3. System Control¶
3.1. Function Overview¶
The system control part includes the configuration of ISP public properties, initialization of ISP firmware, running of ISP firmware, exiting of ISP firmware, setting of ISP modules and other functions.
3.2. API Reference¶
The interface in this document does not support multi process unless otherwise specified.
CVI_ISP_MemInit: Initialize the ISP external register.
CVI_ISP_Init: Initialize ISP firmware.
CVI_ISP_Run: Run ISP firmware.
CVI_ISP_RunOnce: Run ISP firmware once.
CVI_ISP_Exit: Exit ISP firmware.
CVI_ISP_SetPubAttr: Set ISP public properties.
CVI_ISP_GetPubAttr: Get ISP public properties.
CVI_ISP_SetFMWState: Set ISP firmware status.
CVI_ISP_GetFMWState: Get ISP firmware status.
CVI_ISP_SetModuleControl: Set the control of ISP function module.
CVI_ISP_GetModuleControl: Get the control of ISP function module.
CVI_ISP_GetVDTimeOut: Get ISP interrupt information.
CVI_ISP_SensorRegCallBack: The callback interface of sensor registration provided by ISP.
CVI_ISP_SensorUnRegCallBack: The callback interface of sensor anti registration provided by ISP.
CVI_ISP_AELibRegCallBack: The callback interface of AE library registration provided by ISP.
CVI_ISP_AELibUnRegCallBack: The callback interface of AE library anti registration provided by ISP.
CVI_ISP_AWBLibRegCallBack: The callback interface of AWB library registration provided by ISP.
CVI_ISP_AWBLibUnRegCallBack: The callback interface of AWB library anti registration provided by ISP.
CVI_ISP_SetBindAttr: Set the binding relationship between ISP library, 3A library and sensor.
CVI_ISP_GetBindAttr: Get the binding relationship between ISP library, 3A library and sensor.
CVI_ISP_SetCtrlParam: Set control parameters of ISP.
CVI_ISP_GetCtrlParam: Get control parameters of ISP.
CVI_ISP_SetModParam: Set ISP module parameters.
CVI_ISP_GetModParam: Get ISP module parameters.
CVI_BIN_SetBinName : Set the path and file name of PQBIN storage
CVI_BIN_GetBinName : Get the path and file name of PQBIN storage
CVI_BIN_GetBinExtraAttr : Get bin header data information.
CVI_BIN_GetBinTotalLen : Get the total length of bin data.
CVI_BIN_ExportBinData : Save parameters into PQBin file.
CVI_BIN_ImportBinData : Parse the data of all modules from PQBin.
CVI_BIN_SaveParamToBin : Save parameters to PQBin file.
CVI_BIN_LoadParamFromBin : Parse all module data from PQBin.
CVI_ISP_IrAutoRunOnce : Run the infrared automatic switching function.
CVI_ISP_SetSmartInfo : Set intelligent identification area information.
CVI_ISP_GetSmartInfo : Get smart identification area information.
3.2.1. CVI_ISP_MemInit¶
CVI_S32 CVI_ISP_MemInit(VI_PIPE ViPipe);
【Parameter】
Parameter |
ViPipe |
ViPipe number |
【Return Value】
Return Value |
0 |
Success |
Non 0 |
Failure. An error code is returned. For details, see chapter Error Codes. |
【Requirement】
Header files: cvi_isp.h
Library files: libisp.a
This interface is not supported on the linux side of the dual-os SDK.
【Example】
None.
【Related Topic】
3.2.2. CVI_ISP_Init¶
CVI_S32 CVI_ISP_Init(VI_PIPE ViPipe);
【Parameter】
Parameter |
ViPipe |
ViPipe number |
【Return Value】
Return Value |
0 |
Success |
Non 0 |
【Requirement】
None.
【Example】
None.
【Related Topic】
3.2.3. CVI_ISP_Run¶
Run ISP firmware.
CVI_S32 CVI_ISP_Run(VI_PIPE ViPipe);
【Parameter】
Parameter |
ViPipe |
ViPipe number |
【Return Value】
Return Value |
0 |
Success |
Non 0 |
【Requirement】
【Example】
None.
【Related Topic】
3.2.4. CVI_ISP_RunOnce¶
CVI_S32 CVI_ISP_RunOnce(VI_PIPE ViPipe);
【Parameter】
Parameter |
ViPipe |
ViPipe number |
【Return Value】
Return Value |
0 |
Success |
Non 0 |
【Requirement】
【Example】
None.
【Related Topic】
3.2.5. CVI_ISP_Exit¶
Exit ISP firmware.
【Parameter】
Parameter |
ViPipe |
ViPipe number |
【Return Value】
Return Value |
0 |
Success |
Non 0 |
【Requirement】
None.
【Example】
None.
