44. Proc Debugging Information Description¶
44.1. Function Overview¶
The debugging information uses the proc file system, which can reflect the set parameters, 3A statistics, 3A operation results and other information in the ISP module in real time according to the proc param and proc level set by the upper layer for developers to locate and analyze problems.
44.2. Usage Method¶
[File directory]
/proc/cvitek/isp
[Opening Method]
After calling CVI_ISP_After MemInit, call CVI_ISP_SetCtrlParam to set the ISP control parameter u32ProcParam=n, where n cannot be zero.
n is the frequency at which ISP information is collected. ISP information is collected every n frames. The default value is 30
Call CVI_ISP_SetCtrlParam to set the ISP control parameter u32ProcLevel=m, where m ranges from [0, 3]
m=0 means proc function is off,
m=1 means level1 level information is printed,
m=2 means level2 level information is printed,
m=3 means level3 level information is printed, the higher level3 level information is printed, and the higher level print content must contain lower level print content, default value is 0
When using ISP_TOOL_DAEMON to turn on proc , you can Export PROC_LEVEL=n (n 1-3, n=0 does not open) before running ISP_TOOL_DAEMON
[ View Information Methods]
After ISP module is running properly
By calling cat/proc/cvitek/isp in the console, the associated logs are then printed to the console cp/proc/cvitek/isp view to pc
44.3. ISP¶
44.3.1. LEVEL1 Debugging Information Analysis¶
Printing of ISP Module parameters
[parameters Description]
Parameter |
MODULE/CTRLPARAM |
ProcParam |
Indicates the collection frequency of collecting ISP information |
ProcLevel |
Indicates the level level of ISP proc |
AEStatIntvl |
Indicates the update frequency of ISP AE statistics |
AWBStatIntvl |
Indicates the update frequency of ISP AWB statistics |
AFStatIntvl |
Indicates the update frequency of ISP AF statistics |
UpdatePos |
Indicates whether the interrupt update position is interrupted at the start of the frame or at the end of the frame, 0 is the start of the frame |
IntTimeOut |
Indicates the maximum time to get the ISP interrupt timeout |
PwmNumber |
Indicates pwm usage |
PortIntDelay |
Indicates the Port interrupt delay time |
FSWDR |
Enable |
WDR module enable |
MotionCompEnable |
WDR motion detect enable switch |
CombineSNRAwareEn |
The wide dynamic fusion mode with SNR perception is enabled, which can adaptively determine the fusion ratio of long and short frames according to the noise of short frames |
CombineSNRAwareLowThr |
Short frame noise SNR adaptive low threshold. When the estimated noise of the short frame is lower than the low threshold value, general long and short frame fusion is performed, and the noise is between the low threshold value and the high threshold value, and the SNR adaptive fusion is performed in proportion. |
CombineSNRAwareHighThr |
When the short frame estimation noise is higher than the high threshold value according to The SN RAwareToleranceLevel intensity performs SNR adaptive fusion, and the noise is between the low critical value and the high critical value, and the SNR adaptive fusion is performed in proportion. |
CombineSNRAwareSmLevel |
The smoothness of time domain changes in short frame noise SNR adaptation |
ExposureRatio |
Exposure ratio of WDR long and short exposure |
ShortMaxVal |
The maximum value of WDR wide dynamic range |
isManualMode |
manual mode or automatic mode |
CombineLongThr |
Long exposure threshold, image data below this threshold will only select long exposure data to synthesize WDR images |
CombineShortThr |
Short exposure critical value, image data exceeding this critical value will only select short exposure data to synthesize WDR image |
CombineMinWeight |
The minimum weight value for long and short exposure image data fusion. The larger the weight value, the more the proportion of long exposure in the fusion time, and vice versa, the more the proportion of short exposure |
CombineMaxWeight |
Long and short exposure image data are fused with the highest weight value. The larger the weight value, the more the proportion of long exposure in the fusion time, and vice versa, the more the proportion of short exposure |
MergeMode |
WDR motion detect mode 0: Motion detect information takes the maximum value of long and short frame motion information 1: Motion detect information is an equal proportion fusion of long and short frame motion information, and the ratio is defined by MergeModeAlpha |
MergeModeAlpha |
MergeMode mode is 1 mobile information fusion ratio |
C ombineSNRAwareTolLevel |
Noise Tolerance Strength of Short Frame Noise SNR Adaptation |
Shading |
MeshEnable |
MeshLSC function enable |
MeshisManualMode |
MeshStr |
LSC compensation strength |
MeshLscGainLut Size |
Color temperature adaptive LSC compensation gain table quantity |
M eshLscGainLutColorTemp |
The color temperature corresponding to the color temperature adaptive LSC compensation gain table |
RadialEnable |
RadialLSC function enable |
RadialCenterX |
X-direction coordinates of image sensor mirror center |
RadialCenterY |
Y-direction coordinates of image sensor mirror center |
RadialStr |
Low-RadialGainLut |
LSC Radius Form Compensation Gain Table |
High-RadialGainLut |
DCI |
Enable |
DCI module enable |
Speed |
Smooth strength, the higher the value, the slower the change |
DciStrength |
Used to control the strength of DCI, the larger the value, the greater the contrast. |
isManualMode |
ContrastGain |
Keep the lowest slope of each BIN, the larger the value, the smaller the slope |
