pixel Value R) * factor[0] – mean[0] and then rounding。
    • (Pixel Value G) * factor[1] – mean[1] and then rounding。
    • (Pixel Value B) * factor[2] – mean[2] and then rounding。
If the format is PIXEL_FORMAT_BGR_888, the operation modes are as follows:
  • (Pixel Value B) * factor[0] – mean[0] and then rounding。
  • (Pixel Value R) * factor[2] – mean[2] and then rounding。
6.4.23. VPSS_CROP_INFO_S
Define the information required for the CROP function.
 typedef struct _VPSS_CROP_INFO_S {
  CVI_BOOL bEnable;
  VPSS_CROP_COORDINATE_E enCropCoordinate;
  RECT_S stCropRect;
} VPSS_CROP_INFO_S;
【Member】
Member
Description
bEnable
CROP enable switch.
enCropCoordinate
CROP start point coordinate mode
stCropRect
The rectangular area of CROP.
None.
6.4.24. VPSS_GRP_ATTR_S
Define the VPSS GROUP attribute.
 typedef struct _VPSS_GRP_ATTR_S {
  CVI_U32 u32MaxW;
  CVI_U32 u32MaxH;
  PIXEL_FORMAT_E enPixelFormat;
  FRAME_RATE_CTRL_S stFrameRate;
  CVI_U8 u8VpssDev;
} VPSS_GRP_ATTR_S;
【Member】
Member
Description
u32MaxW
The input image width.
u32MaxH
The input image height.
enPixelFormat
The input image pixel format.
stFrameRate
Group frame rate.
u8VpssDev
Specify which hardware this VPSS group will work with.
The parameter u8VpssDev should be set to 0 or 1 after setting the VPSS_MODE_DUAL or VPSS_MODE_RGNEX in CVI_SYS_SetVPSSMode to specify different hardware devices.
  • PIXEL_FORMAT_E
  • CVI_VPSS_CreateGrp
  • CVI_VPSS_SetGrpAttr
  • CVI_VPSS_GetGrpAttr
6.4.25. VPSS_CHN_ATTR_S
Define VPSS physical channel properties.
 typedef struct _VPSS_CHN_ATTR_S {
  CVI_U32 u32Width;
  CVI_U32 u32Height;
  VIDEO_FORMAT_E enVideoFormat;
  CVI_BOOL bMirror;
  CVI_BOOL bFlip;
  CVI_U32 u32Depth;
  ASPECT_RATIO_S stAspectRatio;
  VPSS_NORMALIZE_S stNormalize;
} VPSS_CHN_ATTR_S;
【Member】
Member
Description
u32Width
Target image width
u32Height
Target image height
enVideoFormat
Target image video format.
enPixelFormat
Target image pixel format
stFrameRate
Frame rate control information, proportional control of frame rate only when s32DstFrameRate is less than s32SrcFrameRate. For example, if s32SrcFrameRate is 60 and s32DstFrameRate is 30, then every other frame is lost.
bMirror
Horizontal mirroring enable.
bFlip
Vertical flipping enable.
u32Depth
Get the queue length for obtaining channel images. This is a static property.
stAspectRatio
Amplitude shape ratio parameter.
stNormalize
Performing normalization to accelerate subsequent TPU operation.
None.
  • CVI_VPSS_SetChnAttr
6.4.26. VPSS_MOD_PARAM_S
Set the module parameters through the interface.
 typedef struct _VPSS_PARAM_MOD_S {
  CVI_U32 u32VpssVbSource;
  CVI_U32 u32VpssSplitNodeNum;
} VPSS_MOD_PARAM_S;
【Member】
Member
Description
u32VpssVbSource
Video memory block pool type.
u32VpssSplitNodeNum
Number of block nodes.
This structure attribute is not used in the current version.
6.4.27. PROC_AMP_E
Define the VPSS PROCAMP category.
 typedef enum _PROC_AMP_E {
  PROC_AMP_BRIGHTNESS = 0,
  PROC_AMP_CONTRAST,
  PROC_AMP_SATURATION,
  PROC_AMP_HUE,
  PROC_AMP_MAX,
} PROC_AMP_E;
【Member】
Member
Description
PROC_AMP_BRIGHTNESS
Brightness value.
PROC_AMP_CONTRAST
Contrast value.
PROC_AMP_SATURATION
Saturation value.
PROC_AMP_HUE
HUE value.
6.4.28. PROC_AMP_CTRL_S
Define the VPSS PROCAMP property.
 typedef struct _PROC_AMP_CTRL_S {
  CVI_S32 minimum;
  CVI_S32 maximum;
  CVI_S32 step;
  CVI_S32 default_value;
} PROC_AMP_CTRL_S;
【Member】
Member
Description
minimum
The minimum value of this color control function.
maximum
The maximum value of this color control function.
step
The effective adjustment value of this color control function.
default_value
The default value of this color control function.