【Related Topic】
3.2.6. CVI_ISP_SetPubAttr¶
CVI_S32 CVI_ISP_SetPubAttr(VI_PIPE ViPipe, const ISP_PUB_ATTR_S *pstPubAttr);
【Parameter】
Parameter |
Input/Output |
ViPipe |
ViPipe number |
Input |
pstPubAttr |
ISP public properties. |
Input |
【Return Value】
Return Value |
0 |
Success |
Non 0 |
【Requirement】
None.
【Example】
None.
【Related Topic】
3.2.7. CVI_ISP_GetPubAttr¶
CVI_S32 CVI_ISP_GetPubAttr(VI_PIPE ViPipe, ISP_PUB_ATTR_S *pstPubAttr);
【Parameter】
Parameter |
Input/Output |
ViPipe |
ViPipe number |
Input |
pstPubAttr |
Output |
【Return Value】
Return Value |
0 |
Success |
Non 0 |
【Requirement】
None.
【Example】
None.
【Related Topic】
3.2.8. CVI_ISP_SetFMWState¶
CVI_S32 CVI_ISP_SetFMWState(VI_PIPE ViPipe, const ISP_FMW_STATE_E enState);
【Parameter】
Parameter |
Input/Output |
ViPipe |
ViPipe number |
Input |
enState |
ISP firmware state |
Input |
【Return Value】
Return Value |
0 |
Success |
Non 0 |
【Requirement】
None.
【Example】
None.
【Related Topic】
3.2.9. CVI_ISP_GetFMWState¶
CVI_S32 CVI_ISP_GetFMWState(VI_PIPE ViPipe, ISP_FMW_STATE_E *penState);
【Parameter】
Parameter |
Input/Output |
ViPipe |
ViPipe number |
Input |
enState |
Output |
【Return Value】
Return Value |
0 |
Success |
Non 0 |
【Requirement】
None.
【Example】
None.
【Related Topic】
3.2.10. CVI_ISP_SetModuleControl¶
Set control of ISP function module.
CVI_S32 CVI_ISP_SetModuleControl(VI_PIPE ViPipe, const ISP_MODULE_CTRL_U *punModCtrl);
【Parameter】
Parameter |
Input/Output |
ViPipe |
ViPipe number |
Input |
punModCtrl |
Control of ISP function module |
Input |
【Return Value】
Return Value |
0 |
Success |
Non 0 |
【Requirement】
【Example】
None.
【Related Topic】
3.2.11. CVI_ISP_GetModuleControl¶
Get control of ISP function module.
CVI_S32 CVI_ISP_GetModuleControl(VI_PIPE ViPipe, ISP_MODULE_CTRL_U *punModCtrl);
【Parameter】
Parameter |
Input/Output |
ViPipe |
ViPipe number |
Input |
punModCtrl |
Output |
【Return Value】
Return Value |
0 |
Success |
Non 0 |
【Requirement】
【Example】
None.
【Related Topic】
3.2.12. CVI_ISP_GetVDTimeOut¶
CVI_S32 CVI_ISP_GetVDTimeOut(VI_PIPE ViPipe, ISP_VD_TYPE_E enIspVDType, CVI_U32 u32MilliSec);
【Parameter】
Parameter |
Input/Output |
ViPipe |
ViPipe number |
Input |
enIspVDType |
Field synchronization signal |
Input |
u32MilliSec |
Timeout time, in ms. |
Input |
【Return Value】
Return Value |
0 |
Success |
Non 0 |
【Requirement】
None.
【Example】
None.
【Related Topic】
None.
3.2.13. CVI_ISP_SensorRegCallBack¶
CVI_S32 CVI_ISP_SensorRegCallBack(VI_PIPE ViPipe, ISP_SNS_ATTR_INFO_S *pstSnsAttrInfo, ISP_SENSOR_REGISTER_S *pstRegister);
【Parameter】
Parameter |
Input/Output |
ViPipe |
ViPipe number |
Input |
pstSnsAttrInfo |
Properties of sensor registered with ISP |
Input |
pstRegister |
Sensor register structure pointer |
Input |
【Return Value】
Return Value |
0 |
Success |
Non 0 |
【Requirement】
Fig. 3.1 Figure 2-1 Interface between ISP library and sensor Library¶
【Example】
None.
【Related Topic】
3.2.14. CVI_ISP_SensorUnRegCallBack¶
CVI_S32 CVI_ISP_SensorUnRegCallBack(VI_PIPE ViPipe, SENSOR_ID SensorId);
【Parameter】
Parameter |
Input/Output |
ViPipe |
ViPipe number |
Input |
SensorId |
The ID of the sensor registered with the ISP. |
Input |
【Return Value】
Return Value |
0 |
Success |
Non 0 |
【Requirement】
【Example】
None.