BlcThr |
The threshold value used to determine the range of the dark zone. The larger the value, the larger the range of dark areas included. |
WhtThr |
The threshold used to determine the range of bright areas. The smaller the value, the larger the range of bright areas included. |
BlcCtrl |
Used to determine the contrast of dark areas. When the value is 256, the contrast of dark areas remains unchanged. When it is larger than 256, the larger the value, the greater the contrast of the dark area; otherwise, the smaller the value, the smaller the contrast of the dark area. |
WhtCtrl |
Used to determine the contrast of bright areas. When the value is 256, the contrast of the bright area remains unchanged. When the value is greater than 256, the larger the value, the greater the contrast of the bright area; on the contrary, the smaller the value, the smaller the contrast of the bright area. |
Dehaze |
Enable |
Enable the Dehaze function |
isManualMode |
Strength |
Used to control the intensity of Dehaze. The larger the value, the stronger the defogging strength |
BlackLevel |
Enable |
The BLC module enable |
isManualMode |
PreOffsetR |
BLC R pixel dark current value |
PreOffsetGr |
BLC GR pixel dark current value |
PreOffsetGb |
BLC Gb pixel dark current value |
PreOffsetB |
BLC B pixel dark current value |
PreGainR |
BLC R pixel dark current compensation gain |
PreGainGr |
BLC Gr pixel dark current compensation gain |
PreGainGb |
BLC Gb pixel dark current compensation gain |
PreGainB |
BLC B pixel dark current compensation gain |
PostOffsetR |
PostOffsetGr |
BLC Gr pixel dark current value |
PostOffsetGb |
PostOffsetB |
PostGainR |
PostGainGr |
PostGainGb |
PostGainB |
DPC |
Enable |
The DPC module enable |
isManualMode |
ClusterSize |
The upper limit of the clustered dead pixels area, the higher the value, the better the clustered dead pixels can be corrected, but it may cause the attenuation of the high-frequency area resolution |
BrightDefToNorPixRatio |
The magnification of visible bright and bad pixel value and surrounding pixels |
DarkDefToNorPixRatio |
The magnification of visible dark pixel value and surrounding pixels |
FlatThreR |
The critical value of the R channel to determine the flat area, the smaller the value, the better the edge information can be preserved |
FlatThreG |
The critical value of the B channel to determine the flat area, the smaller the value, the better the edge information can be preserved |
FlatThreB |
FlatThreMinG |
The minimum critical value of the G channel to distinguish the flat area |
FlatThreMinRB |
The minimum critical value of the RB channel to determine the flat area |
TNR |
Enable |
TNR module enable |
DeflickerMode |
Anti-flicker mode |
D eflickerToleranceLevel |
Anti-flicker mode mode4 anti-flicker tolerance value, the larger the value, the better the anti-flicker, but the moving afterimage in the bright area will also increase. |
LowMtPrtEn |
Airspace noise reduction micro motion protection enabled |
isManualMode |
TnrStrength0 |
Long Exposure TNR Intensity Gain |
MapThdLow0 |
Long Exposure TNR Intensity Upper Limit |
MapThdHigh0 |
Long exposure TNR intensity lower limit |
BrightnessNoiseLevelLE |
Long Exposure Luminance Noise Tolerance Value |
BrightnessNoiseLevelSE |
Short exposure luminance noise tolerance value |
RNoiseLevel0 |
Long exposure red channel noise tolerance value |
RNoiseHiLevel0 |
Long exposure red channel highlight noise tolerance value |
GNoiseLevel0 |
Long exposure green channel noise tolerance value |
GNoiseHiLevel0 |
Long exposure green channel highlight noise tolerance value |
BNoiseLevel0 |
Long exposure blue channel noise tolerance value |
BNoiseHiLevel0 |
Long exposure blue channel highlight noise tolerance value |
RNoiseLevel1 |
Short exposure red channel noise tolerance value |
RNoiseHiLevel1 |
Short exposure red channel highlight noise tolerance value |
GNoiseLevel1 |
Short exposure green channel noise tolerance value |
GNoiseHiLevel1 |
Short exposure green channel highlight noise tolerance value |
BNoiseLevel1 |
Short exposure blue channel noise tolerance value |
BNoiseHiLevel1 |
Short exposure blue channel highlight noise tolerance value |
LowMtPrtLevel |
protection limit |
L2mIn0 |
Long-exposure TNR brightness versus intensity gain characteristics table. An array of four sets of values. Define the gray level, the larger the value, the higher the gray level. |
L2mOut0 |
Long-exposure TNR brightness versus intensity gain characteristics table. An array of four sets of values. Defines the intensity gain, the larger the value, the stronger the intensity. |
L2mIn1 |
Short exposure TNR luminance vs. intensity gain characteristics table. An array of four sets of values. Define the gray level, the larger the value, the higher the gray level. |
L2mOut1 |
Short exposure TNR luminance vs. intensity gain characteristics table. An array of four sets of values. Defines the intensity gain, the larger the value, the stronger the intensity. |
PrtctIn0 |
Long-exposure TNR momentum vs. smear removal degree characteristic table, an array consisting of four sets of values. Define the motion level to eliminate the tailing of moving objects, the larger the value, the stronger the motion range. |
PrtctOut0 |
Long-exposure TNR momentum vs. smear removal degree characteristic table, an array consisting of four sets of values. Define the motion level to remove the tailing of moving objects, the smaller the value, the stronger the tailing removal. |
PrtctIn1 |