It is recommended to obtain these attributes before starting the operation on VPSS ProcAmp to avoid the operation failure.
  • PROC_AMP_E
  • CVI_VPSS_GetGrpProcAmpCtrl
6.4.29. vpss_proc_amp_cfg
Record ISP bindata secne.
 struct vpss_proc_amp_cfg {
  CVI_S32 proc_amp[PROC_AMP_MAX];
  VPSS_GRP VpssGrp;
  CVI_U8 scene;
【Member】
Member
Description
proc_amp
VpssGrp
VPSS GROUP Number
scene
the settings stored in bin to use
None.
  • CVI_VPSS_SetGrpParamfromBin
6.4.30. vpss_all_proc_amp_cfg
Define the VPSS all group ctrl info.
 struct vpss_all_proc_amp_cfg {
  CVI_S32 proc_amp[VPSS_MAX_GRP_NUM][PROC_AMP_MAX];
【Member】
Member
Description
proc_amp
color control function of vpss group.
None.
  • CVI_VPSS_GetAllProcAmp
6.4.31. VPSS_LDC_ATTR_S
Define the VPSS lens distortion correction structure.
 typedef struct _VPSS_LDC_ATTR_S {
  CVI_BOOL bEnable;
  LDC_ATTR_S stAttr;
} VPSS_LDC_ATTR_S;
【Member】
Member
Description
bEnable
LDC enable
stAttr
LDC configuration parameters
None.
  • LDC_ATTR_S
  • CVI_VI_GetChnLDCAttr
  • CVI_VI_SetChnLDCAttr
6.4.32. VPSS_CHN_BUF_WRAP_S
Definition of VPSS buffer wrap property.
typedef struct _VPSS_CHN_BUF_WRAP_S {
   CVI_BOOL bEnable;
   CVI_U32 u32BufLine;   // 64, 128
   CVI_U32 u32WrapBufferSize;
} VPSS_CHN_BUF_WRAP_S;
【Member】
Member
Description
bEnable
switch for enable chn buffer wrap.
u32BufLine
wrap buffer row height.
u32WrapBufferSize
wrap buffer size.
  • u32BufLine needs to be smaller than the height of the output image.
  • u32BufLine only comes in two sizes: 64/128.
  • When enabling wrap, u32WrapBufferSize must be greater than 0, and its calculation can refer to the function CVI_VPSS_GetWrapBufferSize.
  • CVI_VPSS_SetChnScaleCoefLevel
  • CVI_VPSS_GetChnScaleCoefLevel
6.4.33. VPSS_SCALE_COEF_E
Define VPSS image scaling algorithm.
typedef enum _VPSS_SCALE_COEF_E {
   VPSS_SCALE_COEF_BICUBIC = 0,
   VPSS_SCALE_COEF_BILINEAR,
   VPSS_SCALE_COEF_NEAREST,
   VPSS_SCALE_COEF_DOWNSCALE_SMOOTH,
   VPSS_SCALE_COEF_OPENCV_BILINEAR,
   VPSS_SCALE_COEF_MAX,
 } VPSS_SCALE_COEF_E;
【Member】
Member
Description
bicubic algorithm.
bilinear algorithm.
nearest algorithm.
downscale algorithm.
opencv bilinear algorithm.
None.
6.4.34. CVI_STITCH_SRC_S
Define VPSS stitch src info.
typedef struct _CVI_STITCH_SRC_S {
   VPSS_GRP VpssGrp;
   VPSS_CHN VpssChn;
 } CVI_STITCH_SRC_S;
【Member】
Member
Description
VpssGrp
VPSS Group Number.
VpssChn
VPSS Channel Number.
None.
6.4.35. CVI_STITCH_CHN_S
Define VPSS stitch chn property.
typedef struct _CVI_STITCH_CHN_S {
   CVI_STITCH_SRC_S stStitchSrc;
   RECT_S stDstRect;
   CVI_U8 u8Priority;
 } CVI_STITCH_CHN_S;
【Member】
Member
Description
stStitchSrc
stDstRect
VPSS stitch dest position.
u8Priority
Priority.
None.
6.4.36. CVI_STITCH_ATTR_S
Define VPSS stitch property.
typedef struct _CVI_STITCH_ATTR_S {
   CVI_U8 u8ChnNum;
   CVI_U8 VoChn;
   CVI_S32 s32OutFps;
   PIXEL_FORMAT_E enOutPixelFormat;
   SIZE_S stOutSize;
   VB_POOL hVbPool;
   CVI_STITCH_CHN_S astStitchChn[CVI_STITCH_CHN_MAX_NUM];
 } CVI_STITCH_ATTR_S;
【Member】
Member
Description
u8ChnNum
the number of vpss stitch chn.
VoChn
Vo chn id.
s32OutFps
Output FPS.
enOutPixelFormat
image pixel format.
stOutSize
Output size.
hVbPool
Attached vb pool.
astStitchChn
vpss stitch chn attr.
None.
