6. Compile the Caffe model
This chapter takes mobilenet_v2_deploy.prototxt and mobilenet_v2.caffemodel as examples to introduce how to compile and transfer a caffe model to run on the BM1684X TPU platform.
This chapter requires the following files (where xxxx corresponds to the actual version information):
tpu-mlir_xxxx.tar.gz (The release package of tpu-mlir)
6.1. Load tpu-mlir
Name |
Value |
Explanation |
TPUC_ROOT |
tpu-mlir_xxx |
The location of the SDK package after decompression |
MODEL_ZOO_PATH |
${TPUC_ROOT}/../model-zoo |
The location of the model-zoo folder, at the same level as the SDK |
6.2. Prepare working directory
Create a mobilenet_v2 directory, note that it is the same level as tpu-mlir, and put both model files and image files into the mobilenet_v2 directory.
The operation is as follows:
2$ cp $TPUC_ROOT/regression/model/mobilenet_v2_deploy.prototxt .
3$ cp $TPUC_ROOT/regression/model/mobilenet_v2.caffemodel .
4$ cp -rf $TPUC_ROOT/regression/dataset/ILSVRC2012 .
5$ cp -rf $TPUC_ROOT/regression/image .
$TPUC_ROOT is an environment variable, corresponding to the tpu-mlir_xxxx directory.
6.3. Caffe to MLIR
The model in this example has a BGR input with mean and scale of 103.94, 116.78, 123.68 and 0.017, 0.017, 0.017 respectively.
The model conversion command:
--model_name mobilenet_v2 \
--resize_dims=256,256 \
--mean 103.94,116.78,123.68 \
--scale 0.017,0.017,0.017 \
--mlir mobilenet_v2.mlir
After converting to mlir file, a ${model_name}_in_f32.npz file will be generated, which is the input file of the model.
6.4. MLIR to F32 bmodel
Convert the mlir file to the bmodel of f32, the operation method is as follows:
--quantize F32 \
--tolerance 0.99,0.99 \
After compilation, a file named mobilenet_v2_1684x_f32.bmodel is generated.
6.5. MLIR to INT8 bmodel
6.5.1. Calibration table generation
Before converting to the INT8 model, you need to run calibration to get the calibration table. The number of input data is about 100 to 1000 according to the situation.
Then use the calibration table to generate a symmetric or asymmetric bmodel. It is generally not recommended to use the asymmetric one if the symmetric one already meets the requirements, because the performance of the asymmetric model will be slightly worse than the symmetric model.
Here is an example of the existing 100 images from ILSVRC2012 to perform calibration:
--dataset ../ILSVRC2012 \
-o mobilenet_v2_cali_table
After running the command above, a file named mobilenet_v2_cali_table will be generated, which is used as the input file for subsequent compilation of the INT8 model.
6.5.2. Compile to INT8 symmetric quantized model
Execute the following command to convert to the INT8 symmetric quantized model:
--model mobilenet_v2_1684x_int8_sym.bmodel
After compilation, a file named mobilenet_v2_1684x_int8_sym.bmodel is generated.
6.5.3. Compile to INT8 asymmetric quantized model
Execute the following command to convert to the INT8 asymmetric quantized model:
--asymmetric \
--tolerance 0.95,0.69 \
--model mobilenet_v2_1684x_int8_asym.bmodel
After compilation, a file named mobilenet_v2_1684x_int8_asym.bmodel is generated.
