3. User Interface
This chapter introduces the user interface.
3.1. Introduction
The basic procedure is transforming the model into a mlir file with model_transform.py, and then transforming the mlir into the corresponding model with model_deploy.py.
Calibration is required if you need to get the INT8 model.
The general process is shown in the figure (User interface 1).
Other complex cases such as image input with preprocessing and multiple inputs are also supported, as shown in the figure (User interface 2).
TFLite model conversion is also supported, with the following command:
# TFLite conversion example
--model_name resnet50_tf \
--scale 1.0,1.0,1.0 \
--mlir resnet50_tf.mlir
--mlir resnet50_tf.mlir \
--asymmetric \
--tolerance 0.95,0.85 \
Supporting the conversion of Caffe models, the commands are as follows:
# Caffe conversion example
--model_name resnet18_cf \
--model_def ../resnet18.prototxt \
--mean 104,117,123 \
--mlir resnet50_cf.mlir
# The call of model_deploy is consistent with onnx
Fig. 3.1 User interface 1
Fig. 3.2 User interface 2
3.2. model_transform.py
Used to convert various neural network models into MLIR files, the supported parameters are shown below:
Name |
Required? |
Explanation |
model_name |
Y |
Model name |
model_def |
Y |
Model definition file (e.g., ‘.onnx’, ‘.tflite’ or ‘.prototxt’ files) |
model_data |
N |
Specify the model weight file, required when it is caffe model (corresponding to the ‘.caffemodel’ file) |
input_shapes |
N |
The shape of the input, such as [[1,3,640,640]] (a two-dimensional array), which can support multiple inputs |
input_types |
N |
Type of the inputs, such int32; separate by ‘,’ for multi inputs; float32 as default |
resize_dims |
N |
The size of the original image to be adjusted to. If not specified, it will be resized to the input size of the model |
keep_aspect_ratio |
N |
Whether to maintain the aspect ratio when resize. False by default. It will pad 0 to the insufficient part when setting |
mean |
N |
The mean of each channel of the image. The default is 0.0,0.0,0.0 |
scale |
N |
The scale of each channel of the image. The default is 1.0,1.0,1.0 |
pixel_format |
N |
Image type, can be rgb, bgr, gray or rgbd |
output_names |
N |
The names of the output. Use the output of the model if not specified, otherwise use the specified names as the output |
test_input |
N |
The input file for validation, which can be an image, npy or npz. No validation will be carried out if it is not specified |
test_result |
N |
Output file to save validation result |
excepts |
N |
Names of network layers that need to be excluded from validation. Separated by comma |
mlir |
Y |
The output mlir file name (including path) |
post_handle_type |
N |
fuse the post handle op into bmodel, set the type of post handle op such as yolo and ssd |
After converting to an mlir file, a ${model_name}_in_f32.npz file will be generated, which is the input file for the subsequent models.
3.3. run_calibration.py
Use a small number of samples for calibration to get the quantization table of the network (i.e., the threshold/min/max of each layer of op).
Supported parameters:
Name |
Required? |
Explanation |
(None) |
Y |
Mlir file |
dataset |
N |
Directory of input samples. Images, npz or npy files are placed in this directory |
data_list |
N |
The sample list (cannot be used together with “dataset”) |
input_num |
N |
The number of input for calibration. Use all samples if it is 0 |
tune_num |
N |
The number of fine-tuning samples. 10 by default |
histogram_bin_num |
N |
The number of histogram bins. 2048 by default |
o |
Y |
Name of output calibration table file |
3.4. model_deploy.py
Convert the mlir file into the corresponding model, the parameters are as follows:
Name |
Required? |
Explanation |
mlir |
Y |
Mlir file |
quantize |
Y |
Quantization type (F32/F16/BF16/INT8) |
chip |
Y |
The platform that the model will use. Support bm1684x/bm1684/cv183x/cv182x/cv181x/cv180x. |
calibration_table |
N |
The quantization table path. Required when it is INT8 quantization |
tolerance |
N |
Tolerance for the minimum similarity between MLIR quantized and MLIR fp32 inference results |
test_input |
N |
test_reference |
N |
Reference data for validating mlir tolerance (in npz format). It is the result of each operator |
excepts |
N |
model |
Y |
Name of output model file (including path) |
3.5. Other Tools
3.5.1. model_runner.py
Model inference. bmodel/mlir/onnx/tflite supported.
Example:
$ model_runner.py \
--input sample_in_f32.npz \
--model sample.bmodel \
--output sample_output.npz
Name |
Required? |
Explanation |
input |
Y |
Input npz file |
model |
Y |
Model file (bmodel/mlir/onnx/tflite) |
dump_all_tensors |
N |
Export all the results, including intermediate ones, when specified |
3.5.2. npz_tool.py
npz will be widely used in TPU-MLIR project for saving input and output results, etc. npz_tool.py is used to process npz files.
Example:
# Check the output data in sample_out.npz
Supported functions:
Function |
dump |
Get all tensor information of npz |
compare |
Compare difference of two npz files |
to_dat |
Export npz as dat file, contiguous binary storage |
3.5.3. visual.py
visual.py is an visualized network/tensor compare application with interface in web browser, if accuracy of quantized network is not as good as expected, this tool can be used to investigate the accuracy in every layer.
Example:
# use TCP port 9999 in this example
$ visual.py --fp32_mlir f32.mlir --quant_mlir quant.mlir --input top_input_f32.npz --port 9999
Function |
f32_mlir |
fp32 mlir file |
quant_mlir |
quantized mlir file |
input |
test input data for networks, can be in jpeg or npz format. |
port |
TCP port used for UI, default port is 10000,the port should be mapped when starting docker |
manual_run |
if net will be automaticall inferenced when UI is opened, default is false for auto inference |