Short-exposure TNR momentum vs. smear removal characteristic table, an array consisting of four groups of values. Define the motion level to eliminate the tailing of moving objects, the larger the value, the stronger the motion range. |
PrtctOut1 |
Short-exposure TNR momentum vs. smear removal characteristic table, an array consisting of four groups of values. Define the motion level to remove the tailing of moving objects, the smaller the value, the stronger the tailing removal. |
LowMtPrtIn |
Define exercise class |
LowMtPrtOut |
The larger the value, the less obvious the smear and the more obvious the noise |
CAC |
Enable |
CAC module enable |
VarThr |
Threshold for edge detect. The smaller the value, the more regions are judged as edges. |
PurpleDetRange |
Threshold for purple fringing detect. The larger the value, the more areas are judged as purple fringing. |
PurpleCb |
The coordinates of purple in the Cb domain. |
PurpleCr |
The coordinates of purple in the Cr domain. |
GreenCb |
The coordinates of green in Cb domain. |
GreenCr |
The coordinates of green in Cr domain. |
isManualMode |
DePurpleStr |
CNR |
Enable |
The CNR module is enabled. |
isManualMode |
CnrStr |
Color noise denoising strength. The larger the value, the stronger the color noise denoising. |
NoiseSuppressStr |
Color noise suppression strength. The larger the value, the stronger the color noise removal. |
NoiseSuppressGain |
Color noise suppression strength gain. The smaller the value, the stronger the color noise denoising. |
FilterType |
Color noise denoising filter strength. The larger the value, the stronger the color noise removal. |
MotionNrStr |
Adjust the color noise denoising strength of the moving object area. Larger values result in less color noise in motion areas. |
DetailSmoothMode |
Denoise detail smoothing function enabled |
Sharpen |
Enable |
Y Sharpen module enable |
EdgeGain |
Edge Enhancement parameters The larger the value, the stronger the edge sharpening |
TextureGain |
Enhancement parameters for detail | textures The larger the value, the greater the detail texture sharpening intensity |
EdgeThr |
The boundary threshold between edge and noise, greater than this value is considered as edge, and less than this value is considered as noise The larger the value, the fewer edges are enhanced; the smaller the value, the more edges are enhanced. When the exposure gain is larger, the value is recommended to be set larger |
TextureThr |
The demarcation threshold between detail texture and noise, greater than this value is regarded as detail texture, and less than this value is regarded as noise |
LumaAdpCoringEn |
Automatic Luminance Noise Rejection Threshold Switch |
LumaAdpGainEn |
Brightness sharpening weights enabled |
DeltaAdpGainEn |
sharpen weights enabled |
W drCoringCompensationEn |
Luminance sharpening noise value compensation is enabled in wdr mode. |
Wdr CoringCompensationMode |
Compensation mode for luminance sharpening noise value in wdr mode. 0: Compensate luminance sharpening noise according to WdrCoringHighThrd and WdrCoringLowthd. 1: Automatically compensate luminance sharpening noise according to DRC tone mapping curve. |
W drCoringToleranceLevel |
Tolerance value for luma sharpening noise compensation in wdr mode. The smaller the value, the more obvious the effect of sharpening, but the easier it is to sharpen the noise. The larger the value is, the less likely it is to sharpen the noise, but the sharpening effect is less obvious. |
WdrCoringHighThr |
High threshold for luma sharpening noise wdr mode compensation. Noise compensation is not performed for brightness below this threshold. If the brightness is higher than this critical value, noise compensation will be performed according to the value of WdrC oringToleranceLevel. |
WdrCoringLowThr |
Brightness between WdrCoringLowThrd and WdrCoringHighThrd is compensated proportionally. Low threshold for luma sharpening noise wdr mode compensation. Noise compensation is not performed for brightness below this threshold. If the brightness is higher than this critical value, noise compensation will be performed according to the value of WdrC oringToleranceLevel. Brightness between WdrCoringLowThrd and WdrCoringHighThrd is compensated proportionally. |
isManualMode |
EdgeFreq |
Image Directional Edge Band Control |
TextureFreq |
Image non-directional detail texture band control |
GlobalGain |
Global sharpening weight |
OverShootThr |
White edge sharpening upper limit |
UnderShootThr |
Lower limit of black edge sharpening |
YNoiseLevel |
Luminance sharpening noise value magnification, one time is 64. The larger the value is, the more the brightness sharpening noise is amplified, and vice versa. |
DeltaAdpGain |
sharpening weight |
LumaAdpCoring |
Luminance sharpening noise values, detail texture or edge enhancement will exclude the enhancement contributed by this tolerance value. The smaller the value, the more obvious the effect of sharpening, but the easier it is to sharpen the noise. The larger the value is, the less likely it is to sharpen the noise, but the sharpening effect is less obvious. |
LumaAdpGain |
Brightness Sharpening Weight |
Saturation |
isManualMode |
Saturation |
saturation |
Gamma |
Enable |
Gamma function enable |
enCurveType |
Gamma Curve Type |
isManualMode |
HSV |
Enable |
Saturation Tuning enabled |
isManualMode |
SatCoringLinearTh |
coring value for saturation |
SatCoringLinearLmt |
Maximum output saturation |
CCM |
Enable |
CCM module enable |
isManualMode |
ISOActEnable |
Enable CCM Bypass function under low illumination |
TempActEnable |