【Related Topic】
3.2.15. CVI_ISP_AELibRegCallBack¶
CVI_S32 CVI_ISP_AELibRegCallBack(VI_PIPE ViPipe, ALG_LIB_S *pstAeLib, ISP_AE_REGISTER_S *pstRegister);
【Parameter】
Parameter |
Input/Output |
ViPipe |
ViPipe number |
Input |
pstAeLib |
AWB library structure pointer |
Input |
pstRegister |
AWB library register structure pointer |
Input |
【Return Value】
Return Value |
0 |
Success |
Non 0 |
【Requirement】
Fig. 3.2 Figure 2-2 Interface between ISP library and AE Library¶
【Example】
None.
【Related Topic】
3.2.16. CVI_ISP_AELibUnRegCallBack¶
CVI_S32 CVI_ISP_AELibUnRegCallBack(VI_PIPE ViPipe, ALG_LIB_S *pstAeLib);
【Parameter】
Parameter |
Input/Output |
ViPipe |
ViPipe number |
Input |
pstAeLib |
AE library structure pointer |
Input |
【Return Value】
Return Value |
0 |
Success |
Non 0 |
【Requirement】
【Example】
None.
【Related Topic】
3.2.17. CVI_ISP_AWBLibRegCallBack¶
Callback interface for AWB library registration provided by ISP.
CVI_S32 CVI_ISP_AWBLibRegCallBack(VI_PIPE ViPipe, ALG_LIB_S *pstAwbLib, ISP_AWB_REGISTER_S *pstRegister);
【Parameter】
Parameter |
Input/Output |
ViPipe |
ViPipe number |
Input |
pstAwbLib |
Input |
pstRegister |
Input |
【Return Value】
Return Value |
0 |
Success |
Non 0 |
【Requirement】
Fig. 3.3 Figure 2-3 Interface between ISP library and AWB Library¶
【Example】
None.
【Related Topic】
3.2.18. CVI_ISP_AWBLibUnRegCallBack¶
CVI_S32 CVI_ISP_AWBLibUnRegCallBack(VI_PIPE ViPipe, ALG_LIB_S *pstAwbLib);
【Parameter】
Parameter |
Input/Output |
ViPipe |
ViPipe number |
Input |
pstAwbLib |
Input |
【Return Value】
Return Value |
0 |
Success |
Non 0 |
【Requirement】
Fig. 3.4 Figure 2-3 Interface between ISP library and AWB Library¶
【Example】
None.
【Related Topic】
3.2.19. CVI_ISP_SetBindAttr¶
CVI_S32 CVI_ISP_SetBindAttr(VI_PIPE ViPipe, const ISP_BIND_ATTR_S *pstBindAttr);
【Parameter】
Parameter |
Input/Output |
ViPipe |
ViPipe number |
Input |
pstBindAttr |
Binding structure pointer |
Input |
【Return Value】
Return Value |
0 |
Success |
Non 0 |
【Requirement】
【Example】
None.
【Related Topic】
3.2.20. CVI_ISP_GetBindAttr¶
CVI_S32 CVI_ISP_GetBindAttr(VI_PIPE ViPipe, ISP_BIND_ATTR_S *pstBindAttr);
【Parameter】
Parameter |
Input/Output |
ViPipe |
ViPipe number |
Input |
pstBindAttr |
Output |
【Return Value】
Return Value |
0 |
Success |
Non 0 |
【Requirement】
This interface does not support multiprocess operations.
【Example】
None.
【Related Topic】
3.2.21. CVI_ISP_SetCtrlParam¶
Set ISP control parameters.
CVI_S32 CVI_ISP_SetCtrlParam(VI_PIPE ViPipe, const ISP_CTRL_PARAM_S *pstIspCtrlParam);
【Parameter】
Parameter |
Input/Output |
ViPipe |
ViPipe number |
Input |
pstIspCtrlParam |
ISP control parameter structure pointer. |
Input |
【Return Value】
Return Value |
0 |
Success |
Non 0 |
【Requirement】
None.
【Example】
None.
【Related Topic】
3.2.22. CVI_ISP_GetCtrlParam¶
Get ISP control parameters.
CVI_S32 CVI_ISP_GetCtrlParam(VI_PIPE ViPipe, ISP_CTRL_PARAM_S *pstIspCtrlParam);
【Parameter】
Parameter |
Input/Output |
ViPipe |
ViPipe number |
Input |
pstIspCtrlParam |
Output |
【Return Value】
Return Value |
0 |
Success |
Non 0 |
【Requirement】
None.
【Example】
None.
【Related Topic】
3.2.23. CVI_ISP_SetModParam¶
CVI_S32 CVI_ISP_SetModParam(const ISP_MOD_PARAM_S *pstModParam);
【Parameter】
Parameter |
Input/Output |
ViPipe |
ViPipe number |
Input |
pstIspModParam |
ISP module parameter structure pointer |
Input |
【Return Value】
Return Value |
0 |
Success |
Non 0 |
【Requirement】
None.
