40. Statistical information¶
40.1. Overview¶
This section describes the 3A statistics provided by ISP and the configuration method.
40.2. API Reference¶
The interface of statistical information must call CVI_ISP_Init interface.
CVI_ISP_SetStatisticsConfig : Set ISP statistics configuration.
CVI_ISP_GetStatisticsConfig : Get ISP statistics configuration.
CVI_ISP_GetAEStatistics : Get ISP AE statistics information.
CVI_ISP_GetWBStatistics : Get ISP AWB statistics information.
CVI_ISP_GetFocusStatistics : Get ISP AF statistics information.
40.2.1. CVI_ISP_SetStatisticsConfig¶
CVI_S32 CVI_ISP_SetStatisticsConfig(VI_PIPE ViPipe, const ISP_STATISTICS_CFG_S *pstStatCfg);
【Parameter】
Parameter |
Input/Output |
ViPipe |
VI_PIPE number |
Input |
pstStatCfg |
ISP statistics configuration |
Input |
【Return Value】
Return Value |
0 |
Success |
Non 0 |
Failure. An error code is returned. For details, see chapter Error Codes. |
【Requirement】
Header files: cvi_isp.h, cvi_comm_isp.h
Library files: libisp.so
None.
【Example】
// Set AE / AWB / AF related statistic window setting
VI_PIPE ViPipe = 0;
ISP_STATISTICS_CFG_S stsCfg;
// Set AE0 windows ROI.
stsCfg.stAECfg.stCrop[0].bEnable = 1;
stsCfg.stAECfg.stCrop[0].u16X = stsCfg.stAECfg.stCrop[0].u16Y = 0;
stsCfg.stAECfg.stCrop[0].u16W = 1920;
stsCfg.stAECfg.stCrop[0].u16H = 1080;
// Set the window number of AWB statistic value in x & y direction.
stsCfg.stWBCfg.u16ZoneRow = AWB_ZONE_ORIG_ROW;
stsCfg.stWBCfg.u16ZoneCol = AWB_ZONE_ORIG_COLUMN;
// Set AWB window ROI.
stsCfg.stWBCfg.stCrop.u16X = stsCfg.stWBCfg.stCrop.u16Y = 0;
stsCfg.stWBCfg.stCrop.u16W = 1920;
stsCfg.stWBCfg.stCrop.u16H = 1080;
// Set AWB statistical brightness threshold.
stsCfg.stWBCfg.u16BlackLevel = 0;
stsCfg.stWBCfg.u16WhiteLevel = 4095;
// Set the AF statistics switch.
stsCfg.stFocusCfg.stConfig.bEnable = 1;
// Set the preprocessing switch of AF statistics.
stsCfg.stFocusCfg.stConfig.stRawCfg.PreGammaEn = 0;
stsCfg.stFocusCfg.stConfig.stPreFltCfg.PreFltEn = 1;
// Set the window number of AF statistic value in x & y direction.
stsCfg.stFocusCfg.stConfig.u16Hwnd = 17;
stsCfg.stFocusCfg.stConfig.u16Vwnd = 15;
// Set AF window ROI.
stsCfg.stFocusCfg.stConfig.stCrop.bEnable = 1;
stsCfg.stFocusCfg.stConfig.stCrop.u16X = AF_XOFFSET_MIN;
stsCfg.stFocusCfg.stConfig.stCrop.u16Y = AF_YOFFSET_MIN;
stsCfg.stFocusCfg.stConfig.stCrop.u16W = 1920 - AF_XOFFSET_MIN * 2;
stsCfg.stFocusCfg.stConfig.stCrop.u16H = 1080 - AF_YOFFSET_MIN * 2;
// Set the AF horizontal low pass filter coefficient.