The CCM Bypass function is enabled under high and low color temperatures. |
CCMTabNum |
The number of currently configured CCM matrices |
CCM |
Color Correction Matrix |
CCMTab |
CCM matrix coefficients at different color temperatures |
YNR |
Enable |
YNR module enable |
CoringParamEnable |
Control whether to use manual coring |
isManualMode |
WindowType |
Denoising filtering locality degree. The smaller the value, the more localized the effect |
DetailSmoothMode |
NoiseSuppressStr |
Noise suppression strength. The larger the value, the greater the intensity of bright noise removal |
FilterType |
Denoising filter strength. The larger the value, the greater the intensity of bright noise removal |
MotionThr |
Object movement threshold. The smaller the value, the larger the range of the frame detected as motion. |
MotionNrPosGain |
Adjusts the strength of denoising in areas greater than the motion threshold. The larger the value, the less noise is preserved. |
MotionNrNegGain |
Adjusts the strength of denoising in areas less than the motion threshold. Smaller values preserve less noise. |
VarThr |
Threshold for detecting edges. The larger the value, the fewer the number of edges judged. |
CoringWgtLF |
Adjusts the intensity of random noise in the low frequency region. The larger the value, the more noise is preserved in the low frequency region. |
CoringWgtHF |
Adjusts the intensity of random noise in the high frequency region. The larger the value, the more noise is preserved in the high-frequency region. |
NonDirFiltStr |
VhDirFiltStr |
Threshold for detect edges. The larger the value, the fewer the number of edges judged. |
AaDirFiltStr |
NoiseCoringBaseLuma |
The brightness value of the motion zone. |
NoiseCoringBaseOffset |
The brightness noise tolerance value of the motion area, the judgment of the motion area is linked with the detecting the TNR motion area. The larger the value, the greater the denoising strength of the motion area. |
NoiseCoringAdvLuma |
Quiet area brightness value |
NoiseCoringAdvOffset |
Luminance noise tolerance value in the static area, the judgment of the static area is linked with the detecting the TNR motion area. The larger the value, the stronger the noise removal in the static area. |
WDRExposureAttr |
ExpRatioType |
Quiet area brightness value Luminance noise tolerance value in the static area, the judgment of the static area is linked with the detect of the TNR motion area. The larger the value, the stronger the noise removal in the static area. |
ExpRatio |
Only valid in multi-frame synthesis WDR mode. When enExpRatioType is OP_TYPE_AUTO, au32ExpRatio is invalid. When enExpRatioType is OP_TYPE_MANUAL, au32ExpRatio is Rewritable, indicating the expected value of the exposure ratio of two adjacent frames of multi-frame synthesis WDR. Value range: [0x40, 0xFFF] |
ExpRatioMax |
Only valid in multi-frame synthesis WDR mode. When enExpRatioType is OP_TYPE_AUTO, u32ExpRatioMax indicates the maximum value of the ratio of the exposure time of the longest frame to the shortest frame. u32ExpRatioMax is invalid when enExpRatioType is OP_TYPE_MANUAL. 6bit decimal precision, 0x40 means the exposure ratio is 1 times. |
ExpRatioMin |
Only valid in multi-frame synthesis WDR mode. When enExpRatioType is OP_TYPE_AUTO, u32ExpRatioMin indicates the minimum value of the ratio of long frame exposure time to short frame exposure time. When enExpRatioType is OP_TYPE_MANUAL, u32ExpRatioMin is invalid. The format is unsigned 6.6bit fixed point, 0x40 means that the ratio of long frame exposure time to short frame exposure time is 1 times. The default value is 0x40. Value range: [0x40, u32ExpRatioMax] |
Tolerance |
Exposure ratio tolerance value, only valid in two-frame synthesis WDR mode. When enExpRatioType is OP_TYPE_AUTO, the larger the value, it means that the exposure ratio remains unchanged when the dynamic range of the scene changes within a certain range. The default value is 0xC. Value range: [0x0, 0xFF] |
Speed |
The automatic exposure ratio adjustment speed is only valid in the two-frame composite WDR mode. When enExpRatioType is OP_TYPE_AUTO, the larger the value, the faster the automatic exposure ratio adjustment. The default value is 0x20. Value range: [0x0, 0xFF] |
RatioBias |
The exposure ratio deviation value is only valid in multi-frame synthesis WDR mode. When enExpRatioType is OP_TYPE_AUTO, the larger the value, the larger the automatic exposure ratio. The default value is 0x400, which means that the calculation result of the automatic exposure ratio algorithm will not be adjusted. The exposure ratio adjusted by this value will be limited by the maximum/minimum value of the exposure ratio. Value range: [0x0, 0xFFFF] |
SECompensation |
Adjust the target brightness value of the short frame picture Value range: [0x0, 0xFF] |
SEHisThr |
Calculate the exposure ratio threshold when the short frame exceeds the long frame (1x = 64) |
SE His255CntTargetDownThr |
If the number of short frame histogram bin 255 is greater than this threshold, the target brightness of the short frame will be lowered |
SEHis255CntTargetUpThr |
If the number of short frame histogram bin 255 is less than this threshold, the target brightness of the downgraded short frame will be restored to the original target brightness |
L EHisCntTargetDownRatio |
If the number of long frame histogram bin 255 is greater than this threshold, the target brightness of the long frame will be lowered |
LEHisCntTargetUpRatio |
If the number of long frame histogram bin 255 is less than this threshold, the target brightness of the downgraded long frame will be restored to the original target brightness |
