3. User Interface
This chapter introduces the user interface, including the basic process of converting models and the usage methods of various tools.
3.1. Model Conversion Process
The basic procedure is transforming the model into a mlir file with model_transform.py, and then transforming the mlir into the corresponding model with model_deploy.py. Take the somenet.onnx model as an example, the steps are as follows:
# To MLIR
--model_name somenet \
--model_def somenet.onnx \
--test_input somenet_in.npz \
--test_result somenet_top_outputs.npz \
--mlir somenet.mlir
# To Float Model
--mlir somenet.mlir \
--quantize F32 \ # F16/BF16
--processor BM1684X \
--test_input somenet_in_f32.npz \
--test_reference somenet_top_outputs.npz \
--model somenet_f32.bmodel
3.1.1. Support for Image Input
When using images as input, preprocessing information needs to be specified, as follows:
--model_name img_input_net \
--model_def img_input_net.onnx \
--scale 1.0,1.0,1.0 \
--test_input cat.jpg \
--test_result img_input_net_top_outputs.npz \
--mlir img_input_net.mlir
3.1.2. Support for Multiple Inputs
When the model has multiple inputs, you can pass in a single npz file or sequentially pass in multiple npy files separated by commas, as follows:
--model_name multi_input_net \
--model_def multi_input_net.onnx \
--test_input multi_input_net_in.npz \ # a.npy,b.npy,c.npy
--test_result multi_input_net_top_outputs.npz \
--mlir multi_input_net.mlir
3.1.3. Support for INT8 Symmetric and Asymmetric
Calibration is required if you need to get the INT8 model.
$ run_calibration.py somenet.mlir \
--dataset dataset \
-o somenet_cali_table
Generating Model with Calibration Table Input.
--calibration_table somenet_cali_table \
--tolerance 0.9,0.7 \
--model somenet_int8.bmodel
3.1.4. Support for Mixed Precision
When the precision of the INT8 model does not meet business requirements, you can try using mixed precision. First, generate the quantization table, as follows:
$ run_qtable.py somenet.mlir \
--dataset dataset \
-o somenet_qtable
Then pass the quantization table to generate the model
--quantize_table somenet_qtable \
--model somenet_mix.bmodel
3.1.5. Support for Quantized TFLite Models
TFLite model conversion is also supported, with the following command:
# TFLite conversion example
--model_name resnet50_tf \
--mlir resnet50_tf.mlir
--mlir resnet50_tf.mlir \
--tolerance 0.95,0.85 \
3.1.6. Support for Caffe Models
# Caffe conversion example
--model_name resnet18_cf \
--model_def ../resnet18.prototxt \
--mean 104,117,123 \
--mlir resnet50_cf.mlir
3.2. Introduction to Tool Parameters
3.2.1. model_transform.py
Used to convert various neural network models into MLIR files, the supported parameters are shown below:
Name |
Required? |
Explanation |
model_name |
Y |
Model name |
model_def |
Y |
Model definition file (e.g., ‘.onnx’, ‘.tflite’ or ‘.prototxt’ files) |
model_data |
N |
Specify the model weight file, required when it is caffe model (corresponding to the ‘.caffemodel’ file) |
input_shapes |
N |
The shape of the input, such as |
input_types |
N |
Type of the inputs, such int32; separate by ‘,’ for multi inputs; float32 as default |
keep_aspect_ratio |
N |
Whether to maintain the aspect ratio when resize. False by default. It will pad 0 to the insufficient part when setting |
mean |
N |
The mean of each channel of the image. The default is 0.0,0.0,0.0 |
scale |
N |
The scale of each channel of the image. The default is 1.0,1.0,1.0 |
pixel_format |
N |
Image type, can be rgb, bgr, gray or rgbd. The default is bgr |
channel_format |
N |
Channel type, can be nhwc or nchw for image input, otherwise it is none. The default is nchw |
output_names |
N |
The names of the output. Use the output of the model if not specified, otherwise use the specified names as the output |
add_postprocess |
N |
add postprocess op into bmodel, set the type of post handle op such as yolov3/yolov3_tiny/yolov5/ssd |
test_input |
N |
