4. Compile the TFLite model
This chapter takes the resnet50_int8.tflite model as an example to introduce how to compile and transfer a TFLite model to run on the BM1684X TPU platform.
This chapter requires the following files (where xxxx corresponds to the actual version information):
tpu-mlir_xxxx.tar.gz (The release package of tpu-mlir)
4.1. Load tpu-mlir
Name |
Value |
Explanation |
TPUC_ROOT |
tpu-mlir_xxx |
The location of the SDK package after decompression |
MODEL_ZOO_PATH |
${TPUC_ROOT}/../model-zoo |
The location of the model-zoo folder, at the same level as the SDK |
4.2. Prepare working directory
Create a model_resnet50_tf directory, note that it is the same level as tpu-mlir, and put the test image file into the model_resnet50_tf directory.
The operation is as follows:
1$ mkdir model_resnet50_tf && cd model_resnet50_tf
2$ cp $TPUC_ROOT/regression/model/resnet50_int8.tflite .
3$ cp -rf $TPUC_ROOT/regression/image .
$TPUC_ROOT is an environment variable, corresponding to the tpu-mlir_xxxx directory.
4.3. TFLite to MLIR
The model in this example has a bgr input, whose mean is 103.939,116.779,123.68 and scale is 1.0,1.0,1.0.
The model conversion command:
--model_name resnet50_tf \
--scale 1.0,1.0,1.0 \
--mlir resnet50_tf.mlir
After converting to mlir file, a resnet50_tf_in_f32.npz file will be generated, which is the input file of the model.
4.4. MLIR to bmodel
This model is a tflite asymmetric quantized model, which can be converted into a bmodel according to the following parameters:
--mlir resnet50_tf.mlir \
--asymmetric \
Once compiled, a file named resnet50_tf_1684x.bmodel is generated.