stsCfg.stFocusCfg.stConfig.u8HFltShift = 1;
stsCfg.stFocusCfg.stConfig.s8HVFltLpCoeff[0] = 1;
stsCfg.stFocusCfg.stConfig.s8HVFltLpCoeff[1] = 2;
stsCfg.stFocusCfg.stConfig.s8HVFltLpCoeff[2] = 3;
stsCfg.stFocusCfg.stConfig.s8HVFltLpCoeff[3] = 5;
stsCfg.stFocusCfg.stConfig.s8HVFltLpCoeff[4] = 10;
// Set the AF horizontal high pass filter coefficient.
stsCfg.stFocusCfg.stHParam_FIR0.s8HFltHpCoeff[0] = 0;
stsCfg.stFocusCfg.stHParam_FIR0.s8HFltHpCoeff[1] = 0;
stsCfg.stFocusCfg.stHParam_FIR0.s8HFltHpCoeff[2] = 13;
stsCfg.stFocusCfg.stHParam_FIR0.s8HFltHpCoeff[3] = 24;
stsCfg.stFocusCfg.stHParam_FIR0.s8HFltHpCoeff[4] = 0;
// Set the AF vertical high pass filter coefficient.
stsCfg.stFocusCfg.stVParam_FIR.s8VFltHpCoeff[0] = 13;
stsCfg.stFocusCfg.stVParam_FIR.s8VFltHpCoeff[1] = 24;
stsCfg.stFocusCfg.stVParam_FIR.s8VFltHpCoeff[2] = 0;
// Set the value switch of each statistical value.
stsCfg.unKey.bit1FEAeGloStat = stsCfg.unKey.bit1FEAeLocStat =
stsCfg.unKey.bit1AwbStat1 = stsCfg.unKey.bit1AwbStat2 = stsCfg.unKey.bit1FEAfStat = 1;
CVI_ISP_SetStatisticsConfig(ViPipe, &stsCfg);
// Set the AF low pass filter coefficient rule.
AF low pass filter has nine parameters {x0, x1, x2, x3, x4, x5, x6, x7, x8} . The last four parameters are symmetrical with the first four parameters (x0 = x8, x1 = x7, x2 = x6, x3 = x5) . Users only need to set the first five parameters (x0 ~ x5).
// Set the AF level high pass filter coefficient rule.
AF high pass filter has nine parameters {x0, x1, x2, x3, x4, x5, x6, x7, x8}. The last four parameters are the same as the first four parameters, with the same number but opposite sign: (x0 = -x8, x1 = -x7, x2 = -x6, x3 = -x5). Users only need to set the first five parameters (x0 ~ x5).
// Set the AF vertical high pass filter coefficient rule.
AF horizontal high pass filter has five parameters: {x0, x1, X2, X3, X4}. The last two parameters are the same as the first two parameters, but the positive and negative signs are opposite: (x0 = - x4, X1 = - x3). Users only need to set the first three parameters (x0 ~ x2).
filter example of parameter setting
the band through which the filter can pass |
Filter parameters x0 |
Filter parameters x1 |
Filter parameters x2 |
0.1 ~ 0.2 |
20 |
16 |
0 |
0.1 ~ 0.5 |
17 |
20 |
0 |
0.1 ~ 0.6 |
13 |
24 |
0 |
0.1 ~ 0.7 |
12 |
25 |
0 |
0.1 ~ 0.8 |
-10 |
-27 |
0 |
0.2 ~ 0.9 |
-10 |
27 |
0 |
【Related Topic】
40.2.2. CVI_ISP_GetStatisticsConfig¶
CVI_S32 CVI_ISP_GetStatisticsConfig(VI_PIPE ViPipe, ISP_STATISTICS_CFG_S *pstStatCfg);
【Parameter】
Parameter |
Input/Output |
ViPipe |
VI_PIPE number |
Input |
pstStatCfg |
Output |
【Return Value】
Return Value |
0 |
Success |
Non 0 |
【Requirement】
None.
【Example】
None.
【Related Topic】
40.2.3. CVI_ISP_GetAEStatistics¶
CVI_S32 CVI_ISP_GetAEStatistics(VI_PIPE ViPipe, ISP_AE_STATISTICS_S *pstAeStat);
【Parameter】
Parameter |
Input/Output |
ViPipe |
VI_PIPE number |
Input |
pstAeStat |
AE statistics |
Output |
【Return Value】
Return Value |
0 |
Success |
Non 0 |
【Requirement】
None.