【Example】
None.
【Related Topic】
3.2.24. CVI_ISP_GetModParam¶
CVI_S32 CVI_ISP_GetModParam(ISP_MOD_PARAM_S *pstModParam);
【Parameter】
Parameter |
Input/Output |
pstIspCtrlParam |
Output |
【Return Value】
Return Value |
0 |
Success |
Non 0 |
【Requirement】
None.
【Example】
None.
【Related Topic】
3.2.25. CVI_BIN_ExportBinData¶
For details, see section 3.1.2 of the 《PQ Tools User Guide》.
3.2.26. CVI_BIN_ImportBinData¶
3.2.27. CVI_BIN_GetBinExtraAttr¶
3.2.28. CVI_BIN_GetBinTotalLen¶
3.2.29. CVI_BIN_SetBinName¶
3.2.30. CVI_BIN_GetBinName¶
3.2.31. CVI_BIN_SaveParamToBin¶
3.2.32. CVI_BIN_LoadParamFromBin¶
3.2.33. CVI_ISP_IrAutoRunOnce¶
CVI_S32 CVI_ISP_IrAutoRunOnce(ISP_DEV IspDev, ISP_IR_AUTO_ATTR_S *pstIrAttr);
【Parameter】
Parameter |
Input/Output |
IspDev |
ISP device number |
Input |
pstIrAttr |
Infrared automatic switching properties |
Input |
【Return Value】
Return Value |
0 |
Success |
Non 0 |
【Requirement】
Header files: cvi_comm_isp.h, cvi_isp.h
Library files: libisp.so
None.
【Example】
ISP_DEV IspDev = 0;
ISP_IR_AUTO_ATTR_S stIrAttr;
stIrAttr.bEnable = 1;
stIrAttr.u32Normal2IrIsoThr = 3200;
stIrAttr.u32Ir2NormalIsoThr = 100;
stIrAttr.u32RGMin = 256;
stIrAttr.u32RGMax = 512;
stIrAttr.u32BGMin = 256;
stIrAttr.u32BGMax = 512;
CVI_ISP_IrAutoRunOnce(IspDev, &stIrAttr);
【Related Topic】
None.
3.2.34. CVI_ISP_SetSmartInfo¶
Set the coordinates recognized by Deep Learning (face, human form, object) for AE metering.
CVI_S32 CVI_ISP_SetSmartInfo(VI_PIPE ViPipe, const ISP_SMART_INFO_S *pstSmartInfo, CVI_U8 TimeOut);
【Parameter】
Parameter |
Input/Output |
ViPipe |
ISP device number |
Input |
pstSmartInfo |
AE Deep Learning recognition coordinate information structure pointer |
Input |
TimeOut |
The frame number of the recognition coordinate information is not updated, and the normal AE mode will be restored after exceeding |
Input |
【Return Value】
Return Value |
0 |
Success |
Non 0 |
【Requirement】
Header files: cvi_ae.h
Library files: libae.a
None.
【Example】
//Set the coordinate position of the face in the raw domain (X, Y , W, H) =(0, 0, 100, 100)
// and frame width/height 1920/1080 information to AE
//Return to normal AE after the recognition result is not updated for 4 frames
VI_PIPE ViPipe = 0;
ISP_SMART_INFO_S stSmartInfo;
CVI_ISP_GetSmartInfo(ViPipe, &stSmartInfo);
stSmartInfo.stROI[0].bEnable = 1;
stSmartInfo.stROI[0].bAvailable = 1;
stSmartInfo.stROI[0].u8Num = 1;
stSmartInfo.stROI[0].u16PosX[0] = 0;
stSmartInfo.stROI[0].u16PosY[0] = 0;
stSmartInfo.stROI[0].u16Width[0] = 100;
stSmartInfo.stROI[0].u16Height[0] = 100;
stSmartInfo.stROI[0].u16FrameWidth = 1920;
stSmartInfo.stROI[0].u16FrameHeight = 1080;
CVI_ISP_SetSmartInfo(ViPipe, &stSmartInfo, 4);
【Related Topic】
3.2.35. CVI_ISP_GetSmartInfo¶
Get the coordinates recognized by Deep Learning (face, human form, object) for AE metering.
CVI_S32 CVI_ISP_GetSmartInfo(VI_PIPE ViPipe, ISP_SMART_INFO_S *pstSmartInfo);
【Parameter】
Parameter |
Input/Output |
ViPipe |
ISP device number |
Input |
pstSmartInfo |
Input |
【Return Value】
Return Value |
0 |
Success |
Non 0 |
【Requirement】
None.
【Example】
None.
【Related Topic】
3.3. Data Types¶
Variables in this document that do not explicitly specify a range of values default to the range of values corresponding to the data type. For example, Variables of CVI_U8 data type range from [0, 255]. Variables in this document, such as data precision, are not explicitly specified. Default is 1.
