8.1. 微服务器定制化软件包
8.1.1. 在微服务器[SE5/SE7]上执行系统打包脚本
下载打包需要使用的脚本: socBak.sh 。
#!/bin/bash
# These parameters are used to exclude irrelevant files
# and directories in the context of repackaging mode.
# Users can add custom irrelevant files and directories
# in the format of ROOTFS_EXCLUDE_FLAGS_INT to the
# ROOTFS_EXCLUDE_FLAGS_USER parameter.
ROOTFS_EXCLUDE_FLAGS_INT='--exclude=./var/log/* --exclude=./boot/* --exclude=./recovery/* --exclude=./data/* --exclude=./media/* --exclude=./sys/* --exclude=./proc/* --exclude=./dev/* --exclude=./factory --exclude=./run/udev/* --exclude=./run/user/* --exclude=./socrepack'
ROOTFS_EXCLUDE_FLAGS_USER=''
ROOTFS_EXCLUDE_FLAGS_OPT="${ROOTFS_EXCLUDE_FLAGS_INT} ${ROOTFS_EXCLUDE_FLAGS_USER} --exclude=./opt/*"
ROOTFS_EXCLUDE_FLAGS_SYSTEM="${ROOTFS_EXCLUDE_FLAGS_INT} ${ROOTFS_EXCLUDE_FLAGS_USER} --exclude=./system/*"
ROOTFS_EXCLUDE_FLAGS=''
ROOTFS_INCLUDE_PATHS='./var/log/nginx '
# These parameters define several generated files and
# their default sizes for repackaging. Users can modify
# them according to their device specifications.
TGZ_FILES=(boot data opt system recovery rootfs)
# Here are the default sizes for each partition
declare -A TGZ_FILES_SIZE
TGZ_FILES_SIZE=(["boot"]=131072 ["recovery"]=3145728 ["rootfs"]=2621440 ["opt"]=2097152 ["system"]=2097152 ["data"]=4194304)
# The increased size of each partition compared to the original partition table
TGZ_ALL_SIZE=$((100*1024))
EMMC_ALL_SIZE=20971520
EMMC_MAX_SIZE=30000000
TAR_SIZE=0
TGZ_FILES_PATH=$(pwd)
PARTITION_FILE=partition32G.xml
SOC_VERSION=0
ONLY_TEST=0
NEED_BAK_FLASH=1
PWD="$(dirname "$(readlink -f "\$0")")"
if [ $PWD != "/socrepack" ]; then
echo "The current path is not \"/socrepack\", please check it"
exit
fi
echo "The current path is \"/socrepack\""
if [ -d "/system" ]; then
SOC_VERSION=0
TGZ_FILES=( ${TGZ_FILES[@]/opt} )
unset TGZ_FILES_SIZE[opt]
echo find /system dir, the version is 3.0.0 or lower, cannot suppot bakpack spi_flash
ROOTFS_EXCLUDE_FLAGS="${ROOTFS_EXCLUDE_FLAGS_SYSTEM}"
NEED_BAK_FLASH=0
elif [ -d "/opt" ]; then
SOC_VERSION=1
TGZ_FILES=( ${TGZ_FILES[@]/system} )
unset TGZ_FILES_SIZE[system]
echo find /opt dir, the version is V22.09.02 or higher
ROOTFS_EXCLUDE_FLAGS="${ROOTFS_EXCLUDE_FLAGS_OPT}"
else
echo cannot find /opt or /system, Please check the operating environment
exit
fi
if [ "$NEED_BAK_FLASH" -eq 1 ]; then
echo bakpack spi_flash start
cp /boot/spi_flash.bin spi_flash.bin
rm fip.bin
SOC_NAME=""
FLASH_OFFSET=0
if [ -e /proc/device-tree/tsdma* ]; then
echo soc is bm1684x
SOC_NAME="bm1684x"
FLASH_OFFSET=0
flash_update -d fip.bin -b 0x6000000 -o 0x30000 -l 0x170000
else
echo soc is bm1684
SOC_NAME="bm1684"
FLASH_OFFSET=1
flash_update -d fip.bin -b 0x6000000 -o 0x40000 -l 0x160000
fi
rm spi_flash_$SOC_NAME.bin
flash_update -d spi_flash_$SOC_NAME.bin -b 0x6000000 -o 0 -l 0x200000
dd if=spi_flash_$SOC_NAME.bin of=spi_flash.bin seek=$FLASH_OFFSET bs=4194304 conv=notrunc
cp spi_flash.bin /boot/spi_flash.bin.socBakNew
echo bakpack spi_flash end
fi
for TGZ_FILE in "${TGZ_FILES[@]}"
do
case $TGZ_FILE in
"rootfs")
pushd /
echo tar $TGZ_FILE flags : $ROOTFS_EXCLUDE_FLAGS ...