The input file for verification, which can be an image, npy or npz. No verification will be carried out if it is not specified |
test_result |
N |
Output file to save verification result |
excepts |
N |
Names of network layers that need to be excluded from verification. Separated by comma |
onnx_sim |
N |
option for onnx-sim, currently only support ‘skip_fuse_bn’ args |
mlir |
Y |
The output mlir file name (including path) |
debug |
N |
If open debug, immediate model file will keep; or will remove after conversion done |
tolerance |
N |
Minimum Cosine and Euclidean similarity tolerance to model transform. 0.99,0.99 by default. |
cache_skip |
N |
skip checking the correctness when generate same mlir and bmodel |
dynamic_inputs |
N |
list of dynamic input names, like:input1,input2 |
inputs_is_shape |
N |
inputs affect tensors shape |
resize_dims |
N |
Image was resize to fixed ‘h,w’, default is same as net input dims |
pad_value |
N |
pad value when resize |
pad_type |
N |
type of pad when resize, such as normal/center |
preprocess_list |
N |
choose which input need preprocess, like:’1,3’ means input 1&3 need preprocess, default all inputs |
After converting to an mlir file, a ${model_name}_in_f32.npz file will be generated, which is the input file for the subsequent models.
3.2.2. run_calibration.py
Use a small number of samples for calibration to get the quantization table of the network (i.e., the threshold/min/max of each layer of op).
Supported parameters:
Name |
Required? |
Explanation |
(None) |
Y |
Mlir file |
dataset |
N |
Directory of input samples. Images, npz or npy files are placed in this directory |
data_list |
N |
The sample list (cannot be used together with “dataset”) |
input_num |
N |
The number of input for calibration. Use all samples if it is 0 |
tune_num |
N |
The number of fine-tuning samples. 10 by default |
tune_list |
N |
Tune list file contain all input for tune |
histogram_bin_num |
N |
The number of histogram bins. 2048 by default |
o |
Y |
Name of output calibration table file |
debug_cmd |
N |
debug cmd |
A sample calibration table is as follows:
# genetated time: 2022-08-11 10:00:59.743675
# histogram number: 2048
# sample number: 100
# tune number: 5
# op_name threshold min max
images 1.0000080 0.0000000 1.0000080
122_Conv 56.4281803 -102.5830231 97.6811752
124_Mul 38.1586478 -0.2784646 97.6811752
125_Conv 56.1447888 -143.7053833 122.0844193
127_Mul 116.7435987 -0.2784646 122.0844193
128_Conv 16.4931355 -87.9204330 7.2770605
130_Mul 7.2720342 -0.2784646 7.2720342
It is divided into 4 columns: the first column is the name of the Tensor; the second column is the threshold (for symmetric quantization); The third and fourth columns are min/max, used for asymmetric quantization.
3.2.3. run_qtable.py
Use run_qtable.py to generate a mixed precision quantization table. The relevant parameters are described as follows:
Name |
Required? |
Explanation |
(None) |
Y |
Mlir file |
dataset |
N |
data_list |
N |
calibration_table |
N |
The quantization table path |
processor |
Y |
The platform that the model will use. Support BM1688/BM1684X/BM1684/CV186X/CV183X/CV182X/CV181X/CV180X/BM1690 |
input_num |
N |
The number of input for calibration. Use all samples if it is 10 |
expected_cos |
N |
Expected net output cos |
global_compare_layers |
N |
Global compare layers, for example: layer1,layer2 or layer1:0.3,layer2:0.7 |
fp_type |
N |
The precision type, default auto |
base_quantize_table |
N |
Base quantize table |
loss_table |
N |
The output loss table, default full_loss_table.txt |
o |
N |
Output mixed precision quantization table |
A sample mixed precision quantization table is as follows:
# genetated time: 2022-11-09 21:35:47.981562
# sample number: 3
# all int8 loss: -39.03119206428528
# processor: BM1684X mix_mode: F32
# op_name quantize_mode
conv2_1/linear/bn F32
conv2_2/dwise/bn F32
conv6_1/linear/bn F32
It is divided into 2 columns: the first column corresponds to the name of the layer, and the second column corresponds to the quantization mode.