【Example】
//Configure AE window weight
#define AE_ZONE_ROW 15
#define AE_ZONE_COLUMN 17
ISP_AE_WIN_STATISTICS_CFG_S aeWinCfg;
CVI_U8 i,j;
VI_PIPE ViPipe = 0;
CVI_U8 u8Weighttable[AE_ZONE_ROW][ AE_ZONE_COLUMN]={
{ 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1 },
{ 1, 2, 2, 2, 2, 2, 2, 2, 2, 2, 2, 2, 2, 2, 2, 2, 1 },
{ 1, 2, 2, 4, 4, 4, 4, 4, 4, 4, 4, 4, 4, 4, 2, 2, 1 },
{ 1, 2, 2, 4, 4, 4, 8, 8, 8, 8, 8, 4, 4, 4, 2, 2, 1 },
{ 1, 2, 2, 2, 2, 4, 4, 4, 4, 4, 4, 4, 2, 2, 2, 2, 1 },
{ 1, 1, 1, 1, 1, 2, 2, 2, 2, 2, 2, 2, 1, 1, 1, 1, 1 },};
CVI_ISP_GetAEWinStatistics(ViPipe, &aeWinCfg);
for (i = 0; i < AE_ZONE_ROW; i++)
for (j = 0; j < AE_ZONE_COLUMN; j++)
aeWinCfg.au8Weight[i][j] = u8Weighttable[i][j];
CVI_ISP_SetAEWinStatistics(ViPipe, &aeWinCfg);
【Related Topic】
None.
40.2.4. CVI_ISP_GetWBStatistics¶
CVI_S32 CVI_ISP_GetWBStatistics(VI_PIPE ViPipe, ISP_WB_STATISTICS_S *pstAwbStat);
【Parameter】
Parameter |
Input/Output |
ViPipe |
VI_PIPE number |
Input |
pstAwbStat |
AWB statistics |
Output |
【Return Value】
Return Value |
0 |
Success |
Non 0 |
【Requirement】
None.
【Example】
None.
【Related Topic】
None.
40.2.5. CVI_ISP_GetFocusStatistics¶
CVI_S32 CVI_ISP_GetFocusStatistics(VI_PIPE ViPipe, ISP_AF_STATISTICS_S *pstAfStat);
【Parameter】
Parameter |
Input/Output |
ViPipe |
VI_PIPE number |
Input |
pstAfStat |
AF statistics |
Output |
【Return Value】
Return Value |
0 |
Success |
Non 0 |
【Requirement】
None.
【Example】
None.
【Related Topic】
None.
40.3. Data Types¶
40.3.1. ISP_STATISTICS_CTRL_U¶
Define ISP statistics information enablement.
typedef union _ISP_STATISTICS_CTRL_U {
CVI_U64 u64Key;
struct {
CVI_U64 bit1FEAeGloStat : 1; /* [0] */
CVI_U64 bit1FEAeLocStat : 1; /* [1] */
CVI_U64 bit1AwbStat1 : 1; /* [2] */
CVI_U64 bit1AwbStat2 : 1; /* [3] */
CVI_U64 bit1FEAfStat : 1; /* [4] */
CVI_U64 bit14Rsv : 59; /* [5:63] */
} ISP_STATISTICS_CTRL_U;
【Member】
Member |
bit1FEAeGloStat |
AE global statistics enable |
bit1FEAeLocStat |
AE block statistics enable |
bit1AwbStat1 |
AWB global statistics enable |
bit1AwbStat2 |
AWB block statistics enable |
bit1FEAfStat |
AF block statistics enable |
bit14Rsv |
Reserved bit |
None.
None.