3.3.1. RECT_S¶
Define the start position of the clipping window and the image width and height
typedef struct _RECT_S {
CVI_S32 s32X;
CVI_S32 s32Y;
CVI_U32 u32Width;
CVI_U32 u32Height;
} RECT_S;
【Member】
Member |
s32X |
Horizontal starting position |
s32Y |
Vertical starting position |
u32Width |
Image Width |
u32Height |
Image Height |
None.
None.
3.3.2. SIZE_S¶
【descriptiob】
Defines the width and height of the sensor output.
typedef struct _SIZE_S {
CVI_U32 u32Width;
CVI_U32 u32Height;
} SIZE_S;
【Member】
Member |
u32Width |
Sensor output width |
u32Height |
Sensor output height |
None.
None.
3.3.3. ISP_BAYER_FORMAT_E¶
Defines the format type of the Bayer array for the input ISP image
typedef enum _ISP_BAYER_FORMAT_E {
BAYER_BGGR,
BAYER_GBRG,
BAYER_GRBG,
BAYER_RGGB,
//for RGBIR sensor
BAYER_GRGBI = 8,
BAYER_RGBGI,
BAYER_GBGRI,
BAYER_BGRGI,
BAYER_IGRGB,
BAYER_IRGBG,
BAYER_IBGRG,
BAYER_IGBGR,
BAYER_BUTT
} ISP_BAYER_FORMAT_E;
【Member】
Member |
BAYER_XX |
The format types of the various Bayer arrays, and the names indicate how the pixels are arranged |
None.
None.
3.3.4. WDR_MODE_E¶
Defines the operation mode of the sensor
typedef enum _WDR_MODE_E {
WDR_MODE_NONE = 0,
WDR_MODE_BUILT_IN,
WDR_MODE_QUDRA,
WDR_MODE_2To1_LINE,
WDR_MODE_2To1_FRAME,
WDR_MODE_2To1_FRAME_FULL_RATE,
WDR_MODE_3To1_LINE,
WDR_MODE_3To1_FRAME,
WDR_MODE_3To1_FRAME_FULL_RATE,
WDR_MODE_4To1_LINE,
WDR_MODE_4To1_FRAME,
WDR_MODE_4To1_FRAME_FULL_RATE,
WDR_MODE_MAX,
} WDR_MODE_E;
【Member】
Member |
WDR_MODE_NONE |
Linear mode. |
WDR_MODE_BUILT_IN |
Sensor synthetic WDR mode. |
WDR_MODE_QUDRA |
Qudra mode |
WDR_MODE_2To1_LINE |
2-frame composite row WDR mode. |
WDR_MODE_2To1_FRAME |
2-frame composite frame WDR mode. |
WDR_MODE_2To1_FRAME_FULL_RATE |
2-Frame Composite Frame WDR Full Frame Rate Mode. |
WDR_MODE_3To1_LINE |
3-frame composite row WDR mode |
WDR_MODE_3To1_FRAME |
3-frame composite frame WDR mode. |
WDR_MODE_3To1_FRAME_FULL_RATE |
3-Frame Composite Frame WDR Full Frame Rate Mode. |
WDR_MODE_4To1_LINE |
4-frame composite row WDR mode. |
WDR_MODE_4To1_FRAME |
4-frame composite frame WDR mode. |
WDR_MODE_4To1_FRAME_FULL_RATE |
4-Frame Composite Frame WDR Full Frame Rate Mode. |
None.
None.
3.3.5. ISP_PUB_ATTR_S¶
Define ISP Common Properties
typedef struct _ISP_PUB_ATTR_S {
RECT_S stWndRect;
SIZE_S stSnsSize;
CVI_FLOAT f32FrameRate;
ISP_BAYER_FORMAT_E enBayer;
WDR_MODE_E enWDRMode;
CVI_U8 u8SnsMode;
} ISP_PUB_ATTR_S;
【Member】
Member |
stWndRect |
rect of Isp output |
stSnsSize |
image size of sensor |
f32FrameRate |
Sensor frame rate |
enBayer |
Bayer format for Sensor |
enWDRMode |
Wide dynamic mode |
u8SnsMode |
Used for selection of Sensor initialization sequences, different u8SnsModes are configured to correspond to different initialization sequences at the same resolution and frame rate.Otherwise, u8SnsModel is configured as 0 by default and can be selected through stSnsSize and f32FrameRate for initialization sequence selection. |
None.
3.3.6. ISP_FMW_STATE_E¶
Define the ISP firmware state.
typedef enum _ISP_FMW_STATE_E {
ISP_FMW_STATE_RUN,
ISP_FMW_STATE_FREEZE,
ISP_FMW_STATE_BUTT
} ISP_FMW_STATE_E;
【Member】
Member |
ISP_FMW_STATE_RUN |
The Firmware runs properly |
ISP_FMW_STATE_FREEZE |
Firmware Freeze State |
None.
