18. Appendix.01: Migrating from NNTC to tpu-mlir
NNTC is using docker version sophgo/tpuc_dev:v2.1, for MLIR docker version reference and environment initialization please refer to Environment Setup.
In the following, we will use yolov5s as an example to explain the similarities and differences between nntc and mlir in terms of quantization, and for compiling floating-point models, please refer to <TPU-MLIR_Quick_Start> Compile the ONNX model.
First, refer to the section Compile the ONNX model to prepare the yolov5s model.
18.1. ONNX to MLIR
To quantize a model in mlir, first convert the original model to a top-level mlir file, this step can be compared to generating a fp32umodel in step-by-step quantization in nntc.
  1. MLIR’s model conversion command
        ---scale 0.0039216,0.0039216,0.0039216 \
        ---test_input ./image/dog.jpg \
        ---test_result yolov5s_top_outputs.npz \
    TPU-MLIR can directly encode image preprocessing into the converted MLIR file.
  2. Model transformation commands for NNTC
    $ python3 -m ufw.tools.on_to_umodel \
        -m ../yolov5s.onnx \
        -s '(1,3,640,640)' \
        -d 'compilation' \
        --cmp
    When importing a model with NNTC, you cannot specify the preprocessing method.
18.2. Make a quantization calibration table
If you want to generate a fixed-point model, you need a quantization tool to quantize the model, nntc uses calibration_use_pb for step-by-step quantization, and mlir uses run_calibration.py for step-by-step quantization.
The number of input data is about 100~1000 depending on the situation, using the existing 100 images from COCO2017 as an example, perform calibration.
To use stepwise quantization in nntc, you need to make your own mdb quantization dataset using the image quantization dataset, and modify fp32_protoxt to point the data input to the lmdb file.
Note
For the NNTC quantization dataset, please refer to the “Model Quantization” chapter in the <TPU-NNTC Development Reference Manual>, and note that the lmdb dataset is not compatible with TPU-MLIR. TPU-MLIR can directly use raw images as input for quantization tools. If it is voice, text or other non-image data, it needs to be converted to npz file.
  1. MLIR Quantization Model
    After quantization you will get the quantization table yolov5s_cali_table
  2. NNTC Quantization Model
    $ calibration_use_pb quantize \
         --model=./compilation/yolov5s_bmneto_test_fp32.prototxt \
         --weights=./compilation/yolov5s_bmneto.fp32umodel \
         -save_test_proto=True --bitwidth=TO_INT8
    In nntc, after quantization, you get int8umodel and prototxt.
It is worth mentioning that mlir also has a run_qtable tool to help generate mixed-precision models
18.3. Generating int8 models
To convert to an INT8 symmetric quantized model, execute the following command.
  1. MLIR:
        ---mlir yolov5s.mlir \
        --processor bm1684 \
        ---test_input yolov5s_in_f32.npz \
        --model yolov5s_1684_int8_sym.bmodel
    At the end of the run you get yolov5s_1684_int8_sym.bmodel.
  2. NNTC:
    In nntc, the int8 bmodel is generated using int8umodel and prototxt using the bmnetu tool.
    $ bmnetu --model=./compilation/yolov5s_bmneto_deploy_int8_unique_top.prototxt \
        --weight=./compilation/yolov5s_bmneto.int8umodel
    At the end of the run you get compilation.bmodel.