40.3.2. ISP_AE_STATISTICS_CFG_S¶
Configure AE statistics.
typedef struct _ISP_AE_STATISTICS_CFG_S {
CVI_BOOL bHisStatisticsEnable; /*RW; Range:[0x0,0x1]*/
ISP_AE_CROP_S stCrop[AE_MAX_NUM];
ISP_AE_FACE_CROP_S stFaceCrop[FACE_WIN_NUM];
CVI_BOOL fast2A_ena; /*RW; Range:[0x0,0x1]*/
CVI_U8 fast2A_ae_low; /*RW; Range:[0x0,0xFF]*/
CVI_U8 fast2A_ae_high; /*RW; Range:[0x0,0xFF]*/
CVI_U16 fast2A_awb_top; /*RW; Range:[0x0,0xFFF]*/
CVI_U16 fast2A_awb_bot; /*RW; Range:[0x0,0xFFF]*/
CVI_U16 over_exp_thr; /*RW; Range:[0x0,0x3FF]*/
CVI_U8 au8Weight[AE_WEIGHT_ZONE_ROW][AE_WEIGHT_ZONE_COLUMN]; /*RW; Range:[0x0, 0xF]*/
} ISP_AE_STATISTICS_CFG_S;
【Member】
Member |
enAESwitch |
HiSilicon compatible parameter, currently not used |
stHistConfig |
enFourPlaneMode |
enHistMode |
enAverMode |
enMaxGainMode |
stCrop[AE_MAX_NUM]; |
AE statistical value input image cropping setting |
au8Weight[AE_ZONE_ROW][AE_ZONE_COLUMN] |
AE window 17 x 15 weight setting |
bHisStatisticsEnable |
AE/Hist sts enable |
u8StatisticsShiftBits |
The AE statistics should be scaled down by a few bits |
u16RGain |
Whether the R channel passes through RGain |
u16GGain |
Whether the G channel passes through GGain |
u16BGain |
Whether the B channel passes through BGain |
None.
40.3.3. ISP_AE_CROP_S¶
Set AE statistics input image reduction.
typedef struct _ ISP_AE_CROP_S {
CVI_BOOL bEnable;
CVI_U16 u16X;
CVI_U16 u16Y;
CVI_U16 u16W;
CVI_U16 u16H;
} ISP_AE_CROP_S;
【Member】
Member |
bEnable |
Enable Cro; 0 is not enabled, the whole picture will be set as the clipping setting; 1 is enabled |
u16X |
Start position of CropX, the value should be greater than 0 |
u16Y |
Start position of CropY, the value should be greater than 0 |
u16W |
Crop width |
u16H |
Crop height |
None.
None.
40.3.4. ISP_AE_FACE_CROP_S¶
Set face AE statistics input image reduction.
typedef struct _ISP_AE_FACE_CROP_S {
CVI_BOOL bEnable;
CVI_U16 u16X;
CVI_U16 u16Y;
CVI_U16 u16W;
CVI_U16 u16H;
} ISP_AE_FACE_CROP_S;
【Member】
Member |
bEnable |
u16X |
u16Y |
u16W |
Crop width |
u16H |
Crop height |
None.
None.
40.3.5. ISP_WB_STATISTICS_CFG_S¶
Configure WB statistics.
typedef struct _ISP_WB_STATISTICS_CFG_S {
ISP_AWB_SWITCH_E enAWBSwitch;
CVI_U16 u16ZoneRow;
CVI_U16 u16ZoneCol;
CVI_U16 u16ZoneBin;
CVI_U16 au16HistBinThresh[4];
CVI_U16 u16WhiteLevel;
CVI_U16 u16BlackLevel;
CVI_U16 u16CbMax;
CVI_U16 u16CbMin;
CVI_U16 u16CrMax;
CVI_U16 u16CrMin;
ISP_AWB_CROP_S stCrop;
} ISP_WB_STATISTICS_CFG_S;
【Member】
Member |
enAWBSwitch |
ISP_AWB_AFTER_DG = 0
u16ZoneRow |
AWB statistics window rows |
u16ZoneCol |
AWB statistics window columns |
u16ZoneBin |
au16HistBinThresh |
u16WhiteLevel |
Threshold setting of AWB highlight exclusion |
u16BlackLevel |
Threshold setting of AWB dark spot exclusion |
u16CbMax |
The maximum value of R/G under different ISO |
u16CbMin |
u16CrMax |
u16CrMin |
None.