LEAdjustTargetMin |
Long frame Target min of each LV 40,40, 40, 40, 40, 40, 45, 50, 60, 60, 60, 60, 60, 60, 60, 60 |
LEAdjustTargetMax |
Long frame Target max of each LV 50,50, 50, 50, 50, 50, 60, 70, 85, 100, 110, 110, 120, 120, 120, 120 |
SEAdjustTargetMin |
Short frame target min for each LV 20,20, 20, 20, 20, 20, 20, 20, 20, 20, 20, 20, 20, 20, 20, 20 |
SEAdjustTargetMax |
Short frame target max for each LV 60, 60, 60, 60, 60, 60, 60, 60, 60, 60, 60, 60, 60, 60, 60, 60 |
DiffPixelNum |
The pixel number threshold of long frame histogram bin 255, if this value is exceeded, the target brightness of long exposure will be reduced |
LELowBinThr |
Only windows whose long-frame brightness is greater than this threshold can be added to AE long-frame photometry |
LEHighBinThr |
Only windows whose long-frame brightness is less than this threshold can be added to AE long-frame metering |
SELowBinThr |
Only windows whose short frame brightness is greater than this threshold can be added to AE short frame metering |
SEHighBinTh |
Only windows whose short-frame brightness is less than this threshold can be added to AE short-frame metering |
ExposureAttr |
ByPass |
AE module bypass function enable, the default is CVI_FALSE In FSWDR mode, it indicates the exposure time of the current shortest frame (VS). |
OpType |
Automatic exposure or manual exposure switch, the default is OP_TYPE_AUTO. |
AERunInterval |
The interval at which the AE algorithm runs, and the value range is [1, 255]. When the value is 1, it means that the AE algorithm is run every frame; When the value is 2, it means to run the AE algorithm every 2 frames, and so on. It is recommended not to set this value greater than 2, otherwise the AE adjustment speed will be affected. In WDR mode, it is recommended to set this value to 1, so that AE convergence will be smoother. This value defaults to 1. Linear mode does not care about this value. |
ExpTimeOpType |
Manual exposure time enable, the default value is OP_TYPE_AUTO |
AGainOpType |
Manual sensor analog gain enable, the default value is OP_TYPE_AUTO |
DGainOpType |
Manual sensor digital gain enable, the default value is OP_TYPE_AUTO |
ISPDGainOpType |
Manual ISP digital gain, 10bit decimal precision, the default value is 0x400. |
ExpTime |
Manual exposure time, in microseconds (us), the default value is 0x4000 |
AGain |
Manual sensor analog gain, 10bit decimal precision, the default value is 0x400. |
DGain |
Manual sensor digital gain, 10bit decimal precision, the default value is 0x400. |
ISPDGain |
ISONumOpType |
ISO num manual/automatic mode switching |
UseISONum |
In manual mode, use the ISO num type to control the gain |
ISONum |
In manual mode, the set ISO num |
ExpTimeRangeMax |
Exposure time range, set the maximum value in microseconds (us). |
ExpTimeRangeMin |
Exposure time range, set the minimum value in microseconds (us). |
AGainRangeMax |
Sensor analog gain range, set the maximum value, 10bit decimal precision. |
AGainRangeMin |
Sensor analog gain range, set the minimum value, 10bit decimal precision. |
DGainRangeMax |
Sensor digital gain range, set the maximum value, 10bit decimal precision. |
DGainRangeMin |
Sensor digital gain range, set the minimum value, 10bit decimal precision. |
ISPDGainRangeMax |
ISP digital gain range, set the maximum value, 10bit decimal precision. |
ISPDGainRangeMin |
ISP digital gain range, set minimum value, 10bit decimal precision. |
SysGainRangeMin |
System gain range, setting minimum value, 10bit decimal precision |
SysGainRangeMax |
System gain range, maximum setting, 10bit decimal precision |
Speed |
The speed at which auto exposure is adjusted. |
BlackSpeedBias |
Screen from dark to bright AE adjusts the deviation of the speed, the larger the value, the faster the screen from dark to bright. |
Tolerance |
Tolerance deviation of screen brightness during automatic exposure adjustment. |
Compensation |
Target brightness during automatic exposure adjustment. |
EVBias |
Exposure deviation value during automatic exposure adjustment, 10bit decimal precision |
AEStrategyMode |
Automatic exposure strategy, highlight priority or low light priority. |
AntiflickerEnable |
Anti-flash property settings. Anti-flash is disabled by default. |
AntiflickerFrequency |
Anti-flicker frequency value |
DebugMode |
AE’s debug mode parameter |
IRCutOnLv |
Environment Lv value without IR Cut, precision is 100 |
IRCutOffLv |
Use the ambient Lv value of IR Cut with an accuracy of 100 |
HistRatioSlope |
The blending weight of the brightness of the current frame and the brightness of the highlight area |
MaxHistOffset |
After mixing the brightness of the current frame with the brightness of the highlight area, the increased brightness range |
ISONumRangeMin |
The minimum value of the ISO num range |
ISONumRangeMax |
Maximum value of the ISO num range |
AdjustTargetMax |
target max for each LV 50,50, 50, 50, 50, 50, 55, 60, 60, 60, 60, 60, 60, 65, 70, 70 |
AdjustTargetMin |
target min for each LV 40,40, 40, 40, 40, 40, 45, 50, 50, 50, 50, 50, 50, 55, 60, 60 |
ExposureInfo |
ExposureTime |
The current exposure time, in microseconds (us). In FSWDR mode, it indicates the exposure time of the current shortest frame (VS). |
ShortExpTime |
In FSWDR mode, it indicates the exposure time of the current short frame (S), in microseconds (us). Linear mode does not care about this value. |
LongExpTime |
In FSWDR mode, it indicates the current long frame (L) exposure time in microseconds (us). Linear mode does not care about this value. |