At the same time, a loss table will be generated, the default is full_loss_table.txt, the sample is as follows:
# genetated time: 2022-11-09 22:30:31.912270
# sample number: 3
No.0 : Layer: conv2_1/linear/bn Loss: -36.14866065979004
No.1 : Layer: conv2_2/dwise/bn Loss: -37.15774385134379
No.2 : Layer: conv6_1/linear/bn Loss: -38.44639046986898
No.3 : Layer: conv6_2/expand/bn Loss: -39.7430411974589
No.4 : Layer: conv1/bn Loss: -40.067259073257446
No.5 : Layer: conv4_4/dwise/bn Loss: -40.183939139048256
No.6 : Layer: conv3_1/expand/bn Loss: -40.1949667930603
No.7 : Layer: conv6_3/expand/bn Loss: -40.61786969502767
No.8 : Layer: conv3_1/linear/bn Loss: -40.9286363919576
No.9 : Layer: conv6_3/linear/bn Loss: -40.97952524820963
No.10: Layer: block_6_1 Loss: -40.987406969070435
No.11: Layer: conv4_3/dwise/bn Loss: -41.18325670560201
No.12: Layer: conv6_3/dwise/bn Loss: -41.193763415018715
No.13: Layer: conv4_2/dwise/bn Loss: -41.2243926525116
It represents the loss of the output obtained after the corresponding Layer is changed to floating point calculation.
3.2.4. model_deploy.py
Convert the mlir file into the corresponding model, the parameters are as follows:
Name |
Required? |
Explanation |
mlir |
Y |
Mlir file |
processor |
Y |
quantize |
Y |
Quantization type (F32/F16/BF16/INT8) |
quant_input |
N |
Strip input type cast in bmodel, need outside type conversion |
quant_output |
N |
Strip output type cast in bmodel, need outside type conversion |
quant_input_list |
N |
choose index to strip cast, such as 1,3 means first & third input`s cast |
quant_output_list |
N |
Choose index to strip cast, such as 1,3 means first & third output`s cast |
quantize_table |
N |
Specify the path to the mixed precision quantization table. If not specified, quantization is performed according to the quantize type; otherwise, quantization is prioritized according to the quantization table |
fuse_preprocess |
N |
Specify whether to fuse preprocessing into the model. If this parameter is specified, the model input will be of type uint8, and the resized original image can be directly input |
calibration_table |
N |
The quantization table path. Required when it is INT8 quantization |
ignore_f16_overflow |
N |
Operators with F16 overflow risk are still implemented according to F16; otherwise, F32 will be implemented by default, such as LayerNorm |
tolerance |
N |
Tolerance for the minimum Cosine and Euclidean similarity between MLIR quantized and MLIR fp32 inference results. 0.8,0.5 by default. |
test_input |
N |
test_reference |
N |
Reference data for verifying mlir tolerance (in npz format). It is the result of each operator |
excepts |
N |
op_divide |
N |
cv183x/cv182x/cv181x/cv180x only, Try to split the larger op into multiple smaller op to achieve the purpose of ion memory saving, suitable for a few specific models |
model |
Y |
Name of output model file (including path) |
debug |
N |
to keep all intermediate files for debug |
asymmetric |
N |
Do INT8 asymmetric quantization |
dynamic |
N |
Do compile dynamic |
includeWeight |
N |
Include weight in tosa.mlir |
customization_format |
N |
Pixel format of input frame to the model |
compare_all |
N |
Decide if compare all tensors when lowering |
num_device |
N |
The number of devices to run for distributed computation |
num_core |
N |
The number of Tensor Computing Processor cores used for parallel computation |
skip_verification |
N |
Skip checking the correctness of bmodel |
merge_weight |
N |
Merge weights into one weight binary with previous generated cvimodel |
model_version |
N |
If need old version cvimodel, set the verion, such as 1.2 |
q_group_size |
N |
Group size for per-group quant, only used in W4A16 quant mode |
compress_mode |
N |
Specify the compression mode of the model: “none”, “weight”, “activation”, “all”. Supported on BM1688. Default is “none”, no compression |
cache_skip |
N |
aligned_input |
N |
if the input frame is width/channel aligned. VPSS input alignment for CV series processors only |
group_by_cores |
N |
whether layer groups force group by cores, auto/true/false, default is auto |
opt |
N |
Optimization type of LayerGroup, 1 or 2, default is 2 |
addr_mode |
N |
set address assign mode [‘auto’, ‘basic’, ‘io_alone’, ‘io_tag’], if not set, auto as default |
disable_layer_group |
N |
Whether to disable LayerGroup pass |
do_winograd |
N |
if do WinoGrad convolution, only for BM1684 |
3.2.5. model_runner.py
Model inference. mlir/pytorch/onnx/tflite/bmodel/prototxt supported.