None.
40.3.6. ISP_AWB_CROP_S¶
Set AWB statistics input image reduction.
typedef struct _ISP_ AWB_CROP_S {
CVI_BOOL bEnable;
CVI_U16 u16X;
CVI_U16 u16Y;
CVI_U16 u16W;
CVI_U16 u16H;
} ISP_ AWB_CROP_S;
【Member】
Member |
bEnable |
Enable Cro;
u16X |
u16Y |
u16W |
Crop width Value range: [16 * u16ZoneCol, image width] |
u16H |
Crop height Value range: [0, image width - 16 * u16ZoneCol] |
None.
None.
40.3.7. ISP_WB_STATISTICS_S¶
Define AWB statistics.
typedef struct _ISP_WB_STATISTICS_S {
CVI_U16 u16GlobalR;
CVI_U16 u16GlobalG;
CVI_U16 u16GlobalB;
CVI_U16 u16CountAll;
CVI_U16 au16ZoneAvgR[AWB_ZONE_NUM];
CVI_U16 au16ZoneAvgG[AWB_ZONE_NUM];
CVI_U16 au16ZoneAvgB[AWB_ZONE_NUM];
CVI_U16 au16ZoneCountAll[AWB_ZONE_NUM];
ISP_AWB_GRID_INFO_S stGridInfo;
} ISP_WB_STATISTICS_S;
Macro Definition
#define AWB_ZONE_ORIG_ROW (32)
#define AWB_ZONE_ORIG_COLUMN (64)
#define AWB_ZONE_NUM (AWB_ZONE_ORIG_ROW * AWB_ZONE_ORIG_COLUMN)
【Member】
Member |
u16GlobalR |
The average value of global R component in Bayer domain. Value range: [0, 0x3ff] Data type: CVI_BOOL |
u16GlobalG |
The average value of global G component in Bayer domain Value range: [0, 0x3ff] Data type: CVI_BOOL |
u16GlobalB |
The average value of global B component in Bayer domain Value range: [0, 0x3ff] Data type: CVI_BOOL |
u16CountAll |
The number of pixels in the global statistical region Value range: [0, 0x3ff] Data type: CVI_BOOL |
au16ZoneAvgR |
The average value of R component in Bayer domain Value range: [0, 0x3ff] Data type: CVI_BOOL |
au16ZoneAvgG |
The average value of G component in Bayer domain Value range: [0, 0x3ff] Data type: CVI_BOOL |
au16ZoneAvgB |
The average value of B component in Bayer domain Value range: [0, 0x3ff] Data type: CVI_BOOL |
au16ZoneCountAll |
The number of pixels between Bayer domains Value range: [0, 0xfff] Data type: CVI_BOOL |
ISP_AWB_GRID_INFO_S |
AWB statistics coordinate information |
None,
None.
40.3.8. ISP_AWB_GRID_INFO_S¶
AWB Statistics Coordinate Information
typedef struct _ISP_AWB_GRID_INFO_S {
CVI_U16 au16GridYPos[AWB_ZONE_ORIG_ROW + 1];
CVI_U16 au16GridXPos[AWB_ZONE_ORIG_COLUMN + 1];
CVI_U8 u8Status;
} ISP_AWB_GRID_INFO_S;
Macro Definition
#define AWB_ZONE_ORIG_COLUMN (32)
【Member】
Member |
au16GridYPos |
Not used yet |
au16GridXPos |
Not used yet |
u8Status |
Not used yet |
None.
None.
