7. Use TPU for Preprocessing
At present, the two main series of chips supported by TPU-MLIR are BM168x and CV18xx. Both of them support common image preprocessing fusion. The developer can pass the preprocessing arguments during the compilation process, and the compiler will directly insert the corresponding preprocessing operators into the generated model. The generated bmodel or cvimodel can directly use the unpreprocessed image as input and use TPU to do the preprocessing.
Preprocessing Type |
BM168x |
CV18xx |
Crop |
True |
True |
Normalization |
True |
True |
NHWC to NCHW |
True |
True |
BGR/ RGB Conversion |
True |
True |
The image cropping will first adjust the image to the size specified by the “–resize_dims” argument of the model_transform tool, and then crop it to the size of the model input. The normalization supports directly converting unpreprocessed image data.
To integrate preprocessing into the model, you need to speficy the “–fuse_preprocess” argument when using the model_deploy tool, and the test_input should be an image of the original format (i.e., jpg, jpeg and png format). There will be a preprocessed npz file of input named ${model_name}_in_ori.npz generated. In addition, there is a “–customization_format” argument to specify the original image format input to the model. The supported image formats are described as follows:
customization_format |
BM168x |
CV18xx |
None |
same with model format, do nothing, as default |
True |
True |
RGB_PLANAR |
rgb color order and nchw tensor format |
True |
True |
RGB_PACKED |
rgb color order and nhwc tensor format |
True |
True |
BGR_PLANAR |
bgr color order and nchw tensor format |
True |
True |
BGR_PACKED |
bgr color order and nhwc tensor format |
True |
True |
GRAYSCALE |
one color channel only and nchw tensor format |
True |
True |
YUV420_PLANAR |
yuv420 planner format, from vpss input |
False |
True |
YUV_NV21 |
NV21 format of yuv420, from vpss input |
False |
True |
YUV_NV12 |
NV12 format of yuv420, from vpss input |
False |
True |
RGBA_PLANAR |
rgba format and nchw tensor format |
False |
True |
The “YUV*” type format is the special input format of CV18xx series chips. When the order of the color channels in the customization_format is different from the model input, a channel conversion operation will be performed. If the customization_format argument is not specified, the corresponding customization_format will be automatically set according to the pixel_format and channel_format arguments defined when using the model_transform tool.
7.1. Model Deployment Example
Take the mobilenet_v2 model as an example, use the model_transform tool to generate the original mlir, and the run_calibration tool to generate the calibration table (refer to the chapter “Compiling the Caffe Model” for more details).
7.1.1. Deploy to BM168x
The command to generate the preprocess-fused symmetric INT8 quantized bmodel model is as follows:
--fuse_preprocess \
7.1.2. Deploy to CV18xx
The command to generate the preprocess-fused symmetric INT8 quantized cvimodel model are as follows:
--chip cv183x \
--fuse_preprocess \
When the input data comes from the video post-processing module VPSS provided by CV18xx (for details on how to use VPSS for preprocessing, please refer to “CV18xx Media Software Development Reference”), data alignment is required (e.g., 32-bit aligned width). The command to generate the preprocessed-fused cvimodel model is as follows:
--chip cv183x \
--fuse_preprocess \
--aligned_input \
In the above command, aligned_input specifies the alignment that the model input needs to do. It should be noted that both fuse_preprocess and aligned_input need to be done for input data in YUV format. The rest formats can do both or only one of the two operations. If you only do aligned_input operation, you need to set test_input to the preprocessed ${model_name}_in_f32.npz format, which is consistent with the setting in the chapter “Compile ONNX model”.