3.3.7. ISP_MODULE_CTRL_U¶
Define control of ISP function modules
typedef union _ISP_MODULE_CTRL_U {
CVI_U64 u64Key;
struct {
CVI_U64 bitBypassBlc : 1; /* RW;[0] */
CVI_U64 bitBypassRlsc : 1; /* RW;[1] */
CVI_U64 bitBypassFpn : 1; /* RW;[2] */
CVI_U64 bitBypassDpc : 1; /* RW;[3] */
CVI_U64 bitBypassCrosstalk : 1; /* RW;[4] */
CVI_U64 bitBypassWBGain : 1; /* RW;[5] */
CVI_U64 bitBypassDis : 1; /* RW;[6] */
CVI_U64 bitBypassBnr : 1; /* RW;[7] */
CVI_U64 bitBypassDemosaic : 1; /* RW;[8] */
CVI_U64 bitBypassRbgcac : 1; /* RW;[9] */
CVI_U64 bitBypassMlsc : 1; /* RW;[10] */
CVI_U64 bitBypassCcm : 1; /* RW;[11] */
CVI_U64 bitBypassFusion : 1; /* RW;[12] */
CVI_U64 bitBypassDrc : 1; /* RW;[13] */
CVI_U64 bitBypassGamma : 1; /* RW;[14] */
CVI_U64 bitBypassDehaze : 1; /* RW;[15] */
CVI_U64 bitBypassClut : 1; /* RW;[16] */
CVI_U64 bitBypassCsc : 1; /* RW;[17] */
CVI_U64 bitBypassDci : 1; /* RW;[18] */
CVI_U64 bitBypassCa : 1; /* RW;[19] */
CVI_U64 bitBypassPreyee : 1; /* RW;[20] */
CVI_U64 bitBypassMotion : 1; /* RW;[21] */
CVI_U64 bitBypass3dnr : 1; /* RW;[22] */
CVI_U64 bitBypassYnr : 1; /* RW;[23] */
CVI_U64 bitBypassCnr : 1; /* RW;[24] */
CVI_U64 bitBypassCac : 1; /*RW:[25]*/
CVI_U64 bitBypassCa2 : 1; /*RW:[26]*/
CVI_U64 bitBypassYee : 1; /*RW:[27]*/
CVI_U64 bitBypassYcontrast : 1; /*RW:[28]*/
CVI_U64 bitBypassMono : 1; /*RW:[29]*/
CVI_U64 bitRsv : 34; /* H ; [30:63] */
} ISP_MODULE_CTRL_U;
【Member】
Member |
u64Key |
Integer value for structure enumeration |
bitbypassxxx |
Each module function controls bit |
None.
3.3.8. ISP_VD_TYPE_E¶
Define synchronization signal with ISP
typedef enum _ISP_VD_TYPE_E {
ISP_VD_FE_START = 0,
ISP_VD_FE_END,
ISP_VD_BE_END,
ISP_VD_MAX
} ISP_VD_TYPE_E;
【Member】
Member |
ISP_VD_FE_START |
Starting signal of FE frame |
ISP_VD_FE_END |
End signal of FE frame |
ISP_VD_BE_END |
End signal of BE frame |
None.
3.3.9. ISP_SNS_ATTR_INFO_S¶
Define ISP sensor properties.
typedef struct _ISP_SNS_ATTR_INFO_S {
CVI_U32 eSensorId;
} ISP_SNS_ATTR_INFO_S;
【Member】
Member |
eSensorid |
Sensor ID number |
None.
3.3.10. ALG_LIB_S¶
Used library information
typedef struct _ALG_LIB_S {
CVI_S32 s32Id;
CVI_CHAR acLibName[ALG_LIB_NAME_SIZE_MAX];
} ALG_LIB_S;
【Member】
Member |
s32Id |
Id of the algorithm library instance. |
acLibName |
An array of characters identifying the name of the algorithm library. |
None.
3.3.11. ISP_AE_EXP_FUNC_S¶
Defines the AE callback function structure.
typedef struct _ISP_AE_EXP_FUNC_S {
CVI_S32 (*pfn_ae_init)(VI_PIPE ViPipe, const ISP_AE_PARAM_S *pstAeParam);
CVI_S32 (*pfn_ae_run)(VI_PIPE ViPipe, const ISP_AE_INFO_S *pstAeInfo, ISP_AE_RESULT_S *pstAeResult, CVI_S32 s32Rsv);
CVI_S32 (*pfn_ae_ctrl)(VI_PIPE ViPipe, CVI_U32 u32Cmd, void *pValue);
CVI_S32 (*pfn_ae_exit)(VI_PIPE ViPipe);
} ISP_AE_EXP_FUNC_S;
【Member】
Member |
pfn_ae_init |
Initializes the callback function pointer for AE. |
pfn_ae_run |
Callback function pointer that runs AE. |
pfn_ae_ctrl |
Callback function pointer that controls the internal state of AE. |
pfn_ae_exit |
Destroy the callback function pointer for AE. |
None.