if [ "$ONLY_TEST" == "0" ]; then
mkdir -p /etc/systemd/system/basic.target.wants/
pushd /etc/systemd/system/basic.target.wants/
ln -s ../../../../lib/systemd/system/resize-helper.service
popd
rm -rf $TGZ_FILES_PATH/$TGZ_FILE.tar
tar -caSf $TGZ_FILES_PATH/$TGZ_FILE.tar $ROOTFS_EXCLUDE_FLAGS ./*
tar -raSf $TGZ_FILES_PATH/$TGZ_FILE.tar $ROOTFS_INCLUDE_PATHS
gzip -c $TGZ_FILES_PATH/$TGZ_FILE.tar > $TGZ_FILES_PATH/$TGZ_FILE.tgz
rm /etc/systemd/system/basic.target.wants/resize-helper.service
fi
TAR_SIZE=$(du -s ./ $ROOTFS_EXCLUDE_FLAGS | awk '{s=$1} END {printf "%d", s}')
TAR_SIZE=$(($TAR_SIZE+$((512*1024))))
popd
pushd /$TGZ_FILE
echo tar $TGZ_FILE ...
tar -caSf $TGZ_FILES_PATH/$TGZ_FILE.tgz ./*
fi
TAR_SIZE=$(du -s ./ | awk '{s=$1} END {printf "%d", s}')
TAR_SIZE=$(($TAR_SIZE+$((100*1024))))
popd
esac
echo $TGZ_FILES_PATH/$TGZ_FILE.tgz : $TAR_SIZE KB
if [ $TAR_SIZE -gt ${TGZ_FILES_SIZE["$TGZ_FILE"]} ];
then
echo need to expand $TGZ_FILE from ${TGZ_FILES_SIZE[$TGZ_FILE]} KB to $TAR_SIZE KB
TGZ_FILES_SIZE[$TGZ_FILE]=$TAR_SIZE
fi
done
do
TGZ_ALL_SIZE=$(($TGZ_ALL_SIZE+${TGZ_FILES_SIZE["$TGZ_FILE"]}))
done
echo partition table size : $TGZ_ALL_SIZE KB
if [ $TGZ_ALL_SIZE -gt $EMMC_ALL_SIZE ];
then
echo need to expand default partition table size from $EMMC_ALL_SIZE KB to $TGZ_ALL_SIZE KB