Example:
$ model_runner.py \
--input sample_in_f32.npz \
--model sample.bmodel \
--output sample_output.npz \
--out_fixed
Name |
Required? |
Explanation |
input |
Y |
Input npz file |
model |
Y |
Model file (mlir/pytorch/onnx/tflite/bmodel/prototxt) |
dump_all_tensors |
N |
Export all the results, including intermediate ones, when specified |
out_fixed |
N |
Remain integer output when the dtype of output is int8, instead of transforming to float32 automaticall |
3.2.6. npz_tool.py
npz will be widely used in TPU-MLIR project for saving input and output results, etc. npz_tool.py is used to process npz files.
Example:
# Check the output data in sample_out.npz
Supported functions:
Function |
dump |
Get all tensor information of npz |
compare |
Compare difference of two npz files |
to_dat |
Export npz as dat file, contiguous binary storage |
3.2.7. visual.py
visual.py is an visualized network/tensor compare application with interface in web browser, if accuracy of quantized network is not as good as expected, this tool can be used to investigate the accuracy in every layer.
Example:
# use TCP port 9999 in this example
$ visual.py \
--f32_mlir netname.mlir \
--quant_mlir netname_int8_sym_tpu.mlir \
--input top_input_f32.npz --port 9999
Function |
f32_mlir |
fp32 mlir file |
quant_mlir |
quantized mlir file |
input |
test input data for networks, can be in jpeg or npz format. |
port |
TCP port used for UI, default port is 10000,the port should be mapped when starting docker |
host |
Host ip, default:0.0.0.0 |
manual_run |
if net will be automaticall inferenced when UI is opened, default is false for auto inference |
Notice: --debug flag should be opened during model_deploy.py to save intermediate files for visual.py. More details refer to (visual tool introduction)
3.2.8. gen_rand_input.py
During model transform, if you do not want to prepare additional test data (test_input), you can use this tool to generate random input data to facilitate model verification.
The basic procedure is transforming the model into a mlir file with model_transform.py. This step does not perform model verification. And then use gen_rand_input.py
to read the mlir file generated in the previous step and generate random test data for model verification. Finally, use model_transform.py again to do the complete model transformation and verification.
Example:
# To MLIR
--model_def ../regression/model/yolov5s.onnx \
--keep_aspect_ratio --pixel_format rgb \
# Generate dummy input. Here is a pseudo test picture.
$ gen_rand_input.py \
# Verification
--test_input yolov5s_fake_img.png \
For more detailed usage, please refer to the following:
# Value ranges can be specified for multiple inputs.
--mlir ernie.mlir \
--ranges [[0,300],[0,0]] \
--output ern.npz
# Type can be specified for the input.
--mlir resnet.mlir \
--ranges [[0,300]] \
--input_types si32 \
--output resnet.npz
# Generate random image
Name |
Required? |
Explanation |
mlir |
Y |
The input mlir file name (including path) |
img |
N |
Used for CV tasks to generate random images, otherwise generate npz files. The default image value range is [0,255], the data type is ‘uint8’, and cannot be changed. |
ranges |
N |
Set the value ranges of the model inputs, expressed in list form, such as [[0,300],[0,0]]. If you want to generate a picture, you do not need to specify the value range, the default is [0,255]. In other cases, value ranges need to be specified. |
input_types |
N |
Set the model input types, such as ‘si32,f32’. ‘si32’ and ‘f32’ types are supported. False by default, and it will be read from mlir. If you generate an image, you do not need to specify the data type, the default is ‘uint8’. |
output |
Y |
The names of the output. |
Notice: CV-related models usually perform a series of preprocessing on the input image. To ensure that the model is verificated correctly, you need to use ‘–img’ to generate a random image as input. Random npz files cannot be used as input. It is worth noting that random input may cause model correctness verification to fail, especially NLP-related models, so it is recommended to give priority to using real test data.
3.2.9. model_tool
This tool is used to process the final model file “bmodel” or “cvimodel”. The following uses “xxx.bmodel” as an example to introduce the main functions of this tool.
show basic info of bmodel
Example:
$ model_tool --info xxx.bmodel
Displays the basic information of the model, including the compiled version of the model, the compilation date, the name of the network in the model, input and output parameters, etc. The display effect is as follows:
bmodel version: B.2.2+v1.7.beta.134-ge26380a85-20240430
chip: BM1684X
create time: Tue Apr 30 18:04:06 2024
kernel_module name: libbm1684x_kernel_module.so
kernel_module size: 3136888
net 0: [block_0] static
stage 0:
input: input_states, [1, 512, 2048], bfloat16, scale: 1, zero_point: 0
input: position_ids, [1, 512], int32, scale: 1, zero_point: 0
input: attention_mask, [1, 1, 512, 512], bfloat16, scale: 1, zero_point: 0
output: /layer/Add_1_output_0_Add, [1, 512, 2048], bfloat16, scale: 1, zero_point: 0
output: /layer/self_attn/Add_1_output_0_Add, [1, 1, 512, 256], bfloat16, scale: 1, zero_point: 0
output: /layer/self_attn/Transpose_2_output_0_Transpose, [1, 1, 512, 256], bfloat16, scale: 1, zero_point: 0
net 1: [block_1] static
stage 0:
device mem size: 181645312 (weight: 121487360, instruct: 385024, runtime: 59772928)
host mem size: 0 (weight: 0, runtime: 0)
combine multi bmodels
Example:
$ model_tool --combine a.bmodel b.bmodel c.bmodel -o abc.bmodel
Merge multiple bmodels into one bmodel. If there is a network with the same name in the bmodel, it will be divided into different stages.
extract model to multi bmodels
Example:
$ model_tool --extract abc.bmodel
Decomposing a bmodel into multiple bmodels is the opposite operation to the combine command. It will be divided into different stages.
show weight info
Example:
$ model_tool --weight xxx.bmodel
Display the weight range information of each operator in different networks. The display effect is as follows:
net 0 : "block_0", stage:0
tpu.Gather : [0x0, 0x40000)
tpu.Gather : [0x40000, 0x80000)
tpu.RMSNorm : [0x80000, 0x81000)
tpu.A16MatMul : [0x81000, 0x2b1000)
tpu.A16MatMul : [0x2b1000, 0x2f7000)
tpu.A16MatMul : [0x2f7000, 0x33d000)
tpu.A16MatMul : [0x33d000, 0x56d000)
tpu.RMSNorm : [0x56d000, 0x56e000)
tpu.A16MatMul : [0x56e000, 0x16ee000)
tpu.A16MatMul : [0x16ee000, 0x286e000)
tpu.A16MatMul : [0x286e000, 0x39ee000)
net 1 : "block_1", stage:0
update weight from one bmodel to dst bmodel
Example:
# Update the weight of the network named src_net in src.bmodel at the 0x2000 position to the 0x1000 position of dst_net in dst.bmodel
$ model_tool --update_weight dst.bmodel dst_net 0x1000 src.bmodel src_net 0x2000
The model weights can be updated. For example, if the weight of an operator of a certain model needs to be updated, compile the operator separately into bmodel, and then update its weight to the original model.