3.3.12. ISP_AE_REGISTER_S¶
typedef struct _ISP_AE_REGISTER_S {
ISP_AE_EXP_FUNC_S stAeExpFunc;
} ISP_AE_REGISTER_S;
【Member】
Member |
stAeExpFunc |
AE registered callback function structure. |
None.
3.3.13. ISP_SENSOR_EXP_FUNC_S¶
Define sensor callback function structure
typedef struct _ISP_SENSOR_EXP_FUNC_S {
CVI_VOID (*pfn_cmos_sensor_init)(VI_PIPE ViPipe);
CVI_VOID (*pfn_cmos_sensor_exit)(VI_PIPE ViPipe);
CVI_VOID (*pfn_cmos_sensor_global_init)(VI_PIPE ViPipe);
CVI_S32 (*pfn_cmos_set_image_mode)(VI_PIPE ViPipe, ISP_CMOS_SENSOR_IMAGE_MODE_S *pstSensorImageMode);
CVI_S32 (*pfn_cmos_set_wdr_mode)(VI_PIPE ViPipe, CVI_U8 u8Mode);
/* the algs get data which is associated with sensor, except 3a */
CVI_S32 (*pfn_cmos_get_isp_default)(VI_PIPE ViPipe, ISP_CMOS_DEFAULT_S *pstDef);
CVI_S32 (*pfn_cmos_get_isp_black_level)(VI_PIPE ViPipe, ISP_CMOS_BLACK_LEVEL_S *pstBlackLevel);
CVI_S32 (*pfn_cmos_get_sns_reg_info)(VI_PIPE ViPipe, ISP_SNS_SYNC_INFO_S *pstSnsRegsInfo);
/* the function of sensor set pixel detect */
//CVI_VOID (*pfn_cmos_set_pixel_detect)(VI_PIPE ViPipe, bool bEnable);
} ISP_SENSOR_EXP_FUNC_S;
【Member】
Member |
pfn_cmos_sensor_init |
Initialize sensor’s callback function pointer. |
pfn_cmos_sensor_exit |
Sensor’s callback exits the function pointer. |
pfn_cmos_sensor_global_init |
Initializes a callback function pointer to a global variable. |
pfn_cmos_set_image_mode |
Sets the callback function pointer for resolution and frame rate switching. |
pfn_cmos_set_wdr_mode |
Sets the callback function pointer in wdr mode. |
pfn_cmos_get_isp_default |
A callback function pointer that gets the initial value of an ISP-based algorithm. |
pfn_cmos_get_isp_black_level |
A callback function pointer to get the black level value of the sensor, which supports dynamic adjustment of the black level value based on the sensor gain. |
pfn_cmos_get_sns_reg_info |
A callback function pointer for sensor register information to implement kernel state configuration AE information. |
pfn_cmos_set_pixel_detect |
Sets the callback function pointer of the bad point correction switch. |
None.
None.
3.3.14. ISP_SENSOR_REGISTER_S¶
typedef struct bmISP_SENSOR_REGISTER_S {
ISP_SENSOR_EXP_FUNC_S stSnsExp;
} ISP_SENSOR_REGISTER_S;
【Member】
Member |
stSnsExp |
Sensor registered callback function structure. |
None.
3.3.15. ISP_AWB_EXP_FUNC_S¶
typedef struct _ISP_AWB_EXP_FUNC_S {
CVI_S32 (*pfn_awb_init)(VI_PIPE ViPipe, const ISP_AWB_PARAM_S *pstAwbParam);
CVI_S32 (*pfn_awb_run)(VI_PIPE ViPipe, const ISP_AWB_INFO_S *pstAwbInfo, ISP_AWB_RESULT_S *pstAwbResult,
CVI_S32 s32Rsv);
CVI_S32 (*pfn_awb_ctrl)(VI_PIPE ViPipe, CVI_U32 u32Cmd, CVI_VOID * pValue);
CVI_S32 (*pfn_awb_exit)(VI_PIPE ViPipe);
} ISP_AWB_EXP_FUNC_S;
【Member】
None.
None.
3.3.16. ISP_AWB_REGISTER_S¶
typedef struct _ISP_AWB_REGISTER_S {
ISP_AWB_EXP_FUNC_S stAwbExpFunc;
} ISP_AWB_REGISTER_S;
【Member】
None.