40.3.9. ISP_FOCUS_STATISTICS_CFG_S¶
AF statistics configuration
typedef struct _ISP_FOCUS_STATISTICS_CFG_S {
ISP_AF_CFG_S stConfig;
ISP_AF_H_PARAM_S stHParam_FIR0;
ISP_AF_H_PARAM_S stHParam_FIR1;
ISP_AF_V_PARAM_S stVParam_FIR;
} ISP_FOCUS_STATISTICS_CFG_S;
【Member】
Member |
stConfig |
AF global configuration parameter |
stHParam_FIR0 |
Horizontal filter first set of FIR parameter settings |
stHParam_FIR1 |
Horizontal filter second set of FIR parameter settings |
stVParam_FIR |
FIR parameter setting of vertical filter |
None.
None.
40.3.10. ISP_AF_CFG_S¶
Define AF statistics parameter configuration
typedef struct _ISP_AF_CFG_S {
CVI_BOOL bEnable;
CVI_U16 u16Hwnd; /*RW; Range:[0x2, 0x11]*/
CVI_U16 u16Vwnd; /*RW; Range:[0x2, 0xF]*/
CVI_U8 u8HFltShift; /*RW; Range:[0x0, 0xF]*/
CVI_S8 s8HVFltLpCoeff[FIR_H_GAIN_NUM]; /*RW; Range:[0x0, 0x1F]*/
ISP_AF_RAW_CFG_S stRawCfg;
ISP_AF_PRE_FILTER_CFG_S stPreFltCfg;
ISP_AF_CROP_S stCrop;
CVI_U8 H0FltCoring; /*RW; Range:[0x0, 0xFF]*/
CVI_U8 H1FltCoring; /*RW; Range:[0x0, 0xFF]*/
CVI_U8 V0FltCoring; /*RW; Range:[0x0, 0xFF]*/
CVI_U16 u16HighLumaTh; /*RW; Range:[0x0, 0xFF]*/
CVI_U8 u8ThLow;
CVI_U8 u8ThHigh;
CVI_U8 u8GainLow; /*RW; Range:[0x0, 0xFE]*/
CVI_U8 u8GainHigh; /*RW; Range:[0x0, 0xFE]*/
CVI_U8 u8SlopLow; /*RW; Range:[0x0, 0xF]*/
CVI_U8 u8SlopHigh; /*RW; Range:[0x0, 0xF]*/
} ISP_AF_CFG_S;
【Member】
Member |
bEnable |
AF is enabled, 0 is not enabled, 1 is enabled |
u16Hwnd |
The maximum number of AF horizontal windows can be set to 17 |
u16Vwnd |
The maximum number of AF vertical windows can be set to 15 |
u8HFltShift |
AF low pass filter statistics shift register values
s8HVFltLpCoeff[FIR_H_GAIN_NUM] |
AF low pass filter coefficient is used to control the frequency response of FIR filter
stRawCfg |
AF Bayer domain related configuration |
stPreFltCfg |
AF prefilter processing enable setting |
stCrop |
Clipping configuration of AF input image |
u16HighLumaTh |
AF highlight statistics threshold setting
None.
None.
40.3.11. ISP_AF_RAW_CFG_S¶
AF Bayer Domain Image Preprocessing Configuration
typedef struct _ISP_AF_RAW_CFG_S {
CVI_U8 PreGammaEn;
CVI_U8 PreGammaTable[AF_GAMMA_NUM];
} ISP_AF_RAW_CFG_S;
【Member】
Member |
PreGammaEn |
AF module Gamma enabled, 0 not enabled, 1 enabled |
PreGammaTable[AF_GAMMA_NUM] |
AF module gamma table settings |
None.
None.
40.3.12. ISP_AF_PRE_FILTER_CFG_S¶
AF Bayer Domain Image Filtering Preprocessing Configuration
typedef struct _ISP_AF_PRE_FILTER_CFG_S {
CVI_BOOL PreFltEn;
} ISP_AF_PRE_FILTER_CFG_S;
【Member】
Member |
PreFltEn |
AF module filter preprocessing enabled, 0 not enabled, 1 enabled |
None.
None.