AGain |
Current sensor analog gain, 10bit decimal precision. |
DGain |
Current sensor digital gain, 10bit decimal precision. |
ISPDGain |
Current ISP digital gain, 10bit decimal precision |
AveLum |
Average brightness information. |
ISO |
Current sensor analog gain*sensor digital gain*ISP digital gain*100, where the accuracy of the gain is 10bit. |
WDRShortAveLuma |
WDR Short frame average brightness information. |
WDRExpRatio |
WDR long, short frame exposure ratio |
LEFrameAvgLuma |
Average brightness of WDR long frame picture |
SEFrameAvgLuma |
Average brightness of WDR short frame picture |
LightValue |
Estimated ambient brightness value |
AE Route |
TotalNum |
The number of exposure distribution route nodes, currently the maximum is 16 |
AERouteNodex. IntTime |
The node exposure time of the node attribute of the exposure distribution route, in microseconds (us) |
AERouteNodex. SysGain |
The node gain of the node attribute of the exposure distribution route, including sensor analog gain, sensor digital gain and ISP digital gain, with 10bit precision. |
AERouteNodex. IrisFNO |
The number of exposure distribution route nodes, currently the maximum is 16 The node exposure time of the node attribute of the exposure distribution route, in microseconds (us) |
AERouteNodex. IrisFNOLin |
WBAttr |
ByPass |
White balance module Bypass enable, default value CVI_FALSE |
AWBRunInterval |
White balance module working frequency |
OpType |
Automatic white balance and manual white balance switching |
AlgType |
ALG_AWB ALG_AWB_SPEC |
DebugMode |
Debug mode |
Rgain |
Manual White Balance Red Channel Gain |
Grgain |
Manual white balance Gr channel gain |
Gbgain |
Manual white balance Gb channel gain |
Bgain |
Enable |
Auto white balance enabled |
RefColorTemp |
The ambient color temperature calibrated by the static white balance coefficient, in Kelvin. It is recommended to obtain 24 color card Raw data for calibration in Macbeth D50 standard light source environment or outdoor sunny environment |
RGStrength |
Auto white balance R channel calibration strength |
BGStrength |
Auto white balance B channel calibration strength |
Speed |
Automatic white balance algorithm convergence speed |
ZoneSel |
When the parameter is | 0 or 255, the white balance algorithm similar to the gray world is used, and other values are used for classification and screening to improve accuracy |
HighColorTemp |
Color temperature upper limit of automatic white balance algorithm |
LowColorTemp |
ShiftLimitEn |
AWB beyond the white point range of the gain map back to the switch of the white point range |
GainNormEn |
Limiting the RGB channel gain can improve the signal-to-noise ratio of low color temperature and low illumination scenes |
NaturalCastEn |
AWB style preference switch at low color temperature |
AWBZoneWtEn |
Screen partition weight switch, the default is off |
stCTLimit.bEnable |
Defines the Gain Range Limit property for self-balancing |
stCTLimit.enOpType |
0:AutoMode |
stCTLimit.HighRgLimit |
Maximum R gain at high color temperature in manual mode |
stCTLimit.HighBgLimit |
Minimum B gain at high color temperature in manual mode |
stCTLimit.LowRgLimit |
Minimum R gain at low color temperature in manual mode |
stCTLimit.LowBgLimit |
Maximum B gain at low color temperature in manual mode |
stLumaHist.bEnable |
AWB brightness and weight parameter switch |
stLumaHist.enOpType |
Auto Mode |
stCbCrTrack.bEnable |
Linkage parameters of | AWB statistical range and ISO |
Tolerance |
The deviation range of automatic white balance adjustment, when the detection error is within the threshold range, AWB will not act |
ZoneRadius |
The range of distances used to classify pixels in auto white balance statistics. The smaller the value, the higher the AWB accuracy, but it will reduce the stability of the AWB algorithm |
CurveLLimit |
The left limit of the automatic white balance color temperature curve |
CurveRLimit |
The right limit of the automatic white balance color temperature curve |
ExtraLightEn |
Whether to consider independent light source points outside the color temperature curve when calculating automatic white balance, up to four independent points |
WhiteBgain |
B channel gain of special light source point |
ExpQuant |
Judging by the external brightness. ExpQuant is the limit value of the brightness that is turned on. For example ExpQuant = 6, which means that the WB light source point is turned on below LV6 (the general night scene is below LV6) ExpQuant =106 means LV6 and above open ExpQuant =112 means it is enabled above LV12 (LV12 is generally outdoor) |
LightStatus |
Types of special light source points, 0: no action 1: Add light source point 2: Delete the calculation near the light source point |
Radius |
The area size of the special light source point, |
OutdoorStatus |
Indoor or outdoor mode (in manual mode) |
OutThresh |
The threshold for judging indoor and outdoor, when the brightness is less than, it is judged as indoor, outdoor LV mostly exceeds 15 |
LowStart |
Lower the weight of high color temperature, the starting point of high color temperature area is recommended to be 6500K |
LowStop |
Lower the weight of the low color temperature, the end point of the low color temperature area is recommended to be 4500K |
HighStart |
HighStop |
Lower the weight of high color temperature, the end point of high color temperature area is recommended to be 8000K |
GreenEnhanceEn |
In the green plant scene, the switch for the green channel is added |
OutShiftLimit |