EMMC_ALL_SIZE=$TGZ_ALL_SIZE
fi
# if [ $TGZ_ALL_SIZE -gt $EMMC_MAX_SIZE ];
# then
# echo The total size is too large.
# exit 1
# fi
echo The generated file partition32G.xml can replace file bootloader-arm64/scripts/partition32G.xml in VXX
echo or replace some information for 3.0.0
echo "<physical_partition size_in_kb=\"$EMMC_ALL_SIZE\">" > $TGZ_FILES_PATH/$PARTITION_FILE
echo " <partition label=\"BOOT\" size_in_kb=\"${TGZ_FILES_SIZE[boot]}\" readonly=\"false\" format=\"1\" />" >> $TGZ_FILES_PATH/$PARTITION_FILE
echo " <partition label=\"RECOVERY\" size_in_kb=\"${TGZ_FILES_SIZE[recovery]}\" readonly=\"false\" format=\"2\" />" >> $TGZ_FILES_PATH/$PARTITION_FILE
echo " <partition label=\"MISC\" size_in_kb=\"10240\" readonly=\"false\" format=\"0\" />" >> $TGZ_FILES_PATH/$PARTITION_FILE
echo " <partition label=\"ROOTFS\" size_in_kb=\"${TGZ_FILES_SIZE[rootfs]}\" readonly=\"true\" format=\"2\" />" >> $TGZ_FILES_PATH/$PARTITION_FILE
echo " <partition label=\"ROOTFS_RW\" size_in_kb=\"6291456\" readonly=\"false\" format=\"2\" />" >> $TGZ_FILES_PATH/$PARTITION_FILE
if [ "$SOC_VERSION" == "1" ]; then
echo " <partition label=\"OPT\" size_in_kb=\"${TGZ_FILES_SIZE[opt]}\" readonly=\"false\" format=\"2\" />" >> $TGZ_FILES_PATH/$PARTITION_FILE
else
echo " <partition label=\"SYSTEM\" size_in_kb=\"${TGZ_FILES_SIZE[system]}\" readonly=\"false\" format=\"2\" />" >> $TGZ_FILES_PATH/$PARTITION_FILE
fi
echo " <partition label=\"DATA\" size_in_kb=\"${TGZ_FILES_SIZE[data]}\" readonly=\"false\" format=\"2\" />" >> $TGZ_FILES_PATH/$PARTITION_FILE
echo "</physical_partition>" >> $TGZ_FILES_PATH/$PARTITION_FILE
cat $TGZ_FILES_PATH/$PARTITION_FILE
sync
准备一个外部存储设备(SD卡,TF卡或U盘等),将打包工具 socBak.sh 拷入该设备下, 将设备插到微服务上, 切换到root账户。
sudo su
登录到微服务器上,使用 fdisk -l 指令查看刚才接入的外部存储的设备文件名,外部存储设备接入盒子后,系统会自动分配一个设备文件名。
fdisk -l
测试使用的设备在微服务上显示的是 /dev/sda4, 后面操作是在此基础上进行的,不同的设备显示可能不同。
在根目录下创建 socrepack 目录,将外部存储挂载到该目录下。
cd /
mkdir socrepack
cd socrepack/
mount /dev/sda4 /socrepack/
给脚本添加执行权限, 然后执行打包脚本。
chmod +x socBak.sh
bash socBak.sh
执行成功后主要生成以下几个文件
└── socrepack
├── boot.tgz
├── data.tgz
├── fip.bin
├── opt.tgz
├── partition32G.xml
├── recovery.tgz
├── spi_flash.bin
├── spi_flash_bm1684(x).bin
└── rootfs.tgz
在X86机器上制作定制的系统包, 推荐使用Ubuntu18.04
下载重打包所需文件:
sdcard.tgz: 微服务器原始卡刷包。
在bootloader-arm64同级目录下创建install目录, 并在install目录下创建soc_bm1684目录;将sdcard.tgz移动到install/soc_bm1684路径下。
最终的目录结构如下:
├── bootloader-arm64
├── install
│ └── soc_bm1684
│ └── sdcard.tgz
安装依赖项。
sudo apt install bison flex bc rsync kmod byobu language-pack-en gcc util-linux exfat-utils dosfstools
sudo apt install cpio uuid-dev cmake libssl-dev fakeroot dpkg-dev uuid libxml2
sudo apt install device-tree-compiler u-boot-tools libxml2-dev debootstrap qemu-user-static kpartx
设置环境变量。
source bootloader-arm64/scripts/envsetup.sh
使用revert_package命令进行拆包。
revert_package
拆包结果会在install/soc_bm1684路径,软件包和文件夹的具体描述请参考《 官方BSP文档 》。
其目录结构如下:
└── soc_bm1684
├── boot.tgz
├── package_update
├── rootfs.tgz
├── sdcard.tgz
├── spi_flash_bm1684.bin
├── data.tgz
├── opt.tgz
├── recovery.tgz
├── rootfs_rw.tgz
├── spi_flash.bin
└── spi_flash_bm1684x.bin
将微服务器上生成的文件替换到install/soc_bm1684目录下。
将微服务器上生成的partition32G.xml替换到bootloader-arm64/scripts/目录下。
使用build_update sdcard指令更新刷机包,得到的定制刷机包位于install/soc_bm1684/sdcard目录下。