3.3.17. ISP_BIND_ATTR_S¶
typedef struct _ISP_BIND_ATTR_S {
CVI_S32 sensorId;
ALG_LIB_S stAeLib;
ALG_LIB_S stAfLib;
ALG_LIB_S stAwbLib;
} ISP_BIND_ATTR_S;
【Member】
Member |
SensorId |
registered Sensor Id |
stAeLib |
AE library structure. |
stAwbLib |
AF library structure. |
stAfLib |
AWB library structure. |
None.
3.3.18. ISP_CTRL_PARAM_S¶
Define the ISP control parameter structure.
typedef struct _ISP_CTRL_PARAM_S {
CVI_U32 u32AEStatIntvl;
CVI_U32 u32AWBStatIntvl;
CVI_U32 u32AFStatIntvl;
CVI_U32 u32ProcParam;
CVI_U32 u32ProcLevel;
CVI_U32 u32UpdatePos;
CVI_U32 u32IntTimeOut;
CVI_U32 u32PwmNumber;
CVI_U32 u32PortIntDelay;
} ISP_CTRL_PARAM_S;
【Member】
Member |
u32AEStatIntvl |
ISP 3A AE statistics update frequency, unit is frame. Value range: (0,0xffffffff] |
u32AWBStatIntvl |
Update frequency of ISP 3A AWB statistics in frames. Range of values: (0,0xffffff] |
u32AFStatIntvl |
Update frequency of ISP 3A AF statistics in frames. Range of values: (0,0xffffff] |
u32ProcParam |
The frequency at which ISP collects information, in frames, with a default value of 30. The higher this value, the lower the RISC-V utilization of the ISP. Range of values: (0,0xffffff] |
u32ProcLevel |
ISP’s proc prints Level, Level 0, proc function is off, Level 1, Simplified information, Level 2, More information, Level 3, Very much information (will also print 3A statistics) |
u32UpdatePos |
Currently cvitek only supports configuring sensor registers at the beginning of a frame with a default value of 0 |
u32IntTimeOut |
Represents the time (ms) at which the interrupt timed out. Cvitek is not currently in use |
u32PwmNumber |
Represents a PWM number. Cvitek is not currently in use |
u32PortIntDelay |
Represents Port interrupt delay time |
None.
3.3.19. ISP_MOD_PARAM_S¶
Define ISP module parameter structure.
typedef struct _ISP_MOD_PARAM_S {
CVI_U32 u32IntBotHalf;
} ISP_MOD_PARAM_S;
【Member】
Member |
u32intbothalf |
Indicates whether the ISP interrupt processing adopts the lower half mechanism, and the default value is 0. Currently, cvitek only supports (reading statistics and configuring sensor and ISP synchronization registers) to be completed in the interrupt service routine; |
None.
3.3.20. ISP_IR_AUTO_ATTR_S¶
Defines the infrared auto-switching properties.
typedef struct _ISP_IR_AUTO_ATTR_S
CVI_BOOL bEnable;
CVI_U32 u32Normal2IrIsoThr;
CVI_U32 u32Ir2NormalIsoThr;
CVI_U32 u32RGMax;
CVI_U32 u32RGMin;
CVI_U32 u32BGMax;
CVI_U32 u32BGMin;
ISP_IR_STATUS_E enIrStatus;
ISP_IR_SWITCH_STATUS_E enIrSwitch;
} ISP_IR_AUTO_ATTR_S;
【Member】
Member |
benable: |
Infrared automatic switching enable. CVI_FALSE: off; CVI_TRUE: enable. |
u32Normal2IrIsoThr |
The ISO threshold for switching from normal to infrared. When the actual effective ISO is greater than this threshold, the system needs to switch to the infrared state. Value range: [0, 0xFFFFFFFF]. |
u32Ir2NormalIsoThr |
The ISO threshold for switching from infrared state to normal state. When the actual effective ISO is lower than this threshold, the system needs to switch to the normal state. Value range: [0, 0xFFFFFFFF]. |
u32RGMax |
R/G maximum value in infrared state. When the R/G of the actual image is greater than this parameter, the system needs to switch to the normal state. 4.8 format. Value range: [0, 0xFFF]. |
u32RGMin |
R/G minimum value in infrared state. When the R/G of the actual image is smaller than this parameter, the system needs to switch to the normal state. 4.8 format. Value range: [0, u32RGMax]. |
u32BGMax |
The maximum value of B/G in the infrared state. When the B/G of the actual image is greater than this parameter, the system needs to switch to the normal state. 4.8 format. Value range: [0, 0xFFF]. |
u32BGMin |
B/G minimum value in infrared state. When the B/G of the actual image is smaller than this parameter, the system needs to switch to the normal state. 4.8 format. Value range: [0, u32BGMax]. |
enIrStatus |
The current infrared state of the device. It should be configured as the actual infrared state of the device, and the user needs to ensure the correctness of the state. |
enIrSwitch |
The infrared switching status of the device, which is read-only. |
None.
None.