When it is judged as an outdoor scene, the white point range limit of the AWB algorithm |
MultiLightSourceEn |
AWB detects whether the current scene is a mixed light source to adjust saturation or CCM |
MultiLSType |
Adjust Saturation or CCM |
MultiLSScaler |
Adjust saturation or CCM strength when mixing light sources |
FineTunEn |
AWB special color detection switch, such as skin color |
FineTunStrength |
Intensity of special color detection such as skin color and blue |
ShiftLimit |
CurvePara |
CurvePara[0-2] Planck curve coefficient, given by AWB calibration tool. Planck Lines depict the color performance of a white patch under standard light sources of different color temperatures. CurvePara[3-5] Color temperature curve coefficient, given by AWB calibration tool. color temperature curve The corresponding relationship between the color performance of the painted white block and the color temperature. |
StaticWB |
Static white balance coefficient, given by AWB calibration tool. |
AttrZoneWt |
32x32 picture weight |
stLumaHist.HistThresh |
Threshold for brightness classification (valid in manual mode) |
stLumaHist.HistWt |
The weight of brightness classification (valid in manual mode) |
stCbCrTrack.CrMax |
The maximum value of R/G under different ISO |
stCbCrTrack.CrMin |
The minimum value of R/G under different ISO |
stCbCrTrack.CbMax |
The maximum value of B/G under different ISO |
stCbCrTrack.CbMin |
The minimum value of B/G under different ISO |
MultiCTBin |
Color temperature segmentation parameters |
MultiCTWt |
Color Temperature Segment Weight |
WBInfo |
Rgain |
Current R channel gain value |
Ggain |
Current G channel gain value |
Bgain |
Current B channel gain value |
Saturation |
current saturation value |
ColorTemp |
Current color temperature value |
InOutStatus |
Indoor and outdoor test results |
Bv |
Current environment bv value |
CCM |
Current color correction matrix value, 8bit decimal precision. Bit 15 is a sign bit, 0 means a positive number, 1 means a negative number, for example, 0x8010 means -16. |
BNR |
Enable |
BNR module enable |
isManualMode |
WindowType |
Denoising filtering locality degree. The smaller the value, the more localized the effect. |
DetailSmoothMode |
The denoising detail smoothing function is enabled. |
NoiseSuppressStr |
Noise suppression strength. The larger the value, the stronger the bright noise removal. |
FilterType |
Denoising filter strength. The larger the value, the stronger the bright noise removal. |
NrLscRatio |
Adjust the denoising strength with reference to the LSC gain. The larger the value, the more proportional the reference LSC gain is. |
VarThr |
CoringWgtLF |
CoringWgtHF |
NonDirFiltStr |
Adjusts the strength of noise reduction in the low frequency region. The larger the value, the more noise is removed in the low frequency area. |
VhDirFiltStr |
Adjusts the strength of denoising in the horizontal and vertical areas. Larger values remove more noise on horizontal and vertical edges. |
AaDirFiltStr |
Adjusts the strength of denoising on diagonal edges. The larger the value, the more noise is removed on the diagonal edges. |
Crosstalk |
Enable |
GE module enable |
isManualMode |
Strength |
G channel balance global intensity |
FlatThre |
Flat area detection node 1-4 threshold |
GrGbDiffThreSec |
G channel balance node 1-4 threshold |
Demosaic |
Enable |
Demosaic module enable |
LumaTunedCoringEn |
(OpType, CoringEn) (x,0): by noise profile (1,1): by ISO table (0,1): by manual |
isManualMode |
CoarseEdgeThr |
Coarse edge detection threshold. The smaller the value, the greater the number detected as edges. It is recommended to debug with the parameter CoarseStr. |
CoarseStr |
Edge roughness intensity value. The smaller the value, the more directional the processing. Conversely, the more non-directional processing. |
FineEdgeThr |
Edge fine-tuning detection threshold. The smaller the value, the greater the number detected as edges. It is recommended to debug with the parameter FineStr. |
FineStr |
Edge refinement strength value. The smaller the value, the more directional the processing. Conversely, the more non-directional processing. |
DetailSmoothEnable |
Detail smoothing enabled |
DetailSmoothStr |
Detail smoothing intensity. The larger the value, the stronger the smoothing strength and the stronger the suppression of false details. |
DetailWgtThr |
Detail preservation range threshold. The smaller the value, the greater the range of detail preservation. |
DetailWgtSlope |
Details retain intensity. The larger the value, the more detail is preserved. |
DetailWgtMin |
Edge detail smoothing preserves the minimum gain allowed. |
DetailWgtMax |
Maximum gain allowed for edge detail smoothing preservation. |
LumaWgtThr |
Luminance detail smoothing range threshold. The smaller the value, the greater the range of detail smoothing. |
LumaWgtSlope |
Brightness Details Smooth Edges Preserve Strength. The larger the value, the stronger the detail smoothing. |
LumaWgtMin |
Minimum gain allowed for luminance detail smoothing strength. |
LumaWgtMax |
Maximum gain allowed for luminance detail smoothing strength. |
EdgeEnhanceEnable |
Edge hardening enabled |
OverShtGain |
Adjust the degree of overshoot. The larger the value, the greater the edge enhancement. When OverShtGain is doubled, its value is 256. |
UnderShtGain |
Adjust the degree of undershoot. The larger the value, the greater the edge enhancement. When UnderShtGain is doubled, its value is 256. |
NoiseSuppressStr |
Noise suppression strength. The larger the value, the more noise can be suppressed from being strengthened. |