40.3.13. ISP_AF_CROP_S¶
AF Statistics Input Image Clipping Settings
typedef struct _ISP_ AF _CROP_S {
CVI_BOOL bEnable;
CVI_U16 u16X;
CVI_U16 u16Y;
CVI_U16 u16W;
CVI_U16 u16H;
} ISP_AF_CROP_S;
【Member】
Member |
bEnable |
Crop enabled, 0 enabled, whole picture set as crop setting, 1 enabled |
u16X |
CropX start position, Value range:[] |
u16Y |
CropY start position, Value range:[] |
u16W |
Crop width Value range: [16 * u16ZoneCol, image width - 16] |
u16H |
Crop height Value range: [16 * u16ZoneRow, image height - 4] |
None.
None.
40.3.14. ISP_AF_H_PARAM_S¶
Define AF horizontal filter parameter settings
typedef struct _ISP_AF_H_PARAM_S {
CVI_S8 s8HFltHpCoeff[FIR_H_GAIN_NUM];
} ISP_AF_H_PARAM_S;
【Member】
Member |
s8HFltHpCoeff[FIR_H_GAIN_NUM] |
AF horizontal filter factor, used to control the frequency response of FIR filters value range : [-32, 31] |
None.
None.
40.3.15. ISP_AF_V_PARAM_S¶
typedef struct _ISP_AF_V_PARAM_S {
CVI_S8 s8VFltHpCoeff[FIR_V_GAIN_NUM];
} ISP_AF_V_PARAM_S;
【Member】
Member |
s8VFltHpCoeff[FIR_V_GAIN_NUM] |
AF vertical filter factor, used to control the frequency response of FIR filters value range : [-32, 31] |
None.
None.
40.3.16. ISP_STATISTICS_CFG_S¶
ISP Statistics Message Configuration
typedef struct _ISP_STATISTICS_CFG_S {
ISP_STATISTICS_CTRL_U unKey;
ISP_AE_STATISTICS_CFG_S stAECfg;
ISP_WB_STATISTICS_CFG_S stWBCfg;
ISP_FOCUS_STATISTICS_CFG_S stFocusCfg;
} ISP_STATISTICS_CFG_S;
【Member】
Member |
unKey |
Statistical Enabling |
stAECfg |
AE Statistics Configuration |
stWBCfg |
WB Statistics Configuration |
stFocusCfg |
AF Statistics Configuration |
None.
None.
40.3.17. ISP_FOCUS_ZONE_S¶
Define the statistical results calculated by AF
typedef struct _ISP_FOCUS_ZONE_S {
CVI_U16 u16HlCnt;
CVI_U64 u64h0;
CVI_U64 u64h1;
CVI_U32 u32v0;
} ISP_FOCUS_ZONE_S;
【Member】
Member |
u16HlCnt |
The number of points exceeding the highlight threshold is counted within the AF zones, and the entire picture will be set as the crop setting, 1 being enabled |
u64h0 |
Statistical results of the first group of FIR filters in the horizontal direction within the AF partition interval |
u64h1 |
Statistical results of the second group of FIR filters in the horizontal direction within the AF partition interval |
u32v0 |
Results of Statistical Vertical FIR Filters Between AF Partitions |
None.
None.
40.3.18. ISP_FE_FOCUS_STATISTICS_S¶
Define statistical information provided by AF FE
typedef struct _ISP_FE_FOCUS_STATISTICS_S {
ISP_FOCUS_ZONE_S stZoneMetrics[AF_ZONE_ROW][AF_ZONE_COLUMN];
} ISP_FE_FOCUS_STATISTICS_S;
【Member】
Member |
stZoneMetrics |
Blocking Statistics for ISP AF |
None.
None.
40.3.19. ISP_AF_STATISTICS_S¶
Define all statistics provided by AF
typedef struct _ISP_AF_STATISTICS_S {
ISP_FE_FOCUS_STATISTICS_S stFEAFStat;
} ISP_AF_STATISTICS_S;
【Member】
Member |
stFEAFStat |
Statistics of AF in Bayer Domain |
None.
None.