GainTable |
Non-directional midrange texture boosts intensity. The higher the value, the sharper the non-directional mid-frequency texture. This parameter is an array | of 33, represented as a continuous 33-segment intensity curve. When the value is 128, the gain is doubled. |
LumaTunedCoring |
AE config |
W i n W e i g h t |
AE metering weight |
44.3.2. LEVEL2 Debugging Information Analysis¶
On the basis of level1, we add some additional information about meshLscGainLut, exposureInfo, and GammaTable
[parameter Description]
Parameter |
Module/GammaEx |
GammaTable |
Node value of Gamma curve |
ShadingEx |
MeshLscGainLut |
LSC grid form red channel compensation gain table, including R, G, B three channels |
ExposureInfoEx |
Exposure |
Current exposure. It is equal to the product of exposure time and exposure gain, where the unit of exposure time is the number of exposure lines, and the exposure gain is 6bit decimal precision. |
ExposureIsMax |
0: ISP does not reach the maximum exposure level; 1: ISP reaches the maximum exposure level. |
HistError |
Statistical information, the difference between the target brightness value and the actual value of AE. A positive value indicates that the current expected brightness information is greater than the actual brightness information, and a negative value indicates that the expected brightness information is less than the actual brightness information. |
PirisFno |
The equivalent gain corresponding to the current F value of P-Iris aperture. |
Fps |
Actual image frame rate * 100。 |
RefExpRatio |
The reference exposure ratio which is used to estimate the dynamic range of the current scene. It will be affected by the equivalence of Tolerance and Speed in ISP_WDR_EXPOSURE_ATTR_S. |
AE_RouteTotalNum |
Number of exposure assignment route nodes. The current maximum is 16 |
AERouteNodeX.IntTime |
Node exposure time of exposure assignment route node attribute, unit: microseconds (us) |
AERouteNodeX.SysGain |
The node gain of exposure distribution route node attribute includes sensor analog gain, sensor digital gain and ISP digital gain, and the precision is 10bit. |
AERouteNodeX.IrisFNO |
The node aperture F value of exposure assignment route node attribute only supports P-Iris, not DC-Iris |
A ERouteNodeX.IrisFNOLin |
The node aperture F value equivalent gain of exposure assignment route node attribute only supports P-Iris, not DC-Iris |
AE_Hist256Value |
Global 256 segment histogram statistics |
44.3.3. LEVEL3 debugging information analysis¶
Based on Level 2, the statistical value of 3a is added.
[Parameters Description]
Parameter |
AE statistics |
LEGlobalAvgR |
Statistical average of R component in global statistics of long exposure frames |
LEGlobalAvgGr |
Statistical mean of GR components in global statistics of long exposure frames |
LEGlobalAvgGb |
Statistical average of GB components in global statistics of long exposure frames |
LEGlobalAvgB |
Statistical mean value of B component in global statistics of long exposure frame |
SEGlobalAvgR |
Statistical average of R component in global statistics of short exposure frames |
SEGlobalAvgGr |
Statistical mean of GR components in global statistics of short exposure frames |
SEGlobalAvgGb |
Statistical average of GB components in global statistics of short exposure frames |
SEGlobalAvgB |
Statistical mean value of B component in global statistics of short exposure frame |
LEHistogramMem |
Pixel histogram statistics of global statistics for long exposure frames |
SEHistogramMem |
Pixel histogram statistics of global statistics for short exposure frames |
LEZoneRAvg |
Statistical average of R-channel components in long exposure frame |
LEZoneGrAvg |
Statistical average of Gr channel components in long exposure frame |
LEZoneGbAvg |
Statistical average of Gb channel components in long exposure frame |
LEZoneBAvg |
Statistical average of B-channel components in long exposure frame |
SEZoneRAvg |
Statistical average of R-channel components in short exposure frame |
SEZoneGrAvg |
Statistical average of Gr channel components in short exposure frame |
SEZoneGbAvg |
Statistical average of Gb channel components in short exposure frame |
SEZoneBAvg |
Statistical average of B-channel components in short exposure frame |
AWB statistics |
LEGlobalR |
R-component statistical mean of global statistics for long exposure frames |
LEGlobalG |
G-component statistical mean of global statistics for long exposure frames |
LEGlobalB |
B-component statistical mean of global statistics for long exposure frames |
LECountAll |
Pixel statistical average of global statistics for long exposure frames |
SEGlobalR |
R-component statistical mean of global statistics for short exposure frames |
SEGlobalG |
G-component statistical mean of global statistics for short exposure frames |
SEGlobalB |
B-component statistical mean of global statistics for short exposure frames |
SECountAll |
Pixel statistical average of global statistics for short exposure frames |
LEZoneAvgR |
The statistical average of R component in long exposure frame |
LEZoneAvgG |
The statistical average of G component in long exposure frame |
LEZoneAvgB |
The statistical average of B component in long exposure frame |
LEZoneCountAll |
Pixel statistics of long exposure frame |
SEZoneAvgR |
The statistical average of R component in short exposure frame |
SEZoneAvgG |
The statistical average of G component in short exposure frame |
SEZoneAvgB |
The statistical average of B component in short exposure frame |
SEZoneCountAll |
Pixel statistics of short exposure frame |
